PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 [115] 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Valve Guide removal?
  2. Integra Driver side motor mount.. are OBD-i and OBd-II SAME THING??!!
  3. Best CA smog legal Header.
  4. b16a build help
  5. crower stroking
  6. Full time Vtec Good or bad?
  7. GSR head on LS block...?
  8. biggest cams for b20/vtec before clearance problems
  9. compression
  10. Do I need a Fuel Pressure Regulator?
  11. B20/Vtec uncut valve reliefs & cams question
  12. help. help high idle on ls-vtec
  13. Air Conditioning Compressor...Please Help!!
  14. whats the best way to make tq..
  15. gsr IM
  16. 0.00cc dome piston for allmotor?
  17. help with RC310's
  18. are B20/vtec's Reliable?
  19. ---need some help understand fuel values on s300---
  20. will noisy valvetrain cause knock retard?
  21. I NEED SOME TIMING HELP!
  22. HAS ANYONE had an Eperience with these EDELBROCK CAMS
  23. JUST REAL QUICK.....Is this a good Product.
  24. One Question
  25. Adjustable FRP
  26. Does a mini-me require > 87 octane?
  27. buddy club cams breaking?
  28. 200whp... to be continued
  29. What is my best solution to this problem? (stripped / o/s threads on block)
  30. my daily driver setup
  31. Valvetrain weight tech discussion.
  32. WHO HAS THIS honda song!?!?!
  33. b20vtec valve clarence
  34. ITR header QUESTION??? HELP
  35. PCT piston to valve clearance??
  36. Replacing Just Head On Built B18C
  37. max rod strech @9000rpms in a b16a =???
  38. crower 3 with KMS valve train?
  39. Bisimoto All motor SOHC runs 9.805
  40. Am i crazy?
  41. My B18B Dyno--- by WHitfield Racing Inc.
  42. is this from running lean?
  43. P1298 code, ELD
  44. ARP Head Bolts
  45. question about my dyno tune
  46. Hybrid CTR READ THIS
  47. Have you read about the stroked b16 using stock parts being more dominate than a LS/Vtec
  48. STR 68mm TB help! Quickly!!
  49. 10,000 rpm N/A B16A2
  50. individual throttle bodies flow
  51. anyone here running M24E cams
  52. idle tuning question
  53. CTR Pistons
  54. Ok to run 101 octane but car tune with 92
  55. d series question
  56. blox tuner / comp. cams?????
  57. anybody has wiring diagram to wire jdm foglights to eg?
  58. Battle of the Imports
  59. I FINALY PICKED A MOTOR SOO HERES MY SETUP!!!
  60. wiesco 13.1 81mm pistons
  61. Where can I buy 14:1 to 16:1 compression pistons for a b18b
  62. ITR/CTR Build up Worth it?
  63. What Walbro Fuel pump on a B20vtec ALL MOTOR!!!
  64. BEST h22 valve train
  65. J32A2 2003 CL-S
  66. high reving!
  67. Anyone ever have problems with with itr valvetrain on blox type a cams or skunk 2 stage 1 cams
  68. FS: Built H22A JDM.
  69. Type-R Header VS Pro-Fab VS RMF
  70. p28 or p72 obd1 ecu
  71. EG h22 axle question!
  72. Blew up my b16 today.
  73. ProFab Tri-y header question
  74. B16A2 Intake Layout...
  75. Can you help me figure out what cams these are?
  76. crank pulley
  77. PR3 vs P28 for shipping?
  78. b16 head w/ b18c1 block
  79. which motor is faster?
  80. Compression Ratios?
  81. Mike Belben Built ls/vtec
  82. Honda Tuner close to Tally, FL
  83. the story so far
  84. Is my goal attainable?
  85. Nitrous in my GSR?
  86. JG sohc vtec camshaft spec??
  87. what is the visual difference between jdm itr cams and gsr cams
  88. SPRING TIME!
  89. Blox type B Overcammed?
  90. H22 Itb's
  91. Toda header on my 2.1L engine?
  92. which motor is better for daily driving?
  93. what motor has most potential torque/hp up to 1750cc's
  94. WTF--After RC 310 instal rough idle
  95. vtec wiring diagram
  96. Help broken bolt!
  97. Boomslang Fabrication OBD2 to OBD1 Conversion Harness
  98. Gear Ratio Opinions / Options
  99. problems with kteller....anyone?
  100. Motor build and tune ???
  101. 20 over bore ?
  102. How/where do I learn to build engines
  103. Thicker head gasket???
  104. please help me really fast...
  105. 96 integra ls b18, b20
  106. ls v tech???
  107. can u use LS crank in GSR block?!!!!!!!
  108. Aleen head bolts near oil filter
  109. header question
  110. mild built type r? idrc?
  111. B16b rotational assembly
  112. RMF 4-1 NARROW vs. SSR 4-1 STREET SWEEPER vs. SMSP 4-1 STAGGERED
  113. Help! CR-V won't start
  114. PR3 VS p30
  115. What do you think of my Mods
  116. 2 Liter LsVtec
  117. power fc or hondata S300
  118. Blox Cams
  119. m22 on built b16?
  120. final drive
  121. What do you think about this Ported and Polished head?
  122. tranny gears
  123. Carbs vs FI (The age old debate)
  124. which motor should i get?
