- prelude using oil
- HELP! Bent valves, need a reputable machine shop... any recommendations?
- what cams for me???
- 82mm Ok on B16?
- SO THE HEAD SWAP ISNT POSSIBLE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- went LS/vtec now...........i gots no vtec?????
- power of 2.5" exhaust sys at 6k rpm
- d15b non vetc and d15b vtec what pistons
- b16 pushing 240fwhp???????
- 70mm tb for a b16a2 too big or just fine???
- Question about wiring a SAFC?
- Ok block setup?
- Tranny problems need some help
- Piston tops full of carbon, got some between piston and wall....How bad is this???
- Need help with starter!(sorta long sorry)
- got my vtech yo for $20 bucks
- Best b series lsd to buy
- Buddy Club Spec 4 Cams Released!!!!!
- Will this stuff work?
- gsr vs itr Problems
- where are the good deals for power enterprise or greddy timing belts?
- ITB & Toda issue,need help on dyno now
- B18b head replacement
- Jenvey Itb pic
- 223 whp lsvtec dyno........
- Ferrea 6000 series or omnipower valves?
- What type of cams to get?
- Vtec or Non, 403's vs 404's vs Vtec head ??
- beating prices everyday
- head swap
- Need ECU advice... h22 all motor
- "MASTER PIECE ON PUMP GAS" video, who made it and where is the link?
- my gsr head's valve cover bolts problem
- best swap for a 96 hatch
- B18c5 Pistons
- D15B ??????
- JG Head
- B18c1 All motor... How much oil should i be burning for 1,000 miles of constant driving?
- Low Dyno #s for NA B16A2, any suggestions ?
- B16 header
- 99 Type R Parts needed
- Best cam for itb
- ALL Motor Shop North Florda Area
- Are CTR pistons really that good?
- B16 and displacement
- Valve clearances on Sk2 stage 2 cams?
- MSD vs STOCK ignition
- 13 sec allmotor
- dynoed with 91 octane...ran with 100 octane
- What is the stock gear ratio in an EJ1?
- What is the biggest bore you can get on stock k20 sleeves?
- crower 404 stage 3 cams for ls
- ARP head studs with out washers
- Oversized CTR Pistons Questions
- camshaft question
- ALL MOTOR OR TURBO
- Motor Build...
- Straight Cable and Throttle Body
- ? For those F20B know it alls
- tunning needed????
- PISTONS PISTONS AND MORE PISTONS
- my allmotor car (short movie)
- give me ur opinion plzz
- Buddyclub cams
- My Skunk 2 cam issue
- Using OEM headgasket to raise compression?
- Inside pic of a valve cover
- Got some new toys...pics of some of my motor build
- Throttle Body Question?
- b18c VS h22a
- B18a1 swap in a 90si hb
- ARP Rod Bolts without Resizing Rods
- Throttle body Questions
- 1/4 Time allmotor
- EK9 pistons into B16a2?
- B&M Oil Cooler Install Question
- Changing trans fluid
- What are the best spark plugs to use on a all motor gsr?
- 85mm 12.5.1 CR on GSR Head
- where to buy ACL bearings
- Where can i buy vibrant headers??????????
- Skunk2 and/or Invidia catbacksystem
- Where to out lines for catch can?
- Are quaife lsd's interchangeable?
- head gasket - cam timing formula
- crower 2 vs zex 105300???????
- v-tec not working?
- Opinions Please
- Catless exhaust system
- block internals for an ls/vtec?
- where can i take my car to get tuned??
- Am I able to use a OBD2 TB on my fisrt gen B16 CRX?
- stainless JDM ITR 4-1 header
- Tuning N/A b18c1
- Bore LS block to 84mm without re-sleeving
- ANy gains with headgasket
- anyone ever use Jeg's engine blocks??
- i want 240 hp w/ ls/vtec
- i need some help making mid range power on gsr
- Whats the website to get Custom B-Series Tranny?
- what engine can i put in to my sol that will support a turbo
- MILLING A D16y8 HEAD
- B16b rods different length than B18C5?
- EnzoRacing Header, Pictures, Pre-install Review.
- Comptech ice box or ARC ice box which one is better????
- DC JDM 4-1 Header DISCONTINUED!?
- AEM FPR- Vaccum bolt fell out- Now What??
- what bearings to use need help
- b16a crazy rpm jump when you hit the gas
- LS/vtec clearences
- CTR Intake Cam only - gains on B16
- Question for Moates burn1 / Uberdata…
- d series build
- WHAT IS THE BEST N/A MOTOR??
- Hamp Oil Filters!
- Injectors: Any difference between 92-93 and 94 + Integra injectors?
- Brad from RLZ
- skunk2 stage 1's or buddy club spep III+????
- BEST N/a Gain?
- b16 rods & b18b block+custom pistons or b18b+overbore CTR pistons
- my setup and what i should do next
- A LIL HELP WITH MY ALL MOTOR SETUP
- jg valvesprings...
