PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. best engine bearings..
  2. LS RPM questions
  3. What header is this?
  4. need help with JDM D15B rebuild part list
  5. New B18C1 Rebuild
  6. buddy club spec 4
  7. hondata s300 or aem ems v1
  8. 97 Odyssey Oil Pressure Light Problems -- Help Please!
  9. B16B Mild build - Looking for ideas
  10. D17 motor rebuild questions
  11. B18C mild build
  12. B16A Mild Build!! 200whp DD! Need some advice, all opinions/ideas appreciated!
  13. Highest Comp Pistons
  14. Supertech dual valve spring and pro2s/3s questions..?
  15. are these cams fixable
  16. b20/b16 oil pump
  17. 2005 Honda Pilot V 6 - ejected spark plug
  18. What's the best sohc with vtec to build
  19. What's the best sohc with vtec to build
  20. Power estimate....
  21. whats wrong with this setup ?
  22. B16 Build
  23. How much pwr from ITB's
  24. KingMotorsports Modded Performer X thread
  25. Going with BLOX cams, but which ones....
  26. Throttlebody fitment
  27. Who has highest mileage on there valve springs and retainers?
  28. H22aEHhatch's JDM GS-R Build: Suggestions/Advice needed
  29. Ls with p72's
  30. help!Advice! b16 Question
  31. itr retainer vs b16 and gsr retainer difference.
  32. NEED HELP WITH CAMS
  33. quick head gasket question
  34. b18c1 all motor cam advice
  35. most power using gsr intake manifold
  36. Spark Plug Torque, weak thread causing poor Idle? w/Vids
  37. need help should i trade b18 for this sohc
  38. old fuel high comp question
  39. Ls-vtec help
  40. b18 build questions
  41. rebuild my b20vtec
  42. Detnate in chambers, need some advice on this!!
  43. ls/vtec all motor.. opinions welcome.
  44. oil on exaust ports B20 VTEC.
  45. another cam seletion thread
  46. I need advice on upgrading valvetrian
  47. Are there any piston manufacturers that make replica p30 pistons?
  48. b18c1 86mm build-advice
  49. Titanium or not ?? Retainer Question.
  50. New build for me B20vtec
  51. Maxbore TB experiance
  52. pump or race gas??
  53. b18c5. Ls crank swap
  54. intake manifold
  55. ctr intake cam and b18c1 exhaust cam in b17?
  56. How "streetable" are the stage 3 cams?
  57. Need Some Guidance For My B18c1 Build
  58. NGK Plugs: BKR7E-11 vs BCPR7ES
  59. highflow cat + NA builds?
  60. Intake manifold test results on a 1.8L Edelbrock ITR IBspec Take a look! -Revised
  61. completely stock b20v ?
  62. Question about ported head.
  63. High RPM sputter?
  64. Early Xmas gift from the GF..thought i'd share with the AM forum
  65. Noob needs help with motor id
  66. E-85??
  67. " hey man " build thread !
  68. Cam selection
  69. Pro1s or Pro2s in a B17?
  70. How to adjust my timing/cam gears to pass an e-test--DESPERATE!
  71. inconspicuous muffler suggestions that won't robb me of power
  72. Portmatch Victor X or hold of with stock for now?
  73. best internal B16A2 OEM rebuild??
  74. B18C5 wont rev past 5k
  75. OEM JDM parts
  76. Fair price to sell ITR IM/70mm TB ?
  77. all motor advise
  78. all motor b18c1
  79. Amsoil or Royal Purple
  80. ITB question
  81. spark plugs
  82. motor build advice
  83. b18c1 Head question.
  84. Insight to a 50whp loss after sk2 pro1's
  85. H22 Feel's Twin Cam Header
  86. N/A build; valve question
  87. b16a all motor - multiple questions
  88. spring/retainer conformation?
  89. Fully built gsr failing walbro or stock ignition too weak
  90. Most cost effective way to 220/160 whp
  91. BLOX valve springs!
  92. What Valve Springs are These?
  93. 11sec, pump gas, DD?
  94. Anyone ever checked clearances on an old/wore out motor?
  95. 91 ef/b18a1 swap, idle and rev limit issue
  96. 98 ls swap into eg NEED HELP
  97. help with my gsr build?
  98. Toda Spec B's on Stock ITR Block
  99. Honda J motor 2D or 3D drawings
  100. Headwork
  101. mitropropane
  102. B-Series piston selection.
  103. YCP or RS MACHINE?
  104. Help please ..... camshaft RS290 vtec d16
  105. d16z6
  106. 0bd0 02 sensor code ( #1 ) Car wont start
  107. best aftermarket conraods for all motor 1.8 na?
  108. throtle body question
  109. Eristic piston kit or npr
  110. To LS stroke or not?
  111. Will the spark plug wires from a GSR fit on a B16 VTEC head?
  112. ls vtec
  113. motor mounts
  114. best mods for b16a2
  115. K20a2 - 100 Shot Wet - Pump Gas Tune
  116. H22 BISIMOTO header tuned
  117. 91 civic swap a6 to z6 help....
  118. B16-B18-B20 questions
  119. easier way to lap valves??
  120. help me identify this plug! obd2 D16Y7
  121. VTEC problem on B16 PR3-3 head?
  122. ls/vtec in ek, hesitates, recently installed ctr cams...doesnt pass 4-5k
  123. H2B Drag Prelude - seeking 10.9999999 - (2/27/13)
  124. opion on b16 build
  125. quick question
  126. 82mm over bore is it safe on my GSR block?
