- can you buy high performance rockers, explain please?????????????
- '97 Civic Dx ( D16y7)
- should i build a whole motor, or just the top?
- h22a stock intake flaps please help
- pistons in a GSR
- D16a6 vs d16z6
- O-ring or step deck D series big bore?
- ITRB Tuning help
- Timing advance?
- would a b16a stroker be worth it?
- would you recomend an exhaust cutout behind the cat???
- Valve clearence question!!!! I did not clay my engine!!!!
- anyone dyno'd Wicked cams yet
- wicked cams
- h23vtec
- What causes.....
- Compisition of OEM rings
- lsvtec?
- LSvtec: is a GSR block better or worse than an LS block with B16a head?
- What kind of exhuast is on this car ?
- apexi power fc
- Best platform for going ALL MOTOR? Is it true and should we....
- B20? Why not sleeve LS to 84mm?
- ECU for B20Vtec
- Burning lots of oil, no power in vtec..
- need quick answer, did search confused=S jdm h22 93 rods jdm type s pistons compatable?
- B16 porting ...what do you think?
- Built B16 Questions
- What T/B size
- Compression test results...
- compression quistion
- gsr comp. /cams question?
- main bolt size?
- Head milled cam timing question
- RC Injector Question....PLEASE HELP.
- timing belt tensioner question's
- CTR Piston question!!!
- Low-Temp Intake Manifold Gasket for B18C1?
- just got h22 now what
- trying to work out some bugs on my new swap-questions???
- Extra HP products
- v6 timing belt issues
- Wicked cams
- my h22a head build up...hp kinda low
- Skunk2 stg 2 question
- almost done h22 itb
- Toda cam gears question...........
- CTRs +.25mm or Wiseco +.50mm 11.5:1??
- Maximum timing advance of a stock P13 ECU
- life of a motor(b16 with ctr piston)
- I need your help guys....
- Lightened Valvetrain
- (time and power)b16 with ctr pistons and cams
- ECU trouble code list
- simple question for yah?
- Burning an insane amount of oil (LONG)
- Difference between liters and power
- lsvtec setup
- is 11.5 cr too high for street?
- code 20 in my GSR SWAP
- poormans R code 10 and 14....plz help
- setup info
- Anybody need some CTR pisons?
- Gsr to B16 head: Problems
- I'm leaving the All-Motor game...
- anyone using 1 layer OEM HG
- My new motor pics!!!
- Building a PMR, have b18c block and b16a2 head, what other parts do I need to...
- ITR IM in '99/00 Si
- 4000 and a b20
- b16a1 vs b16a2 blocks
- Intake inners valve springs on exhaust side?
- DOHC ZC head on D15B2 block
- s100 enough? or should i invest in the s200
- Valve springs too stiff for itr cam??
- New Here: 6k to spend on B16A2
- Anyone here running the SRD crank pulley?
- Need help sizeing correct bearings..
- Belt size minus A/C... 95 Accord Ex
- Honing out the block
- what does na stand for?
- B16 rods and Type R pistons.
- what would you rev to?
- Smartest way to spend your money....?
- help with non vtec set up
- Observations on a CBR954RR/ NA Related
- Trying to find some old friends in So Cal, anyone remember this pic?
- ITR stroker kit
- check out my track times.
- wanna see j's racing dyno sheets
- Highest compression possible with b20 stock sleeves?
- what all is needed to bolt on a jdm 4-1 header with 2.5 coll. to my car????
- Intake install question...
- Finally, the TRUTH regarding K-Series vs. B-Series engine weights!
- Flaws on my block??
- cam sensor and crank sensor HELP??????
- Block assembly writeup or tips
- Sneaky Peeky.........
- Crower H22 cams... Opinions needed/wanted
- b18 or b20?
- build me - $2000 to spend
- Critique my allmotor LS setup
- compression question for b18c1
- Check out new All motor set-up.
- B16A Build-up
- I figure out what I want...
- I'm looking for a gs-r block that's for sale
- should block be over bored (changing pistons for ls/vtec)........
- My mild daily driven setup
- Went to track and blew.....
- help: s80 tranny quesstions
- Lsvtec mildly built what valves should i used??????
- what cams would work best with my setup?
- Willem burner problems, with program. HELP!
- how to wire the vtec from a 1.6 vtec to 1.5 dx
- Welding 2.5 collector where a 2 inch collector use to be??
- Quick Question on building my N/A motor
- B16A1/B18C5
- 1200$ to spend on my b16a block. please help!!!
- B18B1 vs B18A1 Question
- Ctachcan Setup on LS/Vtec and CRV/Vtec???
- N/A setup Questions
- people with jdm 4-1 header in gsr
- VAFC 2 have knock sensor monitoring or not?
