PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 [183] 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. b16 rods(pr3) with itr pistons, how do you make them fit?
  2. B20A2 (89-91 prelude) crank journal size..
  3. Some more work still needed
  4. where did you get your motors built, md??
  5. na/ dyno tuning
  6. how much did you spend on your all motor build?
  7. ???Birth of cams???
  8. B series swap questoin . .
  9. Who should do my head?
  10. engine honing
  11. Top speed IM anyone heard of it? Need all IM suggestions I can get
  12. Base timing recommendations
  13. Please help me with my choice!! (cams)
  14. who on H-tech sells custom p28 chip?
  15. b18b bulit or H22a
  16. maybe someone can help?
  17. need some cam profiles (did search)
  18. what are the best springs for skunk2 stg1??????????
  19. another question for my poor mans itr build (which head to use)
  20. best place to purchase ITB's
  21. Anyone stock dyno #s for ls Graphs if possible
  22. All motor injectors....
  23. has anyone who used a bigger crank ( stroker crank) been able to retain the oil squirters ?
  24. all motor stroke questions
  25. LS bottom end with a GSR crank??
  26. Testing for Bent Valves...how accurate is this method?
  27. What is the difference between SAE and Corrected HP?
  28. TYPE R head!!!!!!
  29. oh god what is crankcase...im sorry guys
  30. b20 cams in b18b?
  31. Hmm .. which crank? ITR or GSR.
  32. Question for all NA ONLY!!!!! people. What do you think of turbo's? pro's/cons.
  33. how to clean upper head of d16z6
  34. Cams for my daily driver
  35. MR CRX DRAG CAR!!
  36. anyone making 220 with 81mm block/;///////////;
  37. What are "valve jobs"
  38. ?? about B20 vtec build
  39. What would be the best set up for my ECU's limits?
  40. m2b4 tranny in eg which axles???
  41. compression ratio for every block/head/piston honda makes
  42. code 5 ??
  43. Weird ground problem...car wont start...HELP!!!
  44. Can I safely run my new setup untuned?
  45. K20 all motor
  46. skunk 2 stage 2 camshafts in b18c (gsr)
  47. do think tis setup will last
  48. h22a4 Rebuild...good setup?
  49. will i see big improvement with overbored TB and portmatched IM?
  50. wtb new, stronger crank
  51. Crower Stage 2?
  52. darton sleeve questions
  53. type r or e.s tunnig
  54. Crankwork questions
  55. something fishy?
  56. skunk2 stage2 destroyed my rockers
  57. Running open header?
  58. Tranny Problems
  59. Good all motor header? Toda? Bisi? AN-r?
  60. pr3 pistons on ls rods
  61. main girdle really needed for lsvtec?
  62. need some advice on manifold?
  63. High mileage LS rods in LS/Vtec...should I purchase new ones?
  64. Advantage to destroking...
  65. is it worth the time and money
  66. B20 Block'''Need Some ADVISE..........
  67. Overbore sleeves for D-series - open or closed deck
  68. dyno ls/vtec
  69. LS+GSR pistons?
  70. already have a CTR intake cam...should i move up to skunk2's?
  71. Toda D's or JUN 4's?
  72. whats a good IM for a 2.0 b18c1 motor for good power on a DD
  73. Which Header and ECU for B20/vtec assembly?
  74. Building/REbuilding a high mile SOHC worth it?
  75. weight reduction is a good idea for my civic?
  76. anyone heard of Blox Racing?
  77. snapped bolt that held the cam cover, what can i do?
  78. S2S1 Cams? Looking for the PRIMARY LOBE specs
  79. who makes chip for ecu's?
  80. my future setup, suggestions please..
  81. Please post ls/vtec numbers
  82. Where to chip ECU in socaL?
  83. Poorman's Trany
  84. What kind of Ecu for this badasss set up LS/VTEC
  85. a very noobish question, please excuse
  86. b16/b17 short block setup
  87. Present build pics of LS/vtec, BCIII+, eagle, Z10 and all that good stuff....
  88. ECU
  89. d17/y8 crx swap?