  127. ugr valves vs used oem itr valves??
  128. How safe are the b20's stock sleeves
  129. ls vtec build, questions about pistons, cams that work well
  130. 85.5mm Bore, 85.5x89, power? DD? Input?
  131. Turbo to N/A
  132. stage 3 cams
  133. euro r h2b vs. itr with b16 tranny
  134. ALL MOTOR B16!
  135. B16 Build... 200+WHP What do you think?
  136. z6 in a 97 civic hatch
  137. Type R head on GS-R block??
  138. Is a H2B Hurt my motor
  139. My B18C1 Build
  140. Who imports?
  141. motor is buring oil -rebuild help time??
  142. help me with my compression readings
  143. Best B18C-R Header
  144. Is FJ Distributors B18C All-Motor Kit Reliable?
  145. Using AVGAS 100LL
  146. Eagle rod rod bolts
  147. Dropped Valve- Pistons any good! Pics inside!
  148. oem b18c1 vavle guides
  149. Got this cam lobe issue.
  150. head milled help
  151. All-Motor Running Alcohol instead of Gasoline?
  152. 2.5" vs 3" Electric cutout.
  153. D15B SOHC VTEC Engine
  154. D16Z6 build, pistons,rods,cam,valves,springs.....?
  155. skunk2 tuner stage 3 camshafts
  156. eg hatch swap
  157. what to use on ls/vtec..
  158. Skunk2 cams n Crower combo
  159. P30 Pistons in GSR
  160. Another cam/valvetrain decision thread-help me out
  161. building ls/vtec need help plz.
  162. H22 rocker arms in a GSR
  163. E85 N/A with stock compression
  164. 2 STEP
  165. Will this seat cutter work on honda/acura heads?
  166. bisimoto/kidd racing header?
  167. Questions on what IM mani to run on 84.5x89 14ish CR b20v on e85.
  168. ►►NOV-DECEMBER | All Motor Classifieds | FS & WTB ◄◄
  169. F20B Rattle/Tapping in Cyl Head, lma's?
  170. Let's bring H-T all motor forum back to life
  171. B18C1 Rebuild time, Need advice
  172. b20 all motor Setup, hopping to get 210whp.
  173. question about timing belt please help
  174. Normal Blow By?
  175. Engine Timing, Underdrive crank pulley dosent have timing marks!!! aaaaahhhh
  176. comp cams
  177. Where should the distributor timing be set?
  178. Is This Motor a B18c-R ?
  179. Port & polish vs stock head
  180. Identify this header Bisimoto SMSP or knockoff?
  181. couple questions for my b20vtec build
  182. Skim cut block how much of a scratch is too much?
  183. My first Type R motor. Input/ Suggestions welcome
  184. Eagle rods for B18c1
  185. H22 head on a F22 block...
  186. question about a sesonator...?
  187. B18C1 camshafts on an B16A?
  188. IFO Montgomery 2010, Allmotor Pro winner (video)
  189. 11.2:1 Compression, 85X89, Enough to make GOOD Power?
  190. Need help with p72-1 head
  191. spark plugs and gap for 12:1 comp gsr
  192. More misfiring/cutting out issues.....
  193. Excess blowby
  194. JDM B16A problems need tips
  195. gsr build w/arias pistons
  196. b18b throttle ()obd1 onto y8 mani (obd2)???
  197. lsv allmotor build
  198. Engine teardown.
  199. Degreeing sk2 tuner2
  200. Need opinions: RMF Drag header
  201. RS Machines Pistons
  202. What does this Manifold belong to???
  203. B20b high Comp pistons ??????
  204. CAM Q's (skunk2/BLox Content)
  205. 3'' exhaust vs 2.5'' on b18c any dyno's??
  206. d15b1 going for junkyard horse power
  207. !HELP! Taping noise in engine HELP ???
  208. Big tube header?
  209. LS/Vtec Build??
  210. D15/16 am I on the right track?
  211. Another Rage Header Install
  212. B-Series Rocker Arm
  213. DIY ITBs or Convert to Dual Carb----
  214. Flat spot around 5k rpm
  215. d15 using d16 pistons w/ ls rods?
  216. LSVTEC BUILDs. WHAT YOU GOT?
  217. Driving with no oil (ouch!)
  218. Best engine builders in Central Florida
  219. High compression LS first start up Q's??
  220. My engine, Help, comments, Discussion
  221. different point of view
  222. 91 octane compression limit
  223. Valve to piston clearence stock B16A
  224. Trading my boost parts for a 96 spec itr motor
  225. wat to do with tranny gearing
  226. Something interesting for you guys.
  227. b20 vtec base map s300 help
  228. Help B16 build
  229. N/A traction bar question???
  230. Header Collector Donut Gasket
  231. what intake manifold is this?? its a weird one
  232. TODA A Camshafts
  233. what is the differences?
  234. My B20VTEC, revised
  235. 86mmx95mm setups life??
  236. gsr head on b16a2 worth it?
  237. Integra Revving issue
  238. Extrude Hone or Port
  239. ls/vtec help please!
  240. 2.5" to 3" Exhaust Issue
  241. harmonic balancer question
  242. Need Help On GSR Build Up (Newb)
  243. D16y8 vtec head port and polished plus head is shaved .30
  244. B16a casting lines in ports
  245. :FIRST B20 ENGINE build ...ENGINE CODE HELP
  246. Stock GSR girdle..
  247. new to honda
  248. My 2.3 liter B
  249. undersize or stock bearings
  250. high comp 2.1 gsr winter reliabilty
