PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 [120] 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Which cam to use with my setup?
  2. Darton Sleeves
  3. upgraded throttle body'
  4. what head package to get?
  5. Cams?
  6. k24 crx header
  7. headgasket
  8. Which pistons should I get?
  9. stroker motor owners
  10. ls block
  11. My vortech CTR. dont be surprise
  12. Diagnosing CRAZY irratic A:F ratios
  13. Valve Clearance Issues with Increasing Compression? (Mini-me swap)
  14. Pros and cons to port and polish K series heads...
  15. How much could this have changed my tune?
  16. 1998 honda accord EX-V6 wine d noise
  17. fan switch b18a1
  18. What plugs for a 15:1 motor
  19. b18a block + b16 head, what pistons for 11:5:1
  20. All Motor Dyno/Setup/1/4mile/Weight
  21. Benson Sleeved block leaking water
  22. ls crank in gsr block got a question
  23. B16A2 Piston Rings?
  24. ls question
  25. all motor question on 94ex coupe accord
  26. f20b
  27. Another P30 LS/vtec build up....EF chassis. (56k killa)
  28. 245whp K series and 2.5 Exhaust?
  29. need help with CR
  30. Any Good Import Magazines out there?
  31. You guys with Lucas Injectors...they fit stock plugs?
  32. Bottles are for Babies Stickers...quick poll for the AM folk.
  33. Weight Reduction
  34. cam choice for this itr setup? Skunk2 Pro1 or Buddy Club Spec IV
  35. What is a good fuel pump to buy?
  36. car goes NUTS at 1500 rpm wth??
  37. Help me i beg thee ...
  38. D16 vs LS
  39. question about a ls/vtec set up
  40. question need help on a torq spec
  41. K or b
  42. Some Dynojet results of Old GSR Powered EG {@ries Tuned}
  43. Was installing Endyn breather kit but... What is this on my block?
  44. RMF Narrow headers?
  45. b18a1 help
  46. <<NEW PIX WhitfieldRacingInc's big tube header!!!>>
  47. diy itb,s ???
  48. blox type a
  49. Opinion and suggestions for B16a block with GSR head
  50. my buddy is looking for a header for his H23
  51. ALL MOTOR PROBLEM....SMOKES BAD SOMETIMES.
  52. MY Sleeved Motor Might be messed up? Help?
  53. ANY EF2 SEDANS!!!
  54. PLEASE HELP!!! What COMPRESSION would I get with this setup???
  55. overboring a b16a block?
  56. pro1 camshafts
  57. tuning ignition timing with big primary cams?
  58. jumpy idle
  59. building my motor advise
  60. Jun 3 cams
  61. smsp profab sparks header in crx....fitment issues with full-race traction bars/crossmember?
  62. will weak ignition cause detonation?
  63. header ?s
  64. Type R header owners I got a ?
  65. King Bearing kit vs. ACL Bearing kit ????????ur opinion
  66. Mystery H22 Valve Spring - Part # in post.
  67. Need some advice
  68. DC 4-1 JDM ITR RACE HEADER or HYTECH RACE HEADER FOR THE STREET???
  69. Cam choice!?!
  70. $$$ Question
  71. advise please......145,000 km
  72. <<<funny pic of WhitfieldRacingInc. S&M >>>>>
  73. Cheap valve adjust. tool avail on amazon again
  74. fyi pistons/rods
  75. b16a build
  76. b16/b18 tranny
  77. Engine click/ticking, a spun rod bearing? How to test?
  78. OBD0 Integra, SAFC or something else?
  79. Ls/Vtec Four Door Build.
  80. ctr motor
  81. ITR or P30's
  82. injectors?
  83. HELP
  84. all motor tuners , i have a question (a/f)
  85. et's of all motor k-series
  86. ITR pistons.
  87. b16 lsvtec ctr pistons what to do?
  88. F20a Injector change 20min
  89. Injector Question
  90. F series motor into Vtec! Will it work?.........
  91. AEM EMS Battery Voltage Compensation Map... 1050 Box...
  92. Ericks Racing Throttle Bodies?
  93. 01-03 Civic Coupe Stainless Steel exhaust $149.99!!!
  94. RS machine camshafts?
  95. Pics. of my sparkplugs..... is my car off timing?
  96. aftermarket piston/rods ?
  97. Double check on degreeing (p-v, advancing, lobe center)
  98. Are ob2 cars suppose to be able to plug in odb1 ecus and work?
  99. Spark Plug Gaps too much or do i need strong coil??
  100. question bout my setup
  101. Ls/Vtec oil pressure problem
  102. RLZ Headwork
  103. Ign Timing and torque curve
  104. Skunk 2 fuel rail ?
  105. built n/a d16z6 into ef. need help with 0bd1 wireing
  106. engine swap
  107. ls/vtec
  108. Introduction Video To Removing/Installing an Eprom Chip & How to Chip a USDM Ecu.
  109. Thoughts on ITB's
  110. JHP STAGE 2'S
  111. Typical charge for bottom end assembly?
  112. blown motor by puddle...
  113. b16a2 transmission fluid change
  114. OEM CTR pistons & Eagle rods?
  115. 96 civic + 00 Si engine harness + OBD2b -> OBD1 jumper + p28 = work?
  116. Looking for someone with the ability to make ITBs.
  117. GBRTuning Allmotor K-series build ...
  118. my gsr build
  119. Skunk2 Intake on GSR.....Emissions Legal?
  120. Injectors on a B20
  121. JUST BIULT B18C5 in trouble HELP HELP car starts and it dies out
  122. Buddy club spec 5 vs. S2P2's?
  123. o2 sensor
  124. How is this port/polish job (Steve Kodd Racing Engines-Hampstead, Maryland)???
  125. JUN3's
  126. next step? would it be a valve train upgrade and cams?
