PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 [162] 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Dipstick for b20b
  2. ls crank vs gsr crank
  3. OEM crank or different crank?
  4. Endyne style breather setup install in a DA?
  5. What to do with my motor???
  6. What to do with injectors????!!?!?!???
  7. All motor b18c setup
  8. My Ls\Vtec dyno results...
  9. ecu suggestion for gsr please
  10. Boost or All-motor?
  11. B17a Head + B18c1 Block
  12. stoker kits?
  13. Timing full advance Reading 13 deg... Car Pinging...
  14. help me with my All Motor build
  15. Stock K20R/EG Dyno
  16. itbs question
  17. Who wants a big D16Y7 cam?
  18. Anybody know where I can download a manual
  19. engine help
  20. guess my hp!
  21. LS Vtec Intake Manifold?
  22. CAn the head be fixed?
  23. Precision Injectors good??
  24. s2s2 okay with.....
  25. shaking
  26. b16b all motor need help
  27. b18 head with b20 block
  28. another d series
  29. can someone tell me how much for this header and who makes it?
  30. F Stroker Motor?
  31. installing bearings.....
  32. How much do i over bore too get 84mm
  33. Difference in TB between B18B and B16B?
  34. Viscosity for B16B oil?
  35. toda spec b question about spec
  36. question for all the B18C all motor guys
  37. reading my sparkplugs, need help
  38. My ported GS-R manifold
  39. How to measure ring gap with domed pistons????
  40. B18B vs B16A
  41. stock itr head flow rating
  42. My new 85mm Copper tops came today
  43. My dyno B18c
  44. wtf???109ft/lbs with lsvtec?
  45. What to do next? All Motor B16 CRX
  46. Top Setup EG6 K20A
  47. -Idle Control Via Throttle Cable?
  48. 85mm B18C headgasket options
  49. .020 top and 2nd ring rap
  50. Jun Style header **read within**
  51. catch can on a H
  52. 0.25 over ctr (pct piston) on ls rods??
  53. Dyno of K24 with K20R head....THCK20EG's car
  54. how much power does my setup have??
  55. B16 with smoke pouring out the back
  56. ctr header vs. aftermarket
  57. what else to hit 200hp?
  58. '91 B16 Hatch.... video inside
  59. Help B18C1..decision making about cams
  60. Need help check light
  61. b20 block with b18b head?
  62. 2.0 base map
  63. H22a distributer question
  64. budddy club cam gears on gsr
  65. who builds k24???
  66. non-vtec b18 vs ls/vtec
  67. Integra individual Throttle body for b17
  68. thin headgasket???
  69. where do you get itb's?
  70. Eristic Gaskets? Anyone use these gaskets...
  71. TUNING
  72. stock gsr, unported head vid
  73. FI to N/a
  74. Thinking about purchasing a high compression b16, but want to increase to 1.8
  75. WHAT DO YOU GUYS THINK ABOUT THE INVIDIA EXHAST?
  76. b18c5 trade for ls turbo??
  77. MISSFIRE ON #1 CYL???
  78. Valve Seat
  79. Most efficient use of $ for a b16b header
  80. Si tranny fluid vs ITR tranny fluid
  81. type r or lsvtec
  82. Timing issue!!
  83. LOOKING FOR FOAM AIR FILTER, CAME ACROSS THIS !!!!
  84. LS/GSR vs ITR Torque Mounts
  85. h23 crank/rods with type s pistons and jun cams in h22, what to look out for valve clearances compre
  86. OEM Gsr Valvtrain Pics
  87. All Motor GSR needs help!!
  88. ls/vtec questions
  89. lsvtec lifespan
  90. All motor K question. WIth regards to the k24/k20 setup
  91. Is a J&S Safeguard a Must if Using an EMS w/No Knock Enduced Automatic Ignition Retard
  92. WHICH EXHAUST??????
  93. best all motor
  94. piston to wall clearance
  95. Timing
  96. H22a built
  97. 1/4 mile times for b16's post here
  98. OEM or aftermaket??
  99. 200-210 WHP out of B18C1 OBD1
  100. need help diagnosing vtec sputter
  101. need help with motor mounts asap
  102. Top Fuel cams?
  103. DYNO DAY with a Few Friends.
  104. tuning....vafc2 ok for now?????
  105. Best Header Design for Nitrous Motors.
  106. D15Z1 - Throttle body?
  107. K20a3 vs. 9krpm mechanical over-rev. . .
  108. b16 BLOCK, LS crank, but which rods and pistons???
  109. 85mm bore B20Vtec w/stock sleeves, anyone?
  110. gsr with head swap missfiring!?!?!?!
  111. OBD1 GSR w/CTR cams VAFC?
  112. How High Do You Rev Your Mild CRVTEC>>DID SEARCH>
  113. Is Steve Sakai AKA SGT Still around?
  114. Balancing my motor... worth it?
  115. b18 motor n/a build up.
  116. Wat is the best Fuel pressure for B20b Full Build Race Engine?
  117. what size injectors?
  118. i need more spark for my h22 eg !!!
  119. DSM 450's too much injector for 2.0L 12:1 B18C w/ITB's?
  120. B16 buddy club head work
  121. Noobie question?
  122. oil squirters on h23
  123. ls power potenial
  124. Question about Bearing clearances & wrist pin movement / spacing
  125. ITB Question DC5 S
  126. timing belt upgrade
  127. 2.5" straight-thru vs 3" chambered muffler.
