- flywheel question
- Cams: Skunk2 Stage 3 vs Toda Spec C2 vs Toda VTEC Killer Cams
- D16y8 i need one
- intake manifold porting?!?
- B20VTEC 85mm 12.5:1 CR, piston skirt knocking cylinder walls, help!!
- itr cams in my gsr
- balancer belt removal
- All motor D Timing Issues
- ls-vtec questions...Help please
- sketchy way to drop a motor...wouldnt recommend it again.
- B-series header help
- building up an mini me swap....got a few problems.
- honda tuning rod stroke ratio experiment
- apexi vafc(black one) VS greddy emanage ultimate
- Any one Dynoed w/ Blox Type A's in a B16 -Debating Help over CTRs
- GSR motor question
- Type S intake cam
- People with expirence with K series
- shooting fire
- B16 Head with B20B4 Block?
- Hondata s300 runs with K series front wideband o2
- ls vtec
- Is engine balancing and blue-printing needed?
- CARB Legal GSR intake manifold?
- pr3 pistons in a stock gsr... tuning needed??
- HELP!!!!!!!!!! Skunk2 stge. 1 cams vs. Buddy Club spec III cams
- Buddy Club Spec III camshafts????
- Washed Engine bay...now valve knock? someone help!
- Port & Polish? who?
- QUESTION ABOUT INSTALLING SPRINGS ON 02 CIVIC!!!!!!!!!!!!!!!!!
- skunk2 valvetrain
- the best header?
- H series Valves in Gsr head
- Cracked head
- B 18 Piston to sidewall clearance
- PLEASE HELP ME
- h22 or f23
- TODA SPEC B CAMS ON GSR?
- Engine swap or modification
- anyone know where i can get the skunk 2 pro series cams for a b series vtec from?
- lsVTEC, oil feed line question, SEARCHED. thickness -3an????
- B20/Vtec project using B18c5 crank?
- engine
- STOCK B18c1 bottom end
- h22 spun bearing?
- i am running 11:8 high compression what's a good header and Inake manifold?
- Lookin for a New Header For Mah B16b
- TIMING (advance)VS COMPRESSION?????
- ls/vtec reliable or unreliable???
- Jackson Racing Header
- 92mm stroker motor retuned-272 Dynapack HP-nothing special.
- question on valves for LS head
- help me out please
- Building a "loose" motor?
- Looking for a p8r head to flow test
- Possiblites? building a block
- Clutch "drag"
- Anyone running crower stage 3's?
- Do Resonators Only Flow One Way?
- which tool do i need to use to loosen head bolts ? ? ?
- K20a swap ect
- EG All-Motor - I want more torque.
- EGT or Knock sensor for street tune timing ?
- Seating new valves?
- injectors.. pen markings or color codes....
- Possible Ways To Build A 2.0L Block (Crank, Rods, Pistons) Your opinions pls.
- B20vtec; Alternator & Throttle PROBLEMS!!!
- Just installed p28, vtec not working??
- IB Spec manifold?
- new build is dead after 3 weeks
- build the head or the bottom end
- Do you know
- I have a B16b but want more torque!
- flow results from my diy port'd GSR head
- B18C1 Block/Head ?
- Need some advice...Skunk 2 mani or Stock ITR mani on a 98 spec b18c.
- b18c head .5mm os valves what is the biggest cam that can be run with out valves sticking
- crome tune help
- some all motor sohc q's
- 9k rpm misshift, now car idles badly = fews question from the newbie
- Any all motor Guys Running E85 Fuel?
- Valve Cover help....
- Whats the main advantage of a tapered TB?
- TDC
- Anyone running an RPM service throttle body?
- Camshaft Degreeing Fixtures
- DIY ITB's: Show me your fuel rail setups!
- h22 sleeving/head porting q's??
- OMG WTF!!! Has anyone else seen this...
- Tranny Experts - LSD question
- Idling SKUNK2 PRO1's a bitch!
- import builders.com.....reliable?
- Info on TODA D cams
- Portflow inner spring ?
- peicing together ITB's
- Where can i get some F20B accord sir pistons
- ls vtec
- what's my next best step??
- engine bore
- head gasket misc..
- How much piston oil squirter to crankshaft/piston clearance do you need?
- what to set idle at?
- SPARKS RACING HEADER
- Review my set up
- throwin cel codes 4,8,9.. help!!!
- CTR Pistons
- Engine Question
- starting my ls/vtec build...replace or use the stock bearings?
- fuel pressure b16 with 11.5:1 c/r
- Whats the price to install a vtec head
- Dyno: J's Racing intake V.S. Stock ITR w/K&N. 2.0L B18C
- BC3'S + 12:1 c/r
- KMS (honda-performance.com) parts
- What First? Headers or Cams?
- Anyone have a Dyno of Hondata gasket vs Spoon gasket?
- Throttle Body? Too big?
- LS/VTEC build questions
- Need recipe for a ghetto ass cheap ls vtec build hi comp
- y8 swap anad build tech
- C32A Engine Weight?
- b16 to b18c build
- Nakamoto gaskets?
- Twin Two Mufflers In-Line Sound Search Friendly
- my daily driver.sort of
- Pic's Of My GSR Motor And Need Help In Gasket......LQQK!!!!!! LQQK!!!!!!
