PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 [70] 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Noobs ls/vtec BUILD. =D
  2. Did I get scammed????
  3. B20 with 4-1 ITR manifold?
  4. Dyno "numbers" discussion. Why the numbers do NOT matter.
  5. b16a add-on
  6. Slighty built b18c1 advice??
  7. type r maifold on b16; troubles
  8. V-tec engagement
  9. Quick question
  10. i have a eg 4 sal
  11. Rebuilding b20vtec after blown HG. Question about undercamming.
  12. Buddy club Valve springs w/ pro 1+ cams??
  13. Question about TopSpeed 4 D16z6...
  14. cam question
  15. Valve to piston clearance issue B18C
  16. Rod and Main Bearing Clearance Question
  17. stock cam shaft on a built head any problems?
  18. Rods weights ? Stock Vs Eagles and others has anyone weigh any.
  19. 95 civic vtec soleniod??
  20. crank pulley ?
  21. Help finding gx pistons!
  22. Which piston for B20 to get a 12.5:1 comp
  23. smell like gas in oil
  24. compatable motors>>>>.Civic97
  25. Motor makes low power and runs like poop after tuning....
  26. best motor to build
  27. b16b stroke
  28. What year B20 to use
  29. Throttle Bodies (Again)
  30. B18C1+R cams dyno
  31. what cc's are b16 injectors
  32. Where would I buy JUN or Toda cams?
  33. what rpm is gsr redline and vtec at?
  34. Break-In oil, suggestions
  35. b20vtec question on vtec
  36. eagle rods on ctr pistons?
  37. whats the web site for the engine calculator?
  38. obd1 or obd2
  39. H22 type s Compression height
  40. Professional head porters: where can i find.....
  41. b18b build
  42. flywheel question
  43. Oil Smoke Question.....
  44. camp1320 h2b header
  45. p72 pistons on ls rods?
  46. any noticeable difference going from 81mm to 85mm?
  47. tuners or pros ?
  48. Looking for stock LS/VTEC dyno charts
  49. Anyone done this to their pistons, rods, crank, etc?
  50. Injectors?
  51. Stage 1 cams, stock valvetrain - is it really ok?
  52. DYNO'ed Again: 86mm / TWM ITBs / TriY BigTube / Alaniz / Neoh2ning
  53. what would be the best cam for my b16 head?
  54. milling head on a b18c5
  55. Nippon Piston rings do they go a certain way up help appreciated
  56. Do anyone knows the bhp(horsepower) of CR 250 1995?
  57. Hydro Hasport motor mounts vs cable Hasport motor mounts
  58. spun bearing. can i reuse the rod?
  59. ...:::K20 Dyno Results/C_A_T Tuned:::...
  60. skunk 2..b16a2.. stage3...
  61. enabling vtec on my engine swap....MY THEORY!!!!!!!!!!!!!!!!!!
  62. Error Code 22 in idle
  63. vtec help
  64. Anyone else run the H22 LMA's in their b-series motor?
  65. please help =>injectors size / e85 /build B16
  66. Timing belt tensioner spring
  67. Pistons, NPR or crap?
  68. Rod Knock question :)
  69. mild built h22 revlimiter
  70. toda timing belt slipping a tooth
  71. K20 Jun cams + oversize valves?
  72. Forged B17 Connecting Rods
  73. P2V clearance never seemed so important
  74. FINALLY!!
  75. Need timing advice
  76. Why is my motor feeling sluggish while driving normal?
  77. header help
  78. Password JDM Carbon Fiber Powerchamber Question.
  79. Blox manifold installed, high idle. Help
  80. hyper's LS All Motor Build w/ optional nitrous
  81. Looking for advice. B16A on dyno
  82. JUN Piston Kit for the H22
  83. all motor gsr cams
  84. im not sure and need a answer
  85. Best valve train for N/A b series. (b20/vtec)?
  86. Anyone converted a D-series to carburetors?
  87. B18C6 burning crazzy oil after going through it.
  88. whats the max all motor D-series hp youve seen?
  89. IMPORTANT??!!?!?!?!?
  90. GSR injectors
  91. Shimming and porting an oil pump?
  92. How long to get your B series Hytech production header?
  93. just got off the dyno. good numbers?
  94. VIDEO: K20 coupe - Part 2, with bonus comedic ending
  95. HELP---Which cams to choose for my set-up?
  96. eshly built gsr spuddering...give me some opinions
  97. Water Pump Choice
  98. General question about degreeing cams
  99. Hytech big tube replica header fitment issues!! WELD IT!!
  100. Crower Stage 2 cams VS. Skunk2 Stage 2
  101. 00 honda hatchback
  102. p72 LMA's in pr3 head?
  103. OT: Every 4-1/race header owner should buy this!!
  104. header vision
  105. Getting block sleeved, is this repairable?
  106. Prelude type s injectors?
  107. The greatest question ever to be asked in the All motor forum..
  108. b20 vtec questions??
  109. lsvtec head question?!
  110. Hasport motor mount bushing stiffness?
  111. Catback for TSX
  112. TPS issue on JDM b18b
  113. Spoon Venturi Plate???
  114. WHICH CAMS FOR MY SETUP...B16A 2ND GEN OBD1 EF
  115. Interesting Intake Mani Design on Ebay...
  116. k20 swap
  117. Coolant mixing with Oil, Need help!!!
  118. DC Header busted up by tow truck, NEED HELP
  119. 2000 Si, stock intake, can't remember how to install
  120. Fuel Guru's Need Your Advice
  121. Thinkin of a K swap...need some info if possible
  122. omni power
  123. Post up your LSVTEC Set ups and Numbers Over 200whp
  124. Used to be a boost head, now i just want to daily drive the damn thing! :D
  125. H22 SUNK2 PRO 3 CAMS W/ REGULAR SKUNK2 SPRINGS RETAINERS???
  126. Noob Piston question....
  127. Type R header questions
  128. LSVTEC Combo questions?
  129. B20/vtec tranny
  130. Looking for insight on my dyno #s
  131. H22 Backfiring. NEED help on this one.
  132. b16a mystery plug (crank shaft plug)?
