- what race header to buy b series
- whats better for all motor jg intake manifold or skunk2
- what size throttle body for high comp ls\vtec
- Which motor to get?
- tried seraching explain to me "bore" and why is it nesscary to?
- Highest HP A/M B16 Motor to date ??? anyone know?
- BC stage 4 for my setup? opinions welcome SEARCHED!!!
- New Motor problems, Oil blowing out exhaust
- CTR/b-16a
- Time for timing belt?
- Help! Crane valvespring ??????
- might buy a built head...need opinions
- idle is very rough and sputtery, fuel filter?
- anyone know where i can get some oem piston rings for cheap?
- quick question- arp head studs 12 point 13mm right??
- I want a b18c5 but not with the typeR price... opinions?
- Mini-me swap parts !!??
- headgasket question??
- help
- Mild compression bump run on stock ecu?
- ls/vtec on stock internals, any input?
- Carbon Fiber AIR Intake Manifold vs. Individual Throttle Bodies???
- Best Intake Manifold for a Built 2.1 NA Engine???
- $1500 to spend on my motor...
- RC fuel injectors part number question??? HELP PLEASE!!!
- DC 4-1 header modification
- Need B20 Tuning Advice !!
- in/ex manifold
- itr pistons with sknk 2 stg 2 cams?
- What ECU for my ls-v set up..Break in period..(already searched) HELP!
- Can i make this block work as a daily driver??? lsvtec
- Buiolding an B16 with 81.50mm pistons
- Need a Motor Swap this week..who can do it?
- B16 vs ITR manifold dyno
- Miller's LS\Vtec
- b20 pistons with ctr/itr dome hight????
- ***Will big cams affect valve to piston clearance?***
- Compression Ratio Question
- compression test messed up ignition coil?
- h22 compression calculator
- driveablie guestion
- b20vtec oilpressure at idle, vtec and on
- few questions about my b20vtec crx swap before i throw it in
- Edlebrock intake manifold to much?
- B16 blox manifold open port on one of the intake runners?
- went to the dyno with my b16 what do u think?
- Need Good Tuner In ATL, GA
- jg303 ls cams
- X beam vs H beam vs I beam
- my b16 build
- Ls engine help...
- NEED HELP on 91 octane LSVTEC build up ?
- Stock LS/Vtec+hondata+RC270cc's??
- dynamic compression
- Oversized Intake Valves with Skunk Stage 3 Cams
- first AM build...all OEM components. How would you build it
- is 9k rpm safe ?
- B18CR what kind of power have you guys made?
- ITR Parts needed...What are the good websites ?
- Ummm... What did I do wrong; Vacuum in my HEAD!
- got my car tuned @ Church automotive testing
- Piston-Valve Clearance and Main Oil Clearance
- need help on my decision
- head gasket
- CR for b20's
- need help d16a6
- Who has actually experienced premature bearing failure with an aluminum underdrive crank pulley?
- What the hell is seafoam and why would any one do it ?
- HOW MUCH HP DOES A STOCK 94 GSR MAKE AT THE WHEELS
- Squeezing more power out of my B18b!
- High compression motor with what octane
- hp guess for my setup
- b16b pistons ... forged rods ???
- experienced tuners....Advise needed please!!!!
- B20vtec reliability question
- Best header for this setup, and any other advice on parts
- B16a What compression with usdm ITR pistons?
- type-r pistions
- cool tool.... dohc locker....
- b16 idling issues. probably simple. please help
- B16 valvetrain / B18b HEAD ???
- h23 head porter????
- v-tec Problems :( Help!
- Fake BC 4 cams??
- What are LMA's???
- What size head gasket with GE kit
- Burning oil?
- Mugen Header... Real or Fake? Worth, Fitment?
- JDM Type R Head on JDM B18C block
- All motor help
- MUCH THANKS to Anthony and Charlie at Street Stuff Racing!!!!!!!
- MUCH THANKS to johnzm of SRZ Racing for tuning my car!!!!!!!
- Injectors size and type
- H22 head port by sinister racing
- H22A Type S... Is it the way to go??
- h22 euro r Valve adjustment?
- All Motor B18B 180-200 HP build up!
- best wideband o2?
- external coil set up nessciary? yes/no
- switching intake manifold
- honda camshaft write up?
- Identifying Skunk 2 Stage 2 cams
- How much should I expect to pay for boring/honing/sleeving?
- ITB questions (searched)
- Crower Cams reliablity... how many miles do you have on them
- import life in long beach
- a few pics and wanting some thoughts as well
- shift linkage problems
- Header......
- Can Someone Explain Lift and Duration?
- who has ported a head themselves?
- brainstorming motor buildup. help
- new pistons, honeing block?
- help with milling head on poor mans type r!!!
- Need advise with High Comp. Build/ Dyno results low.
- BANG FOR THE BUCK CAM GEARS???
- Calling it a career....
- P72 ecu questions need help???
- B18C1 rebuild...need advice...tuning
- would a dc 4-1 header fit?
- Road Trip To DFE Enterprises:beaches, ITBs, HEader testing and more
- ARP Head Bolts
- DC/MD/PA/VA Need To know who to go to for a rebuild
- Engine management troubles!
