- need help with piston selection
- 98 integra LS
- I'm doing a B20 swap with greddy GSR Timing belt??? 22T or 19T water pump?
- Will high compression be okay with ecu?
- got a leak problem!!
- what size TB for a bolt on H22?
- Coolant Leak on a Mild B18C
- ls vtec stock bottom end Please give advice.
- my engine is hitting something internal......
- Roller Rockers ..power gains
- Oil and gunk in exhaust port 2
- hmm dont know what to do with my seutp... jdm b18cR in 95 cx hatch
- P30 Pistons Done into a JDM B18C1 done!!!!
- Built lsvtec, High revs, Low oil pressure???wtf
- DUMP EXHAUST
- H22 Crower St. 3 Non Vtec Profil???
- Low spark
- Need Cam Advice
- valve removal
- has anyone stroked their b16?
- HELP BUilDiNG F22A1! PLEASE GIVE TIPS
- Where to get header springs?
- titanium retainers.
- B20Z2 with OEM oil cooler.
- all motor b20v
- More Piston to Valve clearance questions...
- sir-g header question.
- B18C5?LSVTEC?
- Jge 421 header
- ANyone with an H22 RMF header?
- Gsr or LSV ?? Which would be more preferred
- turbo guy needs your help, max power on stock head? searched!
- Headers and Oxy sensors Help!
- B20 and higher compression???
- searching for power.. with the B16B
- how to identify blox cams
- HELP... what kind of piston are these???
- b18c1 smoking after high rev's
- built gsr questions
- K20-R Dyno numbers and Track Times/Into the 11's with a basic setup
- M21 and M22 Camshaft Valve Clearence
- oil catch can issues
- Anyone have problems with any Brian Crower cams?
- SOHC mini me Questions
- what cams to run my setup?
- Skunk2 or Supertech?!?!?! please help
- Skunk2 TB trouble
- oil leak, need info
- 2.0L All-motor 282 WHP B-series graph Kingmotorsports
- b18b1...
- Buddy Club Spec 4 cams with ITR Dual Valve Springs? Who is using BC4 cams??
- integra map sensor the same as a d16?
- ls/vtec build should i use a thicker oil?
- b16 cranking
- Vtec kick in?
- B16 or B18????
- RS Machined b20ITR Pistons..????
- mods list for 4 gen accord
- revetec motor.....anyone seen this????
- yup, another DIY Homemade ITB post.
- d16y8 cam question
- Can i re-use wrist pins after pressing off pistons and pressing on new ones
- BLEW MY MOTOR! Help
- stock jdm itr bottom and toda spec b cams
- 11.8 compression ratio okay on Phearable chip?
- The "Header Talk" Thread
- Race Shops, Drag Strips or Hang Outs in New Jersey?
- buddyclub valvetrain withstand other camshafts?
- stock b18b block. aftermatket cams help
- I need some info building my B20B for HIGH COMPRESSION !!!
- To much compression?
- Valve guides? OEM or Aftermarket (Bronze)
- What to do to the B20B?
- Daily Driven LS VTEC Question
- Oil Pan
- compression test b20vtec
- catch can on b20vtec
- I need advice on a tranny issue
- Video of some Legal Street racing..
- AEM UEGO Wideband vs. GReddy Intelligent Infometer
- Opinions/knowledge on this B20 vtec set up?
- Buddy Club Spec 3 Exhaust Diameter?
- Gearing and All Motor... finding the perfect combination?
- b17 block question
- help me fined whats wrong with my ls vtec
- Engine Builders/Tuning NY
- b20b compression??? please help
- ls vtec smokin bad
- Who says 3" is 'too big?' (K20 Dyno)
- b16a really slow please help!
- b16a
- b20z cams.
- GSR/ITR OEM Connecting Rod Bearings: Fancy Coating
- want to built a b16 head...let me know if anyone has this setup
- True Hytech header install, pics for clearence questions and fitment on integras
- B20/vtec oil leak
- eg/dc chassis
- Hytech header on, Now in need of 3'' flexpipe..
- B18C3 Crank Can Anyone Please Give Some Input On This
- my 1st crvtec build
- B16 100k miles
- Built N/A ls/vtec Dyno results
- aebs vs blox
- MUGEN INTAKE, WORTH IT?
- hi from quebec
- Cracked header.....experts please chime in.
- Distributor problem with my Tune
- Anyone has any experience with Skunk2 stage3 Tuner cams?
- OEM ITR built GSR - pistons and comp.?
- Boring FRM
- SKUNK2 STAGE2 cams
- Edelbrock VictorX GSR Manifold, 65mm TB, Pro-Flo Fuel Rail fitment question
- Are these real Jun 3's and is it usable?
- b20 vtec rod bearings
- B18 vs B20 connecting rod length Question.
- H22a H23a
- overheating problems on gsr motor.
- JDM B16A n/a trying to reach 270hp
- piston to wall clearence
- Synthetic oil in a high milage engine?
