PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 [122] 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Whats a good cam for a stock compression d16?
  2. Need advice: fluctuating oil pressure (40-70psi @ 3K rpm)
  3. Just wanted to share. Crower 63402's vtec dyno
  4. chipped socketed ecu ????
  5. Motor mount bolts cracked in block….NEED HELPP
  6. cams: b16 or gsr
  7. pro-1 users - what's your vacuum at idle?
  8. Shaving down crankshaft pulley!
  9. just a basic ? about cams and lobes
  10. will i make 200 whp?
  11. ITB runner length.
  12. My 1.8 Build!
  13. b16b or build up an lsvtec?
  14. A special thanks to: CROWER for saving my motor :)
  15. B Series cam identification
  16. K20A Skunk2 high compression valves
  17. How to determine B16 crank?? Need help ASAP
  18. How to measure what bearing size I need?
  19. How to: Fix TWM "sticky" Individual Throttle Bodies for $10
  20. Chambered vs Straight through mufflers
  21. Need to know wats a good intake manifold for my setup
  22. LS/Vtec Dowel Pin Question?????
  23. most horsepower out of a b16
  24. Dammit! intake/exhaust valve seals mixed up! how to distinguish?
  25. ? gsr 0-60s
  26. b16 power
  27. ** Octane's Higher than 91 in So. Cal... Pumps or 5 Gal Pails** Locations
  28. couple ?'s
  29. cam cap dilema
  30. OBD1 to OBD2 Wiring Conversion (EK Chasiss)
  31. Need help identifying these camshafts
  32. i need help
  33. LS sleeve strength
  34. need info for mild b16 build
  35. Budget valvetrain ideas
  36. RM m24 cams
  37. When to change sparkplugs..
  38. Need Help on deciding what Valvetrain to get
  39. All motor then turbo?
  40. bigger injectors
  41. Jenvey ITB
  42. Who has RM M22x cams in stock?
  43. porting
  44. ITB Help
  45. Cam Gear Settings
  46. NA plugs???
  47. AIR CONDITIONING
  48. How high a mileage have you got with 200whp engine?
  49. dynoed B20VTECwith results want feedback....
  50. Jun 3 vs ITR cams on stock ITR DC2 TypeR Bottom End
  51. all motor sohc 142 hp 117tq
  52. does CTR cams give more fatty midrange then s2s1?
  53. F22 setup
  54. ?'s on aftermarket valvetrain
  55. LS/VTEC running issues
  56. Going to the dyno Saturday...Leaded gas? Sunoco VS. VP race gas???
  57. hookups header !
  58. help me with my gsr...
  59. Phone number to reach AN-r
  60. Tilting distributor back to gain horsepower
  61. p30 vtec crossover
  62. high high can a jdm b18c safely rev?
  63. DIDN'T NO WERE TO PUT THIS BUT...
  64. Would there be any benefits to putting a B series in backwards
  65. quick help. car on dyno right now any recomendations for cam sprocket adjustment
  66. used dc headrs?
  67. 252whp h22 thanks to RLZ and RMF
  68. Practical limits of a B16
  69. ls/crv
  70. Just got word from RLZ
  71. Which cam is better for drag racing?
  72. 205 or 195??all motor
  73. Quiet exhaust
  74. Racing Sports Akimoto needs a donner K-series EG/EK/DC for test fittment
  75. Help with LS/VTEC
  76. built b16 head on b18c block
  77. blox c ???
  78. anyone port and polish themselves?
  79. Will ITB's clear hood with a K20/K24 motor in a EK?
  80. Need Stage 1 Cam Opinion
  81. More b20 questions....
  82. will tuning help solve my skunk2 manifold midrange loss?
  83. ls/vtec question
  84. J's racing intake
  85. i have a few bugs i need out of my set up
  86. Rebuilding B17
  87. block guard
  88. Head is off; suggestions on extra things to do?
  89. Another B20 vtec...A few questions
  90. F23 intake manifold porting
  91. Cylinder Head Tech: Reworking the short turn radius, bowl and throat (questions for the pro's)
  92. shaving in coolant
  93. compresion test results...
  94. tranny
  95. skunk 2 cams
  96. Please help...LS smoking problem TIA
  97. TYPE R CAMS QUESTION
  98. AEBS Manifold FTW?
  99. Intake valve to port opening distance on B16a head
  100. Is this low?
  101. Buddy Club Spec IV Valve Adjustment specs??
  102. Help! I snap 3 bolts
  103. block needs re-thread?
  104. TB problem.....
  105. header Bolt on
  106. ***** WHICH COMPANY MAKES THE BEST CAMSHAFT FOR A ALLMOTOR K SERIES BUILD *****
  107. Identify this P72 ECU number....thanks.
  108. Need HELP making a decsion o ACL Bearing Kit
  109. Swapping ITR pistons in stock B18C1 block.
  110. Thoughts about thin head gaskets
  111. need help making a decsion on acl Bearing
  112. ls.vtec throwing code
  113. coil bind with skunk pro1's ?
  114. type one headers?
  115. 4-2-1 4-1?!
  116. need help on idetify some camshafts
  117. b20 question
  118. How to choose the proper cams?
  119. wiring a b18
  120. need help identifying this cam
  121. SSAutochrome is making cams/springs now? Anybody purchase this?
  122. y is my car sooo slow
  123. Which valvetrain combo would you recommend????
  124. Mild GSR Build Numbers...
  125. B20 Desperation (searched)
  126. 13.2 @ 104 Street tires. What do you think.
