- main cap question for b20 with gsr crank......
- all motor tune?
- My DIY GSXR 1000 ITB Setup for my GSR Motor
- best exxxhaust for 94 integra ls
- changing combustion chamber shape
- loaded topic
- Wanting more out of my built B16!!!
- What Stage Cams
- Help: Alaniz's street master P&P enough for...
- crower cams.
- LS/VTEC Build
- Just curious, maybe i can get some help?
- got some questions on using a 99+ JDM ITR/CTR ECU on a 2000 civic SI
- what's a good size TB for a b16a2?
- My planned build
- ITR/GSR Fuel pump? good for 200WHP?
- to skunk 2 or not to skunk2
- S2000 NA build up
- Dh-racing?? Crate motors??
- Compression. how much?
- Hoes anyone ever dyno compared stock IM vs. ITB's?
- How daily drivable are the JUN 3's or Toda C's
- why do the JUN cams break !!!
- engine and tranny swap
- All motor B16 ???
- total timing?
- where to buy LS/vtec oil plug????
- air intakes
- tuner shops near nashville
- GSR w/ls crank or LS/vtec
- Burns Header Pics, some stuff we have laying around
- where can i buy Rocket Motorsports valve springs.
- new motor or tranny..
- Uberdata .bin file request for NA B20/VTEC
- any guess...on whp b20b/itr head/skunk stage1 setup
- Best All Motor Cams????
- our H22a all motor dyno
- my b20vtec...results
- pr3 or p30 pistons for b16 all motor???
- B series shoot out question: GSR head? why? was it a rule?
- Utah Emissions Hookup?
- Ls/Vtec Exhaust Questions
- ls/vec HELP!!!!!
- Lsvtec(b16 crank,Gsr crank,ls crank)
- spun cam bearing journals on a head
- Puddle - 1, me - 0
- LS with ITB's
- I'm back
- Fake j's vs real j's vs Hondasport vs ebay power chamber.. on my 2.0ltr
- Anybody know anything about Ishino gaskets?
- What would be an ideal Clutch and Flywheel setup for 185-200hp?
- Tuned Results Of My ls/vtec setup 195whp 141tq
- Oil cooler 8-AN
- gsr cams in b16?
- BC Spec3's vs Rocket?
- Thinking about buy'n a fuel rail help me decide wich one PLEASE!!!!
- TRANNY QUESTION INSIDE!!!
- 3 inch exhuast
- bisimoto header
- Has anyone ever heard of this!
- H22A N/A engine building
- B16A 85 MM v B18C 84 MM need advice
- Best side exit header for a b series drag car?
- Innovate motorsports Wideband.. what do you think about it?
- Poorman's ITR, whcih ecu?
- What happens if you forgot O-ring on the center cam rail? What is the purpose? zero oil pressure...
- wrap it or sheild it?
- B16 SWAP- TOP END QUESTION
- ITR Pistons will work in a ls vtec motor? with b16a2 head?
- NOT SURe: All Motor???? hmm.. Q's
- Washed Out Rings.....Will my Cylinder Walls Survive??
- Engin?????
- h22 mounts for a DA
- Motor setup *cannot decide*
- Oil pump pics... 1500 miles spun rod bearing
- Is buying used pistons not a good idea?
- Im not getting spark..why?? :(
- On the right path?
- Best bolt-on header
- Ignition Red or white line?
- i have the opportunity to do something ...
- B20/Vtec Timming problem??
- what header do you sohc vtec guys running please post a review!
- High compression on stock head and fully built bottom end for b20 vtec
- Critic my setup
- Dynoed friend's GSR hatch
- JDM B18C, what cams
- type r upgrades
- H22 in Civic 1/4 Mile Times
- HELP ....'87 Civic 1.3 liter
- apexi 3in exhuast on my all motor?
- How can i fix this damn leak???
- Is my theory true/false?
- b16 CTR piston help
- b20Vtec suggestions.
- B16B Pistons
- High Comp. b20 pistons
- more pull at half throttle???
- Roller Rocker Cams from Crane for All Motor ?
- what is a fair price for this all motor car?
- Timing Belt Moves From Side To Side...
- Crank balanced and flywheel question
- WHO HAS SUCCESSFULLY USED OMNI'S METHOD... H22 LMAs IN A B-SERIES ENGINE?
- iacv fix for diy itbs?
- LOW PICK UP, RPM need help!!
- ctr / pct piston coating???
- Aftermath of a mis-shift :(.
- for everyone with ls/vtec
- what compression, and c-speed if not accurate.
- colder spark plugs
- my b18b with 404's dyno chart
- H22 Injectors
- I'm running ITB's and I need a better MAP signal...vacuum is so low......what do I do?
- Does anyone know how much?
- can i add a b20 crank to my b18 to make 2.0 liters
- Have Questions about ITB's, Originally Running Port Matched Skunk2 Manifold. Please Help ITB Guys!
- burning oil after 5000 miles on oem rebuild Please HElP
- distributor
- street vs track confusing
- steel maincaps
- Headwork info!
- DH-racing head
- Got my 404's!!