- b16 and b18 parts interchangeable?
- finished with my B16 stroked 2.0L setup, how much horsepower do you think??
- aebs torque specs
- pistons
- piston help
- LS/VTEC ALL MOTOR
- Short stroke, big bore who has tried and results?
- Recently finished new b20 street motor
- Vafc help
- fastest shipping to ga? need these pistons yesterday!!
- what year was this engine made
- f/s 95 4dr gsr
- ctr/gsr valvetrain question
- Skunk2 Intake Manifold in b16a2
- flywheel
- 12:1 compression in b16 w/ forged pistons?
- Need Some Advice from the NA Guru's
- built head or block?
- Stock B16Z
- Getting the most out of a B16A3 with a tight rule set...
- Type R head
- cvcc motor EJ1
- Cometic HG--ok to split apart and only use one layer?
- BIGGEST CAMS FOR A STOCK LSVTEC
- Gsr rods and pistons in b18b1 good idea or no *searched*
- rebuild didnt start - weird stuff
- Running Synthetic in Motor/Tranny
- Which ZEX Cams do I have?!
- what c/r would ctr pistons make a b18c1?
- HKS camgears install.. having issues.
- My Dyno: 85x87.2 B18C, stock ITR head/cams
- 90 B18A1 into a 88 CRX SI
- Need HELP wit B16!!
- Hows this b20/VTEC build look?
- h22 tranny options
- Finally cracked 240 whp with the 1.8 on Church's Dynapack.
- what valvetrain for stock 96jdm itr head
- B16A SWAP HELP???????????????????????????????
- HELP S2S1 or some othre brand ?
- Engine starting trouble
- DTS chassis dyno, driveline loss %??
- 2 layer spoon h/g fitment, dowel hole
- 17 degrees low and high?
- Skunk 2 Stage 2 or CTR cams in B18c1...
- TSX block and RSX head, what kind of power?
- Skunk2 PRO SERIES in b16a2 PROBLEM
- Need help tuning itb set up with aem ems??? any suggestions
- Peak power / Toda B?
- CHIPPED ECU Question P28 ??
- ??????INJECTOR SIZE 4 B20/VTEC?????????
- Anyone tried using CBR 954 fuel injectors?
- allan bolt on intake side (b16a2)
- helms manual?
- Weak VTEC, why?
- Piston Rings and Head Gasket on B16
- K20A swap acceleration-speedo vid
- Wash out your rings? so how rich is too rich?
- Hesitaition / Bogging / Misfiring.....
- Still haven't chosen cams, damnit!
- 280 psi compression??????
- What compression?!?!!
- cam sprocket question
- an-rcompact on an EF
- POLL: What brand of oil do you use???
- headgasket
- S intake manifold differences
- 93 octane
- help with twm itb's fuel rail is too big for injetors?
- Raditor fan does not come on in my 99 gsr hatch with gsr radiator?
- 181 whp b18c1 2nd run -a little crome, better A/F, sk2 st2 cams
- having problem with my new motor
- new headers and i got problems...
- Skunk2 Pro 2 cams for b16
- Loosing a lot of power.... almost 45% crank to wheels
- most whp with stock header.
- best header for b18c1
- BC or Supertech valvetrain?
- *new* 216 whp tuned-pump gas-no port
- are the CROWER stage2 stock idle cams worth 200$ more ?
- code 22 vtec pressure valve
- I need Help
- Plan Stock B18C1, what piping size will do the job right??
- tuning an h23
- 12.7cr ls/vtec plus juice?
- How many are running stock retainers?
- 11.8cr ls-vtec compression test question?
- 11s finally
- B Series. For every .10 off head, how much to advance Cam Gears?
- Here's the icing on my cake...
- B20VTEC CRX Video
- will skunk2 stage 2 cams work on stock valve train for now........
- B16 head, intake port lenght?
- which springs are which?
- 181whp from a k20a3
- Erik's ecu no start
- help with buddy club cams
- help! ls/vtec ? vtec boggs like crazy @ 25 + psi
- b20 vtec questions????
- Spec II
- crank pulley
- Skunk2 Adj Camgear settings?
- obd2-obd1 troubleshooting
- Building 200whp+ all motor B = waste of time ? ( K series dyno inside)
- do i need to remove the crank pully when changing rods?
- port and polish?
- Mild built b16a2
- ITB or stock intake for road racing b18...
- Possible to make power with 9:1 comp pistons?
- Question?
- CTR cams on B18C1...aftermarket cam gears a must???
- 85 x 89mm ITB dyno graph dropping hard at higher RPMs, VERY WEIRD, HELP
- old vids that we finally had someone host
- B16a1 with CTR intake cam, wich comp. ratio ?
- KK I JUST MADE 210WHP ON A STOCK J SPEC B18C WTF !!!!!
- Sea foam! Argh!
- b20vtec what problems to expect???
- car eatin coils
- Questions about ls/vtec
- b18b with b16 pistons
- taking off resinator good or bad Idea??
- Head Gasket Question
- building my motor
- SOMEONE PLEASE FREAKIN HELP ME!! MY CARS SHAKIN AS I PRESS THE GAS
- K20Z3
- crome or hondata???
