- Why Dynamic compression ratio is affected by cams and so on...
- which fuel pump kit to get for lsvtec?!
- SPRINGS?
- 4-2-1 or 4-1 pros and cons?
- cam adjustment for difference in head heights (thicker/thinner HG)
- Would toda spec b cams work with my setup alright?
- 3 inch exhaust vs 2 inch?how much loss of torque?
- anything wrong with running open headers?
- Titan's Header Test (Bert's pictorial......56k--u wish)
- best header for b20/vtec??
- question?
- Looking for real dyno numbers on the an-r header
- rumor'd 200 whp b16....where is it!?!? on stock parts
- b20 block or head work?
- does installing pistons require your block to be hone?
- sleeving process?
- gsr vs poor man type r
- Need some all motor advice
- What ecu Program to go with a 2.0 Gsr. And what Injectors?
- Is all motor the way to go now?
- what's the best place to buy JE pistons from?
- what do u think my car should run...? i han a g-tech and had a crazy high 1/4 time
- Help with my sohc setup-
- PORTFLOW dual valve springs , any good
- need opinion.to rebore a b18 or b16 with deckplate?
- would this combo be good?
- What size TB for my mods?
- Hmotorsonline LSD ?
- b16 vs itr head flows
- 200whp possible with ITR/CTR cams and 11.8 c/r on jdm b18c??
- 11.5-11.6:1 and stock ecu?
- www.TitanMotorsports.com Header Test Results
- Who here actually has a AN-R header on there car..with pics...
- Decisions: sleeve to 84, 84.5, or 85?
- anyone using JUN 2 cams
- C1 valves VS C5
- switching to obd 1.
- what got you into all motor?
- A question about using an "already tuned" s200 w/ my setup...
- JUN 2 cams , maxRPM for HP?
- Help First Build
- all motor b18b
- What problems does a sunken sleeve cause?
- Less Octane with no knock = more power?
- what should i do next?
- rev hard manifold??
- Traction Probelms in my Type R
- zc header/d16y8
- Best valve springs for 12.5mm lift cams
- what cams
- Will Carbs Pass Emissions On A OBD0 B18.
- does anyone have a how to for ctr pistons on b18c5 rods.
- ericks racing ecu programs
- can anyone verify skunk2's k-series all motor claim of 350hp?
- Highest recorded whp for B-series?
- ODB-1 V-AFC settings
- all motor AND daily driven -- 13:1 compression?
- an-r headers: diff in power btw compact and standard header
- B16a w/ JUN IIIs - what pistons?
- JDM ITR pistons in b18c1
- ITR all motor help!
- toda piston cc ??
- What will i get for HP?
- what kind of ecu should i use. and what can i sfift at safely
- dh-r vs. alaniz for headwork.
- Toda Stroker Kit
- generic cam gears or name brand?
- interesting pics from RLZ
- RLZ stage 2 cam pics
- diy header<<<
- is this a good price for installation on cams and pistons
- stay SOHC??? in need ur input plz!
- Rod Length Preferences
- I need YOUR help! main/rod bearings
- H22A Set-Up in the Works
- Guesstimate my wheel horsepower please
- 93 Accord - Check Engine Light
- help me out K20 vs H22
- best set-up w/ctr cams for 98 gsr
- skunk 2 cams?
- b17 what mods?
- b17 block with b16 head
- Custom exhaust or aftermarket exhaust and why???
- PSI numbers from compression test.
- More Potential LS/VTEC or B20VTEC?
- RS machines VTEC eliminator cams...need info...
- convert to ODB I?
- crower stroker kit on otherwise stock b18a?
- NGK Spark Plug gap w/lsvtec w/MSD
- Max B16 Power?
- What cams and compression do you suggest for 180 whp? (B20Z non-vtec)
- Crower valve springs
- hp and torque guesstimate...
- New Oil Pan
- Looking for Good Valves
- How much did you pay and where are the best prices?
- engine missing occassionally while cruising in 5th
- skunk2 stage1 camshafts with stock itr springs and retainers?
- Aftermarket Rod and Piston Install question
- LS all motor expectations
- the beast GX20
- Block cleaning in DC area
- darton or golden eagle sleeves
- love the treatment of new users
- Head work in NC? Where to go
- Get toda A-spec engine kit or wait for skunk2's stuff?
- Going b20 vetc
- sohc vtec d16z6 vs d16y8 & d16z6 tranny vs D16y8 tranny
- Where can I purchase aebs products for cheap?
- itr pistons in ls long block = piston slap and eventual cylinder failure?
- b20/b16
- ANR Header. Radiator Fitment Problem
- Some really funny stuff on Ebay
- B18A1 ?'s
- Best Vtec CAM ?
- next logical step?
- toda C intake cam and itr exhaust cam?
- JDM a'pexi header
- GSport's 2.0L B18C Crate Motor a.k.a. THE BEAST
- anyone running a aftermarket ignition system?
- Ti Retainers, how long do they last?
- Why no other F22's????
- questions on ecu's
- itbs tuned by stock ecu/hondata
- 220whp possible with Skunk stage 1's....
- what to do next?
- recommended injector CC rating for high comp motor?
