PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. H22A EG6 ITB
  2. Diffrence between b16/Gsr HG(searched)
  3. oil light on at idle...new oil pump?
  4. Clicking Noise
  5. SPUN ROD BEARING 2nd cylinder b16asir2
  6. Wiseco k542m815 piston clear valves for ls/vtec?
  7. What non oem fans to use with aftermarket radiators?
  8. IS THERE A POINT IN WHICH 3" EXHAUST BECOMES OK FOR AN N/A BUILD (B20)
  9. Rod Bearing Size. Need help from the pro's.
  10. Header Question
  11. Nat's H23 Vtec All Motor. 270whp 203 tq. in 98 prelude.
  12. b18c5 bore questions
  13. over revved, vtec turning off and on
  14. what kind of injectors should i use
  15. question about plastigaging the rod bearings.. Please look
  16. CTR Rods????
  17. Built B20 bottom end........rock it or sell it???
  18. B16 Head - Bowl Diameter - 81mm
  19. b20vtec spark plug gap
  20. engine swapp
  21. tps problems
  22. HELP...car wont start (not your basic issue)
  23. arp head studs on lsv
  24. why does my car bog in 3rd when i hit vtec
  25. Top line oil pump any good??
  26. why do i keep stalling??
  27. hytech replica big tube vs reg
  28. my build
  29. toqure specs on crower maxi light rods
  30. 2000 SI... need help
  31. how much more WHP will a ctr maifold ported & polished
  32. crack in the block fixable or not
  33. Prodject 85x95 last attempt at a big B before building a big K. Kingmotorsports
  34. ctr cams, 10.5cr pistons, 84mm LS block-----safe rpm?
  35. About to start assembly on my LS/VTEC, any TIPS from the Professionals?
  36. starting click
  37. 00-01 Spec R head code
  38. 85x89 Dyno numbers and times
  39. hard times starting car freshly built b20vtec sound weird help
  40. E85 vs pump gas
  41. GSR with ITR cams?
  42. LSVtec, timing off half a tooth?
  43. which cams do u prefer?
  44. Pistons on backwards?
  45. curios need help b20vtec fuel pressure help needed
  46. Cable gearbox
  47. b20/ITR gas mileage
  48. H23VTEC with H22 Mahle 11.5 Compression pistons... = what?
  49. gsr burning oil or something
  50. H22 LMA's in b16 head... any write-up?
  51. quick question about rod bolt installation
  52. Initial startup - thud sound... any insight?
  53. B20 with Skunk2 manifold problems.
  54. Cam Gear Torque on Skunk2 Pro Series Gears?
  55. B18a Help
  56. Underdrive crank pulley?
  57. crank question
  58. GSR block B16 head performance(searched)
  59. will b20 pass state REF. on EK?...
  60. cam problems..
  61. ls crank and rods in a b16 block?
  62. Loud ticking from head!!
  63. Informations about Hytech Custom headers ???
  64. oil cooler vs aluminium radiator??
  65. im new at motor mods and i have a zc
  66. ATS 3.007 First Gear
  67. HELP!!!!
  68. How are my A/f's?
  69. d16 cams
  70. B20/vtec what cams should i use?
  71. spark plugs on ls/v
  72. .040 B series headgaskets
  73. Do I need a girdle for this?
  74. Header selection for a NonVTEC B20Z
  75. what cams are in my b16a
  76. 1998 civic ex d15b vtec i need help!!!!
  77. Newen Contour BB - Counter Boring
  78. B16B service manual?
  79. INFO: ARP Headstud and Rod Bolt Torque!!!
  80. LS VTEC CAM OPINION: BUDDY CLUB OR BRIAN CROWER CAMS
  81. oilpressure problems / which oilpan are the best?????
  82. 7 degree keepers
  83. loctite
  84. Carb # for dc header??
  85. Apexi Power FC + all motor b20vtec = good or bad?
  86. iab tank
  87. LS crank... FTL?!
  88. type r
  89. Spoon CAMs Measurment
  90. idling problem
  91. LS-Vtec Stroker Kit question
  92. CTR Pistons Into B16
  93. LS/VTEC - Quck Question
  94. best exhaust dia.
  95. motor running wierd
  96. Installing Aeromotive FPR
  97. 2.25 or 2.5?... that is the question
  98. LMAs for Pro2's
  99. JDM EF9 B16 odb0 pr3 bearing sizes?
  100. Velocity stack or filter that is the question..... any suggestions?
  101. anyone ever us the HP racing intake manifold?
  102. JDM YS1 trans rebuild
  103. noob question?
  104. BLOCK HONING
  105. does being in vtec burn oil?
  106. wtf, car sounds like a subaru, only at 20% throttle below 3500
  107. Professional opinions needed: Friend keeps losing N/A setups (B-Series) - My thoughts...
  108. Piston Hone-Which Type is the best for Honda's?
  109. TSX Mugen upgrades. Before and after dyno graphs. Kingmotorsports
  110. B Series VS K series
  111. head stud question
  112. d16 rebuild for new turbo
  113. All-Motor LS.
  114. k20 integra pass smog
  115. DIY porting attempt GSR Head feedback needed
  116. Vtec Isn't Kicking in as Hard as it Used to ?
  117. same old idle problem with no fix in sight
  118. Skunk2 stg 2 or stg 3 Into B20 setup
  119. MOTOR BUILDING DVD?
  120. honda gurus, puff of black smoke shifting in 3rd
  121. ls vtec compression
  122. fuel pressure question
  123. Oil in Air Intake pipe Normal?
  124. B16B STROKE QUESTION!!
  125. The quest for the best sounding muffler that doesn't rob power
  126. CTR intake cam install, ignition timing on b18c1 before tune?
  127. What makes some factory motors stronger than others?
  128. LS VTEC with ls timing belt?
  129. Any experience with these?
  130. need help swap a y8 head on a y7
  131. swap
  132. Ctr cams in b16??? what should i expect
  133. did i kill my iacv
  134. ignition timing/ tune ?s
  135. where is the ecu jumper on 88-89 crx si to set ignition timing!!!!!
