- Stupidest mistake youve made in the automotive field...
- ignition knock
- Blew up my motor...what to do now?
- How to know what camshafts I can run on my 11.5 setup?
- I'm PISSED
- Putting my H22 together with .070" off the head, looking for some experience regarding clearances
- Intake manifold Questions?
- about light flywheel
- finally done with my b20vtec..
- b16 burns oil only from 4.5-vtec HELP!
- valve cover
- Head stud pattern?
- Tuning a stock motor for MAXIMUM gas mileage?
- rmf narrow header came in with a dent
- How difficult to install a new exhaust manifold?
- Guys one last time! I can't figure out what cams these are.
- Running weird at partial throttle after header install.
- GSR primary lobe cam specs.. Nobody can answer this queston.. :(
- Best bang for my buck. SMSP or RMF??
- Dropping a b16 in a ek
- My b18c5 build
- ** B series vs K series ....does this settle anything? **
- Suggestions anyone??? My future NA LS VTEC set up
- lsvtec ? arp rod bolts bolt torque spec specs cap stretch
- All NGK r-45671a-8 users
- A New Record Perhaps? 340+ hp H22...NA
- NSX Piston rings
- Anyone done ITB's on a all motor LS settup?
- Will a rev limiter help me?
- 8 vs 9mm arp rod bolts?
- b20-vtec or ls-vtec?
- How to clean a header?
- can i get some specs on a JG 85VT35 cam?
- which tuner? APEXi or Hondata?
- Toda Spec Bs not making power
- Powe TB?
- What size injectors should I go with my future setup
- H22 powered
- Exospeed D16Z6 Race SV camshaft
- Highest compression for a H22 street
- ls block with ctr pistons
- o yay another ls/vtec build!!!!!
- Viorent GRIP! eg's : Sport Compact Car Debut : B18 vs K20~oh yaaaaaaaaaaa
- ITB'S STOCK BLOCK? OR BUILT HEAD STOCK BLOCK?
- need some opinions b4 i buy.....
- which axles to use?
- DOHC D16 to mini-me SOHC possible?
- gsr head and ls bottom end?
- ls/vtec question injector size
- intake manifold on a ls?
- Good Setup For Type R motor?
- aftermarket vavlesprings with stock valves and reatiners?
- ITB Question
- ERL Block Girdle: Where to buy?
- Poll: "Help me rev to 20k" threads, Useful?
- vafc, worth the money on a near stock sir-II
- Stock GSR w/ITR Head
- which valves and cams for N/A build?
- Sign affects of a burn valve?
- IAT sensor.
- Need help! $$$$
- Vegas All Motor winners
- blox extended studs????????
- Ls/vtec question
- iacv on itr manifold??
- anaerobic selant between bearings??
- Simple Question, pls help - ITR Fuel pump fits 97 Civic EK?
- TMW ITB's Questions
- To much Throttle body? help!
- sohc header design
- k20 build questions???s
- Question about Cams in a B20-VTEC
- Timing
- Quick question on bore diameters, 81mm =1.6L and and 84=1.8L right??
- Part Throttle Tuning?
- Load Dyno
- aftermarket vs gsr/itr block girdle?
- anyone hear about the new k23??
- b16 with b17 internals is this possible???
- what spark plugs
- piston size, probably a no brainer
- Chicago and area tuners?
- b20 with b16 crank
- What OBD are k-series ??
- Fuel pump or something else??
- Pics inside!!! LS/VTEC!!!! Pics inside!!!
- My dyno graph
- stage 3 or pro1
- Will this setup cost any type of risk? JDM ITR Block w/ GSR head, High compression valves
- Distributor question ??
- engine harness question???
- D16Y8/D16Z6 Hybrid Distributor Question
- Custom Manifold Spec Advice
- Moroso Oil Pan Again????
- Will I hurt anything?
- Will it line up
- Is this build reliable, Opinions please!
- looking for crome/uberdata in Ontario or in MI
- grey/gray ish white smoke ? what's that mean?
- looking for more hp w/o touching internals for b16
- Tranny problems at high rpms?
- b18b1
- Help!!! 99 Integra GSR burning oil and sputtering out of tail pipe... What's up with it?
- Wonder 1.8 killed. Reborn 2 liter rises from the ashes. Graphs.
- 98 jdm type R dyno
- 200whp all-motor d-series HOW???
- who sells race headers???
- Need help finding a previous thread/ TWM ITB (sticky throttle) mod!
- GSR Cylinder Head Castinght
- Couple things on my mind
- Cam Timing Question
- need some help and ideas
- ITBs worth the money ??
- header for SOHC????
- Valve Stem Seals - 2 part #'s? + questions.
- Leaking cylinder head gasket on my 96 EX Civic
- Dyno Test of DC JDM, SMSPx2 and the NEW Rage Big Tube Headers on a high compression LS/VTEC
- 10.93 AllMotor Street Car, New COMP4 record
- Valve adjustment for new cams?
- Help with Injectors!?!
- D16Z6 6800 RPM redline?
