PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 [124] 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. 2000 si $60 obo
  2. ib spec valvetrain??
  3. Questions refering to OEM Timing Marks?
  4. ls/vtec bottom build
  5. obd2 to obd1 alternator plug.
  6. Function7 5 cap girdle
  7. couple ?s, feedback greatly appreciated
  8. how to build up an h23a?
  9. SKUNk 2 MAnIFoLD
  10. newbie: b16a horsepower
  11. Japan power!!
  12. noisy valvetrain with s2s2 cams and b16 lma's
  13. ls vtec budget build
  14. Need help in searching for a shop in Cali to work on my H22...
  15. Opinions for my planned B18C1 NA setup.
  16. new intake what throttle body size is a good choise?
  17. Phearble.net Chipped ECU or Apexi VAFC
  18. B18b, need to check plastigage clearance but sorta confused.
  19. QQ: Where to run PCV line?
  20. Difference between B20 longblock and shortblock????
  21. Props to Tom at Camp1320!!!!!
  22. lsv back togeter but still having problems
  23. ls/vtec: knock sensor
  24. Highest R.P.M. Honda motors can handle.
  25. Let's see what I DYNO with my RMF Narrow.. :)
  26. Jun 3 and Buddy Club 4 - Complete Cam Specs Wanted
  27. CA people, will this get me out of smoging my cars, legally
  28. Cam Degreeing - Primary or VTEC Lobe ???
  29. WTF is going on with my trans?
  30. D16z6 header choice
  31. compression ratio seem high?
  32. k series question
  33. 200 whp dyno- a testament to mr @ries...
  34. Blox HSL competition specs?
  35. Dynosheet of my buddies GSR
  36. safest oversize piston for b18b
  37. fuel rail
  38. The perfect cam
  39. anybody have h22 basemap?
  40. B16B Stroker...
  41. CTR piston specs??
  42. very confused..need some advice on my setup.
  43. whats my hp
  44. Some please help me with them rod length numbers
  45. Looking for over sized pistons.
  46. what to do next??? (ls/vtec)
  47. b18c / type r
  48. please post your cam timing settings with skunk2 stage2 cams
  49. skunk 2 stage2 cams to big 4 my ls/vtec??????????
  50. Need a little direction....
  51. TODA Jun Buddy - Compression Test psi SPECS !!!
  52. Skunk2 stage2 cams full spec sheet
  53. Compeition Flywheel for any good?
  54. for sale JE Pistons 84mm
  55. Mating a GSR crank with a B16a JDM block./
  56. TODA B's inlet cam specs
  57. b20vtec problems, blowing of oil filter seal
  58. H22 VTECH PROBLEM
  59. bringing up compression help
  60. Cam Overlap, Compression Tested
  61. how big of shot can put on fully built lsvtec
  62. ECU question ? ?
  63. RODS, opinions on high rev
  64. MSD digital 6+ and ignitor!
  65. Intalling Cams
  66. All Motor D16Z6
  67. How to idenitfy between different Blox cams?
  68. fuel injectors
  69. Performance parts
  70. Stock Cat, Can Be Bad Sometimes?
  71. A very specific spark plug question
  72. please help
  73. how would you fix this header?
  74. all motor setup, ls/vtec, mild build, 200whp goal...
  75. Tri Y race Header for $650
  76. Broken ring lands...need some advice
  77. which fuel pump for a jdm b18c5?
  78. B18c1/B16a2 Dyno !! Thanks intacracing!!!
  79. obd0 hondata s2
  80. JDM ITR header?
  81. converting obd1 back to obd2
  82. any good honda engine builder in florida?
  83. rocket ls cams?
  84. dropping in a b18c1
  85. cams help
  86. Piston Rings???
  87. compression ratio help
  88. Skunk2 Pro GSR intake manifold - runner angle?
  89. cam gear timing
  90. zspeedracing = Skunk2, Omnipower, Buddyclub....?
  91. cam swapping
  92. after market vlave springs and retainers how to identify
  93. am lookin to put a Vtec 4cylinder inline.
  94. J's Racing compatible K&N filters
  95. What will lower compression ratio when it comes to cams? Duration or Lift?
  96. ITB's or IM
  97. FS: JUN3 Cams, TODA Cam Gears, TODA Valvesprings
  98. FS: SPOON Valve Cover - B Series
  99. what cams?
  100. Anyone See the K series Cams from Skunk2?
  101. o2 Simlator needed?
  102. B18C ARP head stub torque specs?
  103. Skunk2S2 cams and stock retainers
  104. BC4 primary lobe - valve timing
  105. sk2s2 cams and 2 layer hg
  106. Claying a Motor with s2pro2
  107. Compression for K20 w/ TODA A2 cam
  108. High Compression, Right Gas
  109. help wierd results from swap
  110. obx cams on my setup
  111. Velocity stacks on intakes (got a question)
  112. ls vtec #'s
  113. Toda C's vs Skunk Pro1 + cams on a 1.8 ITR motor.
  114. Help! I need 1 REV inner valve spring!
  115. Got 175whp on the dyno today. Should I be happy? lol
  116. Toda header b20 vtec??
  117. about spoon
  118. Rocket
  119. Will a timing belt pulley from D series work on B series?
  120. need help please
  121. Purchasing Intake cam only?
  122. Emissions and Smog experts! I still need your help!
  123. My GSR Build-Up Plan
  124. Good or bad idea? JUN3 VS BUDDY IV?
  125. Looking for a new crank
  126. ITR i/h/e dyno (VID)
  127. Hesitation and sputtering.....
  128. b20a5 stroke
  129. ls/vtec
  130. comp cams stage 1
  131. Which pistons into JDM b18c w/ S2S1 cams
  132. correct TDC setting?
