- Anyone hook up there SAFC? Which wire goes to the throttle signal
- what can lead to failed ring-lands?
- Simple LS/Vtec
- A/F ratio
- Vacuum Reserve Tank?
- ITB question
- cutting out at 6500 rpm
- toda C spec install
- high rev pinging
- LSVTEC vs. B20VTEC
- Arias 10.5:1 pistons on F22a1 engine
- I need DEFINITIVE lsvtec answer...have searched...now I need experienced answers...
- Upgrading LSD cable tranny
- NGK IRIDIUM IX SPARK PLUGS
- propane injection on NA applications... seriously
- One of the fastest all motor civic, quick question...
- look at his itr tranny
- Weights of engine parts?
- Keep the built-up b18c1 or swap to h22a?
- b16 into eg?
- best header/exhaust for 2nd gen integra (searched)
- To Build or Not to build and swap the FU** out of it
- SRR cam gears?
- problems w/ my vtec controller
- going LS-Vtec, need opinion on safe redline
- gsr cams in b16a2????
- Gett'n Codes
- LsVtec project is about to get underway but 2 questions first
- more ?s on a b16a
- prelude questions
- skunk2 intake manifold help
- Machine Shops in N.E
- b18c1 head on b20z block
- Thinking of going All-Motor? Check this set-up please!!
- timing belt keeps getting loose!!!
- Where to Get "Spoon" program for Auto P30 ecu?
- 30 whp loss?
- What is up with Headertech?
- What Octane should I run on my race car? Timming?
- Scavenging/Exhaust efficiency with E Cutout (opened/closed)
- Type R PCT Pistons in a B16A?
- Tuning help please!
- b16 to b18 conversion
- b18b opinions
- h22 vs b16 b18c
- difference between obd2a and obd2b
- crvtec bottom end build-up.
- what are the crower race core stage 2 cams similar too?
- ITR tranny VS. b16 tranny
- Props to Danny (DTR), new dyno numbers...
- b20 swap
- gains from reomving pw steering and ac
- skunk2stage 1 cams on stock valvetrain?
- how do i determine whether gsr block is legit?
- pr3 pistons, stock B18A block.
- B16 Question! Please Help
- 85mm B20vtec fuel requirement?
- Quick question on Hondatas, are they interchangeable?
- 42MM ITB's equal to what size throttle body......
- 2 Easy questions for all your NA gurus :)
- help, in a pinch... head gasket woes!!!
- skunk2s?
- Should this have yeilded more?
- Just a Quick Easy ?
- clutch
- upgrading my fuel pump on my 93 cx, would i need to change my fuel rail & injectors?
- 210hp
- str fuel rail?
- Just wondering did anyone regret goin all motor?
- Where to buy oversized intake valves for B18B?
- RPM 66mm throttle body sticky??
- where to set vtec and rev limit on custom chip, lsvtec
- You have never seen a Dyno Graph like this.
- Timing Belt Tension...Is performance directly related?
- Tourqe specs for Toda cam gear adjustment bolts please
- What exhaust to run??
- ctr crank pulley is it really worth it????
- Will gear ratio's affect dyno #'s?
- setup questions
- NEED HELP with i/m!!!
- headertech header
- In need of GOOD resources:ITR engine swap on east coast for 97 civic hx
- de stroking the b16.. opinions on full race options
- Can someone ID these injectors??
- difference of V-tec and I-vtec?
- Wiring problems with my Y7 Harness for a B16A2 w/ OBD1 Computer
- the zc is good and bad in a way
- my new ET, 94 cx with JDM ITR
- VERY SPECIFIC question about head milling/cam/valve to piston clearance
- Just got skunk2 SOHC cam gear...
- Poor Mans Type R Compression Questions!!!
- h22 injectors okay for my setup?
- I just ordered my Header Tech header.
- Calling all GSR blocks
- $6000 210whp all motor recipies.
- Any H22 guys used these
- Header Topic #2389023829 for EM1 say stock power b16a...
- Toying with a new idea: B series crank in a H motor
- rying to find thread with Darton Build, cant find after searching for 10minutes
- what will ITR internals in a b16a1 do
- oil psi guage
- INT 254 / 503 EXT 250 / 503.... good on stock block ls?
- itr tranny vs. cams and valvetrain
- All motor Sohc build up
- engine terms?
- an-r full size or compact??
- weird sound coming from my car think its my tranny.
- How high to rev....
- Can my lsvtec setup out run stock b20vtec?
- how much power do you think???
- Whats TRUE???? Pistons P3/P30/CTR in B18A/B Clearances and Shaving???
- Assembly Lube Question
- Piston ring placement
- B16A (PR3) pistons in LS/VTEC?
- Where can I find perfomance heads
- "reconditioning" rods
- B20 VTEC
- Can you??
- best place to get a jdm DC 4-1 header
- Can't choose a compression ratio for my build.
- stock sounding exhaust?
- K-20 EG/EK/DC2 street headers
- finally the build begins
- clearance issue.
- VAFC anyone using it with an LS brain?
- Need coilover sleeves for Skunk2 race springs?