  90. GSR Cam cap bolts
  91. USDM 00 B18C5 Factory Valve Lash Specs
  92. B16A2 Headwork.. what should I get?
  93. JDM dc header and USDM dc header?!?!?
  94. b16a2 water and oil pumps work on jdm b16a?
  95. Help Me
  96. Dowell pins for LS/VTEC... where to find them?
  97. RS machine cams
  98. SoCal....Church or Bubba tuned?
  99. Accord Transmission Question
  100. Reputable Machine Shop in San Diego?
  101. building a poor mans type R - which piston to use p30 or ITR .25 over
  102. stoker kit???
  103. How does an-r compact vs jdm itr perform?
  104. Yay? or Nay?
  105. Advice on build
  106. anyone knows how to do uberdata in mn or wi?
  107. My AN-R Header came in TODAY!!!!
  108. oil pan and pump combo
  109. Broken motor mount! OK to drive?
  110. B16A2 buildup
  111. what should I do ITB's or keep skunk2 manifold?
  112. CAM install gone BAD! Need help/opnion on rocker PICS
  113. To Regrind , or not to Regrind camshafts? *chime in regrind users*
  114. Temporary ls/vtec build up, can I get 13's?
  115. is there a way to get around OBD2 and get it.....etc
  116. anyone recognize these sleeves///////........
  117. SKUNK2 SETS NOPI ALL MOTOR RECORD 9.885 @ 136
  118. 92-96 h22a or f23a4 rebuild?
  119. what kinda pcv system are all you ls and b20/vtec guys running?
  120. anyone heard of "Field's SFC-VTEC"
  121. My Personal Project
  122. big expectations for dyno day...or wait and add more mods before the dyno tune?
  123. B16b going 1.8L keep ctr pistons or use JDM ITR pistons.
  124. Ls/vtec engine build, help me guestimate hp, and torque please
  125. ITBs on a sohc?...yeah another itb question
  126. King motorsports says no way
  127. Buddyclub spec3+ vs. Buddyclub spec 4........
  128. OEM Honda Part number...breather plug for back of block>>>?
  129. Ls/Vtec with an RsR ExMag Exhaust Questions!!
  130. THOUGHTS ON MY LS BUILD.
  131. bisimoto header on jdm d15b vtec.
  132. Compression Test Results are in !!!
  133. CRAZY BUILD PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
  134. CAMS
  135. buddyclub cams vs. skunk2
  136. Ls/Vtec Ecu!@1!
  137. B16 WONT START (STARTER?)
  138. crankcase breather setup?
  139. K series potential: k20a EG dynos , stock ECU vs Mugen ECU vs Hondata K-pro
  140. str fuel rail problem!!!!
  141. Cherry Bomb resonator ?
  142. safe bore for gsr 97's stock TB?
  143. My hat's off to Eagle's oustanding rods *destruction pics*
  144. 5 angle vualve job???
  145. Want to know a ballpark hp estimate on my b16
  146. LS v-tech with B-16 head
  147. How drivable are TWM ITB's?
  148. Crank Girdles........
  149. stock ITR cyl port pics
  150. all motor HB with zc swap
  151. My Baseline Dyno Results
  152. BC3+ or ITR cams
  153. block and head
  154. MSD A6 or what?
  155. lsvtec done
  156. Ported GSR intake manifold VS. Skunk2 intake manifold
  157. anybody running a 2 layer stock headgasket?
  158. another b20 vs ls/vtec question!
  159. p73-AO pistons in b18b
  160. Has Anyone seen or heard about this? Beast GX20 Engine
  161. Has Anyone seen or heard about this?
  162. GSRX ITB Question - Did some one fix the TPS issue yet?
  163. Who is actually hitting 12's in full interior TEGS with allmotor B series ??????
  164. B20 VTEC w/ ITR cams
  165. how long did ur b20 block last before sleeves cracked???????????
