PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 [157] 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. does anyone have a turbonator
  2. best catback for b16 ef hatch
  3. Opinions on shop? in MAINE. spindler performance center.
  4. b20vtec
  5. 310cc P&H inj & 255lph fuel pump install. Will stock motor run normally?
  6. B16 tranny w/out lsd question???? need pro help
  7. Does it worth to port & polish an ITR Manifold??
  8. numbers?
  9. i wanna go all motor but i have a couple of questions first?
  10. 81mm JE pistons in b16a2 block?
  11. Rod Stretch
  12. tuning?? semi built b18c1
  13. injector choice to go with?
  14. how many valve springs are in a DOHC and SOHC?
  15. Stainless narrow RMF with a little BLING
  16. ctr pistons & Buddy Club spec 3+ cams?
  17. "Already Searched" Any dyno charts for B18c blocks with P30 SirII pistons
  18. VAFC piggyback chipped p28?
  19. b18cR+pr3,p30 cr??
  20. all motor build
  21. will a neptune ready ecu run a kenji chip or similar?
  22. Tuning questions
  23. Georgia machine shops, who are you using?
  24. loss of power: ls/vtec
  25. Selling Comptech Long Tube Header!!
  26. TODA B CAMSHAFTS FOR B16A
  27. Im interested in doing an h22a swap.. need help
  28. need help asap????
  29. throttle body problems hi fluctuating idle help
  30. Fully Built H series with GSR tranny vs. Fully Built B series
  31. ls/vtec Question
  32. Whats everyone think of Rocket Motorsports??
  33. type r header on b16 help???!!!
  34. pr3???
  35. B20vtec dyno - this can't be right, what's wrong?
  36. Help me out here guys!(what mod(s) to do next.
  37. Decision help!!!
  38. Next Mod for All-Motor... advice needed
  39. megasquirt standalone
  40. Which ITB is best for DIY ITB on a 2.0L B series Vtec Hayabusa? CBR?
  41. JUN STROKER MOTOR ISSUSES
  42. Quick ? about cam/ignition timing HELP!
  43. Throttle cable bracket?!?!?!?!
  44. GSR motor question
  45. Help: Symtoms of a bad pcv...
  46. last time guys im almost done wit my setup b20/vtec in dc
  47. Help ID these ITB Filters.
  48. Need help getting crank pulley bolt off....
  49. Does ARP make main studs for b18a/b
  50. So many intake manifolds, so few cars......Help me pick an IM for my H22!
  51. dissappointing day at dyno
  52. Blown 50a ignition fuse
  53. H22 OEM Valve Question
  54. anr header with air conditioning?
  55. Injector cleaning
  56. motor acting up??
  57. Toda vs DTR
  58. lsvtec tming belt?
  59. Help me out here guys, I need some help finding out which car to get..
  60. cleaning carbon build up
  61. best b series head period end of story
  62. compression calculator
  63. b16 block what crank
  64. Bogging on first start up of the day
  65. Hondata S100 question...
  66. b18c all motor build up question
  67. aem itr intake in ef
  68. Running a z6 or y8 with Crower stage 1/zex59100? post thoughts.
  69. what oem intake works on Victor X manifold?
  70. new or used header
  71. Headgasket? How to tell if its blown
  72. Toda vtec killer for road racing??
  73. Question on Tuning Devices!
  74. Looking for some ideas - SAFELY higher reving ZC - any ideas?
  75. Possible Detonation, Help
  76. Dynotuners... chime in on my dyno..
  77. *Project* All Motor Ls/Vtec
  78. Where to buy rocket motorsports valve springs?
  79. need help asap!!!
  80. My all motor set up
  81. Tuning with different exhaust question...
  82. Dented Header Hurt Performance??
  83. all motor dc5's
  84. piston ring installation ?
  85. anybody use the new narrow style rmf header from import power house
  86. CTR cams or skunk2 stage 1?
  87. Stock 2.0 Litre PGM-FI Engine Mods for Horsepower
  88. Who other than pro drive/circuit worx makes stronger oil pump gears for the H?
  89. Re-seating valves
  90. Header question(gurus welcome)
  91. Need B16A Exhaust Cam...
  92. HEADER HELP!!!
  93. Just got my motor built
  94. compression test
  95. Golden Eagle Main Girdle Kit?!?!?! Worth it???
  96. rc injector trouble help!
  97. b16a1 block bored out to 85mm..whats the perfect head?
  98. Need Help Please, head gasket leak.....AGAIN!!
  99. who has had luck getting the skunk2 pro1's to idle like stock
  100. ITR parts question with LSVTEC build up?
  101. Help me i think i blew my motor!!
  102. Difference between OEM honda bearings or Aftermarket ex.(ACL)
  103. ran my gsr hatch
  104. Individual filters (paper or foam) for ITBs?
  105. How to get ahold of Jerry Built?
  106. what is a cheap valve train upgrade??
  107. any good machine shops in the bay area?
  108. jg manifold throttle cable trouble??
  109. How do you regulate the idle on the ITBs?
  110. Skunk2 Pro 1 vs Rocket M22
  111. Untune mild built Ls/vtec dyno at 164.2 whp
  112. what cams are making the most power for b16a?
  113. glitter...normal in oil???
  114. b18c1 W/ DTR headers..what exaust?
