- LS VTEC Assembly Problem!!!!
- B16 piston with on a GSR block/head, will it clear?
- I got a stock b20vtec whats the biggest cams i can run
- 95 Gsr Block oil cooler question
- how 2step looks like internally
- Run on 12* timing?
- Help?!?! Tips for separating rod cap from rod
- Dual resonators? Will i lose power?
- hytech replica header
- Hesitaion when accelerating, need help!!!!!
- 4-2-1 Vs. 4-1 Header
- quick question
- Jason @ cncport.com Look inside.....
- piston too valve clearence?
- Which one should i go all-motor with B16 or B18?
- portflow inner springs?????
- HELP NEEDED FROM SMART HONDA HEADS
- B16A having rod problems
- what type of gains should i expect b16a2 all motor build
- what size exhaust for my built h22 motor/w RMF header...etc
- B20/Vtec specsG
- vTech Engine
- timing belt question
- b20 crank in gsr block
- obd2 or obd1 ecu?
- 1.8 low 12s high 11s part 2
- B20Z INTO EJ1
- LSV- what size TB??
- Good aftermarket intake manifold for H22a??
- RBC manifold or K20-r manifold?
- All motor gurus check this out... i need some opinions on this dyno
- rebuild time!
- whats my compression
- daily driver
- how much timing advance???????
- all sellers beware of Waterbury CT
- gsr pistons fit into a b16a??
- Rebuilt Engine - hard to rotate crank?
- 92 DA with what swap?
- Jdm b16 swap into 96 civic dx coupe
- Specs for valve adjustment Blox type b
- CRX Overheating problem.
- VTEC nightmare
- does the casting on the vtec cams mean anything?
- what type of power should i expect minor n/a b15
- header question about buying
- Ported Head Part 2
- PnP head install checklist...help!
- OBD-0 Head/OBD2 chassis lsvtec?
- ITR crank ID
- Why was RMF banned?
- girdle neccesary for lsvtec?
- need some measurements...
- 93 4-door Civic 202.7whp
- tough Vtec problem not even tipton honda had an awnser.
- Anyone else having search troubles?
- P30 (SIR2) or P73 (USDM ITR)
- LS VTEC Oil pump question
- best throttle bodies for DIY 81 mm
- How much is a B18 motor...
- valve adjustment on jun stage 4 cams
- Distributor???
- D16 build
- Good Vibrations
- good comp. burning oil
- what cams do i have? help please
- MPFI
- Need exhaust opinions for base DC5!
- Tuning Question
- Cam indentification....Please help
- skunk 2 pro 2 or skunk 2 pro 1
- WATCH OUT BUYING PARTS FROM SKUNK2GOTOGUY
- need help on my itr all motor build
- Painting a header
- Main Bearing Number / Color
- B16A2 all motor daily driven setup help
- Eagle Rods: Journal size for bearing selection D/H series
- Vtec head on non vtec motor??????help
- Going to build a b20 blick
- Question about regarding the rodknock sensor on a 99 civic si with an all motor ls vtec setup
- b18c5 with jun stage 4 cams???
- help on deciding minor b16a block build and head build
- sparks racing pistons?
- What you guys think about my Killer-B
- Degreeing camshafts? benefits? worth it?
- Rebuilding my head which valves should i purchase?
- Opinion
- WHAT WOULD YOU DO?
- civic throttle body question....
- GSR block, need parts, suggestion?
- LSVtec Compression Debate!!! Everyone Please Look
- Input on Premature 6K rev-limit please
- Help installing gauges?
- CAMP1320 header or hytech replica tri y header?
- skunk2 intake manifold question
- Locking Vtec Permantly on Road Race engine
- Compression PSI on Compression Tester
- Hardcore Rice Burner Sound after Cat-Back!?
- Anybody know what happened to Jeff Evans?
- Question about R/S ratio and effect on bearings
- Bisimoto tuned?
- how hard is 400whp
- b16a suggestions help block blown head needs valve job etc.
- Increasing Cams Overlap
- syncing distibutor to ecu help/ advice to pass smog
- Been a Bad Day Yeah.....
- B16 need help on what internals to add
- is bigger throttle body better?
- Can some one hook me up with a Old engine they dont need
- OBD2 car, w/ OBD1 engine?
- Balanced/weight ITR JDM Pistons ?!?
- Cam clearance? b16
- jhpusa "B-Series VTEC High Performance Camshafts Stage 2"
- Rebuilding my block, should I install a block guard?
- itb's or headwork next?
- what could cause this?
- Compression problem
- Bent valves, is the block fine?
- setting up basetune for 12:1 compression and stg3 cam?
- need help with aftermarket intake manifold idol problems
- Recommended mods for all motor D16Y8?
- b16 Looking for Feedback on Buddy Club spec IV cams
- Were to go next with my ITR build
- Stock b16/b18 Valve Sizes
- Dyno charts & setups with buddy club 3 cams
- I HAVE A FRIEND WHO WILL NOT LISTEN (PART2).... please help
- HEADSTUDS
- File-to-fit rings
- how much hp can b18c5 pump out?
