- 1st Gen CRX racers?
- Can I get a W00T W00T?! Omniman's 200hp B16 Project
- crower 404s
- tsx motor vs. jdm-itr
- JDM ITR pistons/rods in my JDM GSR?
- How to get more torque out of a b16???
- Beast Crate Engines
- stock lsvtec comp.???
- Portflow inners what retainers?
- b16a2 goes boom!!
- F22C crank in K20a??
- Difference in Intake Manifolds?
- Instead of a C5 bottom end, What if. . .
- Can I run Sk2's stage 2 with this???
- tach jumps around
- crank and pulley problems
- What injectors for built ls/vtec?
- Good Headers with AC
- Need help, please.
- integra gsr shift linkage in B16 eg?
- b16 harness in eg?
- Broken VALVE!
- all motor sohc
- Buy a new ignitor or buy a refurbished dizzy? They're the SAME PRICE!!!
- "must haves", what parts are must haves for a daily driven b20 vtec?
- Need help in my build up
- Reviews for OEM gasket kit at ProStreetOnline????
- Import Tuner Allmotor B-series shootout - who will win ?
- odd ecu question....
- Help me choose pistons.
- p29 pistons in a d15b vtec
- 2 litre
- For you enine builders: Valve to Piston clearance?
- crower cams broken
- Compression ratio of b16a head on a b18C5 block
- all motor compression
- Skunk2 Manifold power loss
- rc 370 injector dimensions compaired to OEM obd2 240cc?
- Throttle body on Skunk2 IM
- JG 301 Cams
- h22 Info please
- Ben tran @V2 motorsport
- ls/vtec w/ pr3 pistons
- h22a civic ex shats on gts and z28s like nothing
- Header Question
- engine swap for 1995 accord
- Thinner head Gasket???
- what should i do?
- Will a stock b18 crank pulley fit a b16??
- pitson to wall clearance ITR
- 98 Honda Civic with B16A2 Swap
- rs machines cams
- Hard shifting...
- How to replace an altenator in an 89 Civic DX?
- Build my k20A
- how bad is reversion ??
- valve cover breather vacuum?
- LS VTEC and A/C and Power Steering on a Civic Si
- Lsvtec ecu
- ALLMOTOR BUILDING OPTOINS
- my car took a dump. help!
- Best place (price wise) for Air Horns/Velocity Stacks???
- my head is milled-- can i use high comp. gasket
- accord H23er's
- Eagle Stroker (95mm crank) Q?? ... already search
- Sleeving needed with forged pistons?
- Crower Stage 2 Cams ?? how good are they ??
- which octane to use????
- injector size for itb
- what degree are people setting ctr cams at?????
- Help me make more power.
- Skunk 2 cams..how do you tell??????
- d16y8 cam in a d16z6?
- LS ALL MOTOR HELP
- I need power
- ls vtec pcv help!!!!
- B20??
- b17 block
- Took rods to machine shop for milling and pressing.......rebore big end? w/arps's
- thinking about an all motor ZC DOHC but just wondering
- whats my compression
- my build up expectatoin
- All Motor Rocks!
- whats da difference between k20 si and k20 rsx
- New setup...What do you think
- Help me on a N/A B16 Build
- high compression d-series
- titanium exhaust resonator?
- Floating pin question.
- HELP milling my b16a head
- Comptech Race Header any good!
- Best itbs
- have you ever broken and AN-R header??
- Cleaning Engine Internals
- B16A head PnP w/stock valves??
- Skunk2 JUNK????
- Help with motor break in/tuning advice
- anyone running ctr pistons in a b16??
- will a B18C5 make more power on a GSR ecu?
- b18c5 build...high compression wonders?
- All motor GSRs?
- what header for a gsr?
- B18A Dyno
- What do you think? Nifty Pictures inside...
- ANYBODY had any problems with Skunk2 valvetrains (Cams, Valves, Retainers, Springs,etc.)???
- 89 hatch
- 88-91 hatch
- CTR OR ITR CAMS!!!! WHICH ONE???
- ls tranny on b16?
- Looking for a J's racing intake and fake J's for dyno testing! headers too
- b18c5 vs. h22a
- bisi header? yay or nay?
- how long are the b16 ARP head studs VS the Gsr Head studs.!@!
- what to do next
- why are mph always the same at the track
- are 98-00 ctr/98-00 itr usdm/jdm exhaust cam the same ?
- JDM p30 pistons for LSVTEC, WHERE TO BUY.........
- 92-96 Honda Prelude Injectors
- help me make 10 more whp
- Loss of power with header
- 403's or 404's in a b18a w/ctr slugs.......valve clearance?
- B20vtec fuel and ecu
- all motor dohc zc
- All motor setup
- Top Fuel Intake??
- ctr cams or itr cams?
- whp on a stock jdm b18c-r w/ hondata???
- Rebuilding my B18, ots of mixing and matching.
- Mugen N1 ECU
- Life of your fully built motors
- All-Motor Setup Street/Weekend Warrior
- Pics of Ported h22 heads??
