- what size injectors?
- how do u run ur exhaust?
- Can you use b16pistons in an LS???
- Rod length? In h22 100mm and 102mm
- Clutch Questions?
- A.R.P head stud question
- b17...itr cams?
- oil pump died
- some good intake manifold for the h22
- Quick Question for B20 Vtec
- HP Chips.
- VTEC..
- SOHC to DOHC?
- STATE REF FUEL PUMP
- Used Toda A cam (comments?)
- updated on my friend hung's eg with skunk2 cam
- Can't figure out why it keeps getting louder.
- Type R motor w/ RBC Tuned 235whp and 161tq.
- opinions on headers
- Do i need a wideband?
- H22 Running/Tuning Help - Need It NOW!
- New motor !!!
- Help pick a cam
- Advice on beating the beast....
- Which Gen. is better?
- crower vs. brian crower
- crower stage 2 (63402A-2) vs. buddy club spec 4
- 350 for skunk 2 stage 2
- Ls-Vtec Kit
- LOOKING TO BUY SI B16 ENGINE!!!!!!!!!!!!!!!!!!!!!!!!!
- Integra LS or Honda Civic EX???
- OBD1 B16 (what cam's are in it from factory?)
- N/A LS/VTEC RLZ Valve Springs with RLZ III Cams
- ls/vtec gurus info please
- gsr w/ r pistons
- skunk2 stage 1 cams with stock h22 vt?
- Which cams for my setup H22
- B18c1 Build help
- just a few questions...
- how much would porting help my setup? (b20 block, b16 head, blox hsl, 12.3:1)
- How much you spend for your Engine swap
- Machining Stock Rocker Arms vtec motors
- Merge Collector for strip
- LS All Motor
- full synthetic vs. regular oil
- what do you think??? B18a Non-vtec build.....
- Any one have Pro 2's in a GSR?
- b20vtec for ma ej1
- which trans is better
- Cams for a built B16A
- JUN or Ferrea/Crane Rollers for H22
- Jun 3 cams VS Blox Type C cams
- all motor racing
- All engine for a Type R
- D15Y5
- best assembly lube and tourqe specs
- Flexpipe?
- How did I only bend one valve?
- Which retainers with mugen/portflow valve springs?
- Check Engine Light ???
- b16 head b18c1 block
- help me please,
- Remove balance shaft
- learning as much as i can!
- Edelbrock Vs JDM ITR header
- B16a VTEC not hitting
- cam lube
- who do you recommend for head work?
- Dyno results are in... (as posted in the ITR forum)
- Overbore d16z6 with Nippon Racing/NPR 75.5mm pistons...what specs?
- Fuel lines
- Hx Rims Drag Radials... What Size??
- b18c1 with skunk2 stg2 and 11.9cp
- quick question
- Best H22 cams for my setup?????
- but
- Cam grind differences factory swipe pad vs roller rockers
- Which cams would be best?
- Degreeing camshafts: quick shakedown
- continuing belbens thread:: RANT::
- shift linkage
- F22 engine builders please help
- APEXi VAFC II boomslang PnP harness
- Head milling?
- help : pully
- What header is this?
- JUN cam user
- How long did your All Motor builds last?
- blox cams ??
- carbs and b-seris
- Dyno'ed my H22 on AWD Mustang Dyno
- Twin Loop Muffler ?
- I have a bone stock b16, what do i start with?
- exhaust question want opinoins!!
- Apexi World Sport 2...restrictive???
- Re-tuned for muffler change?
- muffler question
- Oil change DUMB question, but im no mechanic
- My 1.8L ITR build - A few questions
- quick ls/vtec ?
- VTEC not kicking in at all
- I'd like to rebuild my YS1 tranny. point me in the right direction.
- Help me ID these cams
- Having problems after rebuild...need some help or ideas
- b20 vs h2b
- acl race bearings any good?????
- Can anyone tell me what D series exhaust manifold this is?
- Sleeves
- radial valves?
- motor help
- Roller Barrel ITB's, anyone seen these?
- Timming effect on engine on high rev.
- True or not?
- noob in b20 field > stock gsr + stock b20z > OK?
- Loud Noise in my engine.... help!!
- rebuilding a b18
- d16y8 allmotor
- ITB...Individual Throttle Body?
- new pistons need diameter specs on block
- Break in on dyno!!!
- Would p73 pistons be a god choice for an LS/VTEC Set up??
- has anyone ever used this crank or ever heard anything about them???
- e85 b16 head im working on
- will dc 4-2-1 header made for b16 will fit in b18?
- BLOX intake manifold for GSR. Fit on my B18a1?
- Dyno difference???
- H22A4 Camshaft Questions! Opinions Needed
- jun 3s
- Question about cam gears before removal
- Have a JDM F22B1 want to build it up to at least over 200hp
- speedo goes nuts after ITB install??
- H2B vs H tranny with after market FD? Check my research.
