- D series trans help
- rsx type s head a ecu
- j's racing header
- Port/Polish
- Chassis dyno guys
- "off the shelf project" in car speedo/tach video.....
- which cams for b16 to reach 200hp+
- BC5 any one have them, ok in a c5
- A little Vid of my EG (tach/speedo shot)
- B20a5 Crv or Prelude ? 74k $100.00
- Check this out.....
- Timing Light?
- Check it out Trackspeedracing.com just got me these fresh pistons
- street vs race harmonic dampers....
- Speedo Question
- Please Read concerning header theory
- b18c-r with buddy club specIV
- Puzzled about piston to wall clearance
- Do i have G1 or G2 Rocket Motorspt springs/retainers?
- Where to buy Turbo for 90-93 Ls non-vtec Teg
- Mild build Ls/Vtec. Opinion needed
- 12:1 comp but what cams???
- Oversized ITR Pistons in GSR Block.
- what gains to expect from porting b16 intake manifold?
- Do I have to replace my pistons if it looks like this...
- changing pistons and rods?
- New Compression test results
- shortblock mix match built LS with GSR crank and rods
- what throttle cable to use with twm itb's????????????
- 95mm crank in b18a block???
- cable tranny vs. Hydro tranny
- Valve job
- Help with a B16A setup. Getting some cams.
- Can I use any ti retainers w/ skunk2 stage2 cams?
- poor mans type r . cam/compression
- h22 vs k20 power band???
- How long has your 200whp+ all motor beast lasted you?
- b16 cams which ones?
- Recomendation for most HP gain with Header+Intakemanifold? H22/Civic
- Small build
- JG 301x cam for d16a6
- Compression ratio help and valvetrain questions
- Mugen Thermostat and Fan Switch?
- Overbore... Displacment increase???
- where to buy H22 Type S
- All motor?
- Looking for a little info!!!
- Can I run Stage 3 Intake Cam with Stock Exhaust Cam
- JDM B16A Idling at 2400 RPM?!?! How do I lower Idle speed???
- apexi world sport (restrictive???)
- Where to buy H22 Type S Longblock NO HOMOTORS dont sell engine only??
- Password JDM or Comptech intake for all motor?
- i want to do a all motor build on my b18c1
- catalytic convertor shape - any difference in power/sound?
- Custom Cams Idea: High Peformance / Good Gas Milage
- Which cam setup is the best?
- OEM head bolt for a B20VTEC
- SOHC ITBS , questions
- Video: My 91 hatch, 202 whp
- H22 CAMS
- dealing with JDogg...
- What cams & springs??
- anyone get buddy club spec IV head package?
- B16B Crank and Rod into B16A2 Block!will this work?
- Huge thumbsdown to Golden Eagle MFG "MUST READ" details inside
- Any info on F20B motor would be GREAT
- quick question
- what valve train for B18c1 ??
- F/S stock gsr headers and cat
- lightest rods???
- P8R Head question.
- Supply and Demand: k20a price depreciation?
- o2 sensor not in any problem?
- Need advice from those more experienced with Civic upgrades
- S200 or S300
- h22 NA build... tradgic storry, suggestions for 225whp
- Building my own Type R version
- Crane Cams - Need opinions
- ls vtec with itr head
- SERIOUS 02 SENSOR PROBLEM, HELP!!
- b18c5 Firing Order on head.... Prob. worst Question ever asked
- spark plugs
- MACHINE OR REPLACE?????????
- s2s3 cams on a buddy club valvetrain will it hold up?
- Turbo?
- S2000 Injectors
- b16 compression??
- ACT 6 puck clutch users
- 2001 Honda Prelude Base tiptronicAutomatic VTEC QUESTION
- ? about Irridium NGK Plugs
- Old all motor video I dont think to many of you guys have seen
- Evolution Industries Vs CTR N1 Crank Pulley
- If you had a choice which standalone would you pick?
- ls vtec wiring?????
- 13.7 and now we need to tune
- Machine Shop?
- Endyne Port and Polish
- How to do it- Integra
- Cant figure it out - Integra
- All motor b16 tuned on saturday...take a look
- B20/VTEC or LS/VTEC????
- Huge :thumpup: to Rocket Motorsports.
- Tranny recommendation for my setup. 4.40fd vs 4.7df
- anyone have a nitrous controlle for uberdata ???
- Where to buy Layout Fluid/Dye?
- Baseline for my GSR today.
- Forgot to put the dowls in the head !!!!
- UGR cam gears
- Do I set lash to ZERO when degreeing cams
- RMF + RLZ = 200(dynojet)whp i/h/e h22a
- D16d2 power loss
- Street Car 1.8L Stock Block w/ Fully Done Head Dyno Results
- Piston Ring Install Help
- ALL MOTOR BUILDING PLEASE CHECK THIS OUT!!!!
- 92-96 h22 vs 97-01 h22 lost motion assembly?
- head swap ecu question
- cams,valves,pistons
- ??Adjust Valves to b18c5 Specs or B16??
- Mild build on K24
- ls/vtec how to?!?
- b16 head for sale
- newbie
- OEM Honda Valve Guide ID (inner diameter) hone?
- i think i know whats head studs but whats main studs?
- which setup
- B20vtec Swap, NO THROTTLE!?!?! HELP!!!
- Help in choosing ACL bearings for crankshaft...
- act 6 puck clutch question
- Is this detonation? one of my piston has sand like dents...