- B16 block with 1.8 Type-R Internals
- Help me decide what to do next
- anyone know the specs of a d15z6?
- This is what happens when your cam gear slips and advances itself all the way
- b18b Timing, Please HELP!
- 94 civic hatch exhaust sytem
- LS B18B1
- GSXR1000 Complete ITB setup For Sale...
- Who knows what a ZC is?
- can somebody help me with this?!
- help me with my ls set-up
- All Motor Chassis?
- Wanted: skunk2 stage 1 cams and gears install + valve ajustment. no tune.
- ZC vs Z6
- Omniman, Rocket, RLZ, Anyone?... Running prelude lma + washer = no go??
- Help N/A Gods, Need Answers
- Eagle Rods=Motor Go Boom
- fuel question
- Need a reputable dyno tuner in Socal!
- Msd 6al w/ blaster coil and cap
- h22 ecu question
- AASCO Flywheel
- h22 build up?
- Msd Pills?
- good engine builder in bay area
- Where to buy JDM P30 Pistons!!!!
- Header setup Complete!!!
- efi hardware ITB's....anyone use em?
- Cam question...
- LSVtec rev question
- skunk2 harness??
- Catchcan setup for ls/vtec???
- help with injectors?
- Are these reall ctr pistons or fakes.
- ITB filters anyone
- K Series Guru Wanted
- N/a engine noe but turbo later...Need help building and deciding...
- what's a better cam for my setup. Toda B's or Skunk2 stage 2's
- Import Builders anyone suggest
- 280 psi is ok for H22A4 with oversize Type S pistons?
- all motor non-vtec question
- can anyone take a pic of their USDM P72 head (dizzy side)?
- GSR all motor question
- help with skunk2 stage2 specs...
- LS/VTEC let go after mis-shift?
- help me and my mini-me.!
- 440cc Injecters and V-afc....
- Typhoon internal modification, pics inside.
- Buddy club, ITR, Gsr cam compairison pics.
- valve clearance ls block with type r pistons?
- b16 comes with dual valve springs?
- oil in combustion chamber.....fixed see how.....
- Stock B16a2 Head/Stock B18b Bottom End
- Car Dyno'd, does this sound right?
- Fuel Additives for "Increase Performance"... Opinions???
- ITR pistons in a b16a1
- trying to start a header tubing ID thread
- tach doesnt work
- ignition?
- B20 with B16 head...crank girdle ?s
- engine is back
- just finished poormans r swap, now vtec is lagging!!!
- Need help w/ TPS on Homemade ITBS
- Question on a/f ratios
- update: b20vtec hits 233 whp and 151 tq on secret services dyno!
- if I deck my block (B18C1) like .015" , should I shortnen the two dowles too ?
- octane booster?
- weisco pistons
- N00b Help Maint Reguird Light
- HELP??? i need the specs on the lobes of S2S2
- NOS on stock jdm h22 w/80k miles?
- 2001 ITR Piston to Cylinder Clearance
- What would you do? LS/VTEC Dilema
- L'NATURAL Racing's DVS Drag Civic Sports New Scheme For 2004
- Honda diagnostics on eBay!!!!
- LS/VTEC...in reverse?
- Head gasket question Cometic
- Hybrid Auto/Redstone Motors H23 VTEC Dyno *video*
- F20c or K20a2??
- Good platform
- b16 build up help
- b16 swap
- JUN GT surge tank??
- Changing cam gear need help
- stroked b16 or b20 block?
- Loud Exhaust....Need to Quiet Down
- DIY ITB??
- Good move to make? or just keep it?
- GSR motor + P28 ecu + Fields VAFC question
- best cams
- anyone in the world with non vtev b20z
- Who sells thinner head gaskets?
- Foolish setup?? Oppinions...
- ~2.0L fuel consumption ?
- 11.5:1 B16 COMPRESSION
- jdm dc 4-1 header or dc sports 4-1 header.....
- Building the d16a6 bottom end....................
- A Challange anyone?
- Anyone know there cooling systems?
- $1500 to spend
- Stroker B16A = LSVTEC?
- code 43
- what exactly does all motor mean?
- will ctr intake cam work good with stock gsr exhaust cam?
- The difference between b16a2 IM and JDM ITR Intake Manifold on built head w/ b18c5
- What about this Block...Input is very Welcome
- ECU upgrade witch 2 go with? And where?
- hypothetical, how much would this setup put out?
- 4.7 or 4.4 final drive
- b18c5 hondata
- GSR crank/rods in B20???
- what kind of Vtec controler is this?
- how to identify crower cams
- h22 or h23
- Skunk2 Contact Info???
- 1st Hand experince with bearing failure due to Pulley anyone?
- Final All Motor Project underway: Head is back and ready for assembly(56k no no pics)
- 99 Civic SI Intake manifold Question
- 2002 Civic Coup LX
- Apexi VAFC Ver.1
- break-in then tune, or other way around?
- Do I need to upgrade the fuel system? N/A LS
- B&M at 42 psi - unstable fuel curve - fpr or fuel pump??
- Anyone have the part number for a 2.5" exhaust gasket (donut) "searched"