- Blown head gasket, need advice
- HELP: Motor not running right
- Dyno Results. Lookie lookie...
- Type-R pistons on stock GSR rods??
- balancing a block
- GS+R/R-GS
- B20(A9) Tuning Suggestions?
- ITM PISTONS
- traction bar dilemma, Z10 vs Full-race
- Vacum leak!
- Where'd you get your Exedy?
- WILL ITR RODS FIT ON LS CRANK
- Goodbye All motor guys
- itr catback exhaust wit stock cat
- itr header vs dc 4-1 header
- B16 head ?????????!!!!!!
- Basic b18c1/CTR build dyno#'s...what next?
- F22 swap swap gains? what should be expected
- Tanabe Super Medallion Exhaust
- 4-1 or 4-2-1
- Dynoed my b16-Toda B's W/CTR pistons
- B18C build up - help me out
- Aebs im on jdm b16.
- fully built b16 head on stock gsr bottem end??
- Direct port Safe/Unsafe
- Current build
- Anyone ever used the ES RACE exhaust?
- Mitutoyo vs. Central micrometers......
- ITR crank in a B18B?
- wll an OBD1 Ls comuter plug into an OBD1 H23 wiring harness
- Review of my new setup...
- ported b17 im on b16a
- ***Vtec Engagement question***
- Best all motor setup for low and midrange power on d16a6
- Can a b16 head go on a gsr block????
- east coast fellas
- integra parts in sacramento
- need mount thoughts ASAP!!!
- mini me details
- What's a 95 PR3-1?
- h22 eg intake mani ?
- no more cheap plugs
- Crank Pulley Fitment?
- WHAT IS A B16A2 LONGBLOCK WORTH
- main bearings/ what color/ what size??? plz read
- after buddy club cam install car won idle? help
- Which motor better for boring: GSR or B20z?
- Am I over camed??????
- How high can you rev a b-series motor before the block flys apart? (assuming head can take it)
- how much whp would this ls/vtec setup make approx??
- just broke my crower vtec stage 3 cam
- My LS Build, need help&opinions
- greddy adapter
- Bore question
- ITM PISTONS
- built b16a whp predictions?
- where did you get your bolts for a motor stand?
- milling question
- what should be my goal for the track?
- engine knock...please help
- what kind of power should i make ?
- b20 allmotor video inside
- Crower 62404 - about where do gains begin on a B20?
- CEL 67, need help plz
- Whats a good cam and valve train for this setup?
- quick question
- Where to Purchase Oversized P30 Pistons?
- Anybody got two (2) Eagle rods for a B18C? Big boneheaded emergency!!!
- rust on flywheel
- gsr oil and water pump in ls vtec
- what is the diffrence between the regular skunk2 manifold and the new pro series
- CEL 41 - Primary Heated O2 Sensor
- A few questions about my setup
- b20 vtec girdle
- Rocket Motorsports KTeller Spec'd H22 H22a Cams and Valvetrain Dyno
- Would you reuse this cam gear?
- Intake manifold question??
- OK GUYS I MIGHT BE IN THE WRONG FORUM
- please help me identify stage 2 cam
- Stock B16A CRX new 1/4mile times
- tuning/machine shops in nj
- all motor ls
- AEBS intake manifold problem on b16a2
- Reputable website to purchase .50 over CTR pistons
- Building up H22a4
- i think we should have an all motor Classifieds area
- proper way to break in
- Hondata Datalogging with Laptop Question.
- OK guys, All BS aside, what is better?
- H22 TB and fuel pump on a B16a powered 89 rex HF????
- b16 eagle rods in ls block
- lsvtec 15,000 after build noticed oil pan bolts/nuts loose
- All Motor build(Need Help)
- Suggestions on new motor setup
- b20 crank b16 block
- wanting to learn about exhaust/header tunning
- FUEL MIXING (i live in cali, octane sucks ass)
- Can't decide what to do next........Need some input
- JUN type 4 cam ?? is it real ?
- k vs b quarter mile comparison
- Oil pressure wtf?
- Anyone has experinced with the DC sports titanium race header??
- Chipping a stock D16A6 ECU - is it really worthwhile?
- whats so special about b16a motor
- ? pipng size
- how much can a b16a handle?
- Valve ? about to buy my haed package..
- 01 JDM K20a Dyno Run 208 WHP | 147 TQ
- milling my LS head.....how far can i go??
- ITR cams for micro polished Skunk2 stage 1's?
- dont tune your car at carb conn...
- good combo??
- onther vid of the itb/f20b accord
- VTEC Problem
- b20 v-tec ?
- Build up for a 99 LS Motor....Suggestions?
- block gaurd
- Sudden loss in Fuel Economy
- B20VTEC build - version 2
- Rod bolt stretch gauge confusion?
- block guard installation method question
- distributor advance
- toda complete bottom end? b16 stroker
- b20 with toda pistons and type r internals
- Skunk2 DC2 back in action?
- Pistons, valves, and spark plugs looks funny... can somebody chime in!!!!!
