PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 [137] 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Interested in a P8R..
  2. Old motor, new dyno.
  3. LS VTEC no leaks, HG issues, etc.
  4. What set-up...
  5. check engine light
  6. H22 need help
  7. Valve Spring Question
  8. Can this be fixed...?
  9. MSD question for everyH-Tbody
  10. would a header really make a difference?
  11. 82mm high comp b18c5
  12. USDM B18c1 vs JDM B18c1 ... Differences ?
  13. Recommend me a catalytic converter?
  14. Which cams to use?
  15. ITR pistons and skunk stage 2 cams? over camming?
  16. one layer headgasket????
  17. i need hondata kit for s300
  18. new performance ecu throwing codes #21 and #9
  19. Will it work? B16A2 with OS CTR pistons with RM M22 camshafts
  20. ignition set ups.
  21. b16 pistons (p30) in stock gsr
  22. H22 header question
  23. OEM ITR muffler to restrictive?
  24. Safest and best way to raise compression?
  25. Opinion on C5 build
  26. Dyno of SMSP D16 Street Car
  27. Tips on DIY crank polishing?
  28. k20 question
  29. ls/vtec plugs
  30. GSR pistons for LSVTEC?
  31. Compression for GSR block with B16 Head
  32. shot-peened rods???
  33. difference in a saturated and nonsaturated rc injectors????
  34. How many adjust belt after startup? PICS of cam gears, decked block...
  35. Modify H22A Intake manifold for more power!?
  36. what to do next ?
  37. ACL bearings buy or not
  38. acl bearins buy or not
  39. stock bottom end ls vtec
  40. itb question
  41. fuel injector for 11:5.1 compression ratio
  42. camshaft upgrade b16a2 head
  43. Advice? when tuning with S300 H22/Civic
  44. a knocking noise from my LS block
  45. How does a bump in compression affect your tune?
  46. Dyno of Stock JDM ITR EG Track Car
  47. what ecu should i get
  48. Few questions from an ITB n00b
  49. help with bearing selection for b18b
  50. Need help. Tuning Question
  51. "New" Crower K20 and K24 stroker kits.
  52. Are b17 GSR pistons any good?
  53. best place to get a 2 layer head gasket?????
  54. Cam Question
  55. New to this stuff... B series questions... and d- for effort
  56. B18a Block, B16 head.. ARP Head studs... help
  57. looking for a new header
  58. knife edgeing
  59. B20 block, reliable for road racing ??need info plz
  60. why is my gearing so long? or seem like it anyways? (vid inside)
  61. new motor build... a little help please?
  62. Built K20z3 330whp!
  63. what else do I need for my all motor set up
  64. b16a1 headgasket problem
  65. FULLY BUILT GSR 0R LSVTEC FOR THE STREET
  66. lsvtec help......
  67. which header for my NA engine
  68. Question about fuel pump?
  69. lma installation
  70. don't know what to do????
  71. WANTED: Quieter exhaust
  72. Triad SBC Race Spec Header Prototype
  73. LSVTEC BUILD coming together Looking for specific Answers. HELP!
  74. DIY ITB ?? gsxr 1000 or honda cbr 929's?
  75. oil pump playing games?
  76. is NOSing on a high compression motor be safe and on 91 octane
  77. WHICH CAMS ARE THE BEST FOR AN ALL MOTOR CAR
  78. norcal tuners??
  79. cylinder head going sonic
  80. skunk2 pro series or blox intake manifold which is better
  81. H2B questions?
  82. lsvtec build question need advice please
  83. All you pro"S help me out
  84. looking for some darton or eagle sleeve
  85. larger injector?
  86. lsd
  87. Saturated injectors ?
  88. rpm problems has anyone ever had this problem?? h-t help me..
  89. Exedy stage 2 clutch kit or ACT 6 puck kit ---- Adding lsd with this set up
  90. ctr pistons on stock b16a2 rods
  91. to/not buy the pro series throttle body?
  92. Euro-R IM porting advice needed
  93. Skunk2 70mm TB
  94. pro2 cams in B16a?
  95. difference btw gsr and itr head
  96. B18B
  97. Safe RPM with b16a2 stock bottom end
  98. Good tuners in portland?
  99. High compression on more boost for overall efficiency (gas mileage mpg)
  100. what do you guys think?
  101. Panek's Video of a light LS/V
  102. Finally a Slider plate for Our 1020 flowbench!
  103. B16a Mild Build OPINIONS?
  104. rod knock for first couple of seconds at startup? thin oil?
  105. Can my Head be SAVED?????????
  106. head setup question
  107. DTR HEADER BEFORE AND AFTER AT LDL. DYNO AND VIDEO INSIDE
  108. help on b20vtec header
  109. who can burn me custom chip
  110. Lets see a tread of a Crower Cam installation......
  111. LsVtec
  112. Dart Head
  113. head job price
  114. tapping from ITR valve train, possible LMA???
  115. SSR Engineering 4-1 Street Sweeper (No need to decide)
  116. knocking noise
  117. Portflow Inners
  118. thinking of building a stroker motor? any suggestions? need help
  119. head gasket question on my ls vtec setup
  120. Change injectors on an lsvtec? yay or nay
  121. most power from unported head.
  122. Skunk2 stage 1 degree numbers
  123. Custom Car Care(Yorktown, VA) anyone been tuned there?
  124. where to get a skunk2 65mm throttle body?
  125. which is better
  126. Video, my NA hatch.
  127. Highend Header Videos (you decide)
  128. d16 main studs?
