- Cam Gears. So many choices...Help me izzout
- all motor h23 crew
- Skunk2 stage 1 vs. stage 2
- What do you think about this setup?!?!
- experience > compression calculators
- HI guys : f20c engine + rsx type s tranny = compatible?
- Need help to know what cams??
- Opinions on Mobile 1 0-W20 fully syntec, I it trully the best for Honda
- 1 CTR Cam and 1 Crower Cam
- b20v vs. All Motor b16a2
- injectors too big?
- S2K throttle body matches up to B Series Intake Manifold?
- supercharger?
- Tech questions (header wrapping, toda oilpump gear......)
- 93 integra B20 help
- brian crower cams
- Dual Valve spring install
- someone break down the term tunning for me?
- Calling anyone with Crower Stage 3 cams in their GSR!
- GSR need help
- please help !!!!
- why get rid of the ballance shaft on h22
- optimal A/F ratio for B series??? any Tuning tips>??
- Ideal Gear Ratios ?
- Engine back together, won't start, fouled plugs, oily smoke from TB.. Help?
- vtec works but then bogs out.
- how do u install a cd changer
- Quick.. Crome Users..
- whp for B16A?
- obd1 b18c1 vtec solenoid..... the green plug
- heater hose question
- Few Questions on ITR cams going into B16 head
- buddyclub cams decision
- b20 dipstick problem
- Intake Manifold
- few questions
- piston rings question
- 73-79 or 80-83 civic info i.e. swap?
- ???What does not using a muffler do to your cars sound and hp???
- ***** Tyler James Nolan *****
- f/s b series parts
- fuel economy with skunk2 pro1 or pro2
- Project Car
- Where to buy decent aftermarket axles?
- looking for good headwork in ohio
- ITG / Pipercross Filters for Individual Throttle Bodies (ITB's)
- Skunk 2
- WHICH CAMS
- ctr cams intake and itr cams exhaust
- Installing itbs..on gsr
- GSR Cams with Skunk2 Pro Springs???
- B18C1 with TypeR pistions, rods an crank. HELP!!!
- Yeah! it's here
- B20 Concerns
- MY 400+ HP all motor VTEC ENGINE
- fawkn machine shop...question for yal...
- ls/vtec power figures
- what to run for oil clearances??
- Which is a better intake manifold?
- b20-b16 head
- So im contemplating my b18c1 build, and i would appreciate your advice and help.
- LS VTEC R/S RATIO
- LS Vtec need help!!!
- Looking to swap
- Magnaflow Spun Cat.?
- Scat stroker kit for b18
- starting the poor mans r assembly
- OEM honda complete gasket kit or eaby???
- what cams would u suggest.
- 97 b18c type R valve question
- The Fight Against Ignorance in the All Motor Forum - I see some hope.
- Info on some cams
- b16 CrankCase Breather dosent fit??
- msd 2 step
- JDM K20A 245whp 166tq Dyno graph and Info!!
- Quick ls/vtec question
- Settings for cams
- ^^^^^^ANOTHER FULLY BUILT B20 VTEC MOTOR^^^^^^^
- Oversized piston weight question
- Supertech aluminum retainers and keepers????
- who sells a quality remote oil filter/cooler adaptor ?
- car dies flat on its face...??
- Civic LX - To V-Tec
- Anyone know of a site with microfiche for my Acura?
- B Series Inlet Port Shape & Flow
- Modding my B16
- Stupid Question: Can CTR cams be used on stock GSR head?????
- My B20 Vtec
- Rod and Main bearing question
- skunk2 manifold with rc 310s....THEY WONT FIT
- Oversize a b18c...81.5 or 82mm???
- port match TB to IM?
- 60mm exhaust - header - what to do? need advise asap! Thanks
- has anyone used this LSVTEC oil sandwich plate
- Question for the "tuners"
- Breather box question
- best way to bump up compression?
- fuel injectors
- Oil temperature sending unit/oil drain plug???
- NA noob here! engine management...
- gsr/type-r pistons fit LS bore?
- Type R vs Blox intake manifold
- Toda forged pistons weight
- ITB MAP sensor question.
- CTR Head or GSR Head
- K20 main bearings for a B series set up, can it be done?
- b18a into a eg
- Are all the B series crank gear the same from OBD1 to OBD2
- edlebrock header..
- New B16b tuning
- RLZ Engineering - has anyone used them, and how to get ahold of them?
- Ls-vtec with b16 head or Gsr
- jdm ss tri-y 4-2-1 header, who's tried it?
- K Series Swap...Worth It?
- what can i expect from this setup
- 12.5 compression?
- remove cankshaft
- K20 into an EG what is someone getting into
- tuning a gsr engine
- looking for a quiet streight through exhaust
- degreeing cams
- B16 head question
- Edelbrock Fuel Pump
- Modified h22 Intake Manifold
- Finally Tuning ... What to Shoot for?