  136. Ye Olde H22 exh. cam wear...
  137. Need someone to double check these bearing clearances
  138. best cams for a b18c1
  139. Dyno-ed my B20 non-VTEC engine
  140. Question for ls V Set up
  141. ~~~Need some helpful comments on my next build~~~
  142. TD-44 vs. TD-68: OBD1 distributor differences?
  143. plugs?
  144. new motor smoking
  145. b20 question??
  146. Car sluggish & Oil light takes long to go off
  147. compression help
  148. Ls non-vtec questions
  149. Bearing clearance question. Advice needed ASAP...
  150. Exhaust barrels, What do you guys run?
  151. machining b16
  152. ls/vtec or b20/vtec
  153. b16a2 rebuild
  154. which cams... 403's or 404's
  155. head gasket reusable?
  156. P30's on Eagle h beams??
  157. 96 EK wiring and vtech problems
  158. fresh build. no oil pressure
  159. Valves for my LS/VTEC
  160. Help with All Motor B16a1
  161. Cam Gear help
  162. a good spark plug gap for high comp lsvtec
  163. B18A1 All Motor Bulid
  164. Spark plug gap - GSR motor, ITR pistons
  165. JUN 3 cam info??
  166. stock type r injector question.
  167. oil catch breather or not???
  168. experienced sudden loss of power
  169. Stock block LS/V waste of time?
  170. Valve ?
  171. d16y7 and d16y8 block, putting a motor together
  172. vtec help!! dented the headers...one pipe closed
  173. crower cams 402
  174. lma's
  175. bored at work question about build
  176. Ls crank in a gsr block.
  177. New Header! Think about picking this one up! What you guys think?
  178. need help, poor mans type r
  179. ls crank gsr block
  180. best all motor trans
  181. poor man type r
  182. ***Headgasket Question***
  183. B16 motor help me.
  184. compression test on a b16 150 all across. Motor has not run yet. good or bad?
  185. itr head ls bottom end
  186. all motor gsr vs a k20 swap
  187. oil leak need help going to dyno thursday and race friday need to solve problem soon
  188. Milled heads, how much is too much?
  189. Piston to wall clearance (Wiseco)
  190. how polished??
  191. ok....engine block cracked...new engine just installed today....
  192. Trying to find the H22A lma washer, please help!
  193. tri-y de-cat/test pipe legnth?
  194. first time dynoed! =D h22- trying to make more power=TUNNING *HELP*
  195. gsr block and head...what pistons?
  196. b18a cam question
  197. Rod Bearing paranoia (sp?)
  198. Blew My GSR ,Time For Rebuild and what block!?
  199. Help with my rebuild problems White smoke and #4 dead
  200. head gasket
  201. tb tunning ?
  202. Proper way to make a 2L ITR?
  203. Companies that make D-series parts?
  204. ## Bearing colour codes ##
  205. DA b20 head b18 block
  206. Chromoly steel retainers vs titanium retainers??
  207. question about my vtechhh...........
  208. pistons/compression topic please add your known opinion
  209. Bore Gage
  210. H22 NA BUILD
  211. Which motor should i drop in my ex
  212. h22a harness
  213. All motor type r Need help choosing??
  214. cr vtec opinions please
  215. NOTCHING B18A??? ESP Rods...
  216. Stock LS head gasket with 81.5mm bore??
  217. skunk2 pro2 compresson?????
  218. 440cc injector pulsewidths
  219. Just dyno'd my new setup.
  220. spinning noise after shut off
  221. Looking for the username and pw to the basemap ftp we setup
  222. Need LS/VTEC List
  223. Built LS/VTEC, what size injectors
  224. What cams are these? I cant figure it out.
  225. f22 bottom end
  226. Just blew my first motor, what next?
  227. Crazy compression test results - DOHC ZC
  228. Hypereutectic pistons for H22
  229. did a ls/vtec conversion, now its blowing smoke and ticking!!!
  230. Can i run B-series cam gears on H series?
  231. Cams effect on compression, Low comp test #
  232. ITB's b18c1
  233. crower 63402 stage 2 cams
  234. bpi
  235. Dyno'd today... bad #'s....wtf?
  236. B20/VTEC WHICH CAMS WORK THE BEST?
  237. B20-Vtec First time at the track (now 245 whp 170 tq) slicks
  238. ok two quick questions.......
  239. compression question
  240. k24 vs k20 rods??
  241. ls vtec ?
  242. lsvtec ignition timing question.....
  243. Oversized pistons?
  244. 2 step???????????
  245. Misfire issues B20 VTEC Tuned 85mm RS machines pistons??
  246. overheating problem
  247. Valve Seal Tool, Best Tool I've ever Owned!!
  248. Innovate LC-1 wideband and Dynojet compatible?
  249. Best Camshaft for my setup!
  250. Finally finished, and tuned. dyno #,s