  125. Main Cap part numbers??
  126. polarbear tuning
  127. Please Leave Feedback on my setup!!
  128. 12:5:1 cr ls/vtec
  129. technical advise for na rebuild
  130. stock block b20/vtec or lsvtec with p30 pistons
  131. LS-VTEC 2.0 idling problems
  132. b20vtec or lsvtec
  133. itr valve springs & retainers ok with stage 2?
  134. main cap install?
  135. What's a good sized tubing for a b16, headers and piping?
  136. "Simple" build, great results - 213whp / 135 ft-lbs *mustang* dyno!!!
  137. ECU for sale
  138. (Help me get on the right track with my build.)
  139. Pistons speeds
  140. ~~~~Need your Input on my build...~~~~~
  141. Rotary engine...
  142. 86mm block with gsr head ?!?!?!?!
  143. Poor Man's ITR
  144. Do cams really make your
  145. need some tuning advice. tuners please lend me your ears.
  146. FOR SALE...B18C5 BLOCK WITH B16A HEAD
  147. resistor box question
  148. How exactly does the ECU measure incoming air, how much more air can it adapt to?
  149. Will i be safe running my STR intake manifold w/ oem fuel set up?
  150. Anyone running ITR cams in a GSR head with stock valvetrain?
  151. Is this normal?
  152. skunk2 stage 2 and skunk2 pro2....
  153. my project...jdm B16a
  154. OEM honda axles.. how much horsepoweR?
  155. what do you guys think of my ls/vtec build?
  156. Buddy Club
  157. Average cost of install on cams/springs/retainers
  158. Engine options - B20 VTEC?
  159. which brand of cat convertor would come close to a straight through test pipe??
  160. Injector Size for LS/Vtec
  161. need some help from the pros
  162. b18C GSR QUESTION
  163. fuel rail
  164. How's this set up for daily driving... 1995 Integra GSR....??? Need advice.. Thanks
  165. All motor LS
  166. ctr cams in ls/vtec
  167. opinions on my gsr build
  168. replaced leaky headgasket, still leaking. HELP
  169. problem help????
  170. Which Universal Muffler for my Set-up'
  171. how do i determine what color or size rod bearings i need for my jdm b16a
  172. crx ls/vtec
  173. wtb motor
  174. throttle cable
  175. Is this Real? 318whp
  176. AEM cam gears
  177. vacum in crankcase @ idle???????????
  178. Calculation to figure volume of a head gasket... anybody know it?
  179. b18c im?
  180. how gain compression in a b16a2
  181. b18b1 ls/vtec
  182. How to store crankshaft?
  183. h22 head clearance...ALL motor read!
  184. block was hotanked, but still dirty...... suggestions..
  185. hondata s200 vs apexi power fc
  186. daily 250whp??
  187. WTB: AN-R Compact version header
  188. Help me choose a flywheel for a boosted application
  189. H22 needs wisdom
  190. just bought bc3's
  191. P30 Pistons in a B18A with B18A head?
  192. Has anybody ever changed their rod bolts in the h22
  193. Motor swap ??
  194. almost build time
  195. lsvtec or poor mans type r?
  196. V-tec Question
  197. rebuilding a d16z6
  198. JDM B18C GSR block. Sleeve tolerance?
  199. make it a vtec???
  200. Rs machines VS Oem Honda
  201. Skunk2 stage are goin to get retired...
  202. DO I NEED an AFTRERMARKET FEUL PUMP?
  203. portflow inner valve springs
  204. Need all motor set-up help on H22A!
  205. Alcohol/Methanol Injection
  206. BAD TUNING = BLOWN MOTOR HELP!!!!
  207. Tech 43 build question
  208. Opinions on My setup PLEASE!
  209. Gaskets from O'riley's??
  210. calling out the big guns i need help
  211. Ultimate MPG
  212. Missifre or detonation
  213. Low compression, High power?
  214. air con removel
  215. K&N and Mobil 1 oil filters identical!!
  216. skunk2 stage 3 cams
  217. Valve Springs
  218. who are using these cams??
  219. b16 vs gsr head
  220. Thottle Body question...
  221. NHRA Street Stock ( B series )
  222. not the ideal cam...i believe...
  223. High Compression Valves In a B20z Vtec
  224. ZEX cams
  225. ARP rod bolt NUT stripped. Any equivalent?
  226. Shaved head compression question.....
  227. Skunk2 stage 2 versus Skunk pro series 2
  228. D16z6 oil pumps?
  229. crank pulley
  230. LS/VTEC ECU and KNOCK SENSOR WIRING
  231. My ls/vtec build
  232. B18C tunning
  233. need some help just getting into racing honda civic si (87)
  234. Crower Stage 3 Cam Clearance?
  235. ls / vtec
  236. B18C1 hb ecu woes.
  237. Itb tuning question
  238. I need advice for my 94 civic
  239. H22A ITB sizing
  240. B20 swap
  241. 86mm bore?!?!?
  242. Dyno ---- 1.8L - Pr3 - M22 - Neptune
  243. Undecided All Motor or Boost?
  244. anyone have an allmotor f23 thats actually putting down #'s
  245. lsvtec valvetrain
  246. how to increase compression
  247. BLOX A Owners, valve adjustment numbers?
  248. All-Motor CRX from Puerto Rico NEW HP #'s
  249. how many degrees with gears on h22
  250. Ls/vtec oil line... need help.