- How to remove copper spray from a head gasket?
- Strange noise on cold starts....
- Has anybody heard of Renteria Bros. Racing?
- Car keeps cutting out (fuel cut?) VAFC, cammed... suggestions?
- All motor plans for my b16a2
- It's Alive!
- Skunk2 Or Rocket Cams?
- Exhaust Back Pressure
- The ultimate NA Setup!
- Max redline for stock D16Z6 valve springs?
- Are these Really ITR Cams [98 spec] - *pix*
- Girdle for LS/VTEC Setup?
- what next for my set up????
- building my gsr
- b18c hp levels
- D17A1... what to do?
- built motor longetivity
- Going 85mm Ls/Vtec questions
- help - gsr motor and i need header help.
- Piston ring recommendation
- Whats up with the all motor street scene in so. cali???
- Manley rods
- Need help! Motor is a complete POS.
- How much compression with a milled head?
- zex 59300 cam without upgrading valvetrain??
- Anyone have a Hytech muffler or catback on their 5g coupe?
- IS CLUTCHMASTERS A GOOD CLUTCH?
- Titan Cam Test Predictions?
- Anyone have this setup?
- how to tell they are skunk2 stage 1 cams?
- Header tech header pics???
- I need help, please!
- Question about Toda setup.
- Valve Guides!
- a couple quick questions
- k20 in ek
- Installing 6 puck
- what is the best setting for toda b's?
- ls/vtec setup pricing ?
- New cams... Noisy engine. ???
- Built head!!
- Budget all motor project. Dyno inside.
- PROBLEMS..
- jdm s80 lsd into an ls motor
- skunk2 stage 1 cams with stage 2 engravings?
- h23 Vtec build similar to b20 vtec or ls vtec build?
- Good idea?
- REALTIME Question
- civic type r pistons or integra type r ??
- cam seal or cam seals?
- Toda B's/C's
- CRVTEC vs. LS-VTEC
- b20/vtec head conversion???
- B16A CRX vs B18C5 Del Sol
- Different catch can set-ups
- LMA problem #1 explained with pix (BIG PIX).
- ignition timing after jun3's?
- primary lobe pre-ignition problem
- Compression Calculator.
- b16 and what pistons????
- built lsvtec what do you think
- New member...here is my setup also have some q's.
- 13:1 compression Daily driven...
- Hows this setup sound?
- B20 Block.......
- My compression results. Is this good?
- wich oem honda pistons in jdmb18c non spec-r
- possible solution for bad idel with ITB
- does block need to be notched for rod clearence?
- 99 ex w/ lsvtec swap .. inspection???
- p06 or p72
- Jun or toda valvetrain kit?
- Skid place for JDM DC 4-1?
- Tuning n00b! where to start?
- fuel filter question
- anyone using uberdata to tune their N/A honda?
- why is my hp so low?
- Q's about Toda B's
- help me out for a sec
- Spark plug wire pops off.
- where are the ls wariors
- Are you happy with your CTRs?
- motorcycle ITB price?
- Wont start
- 99-00 si owners with 200whp n/a
- How hard will a mini-me swap be for a newb?
- headwork and powerband
- ECU program for a p72 all motor setup
- Is this serious blow by or normal - oil squirting out when removed oil cap.
- Mobil 5w-30 2000 Si
- Break in with Mobil 1 issue
- settings on skunk 2 stage 2 cams...
- ls motor spun rod bearing questions
- Allmotor LS Setup
- question about ls/vtec?
- ACL Main Bearing
- still lots of play in the shifter
- valve clearances
- PISTON? brand?
- Pistons: Are these still good?
- what is better??
- Port and polish worth it for a GSR head?
- lsvtec cams pistons how much power will i have
- should i try dsm 450cc's? on the dyno.
- Can I run Toda b's on a stock civic type r motor without upgrading the valvetrain?
- Blue smoke on startup
- S2 Stage 3's and valve train on street car?
- b16a with b18c type r tranny
- re-grind cam question: please read
- Max Power In NA Car With APEC VTEC Controller Fuel Management?
- where can I buy pre made D series Built Blocks??
- Does anybody happen to know the runner length of the TWM ITB's for the H22?
- Scratch in cylinder number one
- k20 built up?what should i do
- itb?
- what fd and lsd for my gsr tranny?
- CTR Cams ?
- need help about valves
- pistons, and engine work??
- Hondata tuned Skunk2 stg1 cams stock B18C
- K series 5.026 F/D kit
- Opening a 95 LS Tranny? How do you do it?
- Idle rev 1000-2000 constantly
- Are the K series motors the best Honda has ever made?
- Couple of questions
- Good muffler shop around Greenville,SC?
