PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 [139] 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Reducing the compression from 12.5 to something more streetable?
  2. Built D16Y8: D16y8 Basemap and tuning questions
  3. Any Carb'ed Guys??
  4. ls vtec
  5. Tubular Front with Stock Front End Pieces
  6. Type-R B16 Heads
  7. b20 head on b16a block
  8. Takata harness
  9. port and polish y8
  10. nice all motor parts!
  11. what u guys think?
  12. D16A6 .040/1.0mm overbore 11.0-12.0 comp piston options?
  13. Merry Christmas NA people
  14. chipped sleeves at top what causes these? can i still used block?
  15. DIY Head Porting-Got a question
  16. What cams are these?
  17. anyone here had any experience on failing oil pumps.
  18. Another which cam thread...need some advice here
  19. need pics of ctr,itr or skunk2 stg1 camshafts
  20. b16 tranny gears
  21. Wondering about you stock B16 guys
  22. which stage is best for me
  23. 09/01 S2000 swollowed valve!
  24. another d@#% intake thread
  25. New ls/vtec build up ........WHAT RODS?
  26. RPM JUMPS BACK AND FORTH
  27. b18b mild build options
  28. 42mm ITBs, big enough diameter for cammed b16?
  29. buy a b20 motor or upgrade my b16a2 block
  30. Gsr belt or Si belt
  31. All motor b16a owners
  32. What does H-T think???
  33. skunk2 stage 3 PRO
  34. Markings on Blox Cams?
  35. b20 vtech
  36. heres a quick dumb question about degreeing cams
  37. B18A1 or B20b looking for general tech advise
  38. Ulitmate flowing head modifications and suggestions
  39. 97 GSR WITH SKUNK 2 CAMS AND....
  40. Need a Motor Machined?
  41. Wiring in an Aeromotive fuel pump...need help here
  42. Give Me your E/T time you car name and what you have in it
  43. Will this bolt up?
  44. low idel problem and RPM jumping backwards
  45. What do b16a swaps run?
  46. headwork info
  47. Need Help Deciding on Cams BC3+ or S2S1
  48. High compression timing belt issues
  49. Help me read my plugs. 100 miles on a fresh bottom end. Low compression...
  50. HOnda n00b here...B20/VTEC questions
  51. port n polish?
  52. VTEC Explained by video
  53. what size vacuum canister for 52mm ITBs on a 2.0 f20c
  54. NEED HONDATA S200 W/DATALOGGIN AROUND FRESNO AREA
  55. valvetrain
  56. stupid questions
  57. crower 402 cams on stock itr valvetrain
  58. where to buy bunch of parts all at one place
  59. Soo, say i was gonna spray on it... (timing?, fuel?)
  60. Road Dyno. Does it Work?
  61. b16 all motor
  62. Told that my new b20vtec has a bad surging idle beacuse valves dont line up ?
  63. Question about using 450 dsms
  64. highest to rev
  65. b20 crank or b18c1 crank and rods
  66. compression ratio
  67. msd ignition box
  68. b16 pulley vs b20 pulley
  69. 310cc or 370cc fuel injectors
  70. Vtec Solenoid resistance...
  71. request pic of an-r header in DC bay
  72. finally decided to go all motor lsv...
  73. PICS Portflow gsr head just came today
  74. installing itbs on type r head (twm 50mm)
  75. all motor build up, b16b block want endyn pistons which to get?
  76. all motor dc2 guys.
  77. b16a is found stock in what car?
  78. looking to purchase a hondata s200 around FRESNO CA area....
  79. s2000 tb on h22
  80. d15b vtec stages?
  81. buddy club IV
  82. Megan 4-1 Header with an Omni Power Test Pipe. Which pipe style to get?
  83. Piston Help.
  84. Injector questions?
  85. racelinedevelopment eg?
  86. Where or what web site can I buy a vss for a jdm b16a,
  87. simptoms to a bad tranny etc.....
  88. Is 700cc injectors good for my setup or should i get smaller????
  89. ATI Super Damper Group Buy, $300 shipped
  90. HOW TO MAKE A STOCK DX MOTOR FASTERRRRR
  91. got a question
  92. Looking for a decent shop in the MD area!!!
  93. how much to mill off LS rods to fit type-r pistons?????????????????????????????????
  94. can i change the k20a3 into a k20a2 y changing internals?
  95. all motor in a 00 civic si?
  96. Billy X setup in Street Stock class?
  97. Question about ARP Head studs and Main studs for a B17
  98. Value of a built head? input please....
  99. early stages of b20/vtec
  100. B16B and B16A crank comparison..... (lots of pics)
  101. Installed New Head ( Now Problems ) Help ! Honda Techs
  102. B20vtec crankcase ventilation.
  103. edlebrock throttle body problems
  104. Skunk2 Head
  105. who makes this valve cover loving would love to get it anybody know
  106. Mini me
  107. Intake manifold
  108. Best All Motor Pistons??
  109. blox exhaust system
  110. location of itunedusa?
  111. just ordered my axles
  112. ok... How to build the best, most reliable LS/VTEC Bottom End
  113. OEM JDM ITR header and the copy cats
  114. Has anyone tried Crower stroker kits (especially on a b18b)? *searched*
  115. LS/VTEC vs SR20DET. Whose gonna win it ?!?!?!?!?
  116. what are ITB's?
  117. skunk2 stage 2 cams on a stock block b16 ?
  118. N/A D16
  119. mitsubishi manifold design
  120. GSR BLOCK CTR PISTONS.....WHAT CAMS?????
  121. valve adjustment question????
  122. will a KMS 14mm lift valve spring hadle skunk2 stage2??
