- C/R Question.
- d16y8 not running right need help asap!
- Finally tuned! dyno graph inside
- PCV question
- boreing block
- tuning
- ed's gsr dyno
- Need Help choosing Injectors
- 250 whp.... Honda's
- 3 Tranny Questions
- need help with all motor gsr build ( no clue wich way to go please help!!! )
- b20 build help
- maxbore... dyno proven
- none genuine stem seals?
- obd 1 distributor questions
- How much is .25 over?
- Lucus oil in your car?
- What company makes intake manifolds for sidedraft carburetors?
- 92 honda prelude h23
- which cams
- rebuild motor due to small amounts of water entering through engine
- VTEC Light. (Noob question)
- Finally Done!! LSV - Dyno Chart !
- cylinder boring and piston sizing
- 2000 Type R Conversion
- motor troubles need help
- Import Builders intake manifold, YES or NO?
- Bottom End Assembly (RS Machined 84.5mm)
- Motor needs rebuild here is are my plans
- who has ran 11.5:1 pistons in a b16a?
- port n polish
- TWM 52mm on stock EG H22?
- Used Buddy Club Spec 3 cams
- LOW NUMBERS.. any thoughts??
- PLEASE HELP!!!!!!!!!!!
- here is why u dont skimp on pistons or rods.. (((CARNAGE)))
- how much to mill???
- BPi Flow Stack ON AEM COLD AIR INTAKE
- B16 questions
- B20x or B18Bx?
- what can i rev up to??? ....
- The difference between b18c1 camshafts and jdm b18c camshafts
- LS Intake Mani On A Vtec B-Series Head, Can It Be Done?
- Header Decision
- Exhuast n Intake sizes for my NA build
- Need some advice JDM GSR build up.
- jdm b16 head
- OBD-0 to OBD-1 conversion help!!!!!!!!
- Clearance issues...
- heating problem
- Wheel size
- minimum piston to head clearance in itr
- Flushing Power Steering Fluid
- Allmotor B 12's on street tires possible?
- individual throttle bodies
- Question, what cams?
- Which Aeromotive FPR for a H22?
- gsr/type r questions.
- LS Vtec build questions.....
- help with my overheating problem
- !?! looking for pistons!?
- connecting rod question.....
- Where to get my car tuned around philly
- I'm planning on making my own Oil Catch Can... help with a diagram ???
- B20z valve clearences with B16 head
- Help needed!! Engine code 43!!
- rebuilding b18c5 head.
- ls/vtec kit for 85 mm bore
- <<they are back guaging interest on group by best intake ever... >>>
- B20 swap into my integra???
- OK I've seached... please help on valvetrain choice for daily driven gsr
- trany!!! PROBLEM!!!
- Need some who know what pistons to get!Engine builders chime in :)
- Sohc Vtec or Non-Vtec build
- speed sensor problem
- have b18a1, wondering about compatability?
- d16 compression
- How much more compression?
- b18c engine, AEM EMS and Pro1's.
- opinions
- ls/v oil line kit Q? SEARCHED
- Maximum PR3 combustion chamber volume
- Y7 to Y8 IM swap questions
- Anyone have any pictures and specs on the EF6 dual carburetors?
- skunk2 stage 1 proseries cams with what valvetrain?????HELP!!!
- Mild head porting, really worth it? DOHC ZC, I/H/E, cams, maybe nitrous later...
- skunk2 stage 1 cams w/ stock valvetrain
- dipstick blowout
- need to rent a wideband (bay area ca)
- honda piston's ? Wrist pin Height
- fujita air filter review
- spoon lightweight flywheel question
- valve upgrade or no?
- Oil catch can off of valve cover???
- ARP Headstud question (lsvtec)
- valve ticking
- B16 Build or LS V-TEC Which is going to make more power?
- rlz engineering?
- Another b16 cam ?
- H23 Questions
- VictorX and 68mm TB? yay or nay?
- How to determine if a motor is salvageable?
- How do you identify Buddy Club 4 Cams, wat should I look for?
- creaky back end
- Having a hard time finding definitive answers on octane and compression
- BEEN SEARCHING ALL NIGHT FOR ALL MOTOR MONSTER HOW-TO
- Crower Chromoly Retainers?
- Massachusetts tuner needed.
- Max lift? Please HELP!
- pr3-3 code on head????
- milling heads
- compression and cam duration
- Fixing a dinged up header....
- Stock relief's on weisco piston clearance question
- anyone tune chrome in tn/ky?
- 92mm stoke X 87mm bore blew up what now
- alternator replacement
- Turbo guys stay out (only for the N/A guys)
- B18C5 all motor set up question.
- Revvin/
- b16coupe4 Where are you????
- wut kind of r's can i get out of buddy club valvetrain?
- b20V build...piston/rod/crank questions
- LMA's and really big cams
- LS/Vtec allMoTor Setup.
- intake mani question
- Your choice of forged piston
- what is the stock vtec crossover rpm for a stock b16b ????
- FS: LS/b20 eagle rods
- Help! Stripped manifold threads
- Mahle pistons in H22
- Chicken or the egg?
