PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 [112] 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. What kind of power?? CRX Si
  2. post ur b18c1 or jdm b18c gsr setups
  3. b20 head gasket?
  4. safe to run GSR cams in a stock b16a2 head??
  5. what cams 4 me
  6. must you use a block guard to bore and hone?
  7. cams?
  8. What will I be looking AT?
  9. Still making AN-R header?
  10. looking for skunk2 pro1 stock block dynos
  11. valve clearance ?
  12. Rebuild: Is this rod usable?
  13. Did I choose the correct header?
  14. high comp pistons
  15. cat or no cat
  16. ECU chipping.... Who? What chip? How much?
  17. Cutout questions??
  18. 12.2 @ 110 ALL MOTOR CIVIC CLAIMS TO BE THE FASTEST NA STREET HONDA IN NYC WHAT DO YOU GUYS THINK
  19. Should I even bother tunning?
  20. motorswap
  21. Anyone running similiar setup? ITR + Buddy Club Stage4 Cams + High Compression Valves ?
  22. Aftermarket VTC systems?
  23. Airbox with ITB's? Is it just an Intake Manifold?
  24. Lets see your all motor RAM AIR setups
  25. so, where are the high rpm b16's???
  26. milling b16 .020 and Buddy Club hg on stock ls/v
  27. slow in low rpms ????
  28. megan header question
  29. cams for b16
  30. main bearings.... ouch
  31. Compression and High Compression Valves
  32. ls/vtec look!!!!!!!!!!!!!!!!!
  33. d16z6 engine build...plastigage results
  34. how to distinguish skunk2 cams??
  35. its hot in herre!
  36. BASIC PRICE FOR COMPLETE K24/K20A2 SWAP INTO EF INSTALLED?
  37. intake manifold
  38. HELP>>>HELP>>>>, engine slugish when vtec engages,
  39. Which fuel rail to buy? Skunk2 IM on B16
  40. all motor b18b's
  41. Buddy Clud Cams
  42. has anyone tuned here? Elite Motorsports? or heard anything about them?
  43. White smoke
  44. where can i get tuned near my location that is good???
  45. oem d16 bearings
  46. which nos wet or dry
  47. OEM rods for around 200 WHP...ls/vtec
  48. b16a temp
  49. gsr block?
  50. Exhaust question - how restrictive is a stock cat in b16a2
  51. rev limit on ls vtec with 8mm arp bolts
  52. Good All-Motor Header?
  53. Dyno of my OEM ls/vtec
  54. quick question
  55. Run ability issue….
  56. Can 440CC injectors be too much?
  57. whats missing on this d16z6 Cylinder HeaD ?
  58. VTEC killer camshafts!!!!!!!
  59. Help Help water mixing with oil ????
  60. B16A header with stock collector size
  61. I'm torn: USDM ITR header, or JSR
  62. cylinder temp vs. cylinder pressure in reference to long or short stroke?
  63. help me identify these cams
  64. Diesel sound/ valve ajustment
  65. itr intake or ported oem?
  66. Are there any Mid 13sec NA Hondas w/AC and quiet exhaust?
  67. b16 potential
  68. B20b all motor looking for more
  69. Buddy Club - Taiwan (Jun San Chen)
  70. HOW TO STROKE A B16? or any bseries at that....
  71. Straight exhaust + stock muffler FTL?
  72. New 2 Honda's...What 2 Do?
  73. Pinging under load? WTF
  74. Wheres Randy (RMF)
  75. Comp Ratio
  76. B20-VTEC dyno results
  77. greddy sp2 exhaust for ls/vtec setup?
  78. use parts for sale
  79. smoking B18C5. good compression,leakdown test results .. what gives?
  80. Will this throw codes?
  81. b18b rev limit
  82. Wut spark plugs to run??
  83. street tune wideband problem....
  84. d series piston rings for my a6 pistons..correct?
  85. 100 octane in So Cal
  86. emmissions test
  87. my cam gears say pr3?
  88. Twin Cam ZC Cam gears?
  89. Muffler Design
  90. SKUNK2 P28 RACING ECU / OBD1
  91. Next thing i should get
  92. Torque Wrench Issue, dialing in below lowest setting tick mark
  93. best cams for daily driven b18b??
  94. anyone running on here a jun intake manifold (well the copy version?)
  95. HEADWORK RECOMMENDATION
  96. What kind of cams are these?
  97. gah n00b question.. just making sure about my b16 headers will they fit on a gsr block?
  98. $$DYNO COSTS$$ WHO AND WHY PAY MORE??
  99. Best Build For ALL motor B16? What works/What Doesn't
  100. CTR Cammed B16: JDM ITR Manifold or Aebs?
  101. allmotor exhaust....
  102. throttle body question
  103. questions regarding b20vtec pt2
  104. opinions
  105. Where to buy a prebuilt b16a racing motor?
  106. D-series duel throdlebody (RARE!)
  107. Gasket Question please help
  108. PCT pistons in B18C
  109. throttle body sizes (stock)
  110. More compression (pistons)
  111. usdm h22 head with type-s cams????HELP
  112. edelbrock header vs jerrybuilt racing header (dyno sheets)
  113. spoon head gasket
  114. Ignition Timing
  115. Head gasket question (NEED HELP SAP)
  116. TODA Hi-Comp Pistons (B16/B18) - re-balance the Crank?
  117. Anybody have Edelbrock Headers?
  118. H22 Vs Ls/v, which is faster and reliable,.
  119. B16's in the 11's all motor???
  120. Engine Find
  121. walbro fuel pump???
