- Stress / Crack in B16a block near oil squirter
- D series TIMING
- stock rebuilt gsr prices, am i getting screwd?
- Another cam ID thread
- are these salvagable s2p2 cams
- questions with my build
- which build would be better too spend cash on.
- ls block w/b16 pistons and ls lead..need tune to daily drive
- Help identify possible head damage?
- GS-R Build All Motor
- Is it worth to rebuild a h23a1 with rod knock and ~200k miles.?
- Reputable machine shop around Everett, WA area
- Newer to hondas possible build help
- Fuel Mileage
- b18b1 knock sensor
- BBK manifold for gsr ever tested?
- em1 b20z dizzy question
- Velocity stack with air filter any dyno charts showing it works
- B20Vtec water in oil after 10k
- Throttlebody no provision for Map sensor
- LS Vtec
- Mixed Up Cam Caps... Any Hope?
- b20 engine not making any power at operating temp!
- 12:5.1 Compression from b16A block & Head?
- rebuild (D16Z6)
- Engine rebuild (D16Z6)
- FIC injectors or DeatschWerks injectors?
- Actual JDM Type R header flange vs USDM Type R flange
- b20z2 swap in my em1 wont start.. help
- Hasting piston rings on stock 81mm bore
- code 10 where is vtc solenoid
- Ls/VTEC build
- DH Racing Head Package...??...??
- Vanadiums 186wkw nz98oct N/A Honda Prelude H22a build
- Anyone put a V8 in a civic?
- GSR honing or boring rust away?
- B18C1 with cam gears, whats a good starting point
- b20vtec oil light flashing
- skunk pro3's, 1mm+ valves_what piston to deck height?
- B18CR problems with oil?!??
- b18c1 trying to raise compression without touching the block
- B18C-R Short block re-buildable?
- Is it possible to turbo an All Motor engine?
- Cam gears off 1/2 tooth or 1 tooth?
- 300+
- which camshaft best for daily driver with performance on H22A/F20B?
- Need ideas on how to build my b16 (maybe ls??)
- engine question 97 acura cl
- 95 del sol Si motor mounts
- b20 vtec knock question
- all motor single cam
- serious compression issue
- gsr wtp on jdm b16 /need hole drilled out to fit?
- b16a Problem
- 98 Integra gsr blox I/M wiring fail
- b20z2 swap in a em1
- b16 head help
- RMF headers fitment
- One Injector not firing on built LS-V
- Need help wit C/R on B20V
- Rebuilding gsr. Ctr pistons?
- What engine to get
- New to this jdm scene
- should i trade?
- b16a camshaft question
- so i spun a bearing on friday.....
- Diffrence between pr4-4 an pr4-5 heads
- Tried contacting jun no reply
- Reinstalling already degreed cams.
- What type of crank would you recommend for a b16 block
- lsvtec timing issue
- D16Z6 engine
- water meth inj on fully built 13:1 b20vtec?
- Too much cam for my b16a?
- Fuel press. releive 12mm bolt, what size adapter to run 1/8npt guage?
- rmf header and greddy turbo 3' catback
- P8R users... looking for some experience advice... valve clearance
- Intake manifold ???
- valve clearance ?
- all-motor guys chime in ls crank with gsr rods
- help gettim my block outta my car
- Spoon Camshafts Diagram??? HELP
- I need f22b help
- whats a pr4 head from
- I've been searching here and google and would like some help..
- Crx intake question help meee
- dont understand this setup i bought
- new school meet old school induction
- Please dont kill me I DID search
- GSR build (Help)
- SKunk2 Tuner stage 3 or Skunk2 pro's??
- b20vtec compression question
- ls auto swap to a gsr with b16 head
- b20 runs great but refuses to idle
- DIY posting a d block
- Whats a Good motor for swap?
- b20 keeps falling on it face...
- help me identify these camshafts steve long racing
- possible f22 conversion to carb?
- Stroked B16's 2cents.
- help just bought a b20 vtec... will not start
- Molykote
- Trouble Shooting B20vtec
- im finally porting a b series head! (and another ecotec)
- Help Identifying problem whilst revving
- jdm b16 crank question
- obd0 to obd1
- S2s2 over pro1?
- obd0 to obd1 conversion 1992 integra
- help! speed issue, not as fast as use to be
- Hytech muffler, dont see many around
- Need help IDing cams
- b18a1 help
- 91 hatch need help :)
- ticking gsr with crower stg2 0012's
- All Motor 1.8L HELP..!
- shot ping ?
- Misfire problem
- which cam for max power and best idle (H22A)??
- My buddies 06 type s dyno results (generic bolt ons)
- aem methanol water h22
- H22 Going lean at high RPM
- bc spec 4 v2v questions...
- Timing Belt tensioner bolt wont move.
- 3 inch header outlet!!!!
- built gsr running lean at high rpms
- How much are your b20v builds costing you guys to build?