- what do you guys think about this setup.......
- Block guard? final verdict
- Dyno'd my mild GSR build.
- All-Motor Mazda 3 - getting closer!
- 2.5 exhuast vs 2.25 on B16?
- type r piston in ls
- What Injectors Built LS VTEC related Need Guidance and Advice
- white smoke after throttle body polish
- PR3's on ls rods??
- D16A6 performance
- HOW HIGH IS TOO HIGH FOR CRANKING RPESSURE??
- will JE pistons work on stock gsr and or LS rods??
- Crower and RLZ question?
- The definitive 97+ Prelude injector flow CCs
- Spark plug ?
- Ls vtec crank help!!!
- type R motor, what mods can i do and still be able to pass smog?
- In which order should I do this?
- Timecert VS Helicoil, options, advice needed
- exhaust that ends before the rear axle
- B20/Vtec with ITR cams----Rev
- DTR 2.0 liter head?
- skunk 2s?
- Good Crank For Ls Vtec?
- an interesting way to check valveclearence...
- d16a6 build question
- spark plugs and wires WHAT DO YOU GUYS USE ?!?!?!?!
- which head will you less detonation gsr or b16a
- Need Info on wiring
- '99 - '00 SI Sleepers.
- skunk2 intake manifold or type-r cams..?
- how to choose CR for piston?
- What's the GSR block good to rev to??
- all motor LS plans and question
- EGT's and All Motor
- New engine, price. What do you think?
- sir or gsr head with CTR pistons????
- LS/Vtec GSR Head LS Block 96 What Water Pump?
- Adjustable cam gears on stock cams?
- Need some dyno plots
- please help
- FYI - New CP Pistons Part #'s
- Porting head
- 2000.00 dollar budget..what to do?
- Check out my friends dyno sheet...
- d15b2 with d16a6 crank ?
- What's wrong with my motor...
- What flange gasket for 2 pieces header.
- how are the UR crank pulley??
- AN-R Header - Street or Merge Collector???????
- Carbs
- Nippon racing CTR pistons with racing nitrite coated rings (BUY OR NOT) Help!!!
- Where can I get internals for my F23A1? My slow ass Accord!
- type-r head problems
- Eagle LS Rods Vs. Cryo Treated Stock LS Rods
- Where can i get Jun 3 cams'?
- 1.6 30 Over Pistons
- B Series Header Flange
- all motor LS set up , waddaya think???
- Toda B's not big enough for 13:1?
- Any info on dyno numbers for Jun 4's???
- how can a compression test tell...
- for Those who have LS/Vtec, what Head Studs did u use
- Car wont start. Getting weird spark/ignition issues. PLEASE HELP
- ls vs lsvtec
- just ordered my dynamic autosport header........pics will be up soon
- 2 O2 sensors and 3 spots??
- Parts list for a B16 head..
- B185c over rev'd problems???
- not to sure what wrong
- Test Pipe for ITR header?
- Baseline Dyno - Seem low???
- LSVTEC PROBLEM HELP!!!!
- Lsvtec (noobie question)
- Flex pipe dilemma...
- what when wrong ??? b18c1 with ctr pistons
- B17 head and ITR head compression
- Poormans R Daily Driven
- why can't b16's make as much power as a 1400cc 'busa?
- VAFC & SAFC?
- Dr. Jeckyll/Mr. Hyde cams
- Valve tips damaged from Lifters?!? Rocket or Omniman's Opinions welcomed!!!
- OIL PRESSURE GAUGE
- Where can I get quality 81.5mm ctr or pr3 replica pistons?
- dart motor part 2 dyno graph inside!
- can there be to much oil pressure for vtec
- Dynamic autosport header
- 1993 Honda Civic Dx snapped valve cover bolt
- Best budget grinder for head/IM porting... whats everyone using?
- milling a b16a head...yes i searched.
- Another J´s racing intake thread..
- LS rods in a SOHC?
- CTR camshafts that good?
- engine management
- cryogenically freezing for free?
- Options in working with a k24a block? 2.7L? destroke? Who is doing it?
- B series headers
- Sqare Porting and Polishing. What do you guys think?
- Where to get a good deal on Type R valves.
- timing belt?
- AN-R header and Radiator question???????
- Single Core Radiator VS Dual Core Radiator Q's???
- Compression test results on 12.5:1 compression and toda B's
- Gears for N/A?
- 11.5 compression and Nitrous
- Where can i get some ARP head studs?
- best cams for a na b16
- Prediction of dyno numbers on my stroked LSVTEC?
- I need more fuel
- ITR 2.3l swap
- time slips ls/vtec
- ls/vtec vs gsr
- What kind of all motor powerhouse can I build for around 2500
- What fuel managemnent for this buildup?
- B18 w/ B16 pistons -- Any Numbers?
- Questions on b20vtec.
- Why titanium valves?
- need buddy club spec 3+ vs. RM m22's info for an ls/vtec