- cant figure out why I am burning oil!!!!
- Auto Tranny question
- help me out please.
- QUESTION SOHC ALL MOTOR BUILD!! HEEEEELPPPPP
- WTB: After market b20 pistons
- question about using skunk2 intake manifold from GSR --> ITR head
- b16 block 12:1 pistons
- ALL MOTOR b18b feedbacks??
- Type r internals into gsr block
- Head question.
- SOHC Allmotor build - Come in and give me some info!!!!
- omnipower or ???...
- ProStreetOnline.com OEM "Spec" Water Pumps... Anyone have any experience with them???
- Custom Header Design help
- B20vtec knock with low octane need Help figuring it out...
- Painting your block
- Dyno #'s from last night!!
- my new motor come see it-thoughts/opinions welcomed.
- Anyone use the MSD knock alert?
- NA Buildup Help
- why cant i post in the lower 2 sections?
- valve train noise
- crvtec questions?
- will a 99-00 b16 distributor work on a 95 gsr head?
- Opinions and or Alternatives to Hondata 3 step
- B series head work
- fuel pressure regulator
- wtf should i do?
- jun 3 cams ?
- over bore on a B20?
- vacuum hose
- Oil light on new swap semi built....
- Tecmo Bowl!
- oil pump part number
- Pros & Cons of H22 Swap
- throttle issues....
- locked distrubitor, now engine wont start??? help please?
- B20 Vtec ?
- anyone have a minor built b16?
- air/fuel R.? settings
- need help motor
- HELP PLEASE!!! my b16 wont turn over!!!
- Would you like a FREE iPod?!?!
- 226 whp/152 lb tq stock bottom end h22 dh-racing.com built
- Eristic gaskets?
- where to get .40 over size honda pistons
- HELP WITH ALL MOTOR LS
- NEED ADVICE ON WHAT ENGINE IS RELIABLE AND PARTS FOR 1994 EG
- Has anybody dynoed an an-r header?!?!
- overreved problems " need help"
- Low Idle Guru's please chip in !! ----- 94 GSR 200rpm idle? so low it will bog
- High idle on B18C swap & Code 9
- hondata datalogging and plx m-500
- cam vs valves
- how can u tell what typr r cams looks like ?
- ctr cam or port n polish?
- Need Headers for K20 in EK
- JDM B16A with JDM ITR cams
- need help rocket gurus....spring q?
- New motor in.......
- hondata?'s.....................................
- TWM ITB fitment issue on an H22
- need help, people who have h22 blueprinted
- Cat Cams
- Picked Up My H1 Engine From DFE Enterprises in Jacksonville, FL
- honda crx motor swap
- New Graphics All Motor SOHC
- What tranny oil do you all motor guys running 11's and 12's use?
- h22 head high compression head gasket
- Post pics of motor....THANKS
- New pic's of my ls/tec.
- My lsvtec setup, help needed
- Which company has the best head set-up for K20A (ITR)??
- GSR all motor
- need some advice
- D Series Internals
- bisimotor or an-r header...ready to buy but can't decide...head hurts! help!
- I having problem
- B18B1 Vtec
- RS has been sold
- o2 sensor working or not??????????/?//
- WHERE CAN I FIND CARSOUND DIRECT FIT HIGH FLOW CATS?!
- type r cams
- resognator or cat?
- 10000RPM
- b17 ls/vtec???
- GSR motor questions
- Finished N/A Project... Need Opinions
- for a SKUNK 2 INTAKE MANI SWAP.. do i need..
- b16 motor, how do i get rid of CEL 1 and 10?????
- block build?
- 200whp N/A B18B!?!
- torque specs on mini me
- 250 allmotor horses with direct port nitrous 80 shot
- i fugked up!!!
- Hot or Cold Plugs?
- IDENTIFY THIS LSD!!!
- My friend got a bizarre engine swap, questions about it
- GSR head on D16Z6 block
- which way does the clutch disc go? need help asap
- Guy making Formula 1 headers...very cool! (many pics)
- Eagle rod/ PR3 pistons combo question
- CTR cams to B16s - How much of a power loss?
- egt on b18c1
- is a 75 shot too high for 11.5:1 comp ??????????????????
- itr valvesprings...
- 85mm 13:1 street car
- SOHC question
- Pics of my new all motor header.... Clears AC!!!!!
- How to tell if I have an ITR manifold?
- ITR cams in B16A
- coolant seeping out of radiator cap after CTR pistons
- has anyone heard about leclerc motorsport in jersey city?
- Suzuki GSX-R Throttle bodies on my b16
- Unorthodox Ultra ss
- Aftermarket cams for h22a that can run on the standard valvetrain?
- simple lsvtec / ARP question... help needed
- Yes. Another buddy club thread. (Skunk2 Stage 2 /JUN 3 owners chime in)
- MSD 6A Ignition box.
- h23 buildup help?
- TODA Spec C's
- help!!! need help figuring out....
- headers and flywheel
- ZEX HELP???
- where to buy "1 layer" headgasket
- skunk2 stage1's vs. CTR cams
- obd2 prelude injectors for a obd1 z6 motor??
