PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 [101] 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. help with motor build
  2. Another Non-VTEC B20Z w/403's dyno
  3. looking more from my b18c1 itr setup
  4. looking for a good machine shop in South Florida
  5. mild b18c1 build
  6. all motor question/help
  7. will ls rods and crank accept gsr bearings, as long as the rod has been tanged?
  8. what would cylinder wall glazing look like?
  9. Jdm Itr B18C How to get 200 whp ??
  10. F22B2, Adjustable Cam Gears
  11. What would u do with the money?
  12. STOCK block usdm gsr cam questions
  13. Whats the best set up for my CRX
  14. D16 Dyno: SMSP & Skunk2 IM vs Modded JG Edelbrock and Ported Y8
  15. First time build
  16. N/A Honda guys help?...
  17. Bogging when going into vtec
  18. 220WHP set-up...what injectors are you guys using???
  19. my na build question
  20. 2.2L B20 Re-Build (Pics)
  21. my custom header (questions)
  22. Benen EG Dyno Chart
  23. Can not get timing right on 93 D15B7
  24. valve spring retainers help
  25. 450's too much?
  26. need some opinion on my b20/vtec all motor
  27. dc sports 4-1 size collector?
  28. brian crower stg 2's
  29. b16a!!!
  30. engine building
  31. Why Degree Camshafts
  32. locking vtec
  33. Arias d16a6 dome top pistons into d16y8
  34. CTR(ek9) vs ITR(DC2) muffler....which one is beta???
  35. Great taste, less filling OR How can I upgrade my D15B8 without losing (much) MPG?
  36. I think I hear a rattling in my head...? :(
  37. cheap ebay headers any good??
  38. Tsudo catback info?
  39. B20B Vtec....What's the best ECU to run it with.
  40. .5mm valves vs. big cams?
  41. What types of headers are good..
  42. ls vtec oil problems
  43. k20a
  44. How do you store a crank?
  45. anyone have a picture of Skunk2 Pro-Series Valve Springs for B-Series
  46. 310 injector?
  47. any na regrets?
  48. Anybody running web cams...good or bad?
  49. RS machine pistons vs honda
  50. arp head studs b16a-b18c help!
  51. Should i put in the pro's 2?
  52. cam help??????
  53. Indiana performance shop
  54. eciding on cams..cam help??????
  55. motor stopped on the freeway last night
  56. H23 Build
  57. Increase Performance for 95 Accord LX. Need help.
  58. My GS-r all motor
  59. Cold Air Intake Question
  60. WTB Stroker pstions
  61. Crank balancing to do or not to do for my app.
  62. B16 w/ctr pistons ITR cams, intakeman&TB.. good idea??
  63. Write-up: How to install valve springs with no tools
  64. My Old LS?VTEC Build!
  65. TWM itb 2000 series owners and tuners unite.
  66. Intake mani and Tb?
  67. omni power flat valves
  68. (Daily Build) Biggest cams for stock itr valvetrain
  69. Can a b18b be bored safely to 84 mm?
  70. Bad compression in #4
  71. Which TRI-Y header for B16A2
  72. block gaurds
  73. How can you tell if your cams are worn-down?
  74. Cylinder Head Flow
  75. Specs of RLZ stage 3 cams?
  76. h22a swap
  77. itbs!! how does pcv system go on/work with itb setup help
  78. simple header for a b16a??
  79. Hondata vs PasswordJDM gaskets
  80. Advanced VTEC / Variable Valve Lift and Variable Cam Timing
  81. H22a skunk2 Stage 2 cam install problem. input needed.
  82. Calculating RPM landing points on upshift
  83. How to seal a Moroso oil pan properly?
  84. Are OBX manifolds a good buy?
  85. stuck on what intake manifold to get
  86. 4-2-1 or 4-1 header
  87. Who's 85mm Sleeves are these?
  88. Various Cast Piston Compression on JDM B18C5
  89. type r vs b20 with type r head???
  90. Assembly time, bearing question.
  91. good cams and cam gears for a b16a2
  92. Picking the Right Camshaft
  93. Post your Pro 2 cam setups , specs etc
  94. B20 CR/Vtec questions
  95. valve angles (do's and dont's)
  96. check engine light wiring
  97. What rod bearings are you using?
  98. ARE THE SKUNK 2 PRO 3 CAMS ANY GOOD?
  99. Reputable places to buy Engines in the East Coast?
  100. where to find chromoly retainers
  101. poormans type-r build first buildfor me
  102. bore
  103. alluminum retainers?
  104. Tps Problem?
  105. So what's the difference between LSVTEC and TYPE R
  106. Tranny and LSD qustion... (GOOD FINAL GEAR)
  107. DO I HAVE ANY OTHER OPTION FOR PISTON AND CRANK B18C1?
  108. All motor LS questions
  109. >>>>STOCK MOTOR ON DYNO PACKS or @ CAT??
  110. need to upgrade bottom end?
  111. dyno tuning prices?
  112. Blox Type A and Smog
  113. Starting my all motor H22a EG...
  114. everything needed for ls/vtec conversion
  115. type-r bottom end build
  116. Around 1100 after paying bills and shit left what to do??
  117. jge valve train ?
  118. Crank balancing to do or not to do for my app.
  119. D16A6 ITA-ish build
  120. Worth it? doable? cheap all motor d15
  121. breaking in my rebuid engine.
