PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 [210] 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. CTR cams ....real??
  2. 18lb vs 9lb Flywheel - Debate???
  3. Contemplating going boosted....again
  4. how to achieve 175 whp on a b16a???
  5. Where to buy an ITR tranny?
  6. Port Polish work vs. combustion chamber work
  7. V-AFC Installation w/o tuning???
  8. Question for some of you SOHC guys?
  9. What rods for mild build lsvtec?
  10. good mileage to begin using synthetic oil...
  11. Ive got to much money!!!!
  12. B16: out of machineshop Fri, Should I buy this clutch?
  13. Best Spring for JUN 3's
  14. Is a 97 h22 head worth anything?
  15. skunk on toda question
  16. p30s on eagles.....
  17. Can anyone get me an k20a2 for $2500 or less?
  18. Motor q's
  19. new valves needed?
  20. Type r head on b16a2
  21. Wanna make a 220+whp B18c1!!
  22. lsvtec spark plug gap?? b18a1 specs or b18c1 specs?
  23. Indiana Hondata tuner????
  24. b20/vtec question
  25. stage 1 or 2
  26. GSR Crank and rods/pistons in a LS block, Will it work?
  27. THE CORE????
  28. Type R heads for GSR??
  29. 3" exhaust system too loud for allmotor ??
  30. jun 3 intake stock b16 exhaust
  31. 12:1 comp on 93 pump gas?
  32. 76 miles on new motor
  33. b20 help ...
  34. B16/B18 question
  35. Hondata Gasket on ebay?
  36. 200whp B18c1 help?
  37. Clutchmaster for GSR?
  38. Thoughts on externally driven oil pumps
  39. toda b's in b16
  40. Not to sure what ratio piston,s I should get Help out!
  41. advantages of itb's
  42. where to buy a SMSP or Hytech header?
  43. LSVTEC Rev ability
  44. what type of tuning would i need?
  45. Timing belt w/ LSvtec
  46. vtec valvesprings in a b18a head
  47. Tuning Options
  48. built 99 b16a what do u think my #'s will be
  49. running low 13s...
  50. motor won't rev passed vtec cross over
  51. What makes a better daily driver???
  52. drastic difference in mpg?
  53. Pressure plate????
  54. 200 whp B16?
  55. Yes, another LSVTEC question, compression
  56. Project DC2...!!!!!!!!!!!!
  57. d16....another crank work???
  58. Comments and Help needed on H22 build
  59. Type-R looking for a good set up.
  60. HASport mounts being born.
  61. how to use pvc valve for the aebs im
  62. All motor LS?
  63. Hondata P28 Problem... one injector not firing
  64. O2 wire for A/F guage?
  65. Clutchmaster or ACT ???
  66. Seriously considering building an other racecar (All-Motor) Help me brainstorm
  67. Plans for an all motor ITR.
  68. Question about Displacement?
  69. jdm header clearence!
  70. how are my gtech times?
  71. timing marks won't align (help)
  72. b20vtec+9k rpm
  73. help lsvtec oil line
  74. Need some advice.. ran my car with new mods
  75. Wideband O2 Sensors?
  76. if you have Skunk stage 1's in our GSR, read
  77. ITR internals with Skunk2 stage2 Cams
  78. b20 vtec - water pump benefits? is it necessary??
  79. Building a All Motor D-16z6
  80. building all motor b16 need advice
  81. Maximum compression on stock b16 block
  82. Clutchmaster Clutch for 95 civic hatch?
  83. ls crank in gsr block?
  84. The Beast: Input on this motor
  85. ZC cam in D15B7
  86. Finding a B18C1 Block-Need Advice
  87. What cams for this set up:
  88. "vero" says his buddy has a 350whp N/A built C5 - post proof here!
  89. ARC Air box or the J's Racing Intake Chamber
  90. ITR IM
  91. When to reuse pistons, when to get new?
  92. is this a good price for what i just bought?
  93. Real Life people using CTR pistons in california
  94. (searched) questions/suggestions for motor build
  95. those homemadeturbo.com guys are out of their frickin mind homemadeITB!??!!
  96. anybody with a built k series on this board?
  97. B20 Buildup
  98. Ok, Type S vs Type R, differences? smogability?
  99. Honda F4i ITB setup's?...
  100. compression question
  101. Open deck/Closed deck differences
  102. B18C1 or Civic Type R engine in a '97 EK?
  103. B16 head gasket
  104. Good absorbing material to use inside Greddy catch can?
  105. wanna put you car on a diet, check this!!
  106. CAM SPECS, CAM TIMING< CAM DEGREEING, CENTER LOBES , ETC...
  107. Small update for the D-series folk....
  108. timing belts - same or different among honda motors?
  109. What plugs for high compression motors?
  110. bisimoto headers: What do you think about them?
  111. sleeved b20: how much can I overbore?
  112. Shawn's "Magic Intake" ???
  113. best cam gears!!
  114. is this rear mount for a B16? ? ? heLPPPPP! ! !
  115. ? About Bore Diameter and Specs- LOOK!!
  116. finished putting in 11:5:1 piston in.
  117. tranny question...
  118. cams
  119. Electromotive TEC3 Anybody Using It?
  120. F20B vs. B series.
  121. need advice:next step in all motor setup?
  122. Motor or Nitrous dyno chart??? **LSVTEC**
  123. SMSP header question
  124. where can I buy pr3 pistons?
