PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. long rod h motor????
  2. JDM ITR SPUN ROD BEARING
  3. LS/VTEC plug wires options?
  4. Blox type c camshafts
  5. B16a n/a build.
  6. 94 Acura GSR
  7. B20VTEC Cheap/Reliable Build?
  8. B18C1, which color rod bearing??
  9. another 96 spec type r build
  10. Installing timing belt b20/v
  11. Head build, which route to go? v-tec? or a big cam? D16A6
  12. crank layed down or up?
  13. Supertech SPR-H100DR - packaging legit?
  14. Low Oil Pressure
  15. Reuseing rod bolts?
  16. Rings gone/going can i "bandaid" this. 94 b18c1
  17. ►► May - June ►► All Motor Classifieds
  18. d15b8 ???
  19. Can a B16A head work on a B16A2 block??
  20. quiet straight through muffler
  21. Which header is better
  22. Honda d15b engine.
  23. G23 spitting on load and VTEC
  24. Header choice for a mild GSR build
  25. aftermarket pistons quality
  26. Minor Rebuild and Upgrade Questions...
  27. annoying exhaust rasp. ugh...
  28. I need advice/help
  29. Custom Header..Need help.
  30. tuned today
  31. pm7 p29 pistons in d16z6?
  32. gates brand product quality
  33. Overheating Issue
  34. s2 74mm throttle body sticking
  35. Engine/Trans issues?!
  36. k vs B series power
  37. TWM 2000 ITBs need pipercross filter help
  38. J35/J37 Engine Weight
  39. Obd1 block in obd2 Gsr?
  40. buddy club head gasket ?
  41. ECU Myth?
  42. Compression PSI # before break-in!!!
  43. Cylinder Head Test: A true back to back
  44. CEL from Accusump??
  45. slow oil; pressure buildup when warm
  46. 2.0l NA build, Skunk2 Ultra Street Manifold & DD Tech cams
  47. reading datalogs
  48. WAKING UP THE FORBIDDEN "92 GSR"
  49. new motor no compression at all
  50. Tech Topic: Exhaust Flow overlooked?
  51. b16 manifold, which iacv?
  52. Omni Power Throttle bodies
  53. B20 rough start
  54. Any idea what hp I maybe making?
  55. f20b mapped
  56. Questions about parts before tuning..Larger TB, Wideband.. ect
  57. 87x97 h22 all motor problems
  58. It would a plm h2b header clear my a/c
  59. built b20v hp?
  60. blew my engine. any thoughts?
  61. What ever happen to S2 ultra B series Street IM topic?
  62. oil catch can routing???
  63. PCT pistons on P30 rods
  64. H23A VTEC Bluetop
  65. Camshafts(S2T2) installation question.
  66. d16a6 vs d16y8
  67. b18c keeps shutting of
  68. cars overheating problem
  69. B16 Block Problem(Stroker Related)
  70. suggestions?
  71. B16A Header Test Hytech vs Toda
  72. oem b18c/r oil cooler
  73. need help identifying these cams
  74. Rockwell hardness of oem honda crankshaft
  75. project "30 day New Company's race car".
  76. BLOWN HEAD GASKET OR DROPPED VALVE---NEED HELP!!
  77. G23 crx SI Redline
  78. H2B Prelude Rebuild
  79. B20/b18b1 oil pan an pickup
  80. B-series header
  81. H2B Header Comparison: NAH2B vs RMF
  82. Complete GSR Rebuild
  83. methanol water spray in N/A?
  84. 95mm crank gsr block - common to notch?
  85. any experience with skunk 2 cam gears?
  86. Auto F20B Valve Spring Seat Question
  87. Fluid Damper on B series CRX?
  88. cam choice question
  89. rdx injectors on b series! need help!
  90. VTEC causing missfire in cyl#3 on/off B18C1.
  91. High torque starter needed?
  92. D15B Vtec Swap Parts Question
  93. Rocket's Back in Da HizzaY
  94. Blox C Opening/Closing/Centerlines
  95. CROME Gold Bin
  96. Realistic NA/DD/HPDE Dreaming?
  97. Bad rebuild on my engine...your opinions on the matter
  98. Need break-in advice.
  99. Tune
  100. Looking for F20B Throttle Body Gasket....what interchanges?
  101. skunk2 alpha 70mm tb on type r im
  102. Good cam/ fuel injector combo
  103. DA-NINE's Poor man's R build
  104. P73 00 pistons. Tell me what you think...
  105. bung for wideband
  106. B18C5 oil squirting everywhere
  107. Main bearing clearance .002 good or bad? b18b1
  108. ls vtec build
  109. b18a1 build
  110. D16z6 Help
  111. Best Cams for N/A B20 VTEC high compression
  112. LS Vtec questions
  113. Need help with bearing color code
  114. B16a block w/ ITR Head
  115. Cams for my LSVTEC build Skunk2 Pro 1 or Pro 2?
  116. b18c1 2.25 or 2.5 header with a 60mm catback
  117. Piston ID help!
  118. fuel octane and power
  119. b18b block question
  120. GSR head, next step ?
  121. just bought motor need some advice
  122. How to take alternator off B16 in a crx?
  123. Running an engine w/ an exhaust valve leak?
  124. individual cylinder trim for lower compression in one cylinder?