- Where can I get these bearings?
- SERIOUS REBUILD issues
- SSR street sweaper v.s hytech big tube copy need sugestions..
- cam gears
- B16 PROBLEMS
- the break in
- Are Tapered Throttle Bodies Good for All Motor?
- I really hope someone besides me has seen this information. the "Polyquad"
- Eagle Cranks and Rods- Once a year sale?
- What size exhaust are you guys using?
- Calling all Chefs! Built d16 with Dyno numbers...what's needed?
- New Official All-Motor LS-non vtec tread
- anyone got there head done at skunk2 back in the day?
- can sum1 please answer my question I have 2 many people telling me 2 many things!!
- My First Build
- F22c Rod Length
- Due u think this is a good all motor setup
- engine knocks until oil light goes off?!? what the hell!
- OEM Valve Seat Specs
- b18c5 semi-built.. couple questions..
- ticking sound from the motor
- B20b, Newly PnP b16 Head what cams please help!
- Supertech valve springs??
- Are stock valves ok for me?
- Broken Axle, Sparks shooting from flywheel cover, need input
- Experience with Crane Stg 3 cams!
- need 2 line up cams and crank ect...
- Help GSR or ITR cam here?
- ring gap issues on stock bore B18C
- LSVTEC or GSR?? Need some opinions.
- Fuel Filter kit?
- Storing a crank shaft
- P30 pistons into a JDM B18C1
- LS/Vtec Suggestions of what to Swap?
- Compression Test results.
- need some port work done! DFW area!
- Skunk2 Pro Valvetrain, Timing belt problem
- Differences between B16, GSR and Type R OEM Dampers?
- Balancing motor
- Keeping the B alive--11.27 @ 119 All Motor Street
- swaping a H22a1 in my 93 prelude have ???
- flex pipe needed?? if so where to put it in exhaust?
- Tri-Y header installation...
- valves
- Will i need larger pistons when i hone my block because of a spun bearing?
- crvtec?
- sleeved b20 or sleeved b18
- Block Question
- d15z1 block help
- 86mm pistons
- Bore Stroke Ratio
- 89mm or 92mm
- Blower motor not working! Need help.
- Need help LS VTEC NO KNOCK SENSOR
- Longevity of XX compression
- How much power should I expect???
- throttle body question
- CP pistons for B18A
- Need some suggestions!
- JDM H22a 345cc PH Injector Latency
- rare b17a1 engine
- acl main bearings for b18c fit b18b/a? SEARCHED
- valve stem seals
- b16 IM/exhaust size preferences
- EM2 K20 Dyno Numbers
- were to buy honda parts cheapest
- Replaced head on h23, Now it wont run, timing is perfect. Help!!
- These Pistons Any good? Let me know
- Skunk2 I-M and T-B
- Need some advice
- Happy 4th of July H-T All Motor Crew!
- Any one ever heard of these people?
- crower cam stage 2 question...two model numbers any diff
- How can I tell if a "B" head has been previously shaved?
- just wanna know
- B-series head on D-series Block?
- bought 95civic eg hatch engine probs
- needed 92-94 engine wiring harness h22 or h23
- Piston to Valve Clearance
- Made up my mind Im rebuilding my ls vtec 270 ftmfw
- First Project ....What should i get ???
- Oer or similiar vacuum block to suit Honda's
- core plug
- B18C build...Valvetrain Assistance Needed.
- b16 head question??
- how to know which hondata to use
- rebuilding my daily. need some info/feedback
- bad RC injector?
- Pic of dyno chart..... she's so unhappy
- ALL MOTOR B16 build
- Proper Valve Adjustment Location!
- edelbrock performer manifold looks alot like k-series
- b18c itr internals 13.5 slipping tires
- performer x manifold install now car runs too rich
- ITB's on a D16Z6...
- Valve train
- help indentify this cams
- ZC - finally time for a tune?
- What stock ecu to break in motor for tuning purposes..
- just got my CTR's in my b20, but knocking/tapping
- Car Sputtering A/F goin crazy
- The unknown B16A tick...
- cracked sleeve
- My 1990 Accord K24 powered
- B16a2 200whp stock block
- cam ya help?
- another h22 dyno chart
- built h22 dyno
- Neeeed Help!!
- high idle and no vacc leaks
- 65mm Throttle Body to 66mm Intake Mani - Is 1mm Difference Important?
- toda a2 cams for b-series, any feedback?
- help with LS-VTEC
- b16 distributor type... help
- ls non-vtec all motor questions
- Analyze My Duno Run
- itr cams???
- B18 Tuning Question -- Dip on dyno curve
- 207whp >>> Want to make 230whp !!! LS-V setup !!
- B18 swap
- itr cam in gsr
- P29/LS rods combo question.
- Car won't start
- vtec solinoid ? how many ohms
- fpr question on my motor
- cant get into any gears, why???
- NA>Boost For Now! Need Insight!
- What to do?
- obd2 tuning questions
- LS/VTEC question
