- Anyone have any info on Cook headers?
- Erics Racing??
- too stiff a spring for a cam?
- d15 and d16 flywheel help please
- CTR head code?
- ls/vtec
- b16
- 239 whp/ 169 lb-ft Dyno
- ls vtec build 200whp
- replacing rod bearing
- lsvtec or gsr?
- freeze plug question
- Centerforce Clutch Noises??????
- B18c5?
- gauge question
- question on a p28 ecu
- help wtb some cams but dont know what will work with my valvetrain
- CTR N1 pully?
- Valve Cover Catch Can? Purposeful for under 220hp??
- ACL bearings??
- LS Vtec question??????????
- A little knowledge goes a long way... The effects of Ram Tuning
- prime garage titanium exhaust
- Best lsvtec header for clearance and performance....
- Running higher compression without an aftermarket cam?
- b16 distriubtor problem
- Apexi Tri-Y Header. Anyone Heard of, or any feedback on?
- All motor SOHC runs 9s
- Will Toda Spec C's work with CTR pistons in a b18c5 or should I go with B's?
- Pit performance titanium exhaust
- Anyone ever use a turbo manifold for their engine?
- Dyno plot of JUN 4 vs Toda C2 vs BC5
- searched but stuck
- Monster all motor CRX-not for the faint of heart!
- My First Header!!...ooo its crude, let the bashing begine :(
- Toda D cams
- First NA Build
- h22 qm times
- 11.73:1 c/r h22 stroker with questions.
- Stage I Cam idle
- I have $800 for a header
- which turbo kit
- Best prices on block sleeving?
- Which I/M-TB ???
- Machine Shop might be ripping me off!!!!!
- valvetrain for bc3+
- fuel pumps
- Is it worth it keeping the ITR crank in a B20?
- Dowel Pins!!! b18c1 head
- Dyno: Simple ITR build - 210whp/134tq
- B series build
- Easiest way to remove cam gears?
- ferrea/crower valvetrain?
- LS/VTEC ProblemS!!!!!!!!!!
- Stroking Gsr Clearance?
- My new eg hb setup
- Engine Help
- anybody know how a good tuner in the nyc/ct area?
- where to buy USDM std. bore ITR pistons?
- SYnthetic ????
- 83mm pistons on a B18
- When Has a Torque Curve Looked Like This From a Honda?
- gsr block w/ctr head
- omni valvletrain??
- Buddy club stage 3's with stock injection system?
- removing crank shaft
- opinions about HMO
- JDM B16A swap.. 1 o2 sensor or 2 o2 sensors? HELP!!
- lsvtec destroyed ....
- give me your thought about my future setup b16!
- ss auto chrome type r cams?
- Anyone use Exospeed for an engine rebuild?
- all motor mods????
- N/A Custom Header Brought To You By Canada!! 56k No Way, Monster pics.
- Burns Stainless Thin Gage 321 Stainless 4-2-1 Road Race Header
- Need Help Picking Pistons and Cams
- VTEC solenoid
- running cams w/ different make valve springs?
- need help on ls/vtec
- #4 Cylinder Not Firing - HELP!
- B16 with ITR/CTR Valvetrain?
- skunk2 stage1 VS bc3+ cams
- BC3+ cams question (searched)
- Spoon Ventuli Plate vs. Hondata IMG
- GSR BLOCK, LS CRANK & RODS.......WHAT PISTONS??????
- Hello Everyone- Im New... Some descriptions of my motor...
- H22 HELP
- is hte b20 a freewheeling engine?
- ls crank....gsr block.......
- Question about STR cam gears
- whats next for my car? i want to hit around 180-190whp help
- p28 ecu ? -searched-
- KSeries Times
- Just got my head back from the machine shop,got a question though????
- How to pick cams...
- GSR Dyno Request
- putting CTR pistons in b16a, what's a good price for shop work?
- Carburated b20-v, 13:1 compression on pump gas???
- b18c5 piston in a b18c1
- New to LSVTEC- Its all stock, need more pull
- b20 VTEC-TODA C's or JUN??
- K-Series Headers...
- Clearance issues...all advice is welcome
- Omni Power Valvetrain vs Supertech Valvetrain
- portflow valve train and JUN 3 cams, will this work?
- H22 starts and then dies
- Does anyone know how to get ahold of STR Power
- something alittle different: the gas pedal
- Integra Type R For Sale
- HeelToe Automotive contact info-
- Basic Mods questions
- jdm gsr dyno
- helms service manual
- B-Series Camshafts Combo Package
- Question about BC cams
- gapping spark plugs
- Head gasket question
- xs power
- GSR build-up question
- For Sale LS Short block with 82.5 oversized CTR Pistons
- which cams??
- answers plz
- Valve seal and removal tool kit???!!!
- ITR cams or NOT (jus bought them)
- Which probe for Autometer egt gauge?
- F20b Pistons (DOHC VTEC 2.0L Accord Type-S)
- proper use of rod bolt stretch guage?
- Need advice on cams.
