- Can I use the amount of vacuum at idle to gauge my ring seal?
- question about degreeing cams
- TWM ITB's?
- JDM K20A need help
- Motor Set Up
- H22, H23 vtec?
- Cleaning out garage need money for new project
- b18b all motor setup help??
- p2v clearance
- Compression test results, advice?
- Supertech or Arais? please help me choose
- Default mild high compression vitaras
- k20a3
- Gsr build want feed back/advice
- Is it Jun 3 camshaft and what valve spring are they? (with pic)
- some one confirm please ->ctr cams ID
- wut rods to go with.. heard bad thing about eagle..
- Exhaust for my car?
- highend or rage header
- my zc wont stay fired
- Looking for input
- almost done with ITB install, some teaser pics..
- LOOKING FOR A SHOP??
- crower camshaft question
- My set-up
- engine rebuild
- Help with injectors?
- B20 w/ 95mm crank = bearing wear?
- Just added Headers., Please comment.
- h22 injector on a b18c1
- power steering choices. please help!
- High compression junkyard built D16A6.
- LA Sleeves
- 20r rebuild help
- H22 JDM Engine for sale
- p30 im vs blox manifold
- ~~~~~ For Sale H22 JDM Engine ~~~~
- LS VTEC BUILD!!!!
- ITR crank in LS block?
- b18a1 BOOSTED forsale!!!!!
- got simple question ..... bout ctr piston in b18b
- h2b ef hatch
- question about T1R Header need Help ASAP
- pics of my blown up all motor build Cont.
- is it a bad idea?
- JDM engine installations
- Tuning Injectors?
- gsr head bolts. are they really reusable?
- something i found while surfing the web
- engine numbers
- How do you tell if it's a buddy club spec IV cams??
- SOHC header/cam......................which is BEST for the $$$$$
- D16z6 head/Y7 bottom......................IS IT WORTH IT?
- IACV Question
- obdo ls/vtec w/b18b bottem end (do i need the knock sensor?)
- F1 clutch kit?
- all motor powah!!!
- Chadil Itb's
- My 81.5 lsvtec dyno sheet.
- greddy header?
- WTB -- bisimoto, smps, or ssr/dtr header
- lsvtec, Missing cam caps...bad???
- yeah another e85 question
- Pistons?
- vtec question
- Omni Power valvetrain......is it any good???
- ctr pistons in b18b...oversize headgasket...
- ls/vtec ?
- B20/vtec owners "ONLY"
- Do you need to get re-tuned after installing a thinner head gasket?
- Help me choose which rod/main bearings to order!
- honda del sol (under construction)
- Spark Racing High Comp Piston 84/84.5?
- wrist pins
- post your all motor LS specs here
- Some pics of my new build
- OEM B Series Gasket dilemma
- New Car.... tuning??
- OEM Honda Coil per Cylinder vs MSD Coils ( K series )
- PLEASE HELP ME!
- Claying the motor
- b20 cracked sleeve
- ACL race bearings ???
- need help with 2000 si converted to obd1
- TODA HEADER!!! Has anyone dynoed this header on a 2L before? Asking because I might by one?
- B16a bolt ons
- B16A2 or LSVtec?
- CV axles??
- Flex Pipe vs Donut Gasket
- JDM H22A FULLY BUILT EG HATCHBACK
- rc injectors
- My GE lsvtec dowel pins are loose in the block...Are yours???
- valves
- DPFI from hell! have a question.
- B series parts
- type r cams better for b18 or b16 head
- BOTI in orlando! anyone racing?
- obd0-obd1 conversion
- jdm gsr question please help
- just clayed motor and NO CLEARANCE!!!... help
- Help to get oem piston off rod?
- B20A5
- NO TOP END
- *****Crower CAMSHAFT ID HELP....**** posibly stage 3 or 2 IDK
- spoonsports 1 piece 4>2>1
- rod installation
- what kind of valve springs do i need?
- ls-vtec and itb's
- ----What Size Fly Wheel-----
- jdm h22 ek w/ twm itbs
- d16z6 motor swap?
- stroker b16a ?????
- never really seen this before...oiling passage at the wrist pin
- Couple of b20vtec tunning questions!!
- Injector Issue
- gsr secondary butterflys
- replace my broken B16 for a b20 block?
- b series cam gears
- help with cam choice b18c1
- CTR pistons in b16
- thinking of getting new cams
- stock itr compression
- d16z6 spark plug gapping
- piston/valve clearance with rs machines pistons in b20vtec
- question b20vtec
- Oem Honda or wiseco?