  125. BC valvetrain and Skunk2 Pro1 cams
  126. what cams do you suggest ?
  127. Before After & ongoing build!
  128. b20b: distributor red dust & stuck camshaft
  129. Quick question on power in my b20 ek9..
  130. any glaring issues with this engine build?
  131. B18c1 Arp head studs fit b16a2?
  132. 20$ Type-R crankshaft....Serviceable?
  133. Edelbrock 4730 B16/B18c Camshaft Dyno Testing
  134. Del Sol won't run
  135. 12.53@106mph stock internal b20vtec
  136. GSR Arp head studs work for b16 head?
  137. b18c built check it
  138. upgrades led to power loss?
  139. Intake cam degree, head milling, ignition timing help
  140. B20V Reliable DD advise needed
  141. two part header question related to my motor build
  142. ride height effect acceleration? all motor
  143. what to expect from my swap
  144. mix and match cam combo
  145. Proper oil pressure- built/sleeved B18CR?
  146. Making power with my turbo manfiold
  147. H22 Skunk2 Stage 1 Pro Cam problems
  148. D16Z6 High Compression build and just started it last night (vid)
  149. Intake Manifolds suggestions
  150. B18C1 build draft. Opinions and advice welcome
  151. cammed diffent satge mpgs
  152. Will a type r(b18c5) oil pump fit a gsr (b18c1)?
  153. Intake Manifold Porting
  154. Need help with my LSV
  155. oil pump H22A1 vs. oil pump H22A7
  156. First Honda - Major problems, please help
  157. Compression vs. VE
  158. Need Help Identifying Pistons
  159. B20C1
  160. B18B(LS Head USDM) Build Ideas.
  161. What are some good camshafts
  162. compression test results question
  163. 99 B16a2 rebuild, looking for more power, cams? higher comp?
  164. B20 Vtec Build up
  165. GSR build need your thoughts
  166. b20b vs b20z WHP Differences High comp build
  167. 9000 rpm motor how to pick reliable parts?
  168. B18c1 n/a build advice
  169. Looking to get a little more HP out of my GSR?
  170. B18C1 Rod question
  171. having problem on DY16 engine or transmission
  172. stock sleeve boring
  173. O2 Sensor Problem, please help!
  174. Engine swap help
  175. Redline increased with S2:Tuner 2's ? *NOOB MOMENT*
  176. Need some opinions if I should still use this head on my build.
  177. electronic exhaust cutout. . . . yes or no
  178. d16y8 worth buliding or build a bseires motor
  179. H22a head milling for higher compression
  180. 1/8 mile run.
  181. Zerg 2ply head gasket
  182. Recommend me to a machine shop..
  183. All Motor/NA section content. **Please read**
  184. d15b vaccum lines
  185. Honda Civic 1.4i 1995
  186. another ls/v all motor build.
  187. B16A manifold question
  188. why 8500 redline?
  189. Engine Swap.....
  190. What are your opinions on a d14 mini-me
  191. Engine building - does this work?
  192. best 2.5 inch exhaust opinions
  193. h22 build questions?????
  194. is this salvageable? cylinder pics inside
  195. my ek build plans
  196. intake length 3.5 to 3 inch v stack
  197. new all motor lsv build with a shot of dope questions
  198. Which plugs?
  199. NEED HELP
  200. LSVtec motor problem
  201. Worst FITV block off EVER!
  202. will my car benefit from a cold air intake
  203. B20 vtec help
  204. Smaller ports for more power?
  205. P72 or P28?
  206. boltons with stock ecu?
  207. First build opinion?
  208. GSR decking question
  209. installing ect.
  210. eBAY
  211. Need help with piston rods
  212. D16 idles issues please help
  213. 82mm Gsr Block? Okay for DD
  214. Need help finding out which specific B series this came off of!!
  215. what size injectors
  216. 12.2 comp c1 dd? or 11.1 dd
  217. are my valve seats worn out or ok
  218. Which oil pump?
  219. Delta 272 Cam Degreeing B18B Help...
  220. b16 all motor.. ideas to gain hp??
  221. mini me need help
  222. h22 allmotor build help
  223. jun 3 cams?????
  224. built lsv what oil to run?
  225. ef to ls swap problems
  226. Head was milled but buy how much how to tell.
  227. b16a jdm
  228. Trying to figure out what b20 I have
  229. b20 swap w/b18 head
  230. Calculating compression ratio help
  231. lsv question
  232. B18C IM Question.
  233. Nauseous_97 civic build where to start since my mind can't be read.
  234. b18 brian and crower build
  235. mixing different piston rings
  236. Vtec rocker shaft orifice "o-ring"
  237. H22 rod bearing oil clearance: .038~.051mm ok?
  238. Throttle body question
  239. honda civic hx 2001 low idle and vibration but no codes
  240. Name this noise...
  241. Help w/Tranfering cam gears over to new camshafts.
  242. 2L build cant decide.
  243. 81.5 vs 82 mm type r pistons
  244. b16 all motor
  245. help needed
  246. Inconsistant rev-limiter?
  247. short block fresh from machine shop! taper issue!?
  248. hey
  249. S2:springs+Retainers install question B18C1.
  250. need machine shop in mid tn