- b18c5 turbo problem
- honda with no back brake?
- cam timing suggestions to fatten up the midrange...a bit long
- K24/20 Help PLEASE!!!!!
- gsr bracket?
- ls rods in a b16?
- b19 build teaser pics
- PROJECT UNIT(ALL MOTOR K-SERIES STREET CAR)
- Brian Crower 0012 (Stage 2, Naturally aspirated) cams???????????
- best all motor setup
- best valves/retainers with toda spec b cams and valvesprings?
- QUICK POLL ABOUT SKUNK2 PRODUCT
- Damaged block, how much is it worth?
- Somethign interesting I learned about the K series adn B series (vid inside)
- quick question about JDM ITR 4-1 Header
- Hole saw size so I can cut my valve cover...
- S300 - Launch control for all motor, is there more to it??
- MSD Pro Billet Diistibutor and Cel 8 (TDC sensor), limp mode ECU maps
- camshaft?
- D15 help?
- ls vtec nitrous set up (need some advice)
- This scared the hell out of me!! OBX VTEC eliminators
- crvtec oil pan and pcv
- Anyone heard of DH-RACING?
- camshaft question
- broken valve spring
- super-D
- crankshaft question
- Crome Chipped P28......i got questions, and hope you have answers
- Ls/vtec stroker question
- skunk 2, Mugen,spoon chip?
- ls crank in zc
- k series itb ?s... any help?
- HELP!! Aftermarket Valve Problems!!! Need Help ASAP!!!!
- Simple Question About VTEC controller...
- question
- D17A1, A2, A6 Valve Sizes?
- Why does everyone upgrade injectors?
- Off the Shelf 250whp motor.
- h2b vs k20
- power estimate on a sohc zc with pm7 pistons?
- POOR MANS TYPE R Dyno Request
- Cam caps...?
- horsepower skunk 2 or type r
- MSD Wires Pissing Me Off'
- hp estimate on b18c?
- H22A V. B20VTEC ??
- h22a injectors
- Setting up spring heights
- Total Seal Piston Rings or NPR Piston Rings
- Opinion on Motor
- 97 civic lx auto? what the hell do I do with it? its toooooo slowwwww
- mildly built b16 injector question
- Skunk 2 Camshaft Cam?
- can't find vtec selonoid anywhere
- do i need a hone?
- TSX motor search
- nitrous on high comp
- B16B intake system
- oem headgasket?
- Were is the thread for dyno numbers on stock 1.8 bottom ends?
- Stock GSR valvetrain with ctr cams
- ITR rod weight?
- Shop in NY
- Skunk2 pro series stage 3 ?'s
- Can RSX type S Injectors work for obd2 gsr?
- Skunk 2 Pro 1s Gsr Question NEEd 2 KNOW ASAP
- Rocket motorsports
- B20B with a B16 head and cams
- K20A2 or K20A head with k24 block
- Cold Idle Issues with Skunk2 TB on a built H22
- buddyclub , rocket , microtech
- Want to build my motor....
- doing lsv... itr or blox stage 1 cams???? helppppp!!
- Motor Sitting Two Years
- Acura RDX Injector
- Need Help/Advice. Low RPM Surge Idle and Water Leak through door/rocker panel?
- JDM ITR CAMS WITH ADJUSTABLE CAM GEARS
- crankshaft balancing?
- G23vtec piston compression question???
- running with no exhaust piping
- B20 vtec n/a or boost?
- Engine theory question again (b16b tuning)
- worn out valve steam guides - good way to fix it?
- b series/hybrid
- JUN 3 camshaft and camgear degree Q???
- camshaft install question
- lookin for sum power ??????
- k24/k20 vs C32
- CP PISTONS RATIO
- Ls/vtec w/p30 piston setups wanted!
- Help with reinstallation of cams
- How many RPM's ???
- obd1 b16 with itr manifold and skunk2 tb
- Need a lil knowledge contribution on an all motor build i'm doing.
- Should I deshroud my combustion chamber on my DD?
- oil on sparkplug
- couple questions
- question about plastigauge on main bearings
- No oil squiters with stroker kit (esp. Crower).
- 2.0 Liter LS Vtec Numbers. Confused.
- B18CT PISTON RATIO
- Going for 200hp+
- HELP light knocking in head
- built motors?
- ls/vtec
- OBD 0 tuning Help.........
- PLEASE DON'T HATE ME HONDA GUYS, but HELP!!!
- question about aftermarket cam gears
- Which coolant to use?
- LS cams in B16 head
- B16's with Crower Stg. 2 Cams, Post results
- Compression Ratio question
- ITR?GSR Crank
- Fuel pressure reg location?
- looking to build N/A SI....need some help
- B16br --> B18cr
- Quick tunning question
- Overseas LSvtec Dilemma - good parts...But Expert input needed
- k20a2 stock sleeves
- Header Test - K20 - SMSP vs DTR/SSR
