PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 [170] 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. H22 swap into an 02 accord?
  2. bolts HELP!!
  3. help!!!!
  4. are nippon pistons good?
  5. what do p72a pistons come out of?
  6. Headers : DTR Fab VS AN-R
  7. Difference in B-series v-tec syleniods
  8. should i use old pistons for rebuild?
  9. Looking to build a motor.... but with....
  10. Can CTR cams run on a stock B16 valvetrain?
  11. Wondering if this is right *pls advise*
  12. ctr cams on a pr3 head rocker scarring?
  13. Opinions on buildup
  14. All motor daily driver vs overcamming
  15. Difference between b16a(XSi) and sir1?
  16. Compression on B16B w/ LS Crank...
  17. s2000 tuners
  18. cams???
  19. ITB's on an allmotor LS worth it?
  20. Vtec still acting up!
  21. b16a2 FPR
  22. "New" Skunk2 B-Series Intake Manifold
  23. Fuel system upgrade
  24. on header topic...
  25. NEED PART NUMBER!!!!
  26. -------Dynoing all motor street car " need test headers"--------
  27. Golden Eagle Benefits
  28. DIFFRENCE BETWEEN AUTO GSR MOTOR AND MANUAL GSR MOTOR ?
  29. IB Spec sheetmetal IM by JG
  30. Let's talk about weight savings while remaining streetable.....
  31. how high???
  32. Price tag of K&N E-2427
  33. Thoughts of what this setup will produce in HP´s??
  34. AEBS manifold
  35. Is 12.5:1 good compression for nitrous setup?
  36. dyno on b16 with buddyclub spec 3 cams and vafc
  37. bone stock b16a 146.55/105.87... more to come.
  38. all motor lsvtec setup? help me out
  39. h22 prelude disater
  40. JDM ITR Crank question.
  41. where can i get Hondata from (cheep)
  42. Rocket cams???
  43. Skunk2 IM or Ported LS IM?
  44. V-afc II Install Harness
  45. will b16 hydro diff fit in ys1 LS cable trans?
  46. Crazy Custom RMF header and b16 Head with major mods
  47. Is it really worth me getting a new intake manifold or should I just swap ECU's?
  48. Mugen Head Gasket
  49. Power Timing belts dropped pricing?
  50. help me decide which cams will get me over 190whp on b16
  51. DIY itb's or CTR cams?
  52. Average Fast N/A Streetable?
  53. civic type r cams?!
  54. ls vtec numbers??
  55. Cartek - Tuning in South Florida
  56. b20z vtec
  57. camp1320 header
  58. 2000 civic ex coupe w/ b20 vtec.
  59. eages rods and ctr pistons ???????????/
  60. Looking for a good H22 cams??? Someone help me
  61. Busa ITB's fit H22....
  62. b16a2 build up?
  63. Idling issue after Buddy Club Spec 3+'s
  64. header talk *i'm going crazy*
  65. which sparkplug would I need to use for a b16 head with a gsr block?
  66. b17a 97 EK all MOTOR!
  67. Boring stock sleeves....
  68. Question about Cometic Head Gasket for 96 B18c-r
  69. stock gsr n1 crank pulley
  70. Gapless piston rings benefit , worth for the money ??
  71. thinking of building a motor and just want some insight and opinions
  72. RM M22 in B16a2 11.1 cr?
  73. skunk2 pro1 vs skunk2 stage2
  74. Vibrant JSPEC 4-2-1 header installed.
  75. HELP ME WITH THIS....
  76. 2.0L LS/VTEC
  77. all motor street class rules<<
  78. Cheapest Site for Crower Stage2 D-series?
  79. head setup/intake question
  80. 12 sec eg
  81. my new b20vtec builup
  82. ls/vtec
  83. Dc sports Header?sounds Bad
  84. Spark Racing I beam rod feedback?
  85. Skunk Pro1 Cams
  86. Tips on Swapping cams installation?
  87. Best engine combonation for a tourqe whore
  88. Claying, locking vtec??
  89. ls-vtec build. Any suggestions?
  90. Can someone post...
  91. will gsr internals fit?
  92. b16 stroker
  93. ACL bearings and your trust
  94. B20B piston on B20vtec
  95. itr valve springs and spec 4's
  96. How big is too Big ?
  97. NEED Help deciding N/A Parts!!!
  98. Lsvtec vs poor mans R
  99. What header should i choose? edelbrock, JDM DC, Vibrant
  100. H22 Quality
  101. ///// Calling all MOTOR GURUS//////
  102. valvesprings..does it matter which side is up?
  103. ls vtec leak?
  104. ITR block with GSR head, Good?
  105. I just got a D16A?
  106. Port n Polish. Yes or No?
  107. would my motor run right w/ ctr pistons?
  108. itb help
  109. Air to fuel ratio...
  110. 11.3-1 compression, what cams have stock like idle but good vtec power?
  111. b16 head
  112. best cams
  113. Buying used valves? yes or no?
  114. b18c3 rebuild
  115. p30s into a lsvtec
  116. wtb one ring 20 over piston ring
  117. H22 GURUS HELP ME FIND A BETTER FINAL DRIVE
  118. !!!!!!!!!!!!!!ok i need some advice CHECK IT OUT b16a w/oversized itr pistons or ctr piston to GET
  119. cams
  120. best midrange cam for b16 w/ stock valvetrain
  121. CTR cams on b16a worth it?
  122. what cams to use?
  123. Best Stage 1 cam
  124. LS and B20 cam difference?
  125. Highest revving B18C*?
  126. golden eagle ls/vtec kit Q?
  127. ls/vtec q
  128. Rocket, anybody, I need help....
  129. CTR cam specs
  130. K20a2 Swap into Del Sol
  131. header instal?
