PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 [227] 228 229 230 231 232
  1. Installing seals
  2. HELP PLEASE Blown head gasket
  3. header gaskets...5th gen accord
  4. Need D16 help.
  5. Please take these Skunk 2 cams off of my hands!!!
  6. Best Header for H22
  7. What's The Best Price For CTR and ITR Pistons?
  8. prelude TB on b-series manifolds
  9. stand alone tuners in washington state
  10. d16z6 with headword and cams, can the stock bottom end handle an 8k redline?
  11. How to identify OBD2-OBD1 adapter harness?
  12. Where can I get the dowel pin conversion on B20B-vtec?
  13. who likes they're TODA cams?
  14. Grinding down intake valve guides
  15. went with skunk2 "stage 3 cams" for my built b20/vtec (did i made the right move)
  16. Computer adjusting, and emmission removal for full race car
  17. just ain't makin power w/ jun 3's...
  18. All motor street car build up...56k beware
  19. quick injector question
  20. all-mota engine rebuild..what parts to replace..
  21. JUN or TODA? which one makes more power??
  22. People using Ericks Racing throttle body
  23. K Motor Cams - Valve Lift?
  24. who has tuned with AEM - EMS opinions
  25. Cam Gear holder > where?
  26. Can i switch back to an NA setup
  27. Toda D's Revisited.........
  28. W2B 94-95 LS wiring harness
  29. Vote For the best Brand-Craziest All motor Cams Ever..
  30. Honda CRV missing at start
  31. Clearance issues with ctr pistons and jun 3?
  32. Need help mounting CTR pistons onto LS Rods
  33. L'Natural Drag CRX for sale!!!!
  34. name the best 14:1 pistons for built motor
  35. B20 Sleeving
  36. Updated pics of my (modified Euro-R h22a manifold) (h22a Dialup users worth it)
  37. power gain with type R head?
  38. distributer jdm b16a
  39. Keep my Sotck USDM GSR or Go B20 VTEC?
  40. Type R motor in a 94 civic...Civic or Type R exhaust???
  41. wut u gusy think of Venom Adj. cams?
  42. n00b question about poor mans R
  43. gauges for ALL MOTOR
  44. crank pulley help, suggestions?
  45. K20 or stay B series
  46. Ericks TB
  47. 11.5:1 with crower stage 2 N b20 vtec
  48. Is this set up good for my 99 civic si
  49. best cams for b series
  50. What fuelpump/injectors should i run on my setup?
  51. what mod should i do next?
  52. all motor drag numbers please analize..
  53. what do you guys think of milling cylinder heads?
  54. B-series with 95mm Eagle crank
  55. Erick's racing motors
  56. Race gas
  57. Best Speed Shop
  58. Endyn's products and work
  59. H22A cam retainers/caps torque specs??
  60. My tuned GSR motor, 181.8/131.2.
  61. My Combo...what kinda of times???
  62. questions on cams gears on stock cams........questions
  63. Got my danny tran race header today!!!
  64. my possible setup plus vafc ?***
  65. GSR cams vs ITR cams??
  66. Honda Civic CAMS, SHAFTS........
  67. my ericks racing header cracked!!!
  68. Does anyone sell P&P heads???? ITR/B16 to be exact
  69. Cold air intake or new exaust system?
  70. Timing advance?
  71. b16 w/ ctr pistons...valve clearance?
  72. how about injectors?
  73. pics of my DTR side exit h22 header
  74. race rules
  75. D16Z6 questions
  76. SDS anyone running it?
  77. AN LS VTEC SHOPPING LIST WOULD HELP ME OUT GIVE ME YOUR OPINIONS ON WHAT TO BUY FOR IT.
  78. some good all motor h22 cam specs
  79. my b18c 88hatch so far...
  80. B20VTEC or LSVTEC????
  81. Opinions on friends "interesting" setup
  82. Difference between B18 and B20 cylinder head?
  83. stock b16a whats the fastest time in the quarter for this motor .
  84. Gas Ported pistons, Ring seal longevity??
  85. all-motor a6
  86. to use possibly "damaged" cams
  87. 1st engine build...
  88. Specs please???
  89. What would you do...all motor vs turbo(not a newb ?)
  90. Rockers hitting tops of retainers...
  91. How much could i sell each of these for
  92. How long does it take to break in a d16?
  93. Cam compatibility website?...
  94. ?????
  95. cr-vtec, ls-vtec, or just gsr
  96. b16a1 in a 88 crx (type r cams)
  97. info on Edelbrock 75mm TB??
  98. ls or lsvtec
  99. deck plate
  100. considering headers for jdm h22accord what headers should i look for
  101. electronic cut-out
  102. H22A (STR) intake manifold
  103. Question about Engine Management + My Goals
  104. All motor crx (what engine, what parts?)
  105. To Port or not to port............need opinions............
  106. Motor Mounts & Axles? ....all motor issues
  107. b16 pistons
  108. check this shit out all motor car try's to run pro front wheel drive
  109. gsr tranny or b16 tranny on a b20 vtec???
  110. SEARCH... callin all mods
  111. Just a Fun Topic...How much money in your motor?
  112. j-spec gsr or ITR motor...
  113. "Flash marks" - carbon tracking affecting spark
  114. b16 questions (weird situation)
  115. safe bore on ls vtec
  116. where do i find an ''Ultra's'' MDI (distributorless ignition)
  117. What valvetrain to run in b18 ?
  118. edelbrock on ls/vtec
  119. LMA's..........yeah?
  120. Honda N1 Crank Pulley
  121. Run stock valves with Skunk2 Stage 2 cams, skunk retainers and springs?
  122. skunk 2 h22?