  122. Crower 403 problems, need help
  123. Ls Crank In Type R Block?
  124. stupid question
  125. B18C in EG build help
  126. Help me build another 230+ WHP H motor :)
  127. Worth it to switcho from Blox B cams to Skunk Pro 1 or 2 cams?
  128. ITB injectors ??
  129. crank pulley power?
  130. Fuel pressure question...
  131. To p&p or not
  132. Jdm sir swap...
  133. Help Me Plz my type R is run 2 rich.....
  134. h22a4 w/ f22 rods and crank. i searched
  135. Walbro 255HP pump problems...Please Help
  136. 79mm d16?
  137. b series crank shafts
  138. Skunk2 Pro1's in a B18C5 Good or Bad???
  139. Help with difference in heads
  140. Is a tapered throttlebody important?
  141. which is better for my future set up.
  142. How much would it make.,
  143. If you had 5K and a stock k20a motor what would you do?
  144. ANOTHER cam thread. yay. lol, opinions appreciated. cam testers? right cam for me?
  145. Honda piston rings?
  146. what's the best cam set up for an n/a type r build up?(your opinions)
  147. ls rods in gsr block
  148. Any sweet AC equipped builds?
  149. d16y8 2 layer oem headgasket?
  150. 83mm gsr block b16 head clearance issues?
  151. Gasket Kit - Are all b-series gaskets interchangeable?
  152. ENDYN Breather Kit LS/Vtec Question????????
  153. Teeing of GE oil plate for gauge
  154. Exhaust leak form header...need help
  155. silk road header
  156. Why does the K make so much more power than the H???
  157. ctr intake manifold...
  158. oem headgasket
  159. Skunk2 Offering to buy your cams for cash on a PRO CAM order
  160. Identify These Cams......
  161. Help Me Out, Im Shopping For Cams... But Dont Know What To Get.
  162. good set up for 97 prelude SH smog legal for CA
  163. b16a dyno..suggestions comments please
  164. Tried search...are there any markings on the buddyclub iv cams?
  165. SOHC ALL MOTOR
  166. k20 with itb's
  167. These pistons legit?
  168. NEED TO KNOW CR WHEN I PUT THE ITR PISTONS IN MY B18C1 BLOCK???????
  169. swap opinon needed
  170. help
  171. ls/v headgaket
  172. b20vtec pcv valve
  173. 310cc RC injectors, too big for this app?
  174. maryalnd machine shops
  175. cam degreeing
  176. Spark plugs question.
  177. bottom end assembly
  178. Scuderi Engine
  179. Going all motor with a b16a
  180. Dyno Questions for new build?
  181. What else do I need?
  182. TRUSTWORTHY machine shops in WI???
  183. Help me diagnose my problem please.
  184. Performance loss through dents...
  185. abs light
  186. bc3+ intake snapped in half
  187. Engine performance parts for A20A3...
  188. LS/VTEC Dyno results
  189. Went to the track- Should I be faster?
  190. 95 mm stroker crank
  191. RS Machine sleeves?
  192. Buddy Club IV B18c setup, what pistons???
  193. can you help me??
  194. possible to have back fires with n/a?
  195. need b18c5 oil squirters
  196. Spoon Sports B-series 5 main brace
  197. header
  198. Where to start on my engine?
  199. best upgrade for the money on DD b20vtec
  200. quick question: Which valves?
  201. Need Some help with a engine set up
  202. WTB: ct corsa cam gears
  203. p30 pistions in gsr block
  204. Do I need Fuel Pressure Regulator or bigger injectors for this setup??
  205. Anyone Ever Skip Teeth On The Crank Gear?
  206. rlz head
  207. B16 or b20/b16 tranny for my crx?
  208. RMF moved????
  209. Finally went to the Track....
  210. What injectors for this setup?
  211. lsvtec results
  212. cam choice for pr3 lsvtec
  213. Fuel Pressure DROPPED when WOT!!!!!
  214. Where can I buy the tool to cross hatch?
  215. safely rev to ?
  216. milled head
  217. how to find out how much your head was milled
  218. CTR pistons in B16A? oh shit
  219. recomendations for b16a road race engine build specs.
  220. Skunk2 Pro series head
  221. fuel injectors
  222. does anyone know ????
  223. all motor ls?
  224. breather chamber on 98 ls block????????
  225. where i can find the best strokers for b16a?
  226. timing with 11.6:1
  227. diy stroker kit yes i have searched!!
  228. can't find motor mounts and bracket for 90 teg
  229. 00 B16 Stock Block, Which cams to chose from.. thanks
  230. pooring oil
  231. Stock b18c1 .... what should i do first
  232. 91 octane, is it enough for buddyclub HG and highcompression flat face valve?
  233. help: timing belt stretch? using a PE belt
  234. Best Cams for an all motor street setup?
  235. Are GSR, ITR retainers really the same??
  236. beneficial to goto a 3inch collect on a header with a 100 shot involved
  237. good lopey cam for my ls?
  238. Sideshows...who's heard of em/
  239. convertin ls/vtec back??
  240. Head milled .015 with 2 layer oem head gasket will it work???
  241. rmf in magazine
  242. semi built type r question with hp
  243. need header for high comp 2ltr dc2 asap. anyone selling?
  244. 5zigen header
  245. airflow vs gas
  246. DnR Performance Port & polishing
  247. Identify these sensors please
  248. im i anywhere near my goal..
  249. B20VTEC MILD BUILD WANNA FIND OUT SOME POTENTIAL POWER OUTPUTS
  250. Budget LS/Vtec (Daily driven/ street) CAM question
