PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 [136] 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Rev limiter for only b18c5
  2. ITR block and GSR Block
  3. Cams
  4. Looking for Camshaft for my 00 Si 16a2/b18c1
  5. Can someone help me out here
  6. are buddy club stage 4's good for daily driving??????????
  7. Type r OR SI tranny
  8. pm rm20 cams
  9. Blox stage 3+ cams !!!good cams!!!
  10. B18b block durablity
  11. Un-doing a LSVTEC prepped head?
  12. all motor d series
  13. b17a what cams?
  14. jun cams
  15. Where to get 5zigen header
  16. alittle help on my build
  17. Post your PCV all motor setups
  18. PROBLEMS!!!!!!!!!!!
  19. piston/rod question
  20. High Compression LS/Vtec Build
  21. pistons to valve question
  22. NEW EXHAUST ON EG6 WITH B18B1 ?
  23. Horsepower gains with coatings???
  24. ARP Head Studs for B18C1 Block with B16 Head.
  25. DIY ITB option, Kawasaki ZX12R ITB's
  26. Whats my oil pressure suposed to be?
  27. GSR with S2S2 cams/milled head having Vtec issues between 4500-6000 rpm
  28. Skunk2 camshaft
  29. What kind of Throttle Body size?
  30. End of the road?
  31. question about selling an engine
  32. D16A1
  33. question
  34. Best fuel pressure for a 00 Si with B16a2/b18c1
  35. how come?
  36. How to check for rod bolt stretch...step by step...post it here...
  37. Ls Belt on a Gsr block?
  38. 3 step rev limiter
  39. FULLY BUILT CR-VTEC STAGE 3 CAM TIMING?????
  40. Individual Throttle bodies
  41. Porting a cylinder head for Anti-Reversion Characteristics...
  42. how much power gains will i see?
  43. LOOK, Need Help, What's Causing This?
  44. JE all motor pistons???
  45. which rods????
  46. what timing belt covers fror LS/VTEC
  47. quick need help Identifying JDM ITR cams
  48. ls vtec what kind of valve springs to use
  49. Blox B's for sale
  50. gsr build questions please help me decide
  51. Differences of exhaust systems
  52. JG intake manifold question
  53. D15b vtec
  54. 5 Zigen Header
  55. 94 B18c1 w/blox manifold in a 95 hatch
  56. How High do you Rev?? What Are Your Mods??
  57. anyone know good place to get tuned in the new jersey area
  58. what will my c/r be anyone have any ideas??????????????
  59. Cam Bearings??
  60. d 16 motor rebuild
  61. b16a all motor
  62. Head Gasket...which one?!?!
  63. GSRB18 Block for sale, excellent deal....check it out
  64. Cams, retainers, cam gears, valve springs.. here good prices
  65. jdm f20b question?
  66. is the CTR N1 crank pulley balanced
  67. gsr motors.. show me what u got...
  68. What happened to the quarter mile registry?
  69. What can I do more to stay street legal/smog legal?
  70. b20vtec question
  71. built gsr moving internals to a b20 block for the bore, opinions needed
  72. Is it worth
  73. k20 swap questions....yes/no....please help
  74. WHAT DO U THINK ABOUT MY DRAG CAR?
  75. Selling my NA power house.
  76. my movie adventure
  77. fired up my motor for the first time and have a few probs
  78. BUDDY CLUB 3 PLUS CAMSHAFTS
  79. tuning question.
  80. head gasket question
  81. b16 block question
  82. Powerforce harmonic dampers...Any input on them?
  83. need help with cams
  84. PR3 B16A pistons in a B18C1....good combination????
  85. anyone here running a RBC mani on a K? would you like to test this
  86. My girl's swapped coupe CROME TUNED by HOOKUPS!
  87. tunning shit
  88. bc spec 4s with itr p73's?
  89. EAGLE stoker kit
  90. Help me decide.......Mild K or Complete built 84x89mm B?
  91. portflow or blox or skunk springs and retainers ?
  92. compression and gas
  93. Stock b16a head with springs/retainers + buddy club three's .....safe?
  94. How do I get more RPM?........
  95. Why is that light coming on again
  96. b18c1/b16a Rebuilt Engine Break In!!!
  97. Moroso oil pan supplier?
  98. I/H/C/E Setup for LS/VTEC
  99. arp rod bolts for gsr
  100. post your time slips
  101. What header for a jdm b16a?????
  102. Help fast! Type R LSD direct fit into b16 hydro tranny??
  103. My jdm b16a swapped hatch. LS/VTEC soon, ultimate goal 12.9
  104. Machine shops in the IL / IN / MO area?
  105. cnc head porting or hand porting ?
  106. LS/Vtec compression????
  107. arp rod bolts
  108. Good number and keeping your low end.
  109. black breather box thing
  110. All Motor H22 questions.
  111. crank pulleys
  112. found oil on my pistons...
  113. all motor LS...
  114. y1/s1 tranny problems.
  115. What clutch?
  116. Looking to Buy ITBs (searched already)
  117. Fast All Motor
  118. jg intake manifold
  119. h22 or ls vtec
  120. ls vtec vs type r
  121. TWM Questions
  122. Flow sheet from MY RLZ B16A head...Brad fixes other's mistakes
  123. SPUN BEARING
  124. lsvtec write up. All motor.
  125. Piston Rings for a B18A, any recomendation on who to buy from?
  126. What to do for tuning and head gasket?
  127. Got money to spend!!!!
  128. what size injectors should i use??????????
  129. ?
