- B20 doesnt start!?!?!? need help!!
- prototype racing
- Is These Skunk2 Stage2 Cams?
- rebuilding short block
- how to spot genuine skunk2 cams?
- crower cams???? how do they compare
- Throttle body on a b16
- quick question
- 1.6 or 1.8 What would be the difference
- final b18c build: BC4's, CTR pistons, PR3 head
- NEED DIY TIMING BELT, Drive Belt D16y8 Change
- Rod Bearing Question
- head porting
- Engine Block Question
- side exit header question
- cam question
- motor fired up on first try - running rich
- are stock injectors fine for 220 whp
- VAFC PROBLEM, something with TPS?
- This is TURBODEEZ with a serious prob on the D
- how can I get more power without upgrading internals on 99 gsr hatch?
- skunk 2 intake manifold idles at 4000
- Fuel For Skunk 2 Stage 2 Cams???
- gsr vs b16 cams
- Enine Swaps?
- will a mr gasket head 82 bore gasket fit a stock 99 gsr?
- baseline dyno and looking for vafc tuning results...
- noob question
- Opinion Needed on Sleeving. Please
- b16 all motor build
- HELP, choosing between b16 or b18c1 head!?
- black spots on rear bumper
- My dyno...not sure if I should be impress.
- Uberdata
- F***ing Axles!!!!! Need help ASAP!!!
- oil sucked into intake manifold from pcv line?
- h22 crower 3 (search not working sorry)
- falling on its face
- quick question
- any one know of a fake Mugen intake box?
- Sweet vid
- 1985 HONDA CRX DX
- CTR motor question
- smoke? white probably from exhaust
- Can you put an F20C head onto an F23 block?
- HONDA CIVIC 04 EX Electronic problems because of CAI
- B16 tranny question?
- My 2000 B16A2 dyno
- what header...and still have ac?
- Removing Oil Squirters -- b18c1
- VTEC is dropping!
- All motor B16, dyno result !!!
- ITR AEM CAI on EG with ITR swap??
- b16b amd '89 acura integra
- Intake on a LS/VTEC?
- obd1 intake manifold on obd0 head????
- hey ne one give me more detail on the poor mans R?
- Supertech springs and skunk2 pro 1?
- blox IM/ rc injector problem
- 230psi on all 4 cylanders!!!????
- CTR intake cam hp question
- anyone using skunk 2 pro 2+ cams
- adjustable secondaries on sms header?
- b18c1 Eagle Rods ITR pistons.....which pistons??????
- My new block RS MACHINES
- Anybody running Skunk2 pro 1 on stock GSR comp?
- Toda Spec C upgrade
- Head Gasket Question?
- mad mileage on b16 safe to have a p&p head?
- Ferrea sodium filled valves aka hollow stem valves
- "Off the shelf project"...222whp 155wtq....Inline Racing
- ys1 and s1 tranny question
- built stroked gsr /shift point?
- What other head gasket fits 99 gsr?
- which cams should i use in my all motor set up jun or endyn...
- nippon pistons
- individual throttle bodies for b18c???
- NOSing gsr
- What will I put down......
- d16z6 ALL MOTOR< IS IT WORTH IT
- Need Advice on buliding LS/Vtec
- skunk pro 1 manifold VS. normal skunk manifold(dyno numbers)
- P30 pistons?
- turbo to all motor
- Header selection
- Rod question
- Heavily street-tuned B20VTEC engine - need some advice
- skunk2 valvetrain... good or bad??
- B20 Intake Manifolds: any dyno tests on both stock types???
- I HAVE AN ALL MOTOR QUESTION
- installed fuel rail and fuel pressure regulator HELP!!!!!!!!!!!
- HELP: Jun stage 1
- valve clearance?
- Injector size w/ SKUNK2 PRO1?
- civic type R compression
- itr pistons in a b18a1
- Port & Polished GSR b18c1 Head with Full Crower Valve Train... Need Suggestions once Again!
- ls vtec with ctr pistons: Valve Clearence with Buddy club 5's
- JDM H22 CRX looking for a little bit more power from the NA gods!!! HELP!!!
- WTB TODA SPEC C CAMS
- Help with my project b18
- B18c re-tuned dyno
- <<~~mY LiTtle MOnSteR~~>>
- b20 vtec
- Vtec not engaging?
- a question for people with chassis dyno's
- Adjusting Valves on B16
- Your Views on B20 Bottom end build
- ls vech reliability question
- 222whp pump gas, more to come
- buddy club 3 cams
- oil squirters on the b18block??>considering ls/vtec
- catch can stuffing
- swap a fully built motor FROM car to car
- PLEASE SUGGESTIONS B20B 3.740 (95MM)EAGLE CRANKSHAFT
- Stroker Kit with NOS
- valvetrain help
- NEED ADVICE ON CHOOSING MY ECU SETUP! HELP!
- anyone ever use this header?
- Need help choosing cams???
- Can someone be kinda enough to have evil drew email me?
- DIY head build.... difficult?