  123. 93 octane in 12:1 LS/VTEC
  124. Big bore throttle body problem?
  125. Ls/Vtec build
  126. stock b16a with bolt ons and ericks racing ecu
  127. anyone have info on Brad Z/wiseco pistons?
  128. Portflow springs vs. Toda springs for TODA B cams...
  129. 12.0+ Compression Ratio
  130. Deck Heights
  131. port/polished B18c1 head VS. port/polished B16/B18c5 head
  132. anyone running non-vtec?
  133. Cam timing
  134. problems with set up. ctr cams pistons in b16....
  135. JG 301 cams???
  136. Questions about CR/cams/milled head/headgasket
  137. Ordered my pistons!
  138. who in here went to las vegas??
  139. B16B or Built B18C?
  140. Help need EG with H-22 motor Nor-Cal.
  141. Ported intake mani - or - Aftermarket
  142. Relyability B20/LS-Vtec/B18c?
  143. Skunk Stage 3's Daily Driver
  144. all motor crankshaft
  145. Dual DCOE's
  146. Lets name all 11 second all motor street cars!!!
  147. H22a power beyond 7500 RPM
  148. Valves clearance?
  149. Anyone know where I can buy just a short block?
  150. Cranked new motor for the first time, oil pressure ???
  151. guesstimate for my dyno numbers ls-vtec
  152. what ecu
  153. what kind of motor...?
  154. Places to buy swaps
  155. ls/v-tec rods
  156. B18A1 84mm LS/VTEC Bottom end build???
  157. Anyone ever used KMS titanium retainers?
  158. Hondata troubleshooting
  159. I am sticking with my D16a6 SOHC No VTEC, Mods gettiing done, What else while it's apart?
  160. :thumbup: Golden Eagle and my B20VTEC
  161. How BIG is TOO BIG? ** T/B discussion. **
  162. b18c dyno numbers
  163. you guys see that ef-1 stuff ?
  164. What kind of spark plug wires
  165. Running GSR pistons with ITR head and intake manifold
  166. Bore b18b to b20 size?????
  167. my allmotor car failed emissions!
  168. ls rebuild
  169. LS/Vtec Help
  170. Engine building/tuning pros, which is better to build for, hp or tq?
  171. ? on a frank motor
  172. The definitive CRVTEC thread
  173. B18 to b16 swap!!! Think it worthed the job??? tips??
  174. Realistically speaking, what would a GSR put out at the wheels with...
  175. Cat Cams
  176. Weight of a 1989 crx si
  177. ? about racing slicks
  178. p72 or p28 with hondata for all motor
  179. need some ideas and advice...........
  180. all-motor newbie question
  181. My dyno
  182. VALVE ADJUSTMENT
  183. Horsepower needed for HIGH 12's?
  184. i tried a serch couldnt find it...
  185. Where to get head work in Northern VA?
  186. Will a 95 gsr head work on my car?
  187. When is a car all-motor?
  188. Adapter Plates for Toyota ITBs to B-series Heads (interests ?) ...
  189. CTR Cams in a b20vtec (b20b block + b16a2), will the valves clear the pistons?
  190. everybodies opinion, whats better to start with...........
  191. could I reach my HP goal?
  192. 1.6 liter.
  193. Bigger Injectors + VAFC = Good Idea?
  194. just picked up a b18c, ready for rebuild
  195. Looking for speed
  196. Heres my set-up.. What size exhaust?!
  197. 2.0 Allmotor BABY!!
  198. ls vs. gsr crank
  199. Cam Gears
  200. how do u convert OBD 0 to OBD 1??
  201. Valve/piston clearence problems?
  202. Toda spring and Jun Retainers???
  203. JUN 4s?
  204. h23 crank
  205. ITR pistons in b18c1
  206. DECKPLATE!!!
  207. Just a quick question on arp rod bolts
  208. motor output
  209. Went 14.8 @ 94, are 13's possible with slicks + traction bars (jimfab)?
  210. i have a stock integra ls... thinking of doing Ls/vtec
  211. HELP: MOTORBUILDERS!!!!! NEED HELP WITH HIGH B16 PISTON/HEAD CLEARANCE
  212. LS Crank in a B18C Block
  213. Stumbles through Vtec X-over when warm. LONG
  214. dyno day tomorrow
  215. TODA or J's Racing Header for B18C5
  216. how much would port and polish a b16a head cost?
  217. Apexi GT Spec header?
  218. B18C in japan type-r engine?
  219. ls ecu??
  220. My Dyno #'s...
  221. Piston to valve clearance: Ctr pistons & skunk2 stage 3 cams in a gsr motor
  222. The Great LMA Debate: GSR v. ITR
  223. Max power with bolt-ons with stock B16 cams?
  224. NHRA new all motor rules
  225. Need a new ecu
  226. Slight rust on used crower springs....
  227. on the nineth run it said caboom
  228. FS: Rota Wheels
  229. d series cam question-some tech kinda
  230. EF-1
  231. OEM LSD?
  232. do I need different valve springs and retainers for ctr and itr cams?
  233. Opionions welcomed; My new setup going in soon
  234. NOObe crank ?
  235. where to buy NEW LS pistons
  236. SMSP HEADER
  237. biggest bore highest compression on pump gas?????
  238. went is a 3' piping n exhaust needed ?
  239. Upgrade paths for 13's (b16)
  240. all motor ls/vtec questions
  241. Stock GSR Valves With Skunk2 Stage 2's?
  242. How many guys fabricated there own headers.
  243. 2.5" Exhaust VERSUS 2.25" Exhaust
  244. Head work?
  245. how can i check if my oil pump is still good?
  246. 97 GSR for sale
  247. any experience wtih bullfrog cams?
  248. Anyone know if the place racing mounts for the DA are out?
  249. want to buy a dtr header for b16a3
  250. How do I properly advance my timing via the DC? 4th gen Accord F22A6