  130. Catch Can on all motor b18b1?
  131. LS/Vtec Built
  132. B18C5 Head Buildup
  133. head dowel pins
  134. 232 HP to the wheels 151 TQ
  135. Stock B16A rods, how tough are they?
  136. B20 Vtec swap questions......
  137. Fuel Rail mounting for DIY itb's on H22
  138. all motor B18B
  139. b18c1 wont hit Vtec
  140. itbs on my d15b
  141. is 183whp and 135lbt too loww for my set up??
  142. Jdm oem 4-1 or Edelbrock Pro Flo?
  143. just looking for a few opinions..
  144. I get a custom header
  145. Skunk2 Pro1s Vs Pro 2s
  146. Which B20's are the best???
  147. H22 w/ GSR/LS tranny vs. H22 w/ stock h22 tranny? TRACTION WISE!!!
  148. whats the best way to build my bottom end? please help « » 12:06 AM 1/19/2006 Reply Edit
  149. tranny for a b18c1
  150. F22a4 block H22 head......need some help
  151. are these cams 2 big
  152. Is there a need to rev Buddy Club 3's over 8200rpm?
  153. ls/vtec head gasket question
  154. Fitment problem of Dart Tall deck block into a civic 4dr...
  155. 2001 Civic LX motor swap questions
  156. F22/H22 all motor
  157. 210 whp goal... here is my setup
  158. Venturi Insert - Do these things work?
  159. whats the best way to build my bottom end? please help
  160. Can Stroker Kits Rev?
  161. Mini-me w/ old block?
  162. b20 vtec pistons???
  163. Deckplate? got some questions about my block!!
  164. kenji211.com ECU !!! ANYONE!!!!
  165. VTEC and revlimite for B16a2/B18c1
  166. Twin Loop mufflers
  167. JUN III+ PROFAB HEADER+ LDL= Good Results. Video inside
  168. B16A1 for sale
  169. what horse power do you think
  170. All in the Family Brake swap for my Car?
  171. ignition help, car runs after key is out
  172. Which Swap is For me???
  173. question on my bent valves
  174. opinons on ls non vtec build
  175. GSR Block Which Head B16 or GSR ????
  176. B18C1 swap
  177. cam and chip
  178. d16a6 head on d16z6 block?
  179. Very low Trap Speed for 13.5 run?
  180. What Machine work do i need when building LsVtec?
  181. Oversize valves and Aftermarket Cams
  182. milling head..cometic or oem 2-layer head gasket?
  183. power from non vtec?
  184. Engine Dimensions
  185. blox camshafts
  186. Poor mans type r
  187. Poor mans type r
  188. PROJECT B VIDEO - TWMs included.
  189. Swapping cams... same valve springs/retainers??
  190. tranny
  191. prelude h22a4
  192. need a good tuner in MA/CT for itb's.
  193. victor x manifold?????
  194. upgrading to skunk2 stage 1 cams: fuel??
  195. a6, z6, 1.7...
  196. one more ?.. RM gen 1 or 2 springs/retainers for pro series?
  197. jdm b18c sir-g spark plug gap .044 or .052?
  198. Ls/Vtec Intake Manifold -GSR-
  199. 68mm throttle body too much for mild built b18c1 which will soon see pro series cams?
  200. skunk pro 1 install questions
  201. how do these chambers look
  202. arp rod bolts???
  203. p30
  204. Anyone actually ever compared JunIII vs. S2S2 ?? On same motors?
  205. ITR pistons in B16A block cr?
  206. K20a2 Head studs - Are they reusable?
  207. Cams for 85x89 ITB engine? Have some ideas need advice
  208. What timing belt to use?
  209. ***** 200whp nonVTEC ***** (dyno inside)
  210. Bang($$$) vs. gains?
  211. ls/vtec build up
  212. k20 rod bearings
  213. Welcome me to the 270WHP N/A Club!!
  214. B18A LS VTEC w/PR3 Pistons Questions?
  215. help. b18c1 , blox IM, 68mm TB and iddle bouncing from hell ....any1 had the same prob? help then!
  216. Phanton grip LSD produck ??????????
  217. Can my ECU mess up my distributor timing..?
  218. Power Rev 191 HP, 155 TQ Stock JDM H22 EK Dyno Video
  219. B Series Engine Stand
  220. builds on a 00 si us spec motor
  221. Idle characteristics on Pro 1 cams?
  222. Finally tuned with Hondata S200
  223. Help me choose header for my setup
  224. would this set-up give me over 200 whp?
  225. d15z1 block/crank/rods with d15b7 pistons, d16y head, what compression ratio?
  226. All Motor 2.0L Integra Type R Project; as it develops.
  227. D16Y7 to a 90 crx si tranny
  228. Building b16, want advice
  229. Anyone heard of Aasco?? Please post bought to buy
  230. LSD on B16a2 transmission
  231. Type R cams Or Skunkstage2 ?
  232. Info on Hybrid-Racing H2B adaptor plate?
  233. whats the advantage of ITB's
  234. H22 All Motor setup, need some input on compression,cams etc...
  235. Combustion chamber/piston size question
  236. crower 2.2L stroker kit
  237. GSR ring gap
  238. angle milling???
  239. Baffled Oil Pan for Autocross
  240. Excessive valvtrain noise after installing toda c's?
  241. Not sure, What Else??????
  242. LSVTEC VS H22 VS GSR
  243. Headers with Air Con and PAS
  244. some new parts for my b20 build
  245. Toda Head Package Help............
  246. An 'all-motor' video you all will enjoy...
  247. Rod length guide any where??
  248. UGR cams?
  249. Cost of putting CTR pistons into b16a
  250. b18c high compression guestions