- Is this Toda A or B? (with pic)
- Spark plugs hard to remove 1995 1.5L civic
- Need a lillte help building my B16A2
- Skunk 2 Pro 2 or Pro 3
- Torque of the M22x cam
- Spark plug info
- JDM ITR motor fuel pressure?
- HEAD WORK.........
- block milling/resurfacing
- b18a1 need help
- Questions about making power with BC3's
- stock 99 LS motor wut to rebuild
- all motor exhaust
- how much power to run 12's
- Are 12's possible w/ a b16 crx?
- Need advice on my GSR build! please!
- The start of my Ls/vtec project Crx
- why dont we have a FAQ all motor?
- lsvtec won't cross over, out of ideas.
- B16a or B17a
- noob question
- Which cams are these?
- all-motor build died on the dyno...
- Headers selection help
- how much is a base model rsx k20 worth?
- looking for crazy strong midrange cams for itr motor :help:
- just wondering....
- Cant get vtec to work
- EAGLE rod and ARP rod bolt need help!!!!!!!
- 95mm crank in ls/vtec puts stress in bearings
- piston ring gap for all motor
- lsvtec stall
- Very loud and weak vtec, with no cel's
- idleing problems....need help asap
- B20B intake manifold question
- Magnaflow 4x9 Oval Muffler (SOUND LEVEL?)
- acl vs clevites
- Any good builder to make my project??
- headers and exhaust system help
- JDM B16A into a 91 hatch
- need some advice/idea's for making 180whp on my B16
- About engine building and leaving off lower timing cover.
- Cams
- D15 head studs
- nippon pistons?
- Thoughts on cutting down crankshafts
- My decent H22 build, check over it and tell me what you think!
- TWM ITB install - 3700 RPM idle
- question for the lsv guys
- Quick question about LSVTEC Compression Ratio...
- Header Question
- ls/vtec ecu question???????
- Got my RMF Narrow !!!
- few questions on mating JDM with USDM parts.....
- Vtec sometimes, other boggs down like its getting too much fuel.
- WTB:b18C stuff
- quick bearring question
- itbs?!?!?!
- will a jdm ecu pass emissions?
- ls rod bushing
- building b16a N/A set up, camshaft questions..
- B16 piston in ls block
- Skunk2 Throttle Body
- Project Pheonix Rising: Part 1
- timing belt..........wtf
- Using nitrous with out shortning my engine life?
- any ITB users Chime in
- HEAD GASKET MODIFYCATION FOR LS/VTEC
- The tale of an epic build
- what is stock ITR head flow at? CFM??
- Happy birthday to me! New engine.
- best spark plugs/heat range for mostly stock B16
- ITR Pistons in ls/vtec???
- Input on Porting an NSX Intake Mani
- How to determine bearing color...
- What u think of this NA Setup?
- Building Engines
- help with some wiring and fuel return for my itbs.
- ATI damper and how my timing was off by 9 degrees!
- how many feet of heat wrap to wrap a b series header?
- how can i calculate the dome cc of a piston?
- JDM type r vs usdm type r tranny????
- Best Camshafts For Daily Driver
- 97 hx surging
- all chrome tuners
- Best street VTEC head setup? LS/VTEC
- all motor ls lmk ???
- whats the best ignition to use ?
- my dyno
- Ignition timing
- 250hp=12s 1/4 mile?
- Please Help Custom Piston Question
- Ls Vtec help!!!
- what to buy next
- good mid range rpm's slow to reach max rpm's
- Header Wrap?
- fuel system question
- The best $300 header??????????
- check out the scarring of my pistons...
- m22x vs. bc4
- b16 pistons in b18a block- piston-to-deck height changes?
- Edelbrock Performer X VS IB spec cnc ITR ?
- Milling Questions
- Buddy Club Spec III+
- LS/VTEC cam question
- Help with setup, please.
- Deegreing Blox Type B's, specified peak lift/center ??
- Tapered Ring Compressor
- B18C1 Build Question
- ************ITB ON A ALLMOTOR CAR*************
- Help!!!I dont know anything about ls/vtec wiring!!!
- Head Milling ?????
- very mild build question...
- Spoon / Jun3 cam / toda B in b16a block?
- buddyclub spec 4 dyno numbers
- oem injectors?
- obd2a to obd1 conversion
- My Not so good experience with PROSPEED LONG ass story
- 94 cx motor/ecu + 97 dx manifold/injectors
- ??? about fuel pumps
- ROD STRETCH ?????ssssss
- skunk2 pro stage1's
- Best Mods for an hx d16y5 engine
- Question about valves?