  125. b16a pr3 ecu on d16z6?
  126. Swapping Pistons
  127. vafc2 intial setup, I need help
  128. Chipping Ecu, engine running rich as hell????
  129. all-motor dyno day in
  130. Buying a new header..
  131. Specs on 1.7L SOHC Vtec engine
  132. How to mechanically find C/r?
  133. SLEEVING ????!?!!!?!?!
  134. b16a2 stock
  135. Transies
  136. H22 Head P&P?
  137. Shortblocks and Longblocks?
  138. Boring????
  139. Cam timing on a shaved head
  140. any opinions on the ericks racing header?
  141. What cams should I use with a 11.6 compression?
  142. b16b head vs. b18c5 head all motor
  143. Few questions on JG/Edelbrock 65mm TB
  144. b18 GSR block w/ b16 head - What Injectors to run?
  145. Best clutch for daily driven all-motor!!
  146. How many valve seals in a head?
  147. injector size
  148. Free Buick GN 280cc injectors or $100 prelude 290ccs
  149. quick balancing question..
  150. detenation??? is it loud
  151. valve spring pressure
  152. which pistons???
  153. Good place to buy JUN3 cams?
  154. Chipped P-28. Who has the best program
  155. B16 internal upgrade quest?
  156. how much is the average labor work cost??
  157. Check out my setup =) good or bad?
  158. Clearance issues?
  159. gasket for 78mm bore D16A6 ?? (to bisi or any dseries mania)
  160. Ram Air for my ITBs?
  161. Want to achieve 170-175 whp w/ B16 SIR2
  162. Anyone need some B series ACL's?
  163. ls vs ls vtec
  164. how to get 170 whp from a b16a2 usdm?
  165. how many miles can a motor take??
  166. high hp all motors???
  167. what the hell!
  168. Comp cams camshaft ?
  169. 72mm TB to big?
  170. what kind of bump would a .025 mill give me?
  171. cometic head gasket
  172. TPS for b16
  173. best thrttolebody and intake manifold?
  174. Not using coolant.. only water
  175. B18B whit ctr piston
  176. will this work? or am i asking for trouble
  177. Piston-Valve clearance.
  178. AEBS Manifold - PCV valve question - ripped hose
  179. highest compression draily driver/premium gas
  180. b16a3 w/ b16b pct pistons yielding 12.1:1 c/r ?
  181. Maximum overbore for B18A?
  182. B16
  183. stroke: how it affects hp & torque
  184. Dyno for a 91 B18A1 with camshafts
  185. AZ head porters?
  186. Stock B16 vs Portflow ported B16 head-flow chart by Alaniz.
  187. FPR with a vafc ?
  188. Header with 3 inch collector...too big?
  189. A little comparison of an ITR IM vs VictorX IM.
  190. i'm a noob. please help me,lol
  191. **p30 pistons on gsr rods????
  192. install a ls-vtec and rev limiter is lower. what the hell?
  193. ABDC valve closing degree of skunk2sand spoon cams?
  194. B16 trans
  195. crvtec w/ f20b ecu
  196. 80mph, timing belt snapped, now.... ?
  197. breaking in new race motor
  198. Hondata IM gasket..few questions.
  199. h23 high compression pistons
  200. can i rechip a skunk2 ECU with hondata?
  201. IB ls/vtec crate?
  202. Thicker head gasket to lower compression to desired level?
  203. LSVTEC w/CTR Pistons ?Streetable?
  204. Custom Stainless Header Tech H22 Header
  205. All motor H22 options
  206. My ITR dyno sheet...*poseted in the ITR forum as well*
  207. bay area head porters, shops
  208. 3 inch exaust on all motor apps...
  209. Where can I get T1R test pipe
  210. PCT .25OS Dome Displacement
  211. Power to the Ground !!
  212. keep my c1 head or get a pr3?
  213. Titanium bootleg exhaust n1
  214. I have spark and fuel. but it wont start.
  215. Little work I did to a Buddy's GSR
  216. **HELP WITH PISTON QUESTION**
  217. how is it possible to mix cams?
  218. vtec integra
  219. OIL SLUMP
  220. Are 2001 type r cams different when it comes to having the 2 grooves at the end
  221. DC JDM 4-1, is it really worth it to get the stainless?
  222. Any special machine work to improve oil flow and reliability?
  223. Endyn vs. IB spec Wiseco
  224. Cams Cams Cams!!!
  225. JG Cams 1001
  226. ls/vtec ?
  227. crower stage 2's or skunk2 stage 2's with 11.3 CR...
  228. Skunk 2 Manifold!!!!!!!!!
  229. type r LMAs
  230. what would it take to get to 10 grand????
  231. whats a good air filter design?
  232. cams in a b16a
  233. h22 head cc
  234. Balance just the crankshaft or whole assembly?
  235. just how much can stock sleeves handle?
  236. Is anyone Roadracing a b20vtec?
  237. JDM 4-1 header on B18b
  238. Which throttle body would be best for my setup?
  239. High RPM missfire
  240. Questions on the differences
  241. E-Manage for N/A ?
  242. B20 VTEC
  243. valve leash specs for b16b cams in jdm ITR
  244. my catchcan ideas
  245. Dont want to over excite myself....help me out!!!
  246. Need help with h22 indentification!!!
  247. Cams setup questions ... please help
  248. Some pics of my completed engine project
  249. ls turbo motor
  250. impressions of JUN 3's and skunk Stage 2's...