- The best induction kit????
- revving safely on a stock type-r block
- LS Vtech installation, V-tech doesn't turn on!
- Does anyone have a base map comparing a stock gsr vs a gsr w/ skunk 2 stage 1 cams ??
- What cams for my setup?
- Cam gear settings with S2S1's and 11.4:1 c/r?
- tiger motors
- gsr exhaust cam -- itr intake cam
- what would be a good vtec crossover point B16b with a GSR head ???
- H/F guru's, F20B question.
- Vacuum Routing Questions....
- Lightest Cam Gears?
- should i keep my pistons?
- head question
- My first ALL MOTOR build - LS/VTEC
- gsr rebuild
- SO CAL TOY DRIVE ----- RACER's GIVEN BACK !!! PLEASE LOOK....HELP!!!!!
- Northeast voyage, anyone want a tune? (Neptune, Crome, Hondata, PowerFC)
- Buddy Club Cams Primary profiles
- ls/vtec have u heard?...
- nos octane booster
- compression vs. cfm?
- Oil spittin out exhaust manifold?????
- B20Vtec, Blox B, and intake valve closing ABDC questions...
- Can you Identify this CAMSHAFT?
- blox valve springs
- 4-1 or 4-2-1 header for my b16b
- Mugen Headgasket install, same torque spec?
- anyone ever built an engine dyno?
- b20v took a dump...
- Can anyone tell me how to get in touch with Jerry??Looking for a Jerry Built motor
- did a compression test and....
- B18A/B ALL MOTOR GUYS
- GSR or B20 transmission cover
- jdm itr question
- damage crank
- Porting a GSR intake manifold
- Little video of my car
- Will I need to clay this?
- hondata s200. Can not pull cel code
- NA build... best approach?
- extreme cams like bc spec5 or skunk2 stage 3s, whats the idle like?
- Drag Hondas Tribute
- My B18C1 N/A setup so far...pics
- ngk spark plugs
- What is spring surge & Why should i make sure my Valve Train is adeqauate
- what's hot tanking a block?
- B16 builds in the 12-14 second 1/4 mile times
- Want to do a poor boy TYPE R need the negitive and positive
- LMA removal question....
- b18b JG 302 cams
- ITB's are they worth the trouble??
- hole in exhaust
- Trouble picking cams...ls/vtec????
- How to install a TWM ITBīs on my B16?
- Everything i need for ITB's
- m24x vs toda c
- Toda B's or Buddy Club spec 3
- Need advice on my setup, please...
- Theory: Instantaneous Torque vs Mean Torque
- All Motor B16A Vs Audi RS4 Chipped and Boost raised (video)
- LS/VTEC TOOK A CRAP LOOKING TO DO A POOR BOY TYPE R WHAT DO I NEED
- my build
- Stock H22A4 cylinder oversized
- JDM GSR Head build Q's?
- m22x vs. m22xx vs. buddy club 4 vs. skunk2 ___
- B20 vtec rebuild
- HIGH COMPRESSION h22a. mmmmmmmm sound good
- Other Hornīs for my TWM ITB?
- Cam choice on B18A1.....Web vs. Crower...
- Wat type of water pump could I use for my B20Vtec
- did compression test
- b18c1 vs b18c5
- Ahh yes, the true colors show all too well in pm....
- is these two cams the same???
- compression test numbers
- hondata intake manifold gasket
- RMF header worth the hassle
- Building H22 in a Teggy
- D16Y8 ARP head studs in a D16Z6?
- B18b: JDM or USDM
- d16
- Ignition probelms on 12,9:1 (B18C6 JUN)
- Project log. ED6
- GSR cams...?
- hondata s300... easy?
- Dimensions
- what should i run?
- Eagle rods VS rev
- Crome users: What is your target idle?
- DYNO : Integra 2.0L B20-Vtec 84mm 215whp / 148lb/tq
- B18c1 Gsr cam?
- LMA Comparison:B16,GSR,ITR
- dyno'ed my h22a4
- Skunk2 Throttlebody question
- Damaged rocker arm rods
- all motor build..what kinda numbers am i looking at???
- Which cam has bigger non-vtec lobe?
- 12.1 CR on 91 octane
- itbs vs victor x
- Head rebuild... soak LMA'S?
- what is best brand 4 2 1 header with dyno proven gains?
- b20vtec dyno video.. ALL OEM PARTS!!!!!!!!!
- oil injectors
- which rods to use?
- Missing on full throttle sometimes
- NEED YOUR SUPPORT
- CAR WONT START LS-VTECH HELP!!
- H2B EG build help
- GSR mild build up need help
- RS Spec B16 81.50mm and Hastings Rings
- Oil Pan Drain Plug Stripped!!!! What now?????
- Experts and Experiencies (Cam Gear questions)
- after compression test
- A line of oil...rings gapped wrong?
- The baddest all motor honda I have ever seen. Watch video.
- CTR Pistons Wont Fit B16A2 Rods??
- PR3 exhaust port short turn radius question