- Setup Help Needed Again!!!
- stock fuel pump LPH <empty search>
- all motor d16y7 help, possible build?
- gsr full build help
- Clutch faulty?
- Stock B20B-LS cams vs Crower 62403-2. Non-VTEC graphs inside.
- Need help what cams on b20vtec
- Evap [?] hose... where to put it?
- Help: Making a crome basemap..?
- I have a problem third gear sputters..
- what compression will i be runnin?
- looking for a good header for the road
- lsvtec with stock ls pistons?
- Build GSR for sell
- K-series headers
- Okay please answer this whats the best
- Okay for the second time around, whats the best tuning program
- B18C(5) compression test results
- I need help with my build (Poorman R)
- swap questions??? need help
- rod bearings: ACL vs Honda?
- Moroso Oil Pan Vs. OEM GSR
- Compression Ratios...new to hondas
- Which intake mantifold should I go with (out of these 3)
- LSVTEC B16a vs B18C1 Head
- Took my ej8 H22 to the dyno(vid/graph)
- b16 v-train and type r v- train
- Ignition Tuning on a Load Dyno - How exactly do you do it?
- p30 piston in ls Q?????
- what kind of tuning program is best for an all motor setup.
- b17 w-m22x and pct's--
- What do you guys think
- type r head onto gsr block?
- pinging under load at low rpm's
- Is this Setup Possible??
- b18b1 vs gsr short block
- LS crank GSR block
- smog on lsvtec
- Why do you guys aim for crazy high compression ratios?
- valve adjustment
- got my b20vtec run last night
- RLZ Enginering ???
- blox a cams
- itr block, b16 head & trans
- GSR Swap Problem
- vtec kicks but now pull...
- b17 crankshaft into a b16 block DEPENDABLE?
- What Cat for Profab header on a DC4??? ASAP
- what upper power steering bracket do i need for a pr4 b18b1 head
- highest compression
- Bottom End Build
- to intake manifold or not to...
- What to do
- ctr crank pulley
- rocket motorsports valvetrain work with buddy club spec 4s?
- Tell me if this B16B shortblock is worth $3000
- All motor set up question
- Welding combustion chambers?
- CROME fuel pressure old vs new vs actual PSI
- 1973 Ford Pick Up 302 V8 no power!
- magnaflow exhaust
- K20a w/ITB's
- Jun 3 - Fuelling & Timing
- Is the snl twin loop the same as the ebay one???
- ITB'S? OR BUILT HEAD STOCK BLOCK?
- buddy club spec3 question for GSR owners
- Uneven AEBS manifold flange
- my modest all-motor gsr setup...but i need header advice.
- Looking for a good book on engine basics and building
- Skunk2 Pro TB???
- hello
- ...:::: can anyone point me in the right direction?::::...
- M24x vs. oversized valves (T-bone maybe u know?!)
- plugs look "lean" on my GSR/type r piston/stock GSR cams/skunk2 IM motor
- smog results on poorman's type r
- cams for 13:1
- ls vtec problem?
- GS-R and B20 Vtec Head Studs The Same???
- how much money am i looking at?: reringing 00 type r engine.....
- Stuttering problems!!!!
- H22 engine build questions
- How much would you pay for a tunable muffler?
- LETS PLAY A GAME! Name these springs and retainers....
- ? on cams for 99 ls
- K24 Simple Build IPS Kme cams dyno results
- Looking to Take Off GSR head off Block.. Need Help
- Decent setup?
- no spark or fuel...car just suddenly dies...
- Hondata+VAFC
- Which H22 Intake manifold is best? Already searched!
- accurate CLT & compression tester??
- bearing clearances?
- what else does it need b18c1 block?
- +.5mm intake valves
- LS and B20 engine parts
- <<< for all the <CROME> doubters out there>>>
- 81.25 bore...better to use Cometic 81 or 81.5mm ?
- Helppppppppppp
- sorry bout the confusion
- questions before i start the swap.....
- What does it take besides these parts to make 280whp
- All Motor parts for sale built si head and b20 block
- general d series question
- Tune vs Suspension
- New Intake Company, anyone seen it?
- all motor b16
- itb and poor gas mileage
- Losing Fuel Pressure...
- What tps plug fits twm itb's
- Valve adjustment?
- Engione Balancing Q's
- New Build Tips/Advice
- selling my ls/vtec crx
- Using pistons made for .5mm oversized valves with std. sized valves...good or bad idea?
- Valve lash on 94 gsr
- b16 head gsr block
- msd issues please help
- ALL MOTOR QUESTION
- since gas prices are up... anybody thought about an 87 octane tune?
- Injector sizing?
- I searchde and came up empty.....ITB guru's please help!
- Skunk2 Throttle body and intake question...
- D16
- Aem tru-power pulley and the Forum under drive crank pulley togther ?
- b16 vs b18c cams
- intake air temps on a all motor build
- Fuel for my B18C5 with TODA D's (Daily Drive Civic Type R)
- VIDEO: LSVTEC coupe on street tires at the track
