- compression?
- h22 in my civic
- pistons for ls/vtec??
- K series Valvespring install question(tool related)
- lil burnout vid of the ls/vtec high cr setup.
- Do Header Flex Tubes Take Away Power?
- Hondata S300 calibration file - help!
- attemping to get 11:1 crvtec with b20z pistons (question for engine builders)
- Hondata S300 CRVTEC Ignition Timing need help
- Is 13.5:1 compression to much for the street?
- type s cams
- How much would you pay for this built motor????
- noob !! ???
- ls/vtec what can i expect??
- Hondata S300 & ITB's
- My H22a4 project.... lots of pics 56k....no
- Exospeed has The worst customer service
- an-r - what makes more power???
- merge or stamp collecter???
- Where did I go wrong?? (built B20vtec Dyno)
- Is building your own header worth a try?
- what valvetrain should i use w/ skunk 2 stage 2's???
- Infamous head gasket leak Stamped side of the block
- New here, introducing myself and my car
- ITB'S ON A S2000?
- Machining cranks: Where to go? Why shouldn't I do it? (searched)
- My D16A6 Econo Build
- D15B N/A
- how to determine gear ratio for LSD tranny?
- D16y8 intake manifold for D17a2??
- Building a new setup for the CRX, opinions.
- Dynos of DIY ITBs
- cam choice.....
- D series piston swap.
- VALVETRAIN SETUP B16A2
- GSR 1.8l Dyno *Skunk2 Pro Series CNC Head*
- Looking for Ideas for a N/A ALL MOTOR JDM 98SPEC Engine "Drag Racing"
- i need to know about how much whp.on a sohc vtec
- Honda Elite ch125
- Type R cams in GSR?
- ONE DAY MACHINE SHOP
- Is Buddy Club Spec V camshafts too agressive for daily driven????
- Machine shops In socal??
- Quick piston/ring question.
- my new header
- Whats the highest compression pistons I can run w/ for 87 octane???
- Transmision experpts. -a little help please
- help me choose the best cams with my set up.. JDM H22A
- hondata or vfac
- b20 crv stroker kit
- Vteckidd 2.0 LSVTEC Dyno *Skunk2 Pro3, Pro2, and more*
- Few cams & valvetrain combo Q's?
- post up your AN-R header dynos and setups
- anyone has buddy club cam gears in stock?
- h22 question
- My build what do u think?
- Decisions, need my car back soon, need OPINIONS?
- Difference between 90-91 & 92-93 integra clutches...???
- HELP!! Bent valves after 3 hours, need some ideas
- Cam Gear gains on s2s1 cams in stock b18c
- m22 cams(please read)
- b18a/b or b20
- soon to be d16?
- puerto rico fastest street honda lucchetti racing
- building 2.0+ B-series engine
- b16a transmission rebuild...?
- what intake manifold for built all motor cr-vtec
- all motor dc's...post ur 1/4 and dyno#'s
- 3.0 timing belt
- stupid search is down: ITR cam, B16a2 valvetrain. Kosher?
- Reusing pistons/rods
- LS or GSR block??
- please post up track times with a k20 in a eg hatch and power
- CTR piston/cam question
- TQ Question
- opinions on resizing combuston chamber wanted
- Supertech valvetrain oem cams?
- Made 195 to the wheels
- crower stage 2 cams and RM Gen2 springs and retainers
- this look like a ported b16 mani?
- bc3+ vs ctr cams top end?
- crower cams with ???
- Problem with ARP headstuds
- f20b pistons want a 85 mm piston for the f20b like 13.0 to 1..
- examine these piston and ring (cracked) pics...trying to determine what caused this damage
- h22 axle question
- hey guys made it to the track yesterday, still learning the slicks. i need to warm them up a little
- torn between exhaust evacuation or breather setup on H22?? thoughts expereinces?/
- Skunk2 Stage 1 vs CTR Camshafts (Please help - search is disabled)
- Another 200 WHP oem bottom end B16 on pump gas
- B16b vs. B20 Vtec
- big thanks to MODACAR.COM for the help
- b16 or type r head
- Where can I get a OBD2A to OBD2B harness?
- jdm or not?
- B20 Crower 404s dyno
- hayabusa fuel rail
- no vtec pressure switch w/ p28 how to wire vafc?
- stock gsr retainers with dual valvesprings
- scuffing on cylinder wall???
- B20vtec:85x87.2or84x89?
- Compression question??
- How do I identify the type of FD in a tranny????
- what headgasket
- Very Slow GSR Hatch
- What B-Series Performance Camshafts come silver?
- what company would u go ????
- Advantages of B16 over B18? If any
- ITR Dyno Numbers
- any one running a k24 w/ type s head?
- Feedback on MOROSO OIL PAN.... for all motor
- THE *BEST* tranny Calculator
- tuning in ATL area
- LS Tranny and LSVTEC 1/4 time
- dyno charts
- dumb ? but never had b16 head b4
- hows my port and polish look???
- two questions #1toda cams #2acl or king bearings
- Can someone give me a ballpark compression number?
- LSVtec oil?
- how much to mill h22 head...
- Distributor Problems, Distributor King doesn't work?
- h22a4 civic coupe
- B16 set up?