  127. Destroked b20/vtec build ???
  128. odb0-odb2
  129. Dynos of Buddy Club 3+ & IV cams in a B18c??
  130. Would aftermarket cams affect emissions
  131. ls vtec 12.7:1 CR
  132. Oversized valve discussion
  133. weapon r race header
  134. VIDEO : D-Rob's LSVTEC coupe
  135. how can I build my d15b bottom end to safely sustain higher revs?
  136. ALL MOTOR 12.1 COMPRESSION ON NITROUS????
  137. Fuel Setup for a B16A2
  138. B16a2 piston in GSR block?
  139. dohc zc ?'s
  140. skunk2 pro1 idle problem
  141. H22 with ITBS
  142. what cams do you think I should get
  143. what cams?
  144. WHAT DO YOU GUYS CONSIDER THE BEST HEADER FOR THE STREET?
  145. B16 CAMS FOR SALE!!!!!!!
  146. which wideband is more accurate - plx or innovate?
  147. B18c5 Dumping Tons of Fuel into Cyl #1...Car wont start!!
  148. New Dyno / Tuning OPEN in SOCAL...
  149. bdl 68mm throttle body?
  150. Christmas in June Ole Saint Earl/Benson
  151. All motor ???
  152. Which Denso Iridiums for NA H22, 11.7:1 comp, 250+ hp range?
  153. Tapping noise?
  154. B7 pistons + A6 bottom end + Y8 head & Gasket...clearance?
  155. GSR gurus need some help....
  156. Gurus I want your opinions/critiques!
  157. What header is best for my b20/Vtec setup???
  158. quick ls-vetc ?? tired of b16
  159. h22a question
  160. what kind of oil to use
  161. Does the Defouler mod screw up your ecu??
  162. skunk2 intake manifold
  163. Is this head junk now?
  164. Problems with a universal oxygen sensor
  165. ANYONE that can burn an OBD2a rom? I got a socketed 2a ECU(2 pass Emissions)
  166. B16A PROBLEMS
  167. Skunk 2 Stage 3's
  168. motor bogging down between 2k and 3k rpm
  169. Question about a throttle body and the bypass valve
  170. pr4 pistons
  171. V-AFC2 settings
  172. what kind of engine mods are you guys puting in ur B16a?
  173. intake manifold
  174. locating IAT for honda accord 02 V4
  175. Engine building question
  176. How Much power should i expect!
  177. Whick size Cometic head gasket do I need?
  178. good intake for a h22a ??
  179. Building my first engine, I have some questions.. (d15z1 d15b pms gx pistons build)
  180. motor calc???
  181. Differences between crower stage 2 and stage 3?
  182. 200 whp b16b?
  183. wut u guys think of this
  184. b18a/b blocks the same?
  185. Engine Bay....
  186. b18c to c5?
  187. B16 block with CTR pistons Problems?
  188. obd2 oil pump
  189. help EG not running good at all
  190. having a hard time tuning itbs on h22...
  191. B-Series VTEC High Performance Camshafts Stage 2, huh?
  192. two engines: back block, good rotating assembly. Good block, bad rotating assembly.... should I
  193. Whatcha think?
  194. 1.6 and 1.7
  195. Throttle Body Identification?
  196. K20 Type S upgrades help
  197. | Re-tuned @ Bubba | JDM B18c w/ BC IV |
  198. Safe revlimt? B18C1?
  199. bearing clearances regarding allmotor... opinions.
  200. which throttle body?
  201. b20 all-motor ?
  202. What b-series intake cam is this??
  203. hand job.......jk, head job haha.
  204. Just found an old video. 257whp SAE dyno pull on the dyno at J and M corvettes in CT
  205. help me with what cams to buy please
  206. Dyno my motor and smoke when it hits vtec
  207. Need Acura b18b distributor
  208. question about valve lash and compression
  209. Piston questions
  210. FUJITSUBO exhaust system
  211. Rod bearings no aligning properly?
  212. Pick and match for LS Vtec
  213. crower stg 3
  214. h22 NA Question.
  215. b18c1 port and polish head?
  216. New goodies just came in !!!
  217. Most all motor hp on a b series
  218. Bearing activity question... Tech forum = no help
  219. 99-00 Si All motor
  220. Buddy Club Spec III
  221. 200 hp for b16a setup?
  222. Skunk 2 valve springs and retainers for b16 setup?
  223. tuning questions
  224. what kind of WHP should I be getting?
  225. P30 pistons in a LS?
  226. LS internals
  227. What would you do?
  228. how far can i adj my cam gears???
  229. all motor LS?
  230. Aftermarket valves for p8r head??
  231. question about engine stand???
  232. Want to dial in s2s1's on dyno, any risk of blowing engine?
  233. Build Log: 2.0l b16b
  234. Finally gonna Tune
  235. Blox valve springs and retainers?
  236. which stock header?
  237. swapping head on 2.4 VTEC
  238. HP Gains with V-AFC
  239. what ecu can i use to pass smog ?
  240. HELP! Problems with VTEC!
  241. Ok this is wierd...ECU help...
  242. Will eventually go all motor, K20Z3, advice?
  243. dont know what to decide!! need your input!!
  244. Did you tune it yourself or have someone tune it?
  245. How much did your motor cost?
  246. 91 crx si b18c5
  247. Axel Help Please
  248. B20 Build ??
  249. DYNO IN UPSTATE NY???????????????
  250. New Header!!!