- tranny bolt help
- Skunk2 Intake Manifold Throttle Size
- which valvesprings for pro2 cams?
- Oil Pan Gasket
- H22 Problem
- Killer looking b-18
- exhaust system that looks stock
- B16B rebuild
- Erick's Racing throttle body in an eg6?
- action clutch website?
- header on a gsr block with moroso oil pan????
- obd2 O2 sensor and aftermarket header question
- Need advise for setting up my car....Spoon CAM with Port and Polished head
- golden egale ls vtec convirsion
- skunk2 pro2 225 at 7500rpm holding to 8600??
- Just got word from Quaife...
- question about deckplates (deck plates)
- crank position sensor keeps going bad?
- Irratic Idle issues?
- AN-R.com Insulated Intake Manifold Gasket
- Need a picture of a b18a/b18b head without valve cover
- LS/Vtec question
- hi, i'm from venezuela and need...............
- What's up guys??? summer CTR thoughts and questions.
- The fastest all motor 1.8??
- Why would you block the Thermostat Bypass on the IM?
- cracked sleeve, average cost to fix!
- Endyn breather kit + daily driving = problems ??
- Does this shortblock rebuild cost sound right?
- stock h22a cams + cam gears
- h22a CP Pistons from CAMP1320>>>>>
- black smoke?
- HELP: crome basemap
- question about boring out h22
- ls vtec
- vtec not engaging properly
- Part 2 - ranta18's H22 All-Motor Build
- JDM ITR SHORTBLOCK????
- Euro-R manifold: Compatible Honda Throttle Bodies?
- speeding ticket in the OHHH so fast VX d15z1 HAHAHA
- Tuning My B20
- intake manifold gasket?
- hondata question
- need some help w/ noisy valvetrain
- Hoping to get a straight answer. Please lemme know.
- Highest horsepower b18c1 without touching the block?
- hp numbers
- itb's
- breather kits
- All motor rebuild: How hard is it?
- Blox B lash Q's?
- Which valves? Ferea Competiton Plus/Sodium Fill hollow stem or Manley
- 96 p28 ECU
- Crome-where to buy, find info
- MAXBORE SUCKS :thumbdown:
- Is resleeving for N/A worth the cost???
- HKS ground wire kit
- AEM Type R 3'' CAI vs. Password JDM J's Racing Replica????
- new toda header version 2
- some PIX of a port and polish begining..LOOK
- VTEC killer cams by TODA?????
- DTR header, gasket, & flange WASHINGTON STATE
- ITR intake mani for a good price or aftermarket?
- Ignition?
- What does it take to get to 250whp N/A?
- Dynos and Specs (Quarter mile times) on all of your cars Please! HONDAS AND ACURAS ONLY, NO 5 POINT
- 96 civic engine harness help
- gsr ot type r
- MHR Performance
- 11:6 comp ratio as a daily driver?
- Compression test.
- HELP WITH MSD!!!
- 200whp with a fully built d-series, think it's possible?
- All Motor 2.0L Integra Type R Project; as it develops. (Part 2)
- skunk 2 pro 2 cams vs rm m22
- HKS Intake
- Built B20Vtec or Built Type R?
- Looking for a good cold air intake
- Plannin On LS/Vtec(Inline4 Kit)
- d16 1.6 Questions?? block assembly?
- best exhaust system for 92 hatch
- ITR cams in a B16A. No tuning. VTEC engagement?
- Eagle rods for D16 1.6?
- Question about the FIT motor.
- b16 cam gear problem HELP!
- biggest bore on stock gsr sleeves
- how to check injector signal
- thermostat ground?
- how much did ur build cost?
- I want to build a motor...
- Type R outers portflow inners with Skunk 2 Stage 2??
- ALL DRIVE MOTOR SPORTS DYNO LIMITED OFFER 4 DYNO PULLS FOR $25!!!!
- HEPLP!!!! CHANGED HEAD GASKET TO OEM 1 LAYER AND CAR RUNS LIKE CRAP!!!!!!
- problem with pro1s
- Whats the Difference between Standard vs HIGH compression valves?
- brand new skunk 2 stage 2 camshafts for sale
- Best way to clean cylinder head of shavings/etc.
- what else would i need for a b20 vtec build up
- Dc2 teg all motor wid b18c
- who out there is using an eagle crank?
- throttle body
- b20 vtec stock sleeves 85mm
- Pics of my Custom TDF B series Header *version1*
- j/w about this pic
- civic type R rod to jdm block
- Racerboyb18c1's 86mm build Pics!
- Safe comp. ratio on stock sleeves
- Defon-Racing project JDM K20A 1999 DC2 Integra
- Which Ti retainers??
- vtec head question
- MSD Blaster 2 or SS coil?
- wbo2 placement on hytech
- Will I be able to fit Oversize pistons in an unbored block?
- Valve Lash or Clearence on H22a Shunk2
- intake manifold questions
- 259whp 167tq B20 VTEC Dyno
- What size slicks do you use?
- gsr rods??
- check engine light throws 3 codes
- Buddy Club 3's and B16 valvesprings