  122. Base map?
  123. Wrist Pin Question couldnt find answer in archives or search please help
  124. What numbers should my LS setup produce? (88 CRX)
  125. sohc help
  126. Help, daily driver exhaust?
  127. machine shop in the Tulsa, OK area
  128. 450cc injector a good choice???
  129. pros and cons with a b16 trans on an LS
  130. whos using carillo rods in here
  131. Removing crank oil galley plugs (balls)
  132. Help! Hit a big Rock on the road...
  133. Please post up your 06 Track Video's
  134. b18a1 bearing spec question
  135. h22a in my dc2
  136. Possible to tell bearing condition while rotating shortblock by hand ?
  137. easy water pump question??
  138. head gasket issue?
  139. cams???
  140. please help
  141. please advise.
  142. Any crome tuners/chippers in the NYC area
  143. smoking white
  144. Just Installed M22x combo, CEL wont turn off....
  145. engine build ?
  146. LS/VTEC Piston choice question. Couple other ?'s too PLEASE HELP!
  147. question about h22 lma's in B18c1
  148. skunk2 question
  149. Rocket motorsports or Ferrea valvetrain
  150. where to buy a iceman intake complete setup?
  151. Toda Spec D Cams anyone running these? Dyno charts? Setup?
  152. my engine won't start. can you help?
  153. B16/B18 valve covers
  154. 190 whp LS graphs inside!!
  155. Throttle body question
  156. GSR RODS ON LS CRANK
  157. throttle body question for f20b
  158. Where to find engine pull pics
  159. TDC issues?
  160. rReputable tuners in Florida?
  161. All motor Gurus...please help!
  162. looking for jdm itr headers in bay area for cheap
  163. 2.0L lsvtec
  164. B20Vtec build ?'s
  165. regular ngks or power cable ngk
  166. What timing cover should i use? B18A1 + JDM B16 please help
  167. omni or supertech??
  168. need help!
  169. becides cams, what next?
  170. I NEED HELP ON THIS!!!!
  171. running vtec all the time
  172. how much to resurface from head? replace valve guides?
  173. b18c1 .... what cams?
  174. comptech long tube race header
  175. opinions on good midrange cams
  176. goal low 13s
  177. Headwork or sleeves? What would you choose? why?
  178. MINI ME HELP A.S.A.P.
  179. D16Y7-D16Z6
  180. 2007 Skunk2 Pro Series H22 IM claims "Outperforms Euro-R manifold by up to 8hp and 6tq at wheels
  181. Shold i stay with da set-up or not
  182. b20vtec obd ?
  183. deck plates and honing??
  184. IB heads
  185. NYCE head work???
  186. How far can i go with VAFC tuning
  187. all motor
  188. B20/LS frankenstein
  189. what header to get......
  190. IPS-K2 Mark II 8620
  191. gsr compression
  192. Should I be afraid of my motor blowing on me?
  193. How to pull CEL code off a obd2-obd1 conversion ecu?
  194. What should I expect with this setup?
  195. All motor gsr Injector ?s
  196. Honda Legend autobox query
  197. NPR Pistons & Rings vs OEM Honda Pistons & Rings.. and difference?
  198. head gasket bore...
  199. ferrea valves too soft?
  200. 2007 Skunk2 Pro Series H22 IM claims "Outperforms Euro-R manifold by up to 8hp and 6tq at wheels"
  201. FUEL INJECTORS
  202. .040 PD....To Much for a D16Y8???
  203. JDM GSR
  204. high compression
  205. car feels slow until 6k any ideas
  206. rc injectors?
  207. B20/vtec turbo ????
  208. JUN MOTORSPORTS
  209. tb idle problem
  210. notice a difference(gsr cams vs b16a cams)
  211. EXEDY clutch - help
  212. Help Making F22b1 all motor
  213. do i have to tune my car???
  214. oil coming from crankcase canister
  215. vafc 2 is it worth $160
  216. HOW TO TELL A B18CR from a B18C Vtir Engine?
  217. My first N/A build/write up
  218. Exedy Hyper Single Clutch ???
  219. TODA spec B or buddy club spec 4
  220. LS VTEC - B16 head or B18 head need help deciding
  221. m22xx vs Buddy Club Spec 4+
  222. itr bearring question
  223. Tuning Question
  224. Skunk2 Stage2s vs IPS K2s
  225. ***ALL MOTOR non-vtec*** post setups
  226. anyone running skunk2 pro 2 cams in lsvtec w/ctr pistons
  227. Basic B16 Build
  228. HT i need help..b16a,b16b,pct pistons.....need advice!
  229. only one adjustible cam gear, Which side? intake or exhaust
  230. twm powere lost again
  231. skunk2 high copm valve vs std cpmp valve
  232. GSR, different IM really worth it?
  233. oil orfice plug in b16 head?
  234. What to set 2step launch at?
  235. Ok...not releted to N/A but im piss off pretty bad...
  236. cam bolts for skunk cams?
  237. GSR build question.
  238. Head milled, do i need to compenstate the timing setup?
  239. twm itbs on stock bottom jdm itr opinion
  240. B20 vs B18C-R oil pump
  241. Those of you running Lude LMA's in B Series heads....
  242. would you expect gain??
  243. Press Release : IPS-K2 8620 produces highest output on K20a Type R motor
  244. headstuds
  245. sohc ..
  246. lsvtec oil squirter questions again...
  247. ls block, what all do i need to run a gsr head???
  248. jun
  249. header suggestions
  250. Itb head question.