- Quick Headgasket question....
- NOOBIE ENGINE REBUILD IN PROGRESS WRITE UP [FAQ]
- spoon head gasket with b16a stock
- whats the stroke of a b18 and a b20
- carbon fiber intake mani????
- Skunk Stage 2's vs Skunk Pro 2's-(your results may vary) Mild 1.8 graphs !!!
- Buddy Club stage 4 or 5s for my 15:1.....
- Reference of H-T's Elite - People Who Know Their ____
- valve springs: itr outers w/ portflow inners. good enough 4 bc4's
- NEED HELP: MECHANIC IN SACRAMENTO??
- a little intake help, please
- Trying to find what size the ID is on a Skunk2 IM
- Compression?
- ALL MOTOR CRX!!!
- what honda motor has a 90mm bore?
- J1 and S1 tranny
- Blowing seals and burning oil, I think I found a solution...
- new b20/vtec build Q's???
- What Motor is the best go with?
- skunk 2 stage 1 cams question...
- Spraying a built H22.
- aem hybrid or password power chamber
- Experience w/B16A2 Block & B18C1 Head? Overheating!
- Dyno of my H1 engine with and without exhaust
- Short rod vs. long rod
- RC Injectors - gaskets?
- steam cleaning
- Hondata S300 For those that care
- want to know of any lightweight 84mm 13:1 compression pistons
- cam related question
- b16 race build question
- b16 race build question???
- Which Cams Will u Choose JuN, Toda D , OR Endyn Bump Stix...
- WHAT ARE THE BEST CAMS FOR N/A JDM TYPE R
- BEst approach for a 250hp gsr step by step ?
- thank you h-t all motor forum, we have success
- Using crank from a different motor requires align hone?
- GSR head on b16a
- NGK Iridum Spark Plugs - My D16Y7 - Partial review, lets hear yours
- yea for me!!!!!!
- Crower CAm ?
- all motor ls
- Bad Bad BAD compression
- is the use of vtec controllers a good idea??
- f*cken ebay....
- looking for base map for crome?
- what shot are you running on your STOCK GSR motor ?
- hondate s200 burner ??
- H22 runnin' way rich
- Intertune DVD...
- crome tuners? 818 need help
- best cam for 85mm 12.8-13.1 compression type r b18c5 head
- Fresh Motor, Timing....?
- ITB's
- vtec cams
- is there any material like fabric that i can use as air filter?
- looking for someone in illinois
- LS/VTEC Woes... Oil leak! opinions please?!
- Kaiten flywheel on a B18C1...good choice???
- Crower 403s and still slow...
- Quick Question: Are all exhaust B-pipes and Axlebacks interchangeable ??
- another header question
- Type S pistons
- Question about combustion chamber design...
- GSR VS JDM TYPE R MOTOR SWAPP?
- Idle Air Control acting up After Engine Rebuild.
- How to mount degree wheel onto crankshaft or crank pulley
- b16 usdm or jdm
- wut injectors should i use
- weird idle... all motor gsr
- Is the hondata worth it with this setup?
- Dyno gains via VAFC tuning.
- Gsr or Itr crank
- CTR/ITR ECU in B16a2
- Honda Concerto Engine dies whilst driving then will restart
- NEED suggestion on which cam to run.
- Type R head GSr head, GSR tranny for sale!! 92 Vx shell
- Alright, I want a straight answer on align-honing...
- Puzzled: sparkplugs re-gapping themselves tighter during tuning
- need help? itb's in a d-series motor??
- Help with CHECK ENGINE LIGHT!!!
- paddle shifter...?
- Issues on Dart B20+ tall block.....
- WAT HEAD GASKET ON A B20VTEC?!?!?
- header question(hytech, toda, smsp)
- should i go ls vtec or gsr in a 97 ek
- Has anyone Used Any Coast Fab Products for their all motor needs?
- B16 or GSR head?
- Is it safe to run 94 octane with 12.1:1 compression?
- Anyone ever use Prostreet Water and Oil pumps?
- all motor single slammer question....
- Piston and rod combo questions.
- valve guides??
- SKUNK2 66mm TB for all motor???
- JUST CHANGE MY AXLES BUT STILL MAKING WIERD NOISE!!!!
- b16 with ITR cams, which valvetrain?
- 98 ITR: blew my bottom -going B20vtec, need advice, road race car N/A BUGET!!
- What's your favorite NON-VTEC intake manifold?
- CTR cams on High comp
- spark plug gap and heat range - does it affect fuel richness?
- Looking to build a 180 whp ls/vtec motor
- problem with the new engine
- 0 deck?
- Can someone please help indentify cams
- b16a for CRX
- hey guys well i finally set ma mind on a motor ne tips
- Friend car pics
- B18C1 N/A, get me started with...
- oil pressure question
- Tuner in north suburbs of chicago?
- TWM ITB"S VS ENDYNE's AIR
- Cam Suggestions
- leak down test kit
- H27 H22 92mm bore/100mm stroke 315WHP/236WTQ dynojet---267WHP/201WTQ Mustang Dyno
- ls non vtec cams
- What cams to buy for my setup? Back in the game so everythign is kinda new
- AEM ITR intake on gsr?
- i cant decide if i want to turbo or build my b16 up
- b18c5 build - suggestions please
- ----> advice - motor is acting all F*cked up- ASAP!
- what are the symptoms of a bad ignition module?