  129. ITR intake manifold B16A1
  130. TODA Valvetrain questions and concerns...
  131. CTR STD BORE PISTON fitting on B16a Connecting Rods
  132. Alaniz or Portflow
  133. LS/vtec build
  134. B20 into a 92 hatch.
  135. TODA Valvetrain questions and concerns...
  136. My New Intake Featuring Turbohoses V-Stack
  137. Are 13.90's possible with my setup?
  138. d16y7 manual ecu... how much will this run me?
  139. CTR Pistons clear my B17?
  140. Need feed back on b16 motor build.
  141. Valve Adjustment Help / Anyone ..?
  142. valvetrain concerns
  143. Custom Exhaust pipes
  144. Best Cams For All Motor Setup Along With Camshafts
  145. what water pump will fit my b16
  146. Cam storage?
  147. most agressive cams on stock block ls/vtec
  148. Raising compression...
  149. B20B p75 head maximum mil?
  150. what is this
  151. Did some combustion chamber machining -- What do you think?
  152. b16a2/b18c1 no spark
  153. B18c5 How much power
  154. LSD from EK9 will fit ??
  155. zex cam timing issue with obd0 dizzy.
  156. Lost Motion Assemblies/B16A/CTR camshafts
  157. i need help buildin a motor for this season, rlz,tbone, any allmotor gurus
  158. Flow charts for a couple of heads.
  159. AME cam gear adjustment.....
  160. Tranny problem...
  161. Will an aftermarket header for a d16y8 fit on a d16y7?
  162. first lsvtec build tell me what u think
  163. B20Vtec build, pics video's comments welcomed...
  164. CAM POLL in a stock ITR !!!!!
  165. 600RR ITB'S ON MINI ME
  166. Do you think i got jipped
  167. GSR Build - Piston to valve clearance?
  168. K&N replacemnt filter for password jdm intake.
  169. Got my car dyno'ed not very impressed: (
  170. Throtle body
  171. no spark after engine swap
  172. timin belt
  173. Built Kseries pricing ?s ...
  174. NON-Vtec B18B Dyno (Integra GS 96')
  175. dualpoint to multipoint conversion
  176. USDM ITR gear ratios?
  177. Quarter Sports H2B Kit
  178. 11.58@116mph all motor no stroke
  179. only have 1 ctr cam?
  180. JDM 4-1 Header...Will RSX doughnut work?
  181. CMI Jan 7-8 2006
  182. block posting in sohc
  183. $15,000 Setup
  184. motor problems -- snapped timing belt, oil in spark plug hole
  185. Weird cam/ignition timing problem on lsvtec
  186. Will a 95 gsr distributor work...
  187. Fuel pressure regulator PSI
  188. 190 lph or 255 lph walbro fuel pump
  189. Random hesitation/bogging....any ideas what I should be looking at first?
  190. d15 piston direction
  191. harness question(need a fast answer plz
  192. I hate my D15B7
  193. fuel system problem b16A/B18c1
  194. Micropolishing Crank?
  195. d15z1 & p28?
  196. Euro R ITB's?
  197. B&M fpr issues I think give your opinions
  198. ACCEL SPARK PLUGS.........
  199. am i missing anything else..mild b16 setup.
  200. Part number needed
  201. clutch problems
  202. How do I install a preformance crank pulley on my 2001 Civic EX.
  203. Cam Gears Poll
  204. Race Car on Stand Alone. Do I need stock wire harness?
  205. LS VTEC ARP ROD BOLTS N ARP HEAD BOLTS
  206. 98 Hatch w/ H22...HELP!!!!!!!!!!!
  207. q about 4-2-1, 2.5" collector header
  208. Buddy Club Spec IV's on ITR valve train
  209. DIY port and polish
  210. Anyone hear from Joe @ Prototype Racing???
  211. VP Racing fuels
  212. honda cbr 954 RR vacuum diagram for diy itb
  213. which crank
  214. *PIC* Which car are these motor mounts for?
  215. F series guru's, specs needed
  216. d16z6=d15b7?
  217. B16a Skunk2 Stage2 Dynojet Results
  218. 2 monsters.....
  219. ITR pistons in GSR Compression??
  220. B18C1 WHP on itb setup???
  221. CEL and cold air intake..how to solve it?
  222. Why is my car burning oil?
  223. What kind of #'s can i look forward to on this mild all motor build? B18c5
  224. choosing the best cam
  225. b20b or b20z
  226. Ls V-Tech Questions
  227. b18c5 build questions
  228. What size of exhaust for b16
  229. overheating problems in my b20 stoker kit motor need help baaaaaaaaadddddd
  230. ctr pistons or itr piston on a b16a2
  231. K20A2 Dyno (dropping vtec)
  232. Help me Diagnose the Problem b4 I pull the head
  233. 300 Cell Spun Metal Substrate Converter w/2200 Degree Matting from SMSP... anyone using them?
  234. 97 usdm ITR cams vs JDM 98 spec ITR cams
  235. Which head gasket?
  236. lsvtec timing belt question
  237. Website to buy crate motor?
  238. Toda head questions
  239. LS/VTEC
  240. help identifying prelude injectors
  241. h22 in my civic not sure?help me
  242. Buddy Club 4s?
  243. Tall block
  244. Best P&P Company Out In U.S
  245. Jun3 Valve Spring Height
  246. 72 mm tb too big?
  247. what RPM is safe on stock ITR bottom end?
  248. Crespocams Stage 3 B SERIES DOHC VTEC CAMSHAFTS any body try it b4?
  249. 92 Civic Engine
  250. How much more power to expect from a port n polish?