  115. camshaft gurus please read this...Tried search sleepless nights
  116. Looking for header dimensions...fabricating a header?
  117. Need some input nitrous people !!!
  118. all motor ls or b20
  119. Car not starting ...please help
  120. Comptech Long Tube Header Adapter?!?
  121. D16A6 vs SOHC ZC
  122. Anyone using EGT gauges????
  123. lsvtec cams
  124. What type of cams for my setup?
  125. Headers
  126. GSX-R ITB on bone stock B18c1 motor and significant hp gains?
  127. just wondering
  128. ** MY DYNO SESSION @ CHURCH AUTOMOTIVE TUNING**
  129. b20vtec or lsvtec
  130. Hondata gains for b20 with P8R and Crowers
  131. D17 Crank Thread
  132. claying motor for clearance
  133. problem with n/a b18c
  134. ?? on my break in so far
  135. what cams can i use WITHOUT after market valve train??
  136. SMSP Spec Z10 Oil Pan
  137. Machining head for LS-V?
  138. Need help with b20vtec cutting out
  139. ITR 4.75 Final drive really worth it?
  140. TECH43 pistons...reliable???
  141. VTEC questions from a noob
  142. need pics of header differences
  143. Which head is better and why?
  144. Quick question? Missing nipple on thermostate housing. It's in manual??
  145. Skunk2 Manifold Inlet Size?
  146. spoon stroker
  147. Tranny Setup for 250+whp?
  148. HAS ANYONE RAN THIS SET UP BEFORE?
  149. itbs and hondata gasket
  150. stock obd2 gsr cams vs obd0 b16a cams
  151. motor assembly in general...
  152. all motor sleeves
  153. STR Throttle Body (What goes here???)
  154. b20vtec question
  155. itr pistons worth the trouble?
  156. power chamber carbon fiber intake
  157. Shot Pein Rods vs. Eagle Rods
  158. best intake manifold for all motor lsvtec
  159. hondata w/ obd2?.....auto wiring harness question
  160. valves and compression question
  161. endyn cams?
  162. aeromotive fuel pump controller problem
  163. b16 head toothpick-sized sensor....
  164. Whats wrong with this?
  165. GSR motor , stock gsr cams, stock gsr ecu 181 whp 129 torque.. dyno vids etc..
  166. Engined Flooded
  167. 1.5l cx motor head torque down measurements needed ASAP
  168. What cams for my motor? ...can't decide
  169. B20vtec...Cutting Valve relief and Cam options.
  170. is skunk2 coming out with skunk pro-2's???
  171. obd0 b16 head gsr block... help...
  172. JUN K-series products
  173. skunk 2 stage 3 cams
  174. AEBS gsr manifold?
  175. hesitation question
  176. Cam question
  177. b16 p30 / B18b LS / VTEC head gasket...
  178. Can YOU Identify these cam gears?
  179. fully built head....now weird vtec problem
  180. Who in maryland rebuilds, tranny, engine, etc??
  181. ctr n1 pulley alterative
  182. GSR block, b16a head, and b16a pistons... should i put skunk2 stage1??
  183. Difference in Rocket m22xx and m22x cams?
  184. C/ R question on LSVTEC build up?
  185. header
  186. Best header to run on my setup?
  187. Best Way to get My Block CLEAN!!
  188. what cam to use. b18b
  189. car runs sluggish when hot
  190. Header Help Please
  191. skunk 2 intake manifold
  192. Hytec headers?
  193. K-series: ERL Performance Inc.'s K24 Superdeck blocks, 89mm & 90mm
  194. 85 mm forged pistons?
  195. K-series: Portflow valve job/bowlwork
  196. whats the torque spec on ARP rod bolts for Ls/vtec?
  197. K-series: Hayward Performance "Street" 54mm ITB's
  198. what berings
  199. B20VTEC guys, need YOUR advice and experience!!
  200. ls springs and retainers
  201. which 4-1 fits ef ?
  202. AEBS manifold, Bracket modding?
  203. who all uses chrome
  204. Im looking for a ITr crankshaft
  205. b-series tranny on h22 motor...
  206. Building my LSVTEC, Bored or Honed?
  207. need help wiring v-tec to 89 civic si b16a
  208. 200whp B18B Needs Help
  209. Nitrous....Bad or Good
  210. Need help with ACL part numbers (H22A4 main/rod bearings)
  211. d15 build
  212. is it easy to replace rod bolts with the engine in the car.
  213. .::need to get new plug wires??::.
  214. knock sensor for B20VTEC help?
  215. is it safe to run .25 over in 12.5.1cp ls block
  216. spining a bearing?
  217. surface rust on rods
  218. Raising redline?
  219. what is stock bore on a b18a crank?
  220. 84mm bore on a lsvtec
  221. b18 gen 1 motor in obd2 car???? easy question, plz help
  222. Ideal CR to run with skunk2 pro 1's?
  223. 11.6 comporession and reformulated pump gas in WI?
  224. crower stage3 and compression
  225. Lightweight Non Adjustable Cam Gears B Series. Anyone Interested?
  226. timing belt help
  227. recommend some trustworthy places to buy ustom built shortblocks from please..
  228. Ran my stock B18C in an EJ1 (had to before the modding starts)
  229. what should i buy for my b16
  230. Choosing the right bearing for a motor??????
  231. any cam recomendations for this setup?
  232. air filter for j's racing intake apexi's
  233. K-series Cunningham Rods: Assorted c-c lengths, non-ultralight
  234. intake main????
  235. can some1 help!!!!!!! radiator? which to power a 11.6-1 compression
  236. honda accord software
  237. What size collector will good for light tuned engine??
  238. specv's on portflows.
  239. cheap header??
  240. did a compression test, wondering about my results
  241. stock ls rods with arp rod bolts
  242. Ls Oil Pump?
  243. Having second thoughs need some opinions...........
  244. Ultra Bling Header Made by Randy Monroe (RMF)
  245. valvetrain and cam how to???
  246. No cel and no vtec on a minime?!!?!?!
  247. anyone know the guy who made this intake mani?
  248. lsvtec..wut rpms??
  249. Really need help with ignition, engine gurus needed.
  250. what do you guys think