- Does this look right? (Rod bearing)
- Main Bore Diameter + Align Bore Question - D16Z6
- welded b16 combustion chambers?
- Anyone using SMSP header in a DA9 chassis???
- cams for a mild build gsr?
- i Need a motor in nor cal holla
- who knows the part no. for b16a2 main LOWER bearings
- Is a IM worth it
- Shudder----in 1st gear.....:(
- Cam Gears nessecary for this?
- Blox Tuner type b cams!
- Blox cam question
- Another Camshaft Choice Question on B18C
- Skunk2 IM Owners with GSRs. New Intake?
- what do you guys think of flywheel weight?
- All Motor H23 pre-inspection
- rs b18b block 86mm
- eagle rods on p30 piston.. HElp
- when it comes to bearings what does DAIDO and TAIHO mean
- catch can with itbs??
- What camshaft should i go with on my B16a2?
- k20/k24 torque vs gear ratios
- Help Identify These Cams PLEASE!!! searched and no results
- Thoughts on the "Ebay Tri Y"....
- Metal Shavings After Build
- b20 build need help
- ---- What FEUL to use for 14:1+ compression?
- P30 pistons
- K20A ITR baseline Dyno. Guess the VTEC transition.
- SOHC done right. My d16z6 build.
- b series intake manifold
- Cam setup with cam gears and New Valvetrain little info
- ls vs ls/vtec
- UNDERSTANDING THE LS 5TH GEAR SWAP
- First ALL Motor Build 99 Sedan
- B20 block
- exhaust size discussion.
- Need info on Mizumo pistons
- Need Help: Piston to Head Clearance
- SMSP FTW
- rings and bearings......
- making a b16 into a b18c
- b16a to b18????
- B20 PCV fitting size?
- B20A5 Crankshaft question
- jdm 4-1 dc header??
- Ls vtec quick question
- Just finished another ALL-MOTOR 1.8 liter build
- High rev question...ASAP!
- Power Problem - HELP
- Skunk2 pro2 cams with 1mm over si valves.
- HOW SAFE IS THIS BULID NEED SOME HELP PLEASE
- B18 headbolt length...
- CAM GEAR!! Look Normal ? Help .
- Wrist Pin Alignment???
- B20/vtec cam questions... need help sorta quick please
- Some Questions
- Attn: engine builders.. When checking for V2V clearance...
- Need advice for my summer build!!! ITBS, etc, etc.
- Intermediate Shaft Bolts
- Skunk2 Pro2 Cams + CTR Pistons
- b18b crankshaft problem
- Allmotor worked S2000 Endyn head (NHRA World Record holding)
- identifying obd1 h22 injectors
- I did a leak down test on a 97b18c-r?
- bore out the tb?
- adjust timing for altitude
- ALL MOTOR b16a2?
- d15b7 and d16z6 head
- cometic head gasket, removing middle layer and wiseco question...
- Where to find parts for a D16Z6?!
- JDM B16B Engine w/ JDM ITR Stroker Kit
- post your lsvtec end gaps (searched)
- adapting other brand TB
- H22 52MM TWM Throttle Bodies
- 12.5.1 comp ratio how much spark plug gap
- need help identifing some injectors
- cam cap holders
- Please Help...Question on cams
- All motor B16 questions
- ls crank/gsr block
- Piston Ring Gap Question
- Fully Built B18C1 should i???? nitrous oxide????
- ls crank into b 16a2 block
- Advice on my B17 build
- dome heights
- Best Injector location / injector pulse cycle??
- sr20 civic
- (Valvetrain) 91' B16 Head vs 96' GSR head
- Cam Gears/ Valve Retainers & Springs
- valve springs help please
- BC spec3 cams vs Skunk2Pro1s
- portflow/itr with s2s1's question(s)
- Spoon 10,000rpm engine!
- Benefit from light weight Pully?!
- Need some questions answered...
- no low end power or at 60mph
- lag w/skunk2stage 2
- will it be ok installing blox b's without tuning for a couple weeks?
- GSR pistons and rods in a B18A1/B1 block will it work???
- Manifold
- Calculating effective CR
- E85 All Motor Build?
- HELP- New Cam/Gear Install, Problem with Idle.
- ITBS the right route for me?
- b16 valve spring color
- Any All motor F22A1s here?
- Is this the reason why my vtec wont engage?
- B17 build up
- Building a B20A5 - First time
- advice on head work
- Help: Oil Filter Mounting Stud Removal
- Advice w/ my B18C1 build
- help me pick my clutch/flywheel
- how restrictive is a high flow cat?
- Average cost for tuning?
- profab, rage, smsp header fit with a full size radiator?
- All Motor B16.
- what cams for my setup
- WOW huge Intake Manifold
- valve spring questions??
- NEW CAMS CAUSING IDLE PROBLEMS
- running aftermarket springs with stock retainers?
- Seriously... What is the difference between the two!?