- N/A motor builders
- Sudgestions for my setup
- cam caps torque specs
- Sounds like valves hitting pistons during idle......
- h23 with hh2 pistons
- b20vtec...type R pistons?
- few probs with my all motor b20...any advice would help
- Few B series hybrid questions.
- b18b specs
- Ghetto ITB's and brake booster vacuum.
- what to do next?
- aebs manifold for a b18c1
- rc injector leaking gas??? help
- check engine light code 45...
- type r head on a b16a?
- BOTI SEPT 18-19 RAN MY BEST ET AND TOOK 2ND PLACE
- Vtec Valves
- piston help
- Dyno question???
- ecu modding
- Anybody use a crankcase vacuum pump
- rev limiter hittin at 5000? zc vtec
- best all motor sohc setup for 91 crx hf
- Need VAFCII tuning Help!!!
- The TRUTH about Port 'N Polish!
- Best setup for 2.0 LS/VTEC
- Safe???
- List your hp with an ls/vtec in ur car.
- How hard does your vtec kick in??
- Which block to sleeve??? GSR or LS??? Why???
- d-serise rods in b-serises block?
- Some very good climate vs. engine performance websites.
- b18c1 interference motor?
- good sites for b16
- Would no Cat. in exhaust cause CEL to stay on?
- How do I know if my factory PCV system is sufficient for a 12:1 2L engine?
- BLock resurface on my ITR how do they do it is it needed
- I was wondering what kind of mods you can do to a d16z6?
- what are some light weight pistons?
- LSvtec Q's
- 99 CRV questions
- Setup so far - what next?
- TOO MUCH COMPRESSION
- TIMING PROBLEM PLEASE HELP I NEED TO GET MY CAR WORKING SOOON
- owners of sk2 st2 cams, what dose your car idel at...............
- Sleeve or not
- GSR Build ?'s
- Weapon r race header dyno
- Which oil should I go with...
- A favor please: Check my main bearing codes/colors!!!
- building new motor need help on head work
- is nitrous okay with my setup?...
- gsr swap
- WICKED IND. CAMS FOR SALE AND RC INJECTORS
- Catalytic Convertor Power Losses
- Valve Springs for BC3+
- pistons in b16 question
- 13.6:1 compression stock sleeves???????
- AEM V2 clod air...
- 4.785 Final Drive tire match
- JUN 3 cams lifetime?
- how much bore can gsr throttle take?
- Compression question
- Bergenholtz / Golden Eagle All Motor Mazda 3 - she's painted!!!
- ls/vtec question
- need advice from SOHC guru's
- Compression test at 240?
- whats the best ITB's
- crower stg (first time)and crower stg3 (redynoed) results
- Can i use stock valves???
- tranny swap questions
- buddy club III+ cams on stock b16 valvetrain???
- Headers worth it with stock exhaust?
- having trouble tuning my setup
- what should fpr be set at?
- diff between ctr & itr piston?
- Airmass Pro-Step Header?
- what do i do???
- (Searched) Dyno chart comparing JDM ITR 4-1 header VS. DC 4-1 header
- Need help tuning Spoon cam gears
- ITR pistons in LS
- 90 91 intergra ls distributor on a b16a1???? will it work?? I NEED HELP NOW
- Hesitation stumbling '92 accord ex
- vtec question
- timing mark
- dyno numbers ver. 2 (230whp)
- Ls/Vtec Running lean, Need advise to correct this problem.
- vtec at idle
- which cams do you guys recommend for mild setup for gsr???
- stage 2 cams for 95 civic?
- what are the best shop in NOR CAL?
- Daily driven motor
- 20 thousand off head ???
- Anybody have experience with or dyno sheets of Crane Cams?
- Broke 200 whp today :-)
- Valve Journals
- ITB's
- trying to make 200 whp and rev to 9000 rpm
- compression?
- Timing belt walk? WTF?! It cut hole in my valve cover...
- Need help decided my next mods
- honda-challenge h1 prelude, very mild...see the numbers...
- Hondata S100 costs $400-500 in just parts?
- Blowing up your engine
- CAR CREW
- header
- LS Motor w/ US ITR pistons...smog issues?
- My GSR dyno. Toda As, 11.2 CR, etc
- Numbers ??
- LS VTEC HOW TO: (I SEARCHED)
- Will this combo make 200 whp
- Time to decide what to do with my block .. b16a2 ..
- LS/VTEC Toda..Skunk 2...
- lsvtec prob no vtec?????
- MINI me Swap __HeLP____
- 12:1 compression daily driven h22?
- advise on motor build, "making parts work together"
- I need help tuning my car??
- JDM d15 vs usdm d16z6
- wideband 02
- Need Help
- Q's on new settup... b16, jun3 ctr pistons...blah blah blah
- B Series LSD Cable Transmission questions
- How to Lower 13:1 Compression Ratio to 11:1?
- ---some ideas for why my car is running rich>?---
- will d16z6 internals work in a d15b7 block?
- LSD help plz!!!