  128. skunk2 stage 2 recommendation
  129. b20 header: same with or without vtec
  130. No n/a love!!!
  131. UPGRADES FOR 2002 3.2TL TYPE S?
  132. Need opinions on what type of headwork to be done on my setup.
  133. are there any good tuners in washington or idaho?
  134. help with GSR head build
  135. Engine Noise
  136. D-Series Build. Need advice.
  137. Swapping gears............Thoughts/Comments!
  138. fpr damage cause bad pressure reading?
  139. Ring Gap for Hastings rings??
  140. cant set timing after cam install????
  141. 70mm throttle body too much?
  142. ARP rod Bolts Necessary?
  143. Arizona Race & Machine?
  144. b17 all motor clearance issues??? need help!!!
  145. High Compression Combination
  146. Nyce1s Presents.......Adelso's CRX Video
  147. quiet exhaust for ls/vtec in a DA
  148. Rocket H22 Cams
  149. Will this work?
  150. weird tuning related issue - 440 injectors max out and still lean on vtec x-over ?
  151. Compression ratio + 91 octane + 75 shot
  152. Will stock injectors be OK???
  153. header gain?
  154. What can I expect going from GSR head to ITR head ?
  155. N/A B16 setup.....hp numbers, times???
  156. Funny sound at high rpm
  157. Please help me find the compression!
  158. Best Tranny for Built LsVtec
  159. question on k20
  160. Will a stock ITR muffler be too restrictive on a built ls/vtec?
  161. what head gasket should be use?
  162. Is this too much cam for the 2liter?
  163. any good places to buy long resonators?
  164. Air Filter for ITBs?
  165. half-shaft removal
  166. Whats my next buy?
  167. micropolishing cams?
  168. New Kteller exhaust set up
  169. Timing Belt flapping and shredding edges. VIDEO and PICS- HELP!
  170. Head Gasket
  171. Jun products in the USA. Who imports them?
  172. 99 civic engine swap
  173. Searching: Thread about OEM Valve Springs
  174. PIG RICH and dont know why....HELP!!!
  175. 2.5 COLLECTOR MOD ON EDELBROCK PRO FLOW HEADER
  176. Best cam for a race only car..S2 Stg 3 or Crower Stg. 3?
  177. does this compression idea make sense to anyone else?
  178. GSR build up questions?
  179. Nyce1s Presents.. C-NYCE'S Hatchback @ E-TOWN,Summer 2001
  180. b17a1 vs b18c1
  181. buddy club spec 5
  182. piston help
  183. Should I change my header??
  184. WTB: J'S racing carbon airduct for jdm itr front end conversion
  185. 4ag ITB's
  186. Profab or comptech header?
  187. What should i add or change about my setup b16 all motor
  188. I CANT MAKE UP MY MIND!!!Sorry to bug w/another "what should I do". I need insite on either K20 swap
  189. cam gear question
  190. NEED HELP!!!!
  191. Whick Site can Get RSX Type-R Pistons?I'm looking for buy online!
  192. Skunk2 Pro B-Series Series 1+ Camshafts
  193. b16 or poor mans type r all motor?
  194. CTR exhaust
  195. thick oil..... can using it cause......
  196. JG Edelbrock vs. Blox Which one?
  197. Espelir JGT-500, or other JDM Exhaust Question
  198. TRANSMISSION STARTER QUESTIONS!?!?! HELP...
  199. technical question
  200. boring the stock block
  201. the best DOHC cams
  202. rod bearing specification for h23
  203. ATTN ALL LS/VTEC DAILY DRIVER OWNERS!!!
  204. Stock bore 1.8L with after market pistons??????????
  205. expierience with b16b all motor?
  206. very good comp test and leak down results. wats the prob???
  207. 4-2-1 or 4-1 header?
  208. Ls/vtec or Gsr
  209. carsound cat
  210. Piston Valve Clearance
  211. What to do???
  212. straight SAE 30
  213. My comp and leakdown test on ls/vtec..need advice..
  214. valvetrain upgrade needed?
  215. Anyone has experiences with JE Crvtec pistons? Mainly valve clearance.
  216. JUN II cams, stock b16a valvetrain..can i do this?
  217. post pics of your blown up engines
  218. how can you tell the year?
  219. b16a1 w/ ctr pistons
  220. air filter on valve cover?
  221. How many miles/kms do you on your forged pistons?!?
  222. Steel Braided Sizes needed... Post your setups..
  223. Quick question about Timing Belt Kit??
  224. ls vtec knock sensor/vtec solenoid wires
  225. B16 Build
  226. walbro 255lph question
  227. how high rev stock gsr rods
  228. B20B all motor recommendations...
  229. Replacing valve springs and seats with new springs?
  230. where do you guys recommend i buy my crower valve springs?
  231. catch can hoses
  232. Need help ASAP Hondata S100 help!!!
  233. USDM H22 VS. THE JDM H22
  234. b20 vtec??
  235. ebay header good or no?
  236. catatytic insufficency
  237. Debating Boost!
  238. allmotor built b16
  239. Sleeving??
  240. synchro set for hydro b16 trans
  241. burning oil at high rpm's?
  242. Need advise for N/A build
  243. Help please Sp alternator fuse keeps blowing?
  244. Omni Springs dropping a valve?
  245. b20 vs b18ls
  246. What might cause this roller coaster torque curve?
  247. Help Please
  248. ls/vtec whats a good setup
  249. cam install help question
  250. New motor