- got my cams today
- lookin into b20/vtech build and swap and need some info
- (URGENT)!!!help with valve seals
- type -r pump -vs- gsr pump
- chipped b6 puter
- question about using a GSR head w/dome pistons
- b16 bore and stroke
- How much do ITR Valve springs and retainers cost from the dealership?
- torque specs
- Mix n' Match Exhaust choices for college budget.
- Rough Idle problem
- ATTN engine builders or experts....valve seals
- What valves are these??
- MSD knock alert anyone got one?
- whats the deal with just slapping a vtec head onto a b20z?
- B17A stock internals - Considering CTR cams...
- My new toys
- AN-R & Prospeed
- 4.9 FD and VTEC engagement? (fuel economy)
- Ethanol and other alternative fuels?
- what size is the tb port on a itr intake manifold?
- Flow of AIR CF mani vs ITB
- spoon cam timing settings
- How can I identify TODA Valvesprings
- Question about Skunk2 Stage 1 cams....
- Looking for cam recommendations.....
- Is 12:8.1 safe on 93 pump gas?
- new all motoer set up pictures
- aebs or arp head studs
- header w/ 2.5 collector plus a type r cat back a good combo.
- Looks like Rust on my Rods, NEED HELP!!!
- What gauges should i get
- getting power out of my b18c1... please help
- Whats a good cam upgrade for my combo?
- Autometer Air & fuel meter gauge acting wierd after P28 ecu installed.
- need more power. no boost for me.
- What should i expect?
- Fields sfc-vtec controller-- Can I expect any hp gains???
- Cracked all 4 sleeves on my B20/Vtec..Help on new project
- H22 ITB 5 minute video + others. 56k no use.
- b16 pistons in ls block with crower stage 3 cams?
- K20 or B18c5
- Searched a little, CTR pistons in Itr?
- HELP FLuid leaking
- Do any of you guys have SGT's number?
- Professional Products Intake Manifold for a B16A1
- How much better is Hondata S200 than the V-AFC?
- Good machine shop? General prices wanted as well.
- Toda B's V's CTR's
- crower cams and EF-1 valve train setup good?
- itr oilpump
- dseries guess
- what is the best next upgrade after getting all the bolt ons??
- header-tech header on a gsr?
- All motor em1
- Stock Crx B16a w/ a few Bolt on's Dyno'd 170hp/115tq
- 16a pistons in ls block ( I have searched)
- Fuel Startup problem, Hondata related.....it's really an odd one
- obd2 - obd1 w/ hondata (question)
- Stock b18b sleeves bored .40 over safe?
- Need 2 know great place to get all-motor/JDM parts online??
- Makin 215whp but using a stock ITR exhuast HELP!!!!!
- high compression nitrous compatible pistons?
- just dynoed stock B16
- Cursed?
- Where to get new final drive set?
- stock and max. bore on B18B block
- b18c1 set ups
- compression questions...
- NEED WIRING DIAGRAM FOR APEXi REV SPEED METER FAST(apexi website is down!!!!!)
- Question about Skunk2 Chipped ecu in Mild Built ls/vtec
- Need INput on all motor setup!
- Portlow Inners/Itr Outters w/ Skunk Stage 2?
- Vibrant Header
- Has anyone ran skunk2 stg. 2 cams with their .5mm oversized valves on their h22s?
- B20 EF?
- ITB on the streets
- 'Mr.Gasket' Stackable headgasket? Has anybody used this?
- RC 310 cc injectors on a stock b18c1
- What crank and stroke for an 85mm sleeved B18C1?
- bought some 2001 itr cams but what springs ?
- Mugen Head gasket??
- dyno: B16 built topend+stock block
- Another K20 into EG swap from Hybrid racing
- ctr cams QUESTIONS????
- Eagle rod weight compared to stock GS-R?
- Suggestions putting new motor together...
- has anyone use this valve spring compressor tools ?
- Hone the H22a1 before dropping pistons?
- Need All Motor H22A/Accord Help
- 9000+ RPM buildup checklist
- crank spinning problems?
- Opinions on intakes
- My build plans...please rate...
- well i used no pcv
- vtec question, need help
- Pictures of my head.. could you help?
- Allmotor 2.0 hatch vs turbo si..
- Custom .40 over type R pistons???
- what size injectors
- Opinions on Setup
- p30 pistons & ls rods
- Valvetrain options on a6...(56k sloow)
- which arp products for lsvtec
- lsvtec build question
- Will I be fine with my ECU for a CRVtec?
- Engine Life for 2 different set ups
- I want to subscribe on a HONDA/ACURA tuning magazine
- anyone use custom mandrel bends for a custom exhaust system??
- Can you reuse ARP rod bolts
- need B18c1 zdyne tune
- Question about ls tranny?
- So you guys think a car on 12:5 comp could be tuned to run on the street?
- greddy e-manage
- HELP HELP HELP!!!!! soooo many headaches b18c1 all motor monster
- is a pcv really needed
- car smoking like a mutha.......
- oil cooler width and length
- need help on toda c's????
- bullfrog head package
- my new header
- LS/ with GSR head, BUT NO VTEC ????
- Give your thoughts on this setup.