  123. how do i PM peoples in here?
  124. I have a built LS bottom end, Someone wants to give me a deal + a b20 block Come read please
  125. just wanna ask?1
  126. The new Civic Si dyno chart and comparison.
  127. B20 block with a B16b head
  128. LSVTEC - What header are you running?
  129. gsr trans with 4.7 final drive
  130. skunk2/ HRD cnc head flow numbers? Versus say RLZ, portflow, etc?
  131. What is better a H22 Or a B20
  132. Toda Header vs SMSP
  133. typeR/gsR with stage 2 cams...need some help
  134. What are the essentials for building a Honda engine?
  135. Must resolve arguement
  136. B20 Block==== Need to do the CR-vtec ASAP
  137. 00 civic Si ===== B18c1 block/B16a2 Head
  138. my idling is bad
  139. what plugs should i use?
  140. ignition
  141. compression with skunk2 stage 2 cams question.......
  142. First Dyno - Baseline
  143. Theory question of the day... how much HP for D16z6 on SCCA E-production specs?
  144. Measured Prelude LMAs vs B16 LMAs
  145. Looking for Experience with Blox B's in Stock Block B18c
  146. ls/vtec just building bottom end.. can u confirm the parts for me
  147. TWM ITB's
  148. skunk2 pro stg 2 valve lash?
  149. Apexi Active Tail Silencer to Quitet Down Loud All-Motor Cars
  150. anyone using stock valve's with aftermarket springs and retainers?
  151. I NEED HELP ASAP!!!
  152. Calling all b20 builders 11:5:1 pistons need help please!
  153. Need help a lil confused on what to do.
  154. B20 non-vtec FAQ Guide including P8R head information
  155. To VTEC or not to VTEC? Need suggestions
  156. A good manual to help with motor build..?
  157. reccomended compression on a daily driver?
  158. How do you take out the Intake & Exhaust rocker shaft orifices.
  159. Broken tap in header bolt hole
  160. timingbelt part numbers
  161. Waterpump failure?
  162. 68mmTB??? too much?
  163. RSR HEADERS??
  164. Timing Belt ITR OEM, GREDDY, or TODA
  165. suggested piping size for a built up gsr
  166. Help Help in the middle of my build need to know what this is!
  167. When building an engine, what attention does the crankshaft recieve?
  168. whats the price on port and polish
  169. getting some engine ping
  170. RSX Type S Muffler on an 94 Integra
  171. which gear ratio should i go 4.7 or 4.9
  172. boosting a ctr
  173. buying cams 2morrow!!!!
  174. b series oil pumps
  175. Final drive question
  176. B18c Rebuild- Compression Test Results
  177. ITB's
  178. B18c1 block w/ b16 head
  179. How significant is back purging on headers?
  180. Coming from turbo setup to a N/A project.. help a newbie out!
  181. oil pump and pressure ?
  182. b20 specs
  183. ______ Puttin in new valves and need opinion!!!________
  184. Countershaft bearing removal
  185. lsvtec questions??? couple of questions please help!!!!
  186. What do you think about my rod choice?
  187. My Setup and Dyno #'s
  188. With My Mods
  189. OBD2 LSvtec question
  190. toda b specs
  191. Port and Polishing
  192. All Motor B16 *Dyno Grahp*
  193. Timing belt for Dart Tall deck block....
  194. how would you do this if you had my car??
  195. Look at my spark plus, am i running to lean
  196. Changed to built Head now fluttering noise ?
  197. engine rebuild questions
  198. Question on using P8R B20 head. Need some advice.
  199. Question about valvetrain for you all motor guys
  200. b19 build opinions and comments
  201. piston queston
  202. ITR cams + b16a
  203. 2 layer OEM head gasket
  204. b18c1 aebs intake mani probs
  205. all motor b20
  206. 19T water pump vs 22T water pump....
  207. complete k swap
  208. ITB Question
  209. Throttle Body to match AEBS intake manifold on B16
  210. Hand Ported VS. CNC Ported Heads
  211. Hybrid H22a idle problem?
  212. LSVTEC- How to drop compression? Headgasket Q
  213. Couple of questions
  214. all B17 engines!!!
  215. CP Piston Valve relief Modification
  216. what to do b16a/b16b build
  217. 23's or 22's for 220whp+...
  218. Oh Boy!!!! The Realities of Drag Racing!!!!
  219. 88-89 Integra P29 (d16a1) Pistons
  220. v-tech does not engage
  221. Dual valve spring install
  222. 15:1 Compression
  223. OEM reverse rotation dry sumps
  224. vtec is not kicking hard
  225. K Series Road Race Inconel 625 lightweight Tri-Y header
  226. Need HELP finding website
  227. For anyone who uses 59300!!!
  228. serious issue need help gsr head on b16 block
  229. Build a strong head.......but stock botom?
  230. what header should i go with for my setup?
  231. Tuners In Jersey ?
  232. where can i get Toda B cam card?
  233. itr head on b16a2
  234. why vtec water pump?
  235. Please give me some insight on my winter motor build.
  236. what header gasket to use?
  237. Type R head
  238. I NEED ENGINE BEARINGS
  239. Line Honing head? Who,Where
  240. using stock clutch on lightened flywheel. will ther be a problem.
  241. b16 head on stock gsr block questions
  242. 1.9 Gsr Setup (need info)
  243. GSR Crank in B16 block
  244. j's copy intake question
  245. Is this True?? B-series exhaust cam
  246. Socal Shop to balance LS block
  247. SK2 Pro3's ???
  248. What year and model is cylinder head code is PR4-6???
  249. EF LS-VTEC which pistons?
  250. Too much HP and Torque?