  132. Need suggestions as far as pricing. B18C block with b16a2 head
  133. JDM 4-1 Requirements
  134. Degreeing BC III+ Cams
  135. Reccomend me a TB for my 2.0L ITR
  136. anyone run skunk 2 stage 2 on their stock bottom end gsr?
  137. timing belt quesion for my B20
  138. help, timing belt problem.
  139. help me if you can Plz
  140. ITB"S good or bad on my set up?
  141. poor mans R
  142. Anyone know the different from itr and ctr
  143. Identify this exhaust cam
  144. Stage 2 cams
  145. Best flowing air filter??
  146. Anyone around the Amarillo Texas area willing to help w/ a swap?
  147. crazy question:
  148. How much milling...? B16A2
  149. WHATS BETTER SINGLE OR DUAL EXHAUST????
  150. Snapped Cam Cap Bolt in P8R head.
  151. B16 Cam Gear install (keeping cams from spinning durring)
  152. Buddyclub Championship winning ek4 civic
  153. how high should i rev
  154. my cars dead. i need b16a2 distributor fast anyone hav 1???
  155. valve job
  156. VTEC HEAD what to pick????
  157. B16 shootout follow up
  158. 84mm Cp Pistons!i wan to know how much compression this set pistons can gain wif B20B and B16A2 head
  159. Mugen ECU vs. Rcrew Kpro K20A
  160. gsr intake manifold
  161. Mid Atlantic st00pid Dyno/Tuning Days Sponsored by Boostfed Racing In Virginia April 15-16th Sign UP
  162. DTR B-unit Vs. Hytech..
  163. what is the difference between a race header to a street header.
  164. JG edelbrock or SKUNK2 ?
  165. how do you tell if you have a gsr tranny
  166. need help with these terms.
  167. What differential for jdm y1 b16 trans?
  168. Stripped Flywheel Bolt..
  169. spoon cam lobe size?
  170. ive got $400 what can i do to get more horsepower on a 94 del sol 1.5 Sohc
  171. CBR 600rr throttle bodies?? Good for DIY ITB setup?
  172. i need some HELP! What should i put into my motor!
  173. what things can I put on my Del Sol for more horsepower for under 400 dollars
  174. Laptop requierments for Emanage
  175. B20 head buildup
  176. rmf header....anyone actually test them against a dc or something?
  177. Sprak plug chamber problems
  178. ***Attn:East Coast All Motor Drag Guys***
  179. Rev Limit of stock LS lifters - B18B
  180. SORRY CANT POST ANYWHERE ELSE HELP ME...GOOD DEAL RIGHT HERE CHECK IT OUT
  181. has anyone ran 12's in a 94-01 integra body?
  182. anyone making 200+ on a stock block jdm gsr?
  183. 201whp All motor GSR
  184. What you making on 91 octane ?
  185. blox type A safe on stock valvetrain?
  186. Throttle position sensor
  187. How many of you guys are putting down 200+whp on a stock head?
  188. should I buy this ITR block&head for $3,450?
  189. ls built or ls vtec
  190. high compression head gasket worth the extra money?
  191. Fuel Pressure question. AEM & LS/VTEC
  192. 88 accord procect bseries w/ solex, got a couple of??????'s
  193. intake manifold???
  194. Should these valves effect my performance? Look!
  195. itr cams vs b16 cams
  196. All Motor Head Help
  197. All Motor Bucket Build
  198. JG cam valve lash please help
  199. Highest Compression
  200. Exhaust Piping help
  201. PLX M300 Install help
  202. Euro R H22 swap... Just raced a fully built GSR hatch
  203. how to post a pic out??????
  204. Any high flow cats that are 100% street legal in CA for civics?
  205. do it dyno
  206. 2000 B20b Quarter mile times.
  207. Another LS/V question...click me!!
  208. tec vs. no tec DEBATE! Important!
  209. Times for my 2000 honda civic 4dr
  210. Piping Size
  211. NEED HELP Extremely bad. (tappet popped out of p8R head)
  212. 00si b16a skunk2 stage 2..over caming?
  213. Skunk2 S1's vs. S2's
  214. Has anyone here CC'ed a spotfaced head (B-Series)
  215. consequences of running loose lash?
  216. can anyone tell me what msd i need ?
  217. CTR pistons in a B17 block
  218. itb manifold
  219. ITB for d-series
  220. greddy e-manage to run N/A h22 coup
  221. how do i know how much i can mill my head
  222. skunk2 pro.'s 1+
  223. FS FLUIDYINE HALF SIZE Radiator for sale fits any 92-00 civic with fan
  224. CTR pistons On eagle Rods.
  225. ITB's or Throttle body
  226. Help me out with my motor!
  227. use math to build motor?
  228. Type R pistons on LS rods (ive searched)
  229. Cam opinion for a6/z6 mini-me?
  230. Omni Power
  231. Who's still running Toda C's nowadays?
  232. SOHC cam swap
  233. ECU wiring guys needed..CLICK
  234. Should I have to clay my GSR after cam and piston install
  235. Dh-racing engines
  236. ls vtec or gsr??
  237. Need some Motivation..How long did it take to complete your project?
  238. good machine shops in miami?
  239. Stock p&p vs AEBS intake manifold
  240. Fuel setup, etc.
  241. Dynoe some Skunk Pro1's on a GSR
  242. need more torque
  243. all motor d16a6
  244. OBX H22 cams??
  245. formula for compression with head milled
  246. Crower 63403 or Skunk2 Stage 3's?
  247. 225 pump gas daily driver
  248. 12lb vs. 8lb flywheel
  249. Four-oh-four's, what exactly is the "nasty idle"?
  250. All motor b18c top end lean out