- HELP ME PLZ
- chipped p28 ecu stand alone...
- roller followers
- Check Engine Light goes away before i have a chance to pull the code...
- More Power on a budget
- low dyno numbers fresh b18c build
- Could I Put a Stage 2 Cam in a Stock d16y8?
- Head resurfacing ?'s
- weapon r headers
- p30 pistons in LS
- Tuner's in South Carolina
- vtech theory
- Just dynoed with low numbers, what could it be? (Graph pics included)
- KMS block Girdle
- VSS code in a 1991 integra with a P28 ecu
- Your receipe to make 220whp with a b18c ITR engine
- SMSP copy header...
- Chiptuning ECU on H23A3 engine
- VAFC II !!HELP!! dial is flashing green and red
- Need Help with Stroked b20/vtec setup
- Where to buy?
- B16A Dyno comments and recommendations appreciated
- downpipe diameters?
- fuel set up ?
- burning coolant, cant figure it out
- Help: Piston slap?
- Engine management: Hondata, Crome, Emanage, Power FC
- ls/vtec question
- jun stage 3s
- B18C1 GSR with skunk2 intake manifold?
- what is the fastest street car out there?
- header and cat-back? mild b18c1 build...
- Anyone Ran these yet ??? JGE/BP Manufacturing Headers ...
- Cooling Fan Running with Hondata
- It's a GE crank worth it?
- Throttle Bodies Size .. How to decide??
- Best exhaust for all motor app.
- idle problem
- i wanna have my fuel rail bored out.
- all motor headwork???
- d15 all motor setup
- fgk stainless steel heade...
- s2p2 cams and oversized valves?
- SHOOT ME NOW.....OIL LEAK FROM BACK OF HEAD ON FRESH LS/VTEC SWAP
- Randy at RMF
- What crank for my 84mm B18C?
- Which brand timing belt for Dart tall deck?
- anybody with b20 vtec? look here!
- LSV rev limit and vtec setting?
- running carbs on h23 vtec????
- B16b...Hytech or TODA?
- Is a 3" collector too much?
- rocket m22xx... boost?
- i know this has probabily been asked a whole lot....b18a1 or b18c w/b16 head..whats better
- Buddy Club B series exhaust manifolds...TODA copy?
- motor build help
- B16 valves...
- 1.8 Build
- wanted to know something about compression
- NEED HELP WITH ENGINE WIRING!! PLZZzz
- 1.8 low 12s high 11s???
- Hondata S100 / Fuel Octane Question....
- obd2 plugs *help*
- K20 pistons in B-series Motor
- motor set up for dd b18c1 sk2stg2
- need input, so i don't waist more money?
- B18C1 Dyno Results.
- what do you think is the best b series combination.
- B16 valve spring question
- B20 w/95mm crank?
- question on ecus and b18c1
- So who has the fastest 1.8 OEM bottom end??
- Is there a way to...
- NEW TO HONDAS WANT TO GO FAST
- ITBs: TWM vs Jenvey
- b18 ctr pistons skunk stage3 cam
- Help calculating displacement
- Want to do an LS/VTEC - need help deciding max bore
- Skunk2 pro2s and B18C6 psistons?
- What header would be best??
- what is the fastest all motor set up out there? ls/vtec, h22, ext...
- B20B Help
- pro1s or skunk2 stage 2s
- valve gudies troubles.....help
- problem with sleeved block
- Thinking of sending my B18 to Bensons...
- just got my HONDA bearing codes
- Ovr sz. +1mm Valves / Piston Clearance w/ High Duration Cams, LS head
- DPFI to MPFI
- H22: Valve Stem Diameter: Seals
- Bloxs type A cams
- Vacuum reading on intake manifold at WOT. Tell you anything?
- H22-Skunk2 Pro-series Stage 2 Cams: NEED SOME HELP!!
- built gsr- surgin idle is it iacv or pro1's ?
- BLOX spec B question.
- Skunk 2 valve springs????
- sleeves and pistons
- ...Question on Injectors and its Ups.!.
- HELP! Need to tune with VAFC.
- ls/vtec best head/intake combo for tq
- i got owned.................need help please
- valve spring question?
- Best Crome Base Map??? TUNER OPINION NEEDED!!
- Tuning with "CHROME"
- installing a built head? can i use ctr cams without snapping them?
- vtec controller question?
- all motor "B18A/B" LS
- ANYONE LIKE THEIR SKUNK 2 PRO 1 CAMS ????
- what header in my ek
- anyone have the skunk2 pro series stage 1 cams
- hey guys my dad is stupid answer something please.
- B20/V WITH B16 OR GSR TRANNY
- Reward for my brothers stolen EK hatch, BelbenBuilt motor/trans, Springfield MA
- so i reworked the combo chambers on one of my neon heads.......
- My setup
- 92 LS with 92 gsr tranny?
- Honda Service Manuals
- A Few Questions For my LSVTEC Build..