- Already tuned my B20 85x89 w/S2 pro1s w/wideband & VAFC, have a question
- Toda spec B on stock european GSR??
- RMF w/stock exhaust=problems??
- b18c1 or b18c5 or k20a or k20a2.....
- b16a cam caps
- Question?? (about a underdrive pulleys)
- crankcase ventilation issue
- TrackSpeedRacing ITR project 230whp 146trq... prototype manifold, dyno update
- ideas on a chip for built motor?
- How to Tell Condition of A Shortblock
- exhaust setups?
- can i do this?
- buddy club valves
- Headwork
- Edelbrock Intake Mani........any opinions??
- Cam decision for my ITR i need some help
- Built D16Z6 Not Running Right
- RM Gen1 or Gen2 on a street H22?
- widen your spark p gap and lose power?
- NEED HELP!!! THROWING CODES!! HOW DO I FIX??
- Hondata S200 messing with the rev limit?
- AEBS Vacuum problem?
- are all d sereis blocks the same.
- All Motor LSVTEC build / dyno
- Rod nut torque
- Help with cam and piston choices! maybe 13.5:1 compression?
- Need little help with timing please!?!?!?
- some one that can help 97 OBD2 civic engine into 92 OBD1 hath
- is this the golden age of h-t's allmotor allstars in the media?
- Please Help Diagnose Compression/Leakdown Test Results
- where to find D Overbore pistons?
- skunk2 pr01 tuning
- Does Being Called a Liar Piss You Off as Much as Me?
- BOOOOOOOOOOM!!!!!!!!!!
- Oil viscosity and horse power-there is a relationship. Graphs.
- Got some qustions about a exhust for my eg gsr swapet....?
- all motor b18c1 internals
- 200k ls motor with it?
- B-Series and H-Series engine weights
- Spark plug reading help please.
- **Church tuned-whp-track times??????? Post it**
- Which header for stroked motor?
- question about cam works anybody,
- valve cover vent has vacuum, is that normal?
- LS/Vtec And B20/Vtec
- Jerry Built where u at?
- vtec heads?
- DC5 low 13s?
- BASE TUNE- stock h22 w/ rocket m24x
- Skunk2 Pro1 cam specs
- Fixed but not...
- Need info on main bearings and rod bearings
- Running Toda cams w/ctr pistons will valves clear???
- GSR MOTOR POST'EM
- Cams
- IAB between series?
- Picked up a header from Tom at Camp1320
- honda civic 4DR 4SALE
- New CTR motor, what else do I need?
- bearing selection
- oil PSI h22
- ls crank gsr rods in b20 good idea or not?
- .::: Got My RMF Header but doesnt fit :::.
- Knock sensor not needed?
- My Newest creation
- HELP PLEASE? (IM NEW TO THE HONDA WORLD)
- b16 or gsr in a civic
- D15 TO B16A
- b16a head on b18c1 block???
- Black chalk on exhaust...
- who stocks overbored thicker cometics????
- alright guys i need your help on what size slicks and rims
- My buddies EH2 w/ JDM h22a's track results. 13.3 all motor
- rpm service throttle body problem
- Crazy fuel pressure drop on the Dyno w/ CTR cam today??? Why?? HELP
- H22 injectors on this setup?
- Comp4
- small combustion chambers for better resistance to detonation
- Bigger valves are they worth it?
- Titanium retainer life span?
- d16z6???'s
- RC 270cc injector seals!
- TWM ITB's
- B20 TB Question
- i need opinions on B18C mild N/A set-up
- Anyone have any ideas what happened here.....?
- My Holley Throttle Body STICKS
- B18c1 head vs. B16a head
- vtec problemo...
- B16 Dyno - Church automotive
- Trying to start a Team in IOWA!!!
- TODA 2000CC Forged Piston Kit
- Engine build in process, need some input (experienced builders only)
- Running B18C on P28 map ok?
- B16A feel sluggish?
- where to send tranny for rebuild
- Is it possible to reuse sleeves
- Need help from anyone with a megan adjustable cam gear.
- all ls/vtec post numbers
- Help determining compression and milling question.
- compresion RATIO for poor mans type R
- Greddy Emanage Question
- Why so rich?
- NEED some help with crome quick. someone help- fresh ls/vtec-wont start up..........!!!
- help! cant get car running
- b20 vtec dyno results
- Can valvesprings be too stiff? (ITR Cams in B18C)
- Mugen ECU
- First Dyno of new setup on gas 250hp 183tq...trying to keep the "B" alive!
- noob question
- wgat 1/4 mile times are you guys running on your n/a setups?
- PLease help honda tech 2003 new DOHC owner
- Possible Bent Valve *Video*
- help opinions about the spoon ecu
- piston moving around in cylinder
- STROKER KIT FOR GSR......
- need help quickly. ordered motor from PasswordJDM, won't turn over at all
- Strange idle after vafc install?
- eating coolant and oil....headgasket?
- LSVTEC Problem
- Vtec won't engage after mechanic F*** it up
- What to do next? Hmmmm!!!
- Started new engine. Some problems. help if you can.
- b18b engine miss firing
- Questions regarding the DC5 Type R muffler.....
- 91 crx
