Replacement K24A1 VTC Actuator question
Replacement VTC actuator for K24A1 has changed from 25 degrees to 50 degrees. I am concerned this will cause issues? CRV 2.4 RD7
re: Replacement K24A1 VTC Actuator question
Why ??? If you don't command greater than 25 degrees, you don't get more than 25 degrees. No issues.
Re: Replacement K24A1 VTC Actuator question
OK great thanks. I wasn't clear on how the command works. Sounds like a feedback loop between the solenoid command and the cam position sensor then?
badboyr66
18
05-07-2008 02:53 PM
blufke
04-18-2003 02:00 PM