- hytech big tube vs Bisioto v2
- need help/words of wisdon on a b20vtec
- ITB throttle cable
- Cylinder Head Gurus - Combustion Chamber Damage/Flaw Need Repair?
- Header for b20 vtec
- Motor turns off when cold
- Best road racing header
- Best injector size for my setup????
- Here are the colt cams B-series non-vtec specs.
- B series block choice!
- K&N drop in filter...Something can't be right and must be a simple fix.
- K20a2 Rcrew cam injector help!! Please
- My old GSR build 197whp/137tq
- Should I buy this motor based upon these facts?
- D Series Build safe for daily?
- I can't get the cams to line up.
- 86.5mm b series weekend warrior
- H22 Exhaust Port?
- Crower 62402 & 62403 question?
- cams and stock cam gears
- Gsr block , questions on internals!
- Rs machine piston on gsr rod?
- ANYONE tuning CNG...
- d16A6 block or d16Y8 block
- common b16 bolt ons worth the money?
- GSR dyno number?s
- B20b with P8r head
- greddy b pipe to JDM integra type r muffler
- Oversized valves
- ALL MOT0R STAGE1 CAM TEST (DYNO GRAPHS INSIDE)
- e85 and high comp.. what size injectors?
- ALL MOTOR ROUND 2 DING DING
- H23 vtec bluetop anyone been messing w/ these engines?
- need to make a crankshaft holder?
- Blox Adj. Cam gears?
- piston to wall clearance
- problem with my b20z
- build question?
- 98GsR's Daily Driver Build
- how far can you take the buddy club spec 4?
- b20vtec losing compression
- ITB.
- Poor mans type r questions?
- all motor gsr. built head stock bottom
- Looking for a diagnostic
- RLZ Engineering???
- ctr cams with stock b16a valvetrain
- b20/vtec ignition
- B20 with b18 head build help
- Bisimoto Custom Header and its NOT a Honda
- what cams have a A stamp?
- 1998GsRIntegra's Motor and Cams from AllM0T0R
- need help with head build
- F22C engine
- B-Series HKS Racing Suction
- Help me out with my B16 build
- Compression Ratio
- lsv vs k20 vs lsv-t daily driver
- What gas stations carry the best 91-93octane gas
- Hone question
- STOMPED! RS machine piston b20, nonvtec=130psi compression:(
- Most all motor hp made on a h series stock block
- 3k budget.. undeceive on swap.
- Shooting for 225whp B series
- D16a6 Block and a d16a1 dohc head
- GSR build input please
- a talk about clearances : bearing oil clearance and rod side play
- ALL M0T0R Stage 1 Cam Test
- need oem part number
- Rod/stroke ratio inquiry
- Chrome Engine Accessories
- Oil in the intake side of cylinder head
- new crx with b18b1 wanting slight build help?
- Cam fixture kits ?
- Best Intake Size for b20b w/bolt ons
- What motor oil to use on my 2.0 lsvtec 85x89mm
- POST YOUR POOR MAN'S TYPE R AND LSV SET-UPS!!! WITH STOCK BORE
- getting ready to break in my build, need help
- building lsv have some questions
- H22a rmf replica header
- 2,5" vs 2,75" vs 3" Exhaust on All Motor
- Skunk2 st2 cams on ITR 98 head
- h22 drag header, dent in the oil pan?
- 95mm stroke or stick with 89mm?
- how much hp ls rods can take?
- Camshafts Blox B vs ITR 1.6?
- Questions on B16/B18 build
- poor man type r help
- Finally got my money saved up!
- Aftermarket Pistons
- Motor Swap questions.
- 87 civic hatch Y7/Y8 combo Dyno
- Toda Spec C2 Cams
- Need Help!!! strange issues...
- how to swap d15b7 to something simple?
- my next B20V build: tuning with Crome ITB tools
- which block would do better on the long run?
- How can i make my d16y8 faster
- Cam rail/Cam alignment method
- All Motor Factory Block GSR Dyno/Track Results
- high comprssion 84mm b16 piston??????
- which clutch is best for lsvtec
- B18C5 Input / Suggestions
- PLEASE READ,NeEd HeLp!!! 91 DA9 w/ B20b non vtec
- big tube vs reg tube: hytech rep
- Header and exhaust pipe size?
- dtr street sweeper or bisimoto v2 header
- Stalls while driving; tach fluctuates
- talls while driving; tach fluctuates
- weapon r secret intake
- 81.5x89 Build question
- Remote MAP Sensor Mounting
- Trying to ID some camshafts
- mugen f3 engine.
- Stock PCV on 8k motor?
- Kamikaze Header for ZC/Dseries?
- gsr block with a ls crank
- hows my build looking?
- EM1 header that clears a/c...
- B20 Swap power steering ???? HELP
- 12:5 82 mm build
- Jun 3 camshafts.
- lsvtec