- K-series (or any series for that matter): 105mm throttle body
- B20Vtec injectors choice
- r this JDM type r cams (95-00)
- new to the all motor scene
- ls vtec race build
- Skunk2 Cams on Type R Valvtrain
- How to install VTEC controller VART swoosh into EK4
- Hybrid_Vtec's N/A LS Dyno Part 2
- Help me please , i want to know about 95mm eagle strokker
- b20 question
- what intake manifold for gsr?
- SDS fuel management
- best cams for big motor
- skunk 2 or crower
- Has Anyone Gotten an Email From Me?
- h22 all motor with h23 crank
- ctr pistons with jg head
- 403's with Toda valve train
- D16Z6 Build, my list, what would you recommend?
- HOW HIGH CAN YOU REV
- mid pipe resonator
- Best New Mod For My Setup Help....
- Saenz Rods
- valvetrain question
- wat would cause this
- b18b crank into b20a block
- 2000 honda civic hx tranny
- civic.jdm b18b idle prob?
- ls/vtec dowel pins
- No-start - how do you test a coil?
- crower good enough?
- valve specs with 403's?? please help...
- What are best cams for my setup?
- Hondata S300
- Does this head have a bad valve?
- Quick Question...PR3 pistons I won on Ebay, good deal?
- Carburated B18b? Strap a 4bbl Holley on the B*tch!!!
- k20 or sleeved b series ??
- Biggest you can bore a B20???
- Best cam for stock JDM b18c with 10.6 compression (stock)
- best header under 600
- RM M22 on a stock b16
- evasive?
- non-LSD Q????ASAP
- Wanted: GSR w/CTR cams dyno graph before and after
- I found a JDM wholesaler
- b20vtec stock pistons?
- *Side Exit Header*
- zc sohc vtec????
- All Motor H22
- Best Overall Camshafts For B16b engine....
- problem with buddy club cams????
- b20b cams in b18b1 ??
- LS Mild Build
- What Oil in ur LS Crower 403/404 setups??
- what compression do i need to moifiy with head?
- best header and cams on a 1.9 all motor gsr setup
- Hytech Production Header?
- Q on Euro R Camshaft for a H22A
- n/a header noise?
- help, question about o-ring under the 3rd bridge cam holder.
- Skunk2 Pro 1 in GSR?
- h23 accord help?
- Any one delt Castillo's Crankshaft recently?
- B16A1 Dyno sheet with few mods
- WTF? 181hp & only a 15.3 1/4mile. Need help
- Ditch B16 for GSR?
- All motor
- GE LSVTEC KIT with 2 PLUGS?
- INFO ON LS V TECHr
- good for this b20/b18c1 setup?
- ARP GSR Head Studs DO NOT Thread Into my LS B18B, LS/VTEC wtf?????????
- any info. on vegas.
- suggestions on set up b16 or ls/vtec
- Pics of My SMSP Header Installed
- B-Series Head Flow Chart (Experts Please Chime In)
- Engine Modifications?
- LS tranny or B16?? with B20Z
- need help codes
- Experiences with Crome rings
- parts for h22 and h23 same or differnt
- Clevite bearings
- ignition nightmare!
- What gains will i notice after Hondata?
- Anyone with an All-Motor H22 build...post up!!!
- Why is my distributor so far advanced?
- k20a2 in a hatchie
- Removed VAFC and now no power to ECU?
- Anyone else found that sk2 Pro 1's have COMPLETELY changed their exhaust sound?
- skunk2 stage 2?
- Allmotor guys: How do you tune timing on the street?
- skunk 2 cam gears and AEM wideband for sale *new*
- intake ?
- Need torque specifications 4 ls rods and head....
- got my built and ported head on....intake whistles like a mother
- how does this sound for reliability?
- Crower 403 on 9:1 CR
- K-series: K24 simple build - part deux
- Safe to rev to 9K on stock retainers?
- good header for a b16 crx
- cataylic converter question..
- Idling issues on rebuilt motor
- clutch
- Different route on an "all motor" setup, more of an "all OEM" setup
- 1st v-tec how too
- stock jdm itr block on BC5 cams
- My all motor build, opinions much appreciated.
- CTR or ITR valve springs
- BEST HEAD PACKAGE...I NEED HELP TO MAKE DECISION...THANKS ADVANCE
- h22 question...NEED HELP!!
- integra gsr carb header
- s2000 throttle body can it be used on b series engines?
- Intake manifold test-ported ITR vs JG Sheetmetal--Dyno!
- *How to Tell if LS-V* Click me i give u $1
- CNC PORTED ITR MANIFOLD?
- ALL MOTOR LSVTEC
- Built D16 finally finished and running smooth!!
- Old Car Search
- general question about reliability, b16a's, performance parts, cust. exhaust and header choices.
- b20 lsvtec , allmotor , is blockguard or posting needed?
- dc jdm type r 2.5 donut gasket? and bracket too short w/ b16
- LS crank or b20 crank....
- A few questions on the RSX
- TrackSpeedRacing JDM ITR EG w/ Hondata s200....dyno results
- Engine Hesitating 2 turn on ...please help
- How Many Miles On The Motor???
- CTR piston LS/VTEC pump gas???
- Little question about GSR JDM...