  133. b18 compression test- cylinders uneven!!
  134. help me choose an intake mani!
  135. D16Y8 Cam choices?
  136. Drop a valve? help me study a trend
  137. Dyno numbers on built ITR
  138. Headers?
  139. fuel pressure drops after priming
  140. ctr/itr cams question
  141. gsr build
  142. flat faced valves?
  143. Fastest Time NA RSX Type-S question
  144. Skunk2 Pro1 cams, power to 9.5k?
  145. 12.5 in a ef four door
  146. Choosing cam
  147. Throttle body/IM for my setup???
  148. freeway+rock+dc header=dent
  149. b16 motor build
  150. LSVTEC temp gauge problem??
  151. wtb p72
  152. RS*R Exmag question
  153. h22 eg questions
  154. LS water pump & oil pump in gsr?
  155. What header is this?? Shit is nuts! Rodrez's car!
  156. Radius Valve job vs. 5 angle?
  157. headwork?
  158. Staking bearing into case?
  159. hondata intake manifld gasket vs. passwordjdm?
  160. Ernie Penner Ported Head
  161. Intake Dia. and length
  162. would you trust these valves?
  163. Just tuned my car yesterday. TELL ME WHAT YOU THINK?
  164. searched cant find need help on valve clearance
  165. feash motor leaking.
  166. formula for cam degree timing(milled or thinner HG)
  167. Question about rods/pistons in B18c1 setup?
  168. no more custom an-r, best h22 header under $800
  169. CRX+Allmotor questions....Stroked?
  170. wat the hell is a b20a5
  171. crank angle sensor *seached*
  172. odb2 to obd1 distrib utor woring problems
  173. [Dyno] USDM ITR motor + Skunk2 Pro 1 Cams
  174. EK B20
  175. Anbody got specs of the fastest all motor b series???
  176. lsvtec 200whp?
  177. ticking sound from engine
  178. jdm d15b rocker arm assy and cams on y8 head question
  179. TWM users chime in , having more problems !!!
  180. lsvtec setup with plenty of questions!!
  181. b20 vtec!
  182. ANOTHER lsvtec setup
  183. b20 vtec cam question
  184. ? for the PROs: dual valve springs loose torque?
  185. Timing help wanted
  186. b20 vtec with 50 shot
  187. Supertech springs & retainers (concerned w/ how they fit) PICS inside
  188. What cams to run for my 2.0??
  189. jdm vs usdm.
  190. Kenji's phone number
  191. b18b all motor ls???
  192. ?? where to get small hose for diy itb's ??
  193. HELP MY EK SUCKS!!!!
  194. Rod side clearence???
  195. What exhaust should I get?
  196. Piston/valve clearance B18/b16
  197. b series injector sizes?
  198. 200 whp possibilities with this setup?
  199. d16z6 high comp. piston ? ?
  200. 93 Civic DX engine swap
  201. valve clearance
  202. Cam Overlap? M24X
  203. K24 Project Car w/ Dyno
  204. lsvtec or turbo SOHC
  205. Anyone tune their ls/vtec to only rev to 7500ish?
  206. aftermarket valves vs. oem valves?
  207. itr pistons and rings...
  208. Skunk2 Pro 2 Cam Specs
  209. setup options ls/v or gsr w/p30 pistons?
  210. Need advise on which exhaust to get for the header.
  211. a few questions about pistons...
  212. itr pistons...
  213. Crank pulley and bearing replacement.
  214. Need Help!!!- Trouble Code 0= ECU. . . how to know if its 0
  215. Skunk 2 manifold
  216. which header to use
  217. Which CAMS to run on a Built GSR?!
  218. readiness monitor codes obd2 smog
  219. cable or hydro tranny ??
  220. Integra LS Non-Vtec All-Motor 14.0 @ 97mph!
  221. Jun 3 cam kit
  222. lsvtec questionS
  223. Valve spring question
  224. CTR semi build
  225. how much hourse power will i make
  226. what do you know about WEBCAMS...cams?
  227. h22a and aftermarket pistons rings.
  228. B-series HI performance starter
  229. N/A GSR Build..NEED HELP
  230. jdm zc pistons?
  231. b16 intake question
  232. Kenji's phone number
  233. CRX VTEC SWAP HELP PLZZ
  234. Cali + Engine build + OBD2 + Smog = ?
  235. Toda Killers, Race Kar, AEM EMS, Videos, Joy!
  236. Buddy Club IV cam owners....how is your valvetrain holding up
  237. I'm gonna have torque soon....
  238. is this head salvageable?
  239. claying motor - while in the car?
  240. typre r pistons
  241. exhaust and intake manifold for 92 gsr hatch
  242. b16a head on b20B - issues?
  243. VIDEO: H22 CRX Dave Hickman (DH Racing) Runs 11.5 at CMI
  244. Prelude injectors in Gsr
  245. VAFC for dyno tuning.. worth it? plz help
  246. Prelude H22A vs Integra LS Non V-Tec
  247. h22 help
  248. skunk2 adjustable cam gear torque settings
  249. For all of you peeps who has a PoorMansTypeR...
  250. what do u fink? which one to choose?