  133. h22a1???
  134. axle xommin out of tranny
  135. Rotor seized in distributor. Any suggestions?
  136. hey all you b20vtec motors, whats your average mpg?
  137. CRX HF LSVtec Project
  138. All motor ls/vtec.....whats ur opinion on next mod?
  139. LSVTEC oil leak from LS dizzy
  140. what next
  141. B16a ITR Cams help valve spring question
  142. usdm itr vs. ctr
  143. Help pls
  144. which would you use JUN intake manifold or TODA itb's?
  145. basic ls vtec or gsr
  146. 12:1 Compression ratio too high for dd?
  147. whats the ingredients for 300hp for a h22 (injen swap in an integra)
  148. b16 head on GSR block
  149. my car bogs help
  150. Building A b16....PLEASE HELP
  151. S2K PRO-2 STOCK BOTTOM END
  152. ls rods
  153. dh-racing heads
  154. piston recommendations for my b18c1 block, itr head
  155. need help!! or opinions
  156. Compression doesn't make sense
  157. Stock b18b pistons in ls/vtec?
  158. replace new hg after torque
  159. intake manifold question. please help!
  160. Repairing a cracked block?
  161. 10 second club members
  162. my new build.......
  163. B18a block ls or gsr crank?
  164. Does any body know who has the fastest B SERIES all motor street car?
  165. Beating a dead horse: Engine block serial numbers tracable?
  166. my b20vtec build. any HP estimates?
  167. Help!! Valve adjustment specs for bc3+!!!
  168. Intake reviews?
  169. Should i have clayed my motor?
  170. my valves are knocking help
  171. Timing problems Need a pro to figure this out..
  172. fully built h22a1 no power!
  173. spun main bearing, block/caps still good?
  174. ...Milling Head...
  175. build threads......please read
  176. Stock or aftermarket valves?
  177. Toda spec B's + stock block?
  178. d15 high compression build. injector size ?
  179. Headgasket help
  180. will a b18 trans work with a b16 motor?
  181. b16a rebuild specs
  182. injectors?
  183. blox intake manifold with stock throttle body
  184. VTEC sputtering in 2nd and 3rd gear (HELP)
  185. please help me!! vtec cuts out in higher rpms
  186. TYPE R SINGLE CAM!!
  187. Head Gasket...HELP
  188. D15B ....can you use D16z6 parts on it???? please help
  189. how to determine TB size for b16a?
  190. Toda cams for DD?
  191. B18A1 build plan, any advice?
  192. How do these end gaps look to you?
  193. do i need injectors?
  194. PLz Help B20vtec Built now has a Problem HT MEMEBER PLZ HELP
  195. i dont have a clue
  196. Need help with motor Break in!!!!
  197. 00b18b Allmotor LSvtec build
  198. Summer project engine build
  199. obdo to obd1 head swap
  200. ARP headstuds
  201. engine prefrences
  202. Will a gsr motor directly bolt on to my civic?
  203. skunk 2 stage 1 safe on type r train
  204. B20vtec Buildup! in progress!!!
  205. Motor Parts for a Rebuild
  206. ?Are H23vtec (BLUE TOP) cams the same as Type S cams, Did a search but got mixed answers
  207. do jdm heads have the oil ports for vtec pressure switch?
  208. Reverse threaded differential bolts
  209. honda injector nozzle type
  210. all motor del sol
  211. E-85 gas on all motor set up
  212. Should i upgrade fuel system?
  213. 4-1 or 4-2-1 header? please help?
  214. lsvtec
  215. Problem reving pass 7.5RPM.. HELP!!!
  216. Which Supertech springs w/ Blox Type B cams? *noob*
  217. B18B1 with B18C1 Head
  218. need help pls
  219. skunk2 stg1 tuner series.....
  220. building b18a with p8r head- need help with headgaket and milling
  221. Changed intake manifold, Now Smoking!!......Valve Stem Seals? Oil Rings?
  222. Dont know where to ask this....but d15b2 with y8 manifold......what ecm and dizzy to use?
  223. Exhaust tip swap??!!! 2-1/4 gready sp2 tip on 2.25 piping??
  224. Invidia Test Pipe
  225. B20vtec specs and dyno, 220 whp/153 tq
  226. Question Regarding Using DSM Injectors
  227. DIY porting info?
  228. 345cc injector with resistant box
  229. -{Project: Circuit Hero K20/EG6}-
  230. l/s or si(b16)
  231. refresh my motor
  232. b16 block gsr add-ons
  233. CTR intake valve part#?
  234. eagle rods or stock rods???
  235. Built GSR cutting out
  236. back from the dyno, what do yal think...
  237. micrometers...engine building related
  238. my car cranks but not starting
  239. DOHC noc vtec ZC Camshafts???
  240. AKMEE B16 valvetrain???
  241. Need help on B16a2 setup :)
  242. ITR CAMS VS CTR CAMS
  243. Exhaust question? exhaust tip matter!!!
  244. rlz valvetrain and pro2's???
  245. 95 civic cam shaft swap
  246. Castrol Edge
  247. Help!! fuel cut off and bogs around 4.4-4.5 rpms!!
  248. Just checked my machinists work....
  249. b20/b16 head use same ARP head studs as B18/ITR head right??? LS/VTEC head studs
  250. CTR Pistons Question