  166. Daily Driver with 1-layer
  167. Decking head vs compression. Check my math.
  168. 00ITR with BC3+ Dyno Day!
  169. Torquing AEBS Head Studs
  170. pistons and valves
  171. f-series crank into k24?
  172. price estimate for this job.
  173. any idea on how much power??
  174. what will a Built b16 head do to a GSR??
  175. Oil starved pistons?
  176. Wicked-industries camshafts
  177. Which Rings to use?
  178. Arp Head Studs!!!!!
  179. Compression issues 0 on number 1 after over rev.
  180. B18C 84mm to B20B 84mm
  181. ?? about compression check on a gsr
  182. need some input..........
  183. WICH CAMS TO BUY FOR ALLMOTOR???
  184. LS build questions.
  185. Switching my exhaust, need some advice.
  186. 6-speed sohc trans-
  187. Catco cat questions. Whoops.
  188. Ran at track lastnight. Ls/Vtec
  189. best a/f by experience?
  190. what ecu for me?
  191. help me hit 13's all motor
  192. ls block with ctr pistons (what horsepower? Times? )
  193. I'm Back!
  194. pnp on a ls head question, and set-up?'s !!!!!!
  195. Forged 84mm B20 pistons questions:
  196. question about retainers and valve springs
  197. Need a new timing belt but not sure what to use b20vtec (b16a1 head, b20b block) ?
  198. all vtec cam gears the same???
  199. My car too heavy to be quick????????
  200. what do to make d16 faster
  201. B20B Sleeves/Setup..Will they crack?
  202. Reccomend Radiator
  203. Cam Gears
  204. b18c1 1989 crx hf can someone look at my link and see if they can help me out.
  205. b18c1 block
  206. Here's my setup so far!!!!!!!!
  207. Need a Bisimoto header...where's exospeed or Bisi???
  208. How much power can i make with a Sotck B16b civic type r bottom end?
  209. nitrous
  210. how to improve 60' times?
  211. JG Intake Manifold for H22
  212. Reasons why car might over heat?
  213. header
  214. Buddy Club Spec 3's DYNO
  215. # of cam gear bolts, does it matter?
  216. Just can't get 200WHP - Please help w/ suggestions...
  217. IB project motor dyno inside.
  218. b16a2/ctr piston's thinnest head gasket????????
  219. Where to get a New Catalytic converter?
  220. PR4 rods and OEM pistons
  221. loud tick....any ideas?
  222. cam reccomendations?
  223. lsvtec oil pressure
  224. B20 ALLMOTOR NONVTEC street car 12.12 @ 111 World fastest????
  225. Installed JUN 3s, car bogs when VTEC engages
  226. What kind of gains will i get?
  227. Identifying CTR valvetrain?
  228. GSR Injector question...I've searched
  229. B20/vtec setup ?
  230. 3" exhaust overkill on my car?
  231. allmotor help what cams for sleeved 85mm block
  232. *JG vs ITR*
  233. coolant bypass, already searched
  234. having issues.....
  235. Can my clutch handle 190-200+ HP?
  236. could someone give me some advice please....thankz
  237. Skunk 2 Header????
  238. Another idling issue! Help!
  239. Import Tuner Allmotor B-series shootout " and the winner is thread!! "
  240. Injector Help
  241. More Power out of my B18B
  242. 400hp NA possible?
  243. skunk2 stage1's or buddy club spec 3+
  244. oil pressure problem with my zc
  245. Help Guys!!
  246. ANR header, Differences???? Help!
  247. Question on Car Longevity
  248. engine bay swap intake CAI doesn't fit...
  249. Dh-Racing Premier GSR B18c Head on ebay????
  250. car hesitates when i hit vtec