  127. forged rods?
  128. Mugre's All Motor Civic EG Video....
  129. cracked profab hmmmmmm
  130. What compression????
  131. help car wont start
  132. Car bogs and 'putters'...
  133. need opinion on temporary fix to broken guide
  134. 81.5mm pistons w/ Spoon 2layer hg?
  135. Endyn "Rollerwave" Pistons N/A 7.45cc
  136. AEM cold air on my jdm b16
  137. 2 blown headgaskets in 2 weeks
  138. what is the highest hp n/a engine on this site?
  139. skunk2 70mm catback exhaust
  140. kteller exhaust profab header
  141. CTR cams on a stock B18C1....what other mods would I need to run them???
  142. b16 or b18
  143. making a custom intake manifold, how big should the plenum be?
  144. Need a little help with tire size
  145. c'mon u all motor gurus
  146. Running lean or rich?
  147. Skunk2 Pro3s Or Toda Ds
  148. Sounds like its dying!
  149. dyno'd today on a mustang dyno and i wanted to see if the numbers about right, what's your opinion?
  150. All Motor Drag Car- B16 Powered build....
  151. Head problem, loud noise.
  152. import ss built
  153. Will adding Toulene Xylene raise my octane?
  154. probs with my b18c3.
  155. B16...add-ons?
  156. What compression am I looking at?
  157. Question on CTR piston marking
  158. would like to see specs and hp for all motor cars
  159. Older 3 bolt STR cam gears good? And what about these?
  160. ls/vtec build questions
  161. understanding cam specs
  162. cat and header emtremely smokey
  163. Side-Gapping Spark Plugs
  164. knock...rod, main or something else?
  165. need engine blueprints and manual....
  166. quick question about catback
  167. Which forged piston?
  168. vtec not working and idling at 1500????
  169. bearing problems...
  170. Type R motor: NOT FAST ENOUGH!!! HELP!!!
  171. weight differences in oem B series pistons?
  172. headgasket layers and compression
  173. a mild build for b18c1
  174. Which cams to get?
  175. lsvtec timing?
  176. lsvtec fuel system?
  177. will obd0 timing belt cover fit?
  178. Needing a new set of headers
  179. 06 rsx type S vs 00 Civic Si
  180. Throttle body
  181. machine shop vs remanufactured of old motor?
  182. swap/timing
  183. Just had to get it, how is this header
  184. K20 Build???
  185. ideal AFR for stock b16a2
  186. Tuning with VAFC vs premade chip
  187. what does forged pistons do?
  188. ....:::: sImPL3 yEt VErY EfFeCTiV3::::....
  189. Follow up from my Dynoday
  190. Where to find a b20z shortblock????
  191. Weight of B16A w/gearbox
  192. B18C to B20 Vtec question
  193. LSV burning oil still............please read
  194. dc race header
  195. Facts of oversized valves.
  196. b16 question
  197. a little more B-SERIES heat..
  198. ordering rmf headers
  199. want to rebuild my stock type r for more HP any ideas?
  200. importpowerhouse
  201. what should i do ?
  202. OMNI Valve Train system??? wat u think
  203. Intake manifold porting...
  204. is this a good set-up?
  205. Open headers?
  206. All Motor Buildup B18C1 or B20
  207. HIGH idle! 2500 RPMS....
  208. ok wut u think of my setup i am doin
  209. B18B1 wirring harness
  210. Hondata s200 problem, wondering if its causing my tune to be off?...
  211. b18c1 skunk2 question + pullies
  212. Need an overview of how to swap pistons in a d16
  213. an-r Custom Street/Race Header - Standard Version, b series in a ef? pics?
  214. FITV blocked, tb hole still sucks air....why??
  215. deceleration backfire/idle problem..need help!
  216. CTR/ITR Cams vs S2S1's
  217. Fuel filter inlet\outlet sizes?
  218. Jdm omni power test pipe.... HELP!!!!
  219. How many people have had an AN-R compact header that cracked?
  220. LS and GSR combo?
  221. v-tec controller and ecu which to go for?
  222. Whic cam would suit my setup better?
  223. individual throttle bodies
  224. need some advice more power????
  225. Greddy Evo2 Exhaust ...
  226. Just another B16 looking for a cam sugestions BC4's?
  227. what's wrong
  228. Knocking and Ping from motor? Please help explain...THX
  229. Center lobe specs for Jun 3
  230. Quick Questions
  231. b16 in a ef, what hp #s whith what im geting and times?
  232. WTB prelude type s cams h22 head studs got cash in hand
  233. Rocker arm ratio discussion (custom ratio inquiry)
  234. help me find a cam!!!
  235. Tuner in SC
  236. anyone know?
  237. Substitution of 1991 Civic EX camshaft in a DX motor
  238. AUTO TO MANUAL CONVERSION?
  239. ls/vtec build for my crx
  240. M24X cam specs, fresh from Mr. Rocket
  241. from what year d16 are they from ?
  242. RMF Headers......
  243. Camshafts for a H23
  244. What cams?
  245. Major idling problems need solutions please help?
  246. injector rating!!
  247. what timing belt do i use with a 1"tall deck?
  248. Help with shops in san jose area? For tuning etc
  249. cheap ls vtec build.
  250. quick question....
