- good set up?
- www.maxharacing.com/?????
- LS/VTEC oil return line
- How fast were those two built JUN civics from a couple of years ago?
- Valve Clerance Question
- Is this really worth it for the buildup allmotor valves
- B18C5 head...
- i need a run down on building an LS vtec
- ls-vtec vs. type-r
- Critique my future setup
- Built motor hesitating above 5k?
- JDM B18C(GSR) 93 Civic EX 4Dr (1/4 mile time and dyno)
- Fastest all motor 98+ coupe full interrior ?
- a6 head or z6 head?
- my under powered gsr build predictions (dyno on friday)
- ITB'S on a h22
- A larger all motor field for NHRA/IDRC/NOPI finals
- Just a little FYI if your VTEC does not work.
- 1.8Liter ---> 2.0Liter
- Sorry about this...
- Difference between GSR and ITR cams???
- how much difference will a vtec trans make?
- Installing new valves in H22 head. What to do?
- S2000 parts on RSX motors
- checking cel with two different ecu
- All-motor GSR?
- Who has stroked their b16a using an OEM crank, other than a b17??
- LS/VTEC HELP!!!!
- Looking for Hondata Tuner in the Bay Area (dyno-tuning)
- all motor b17 bottom end
- Pics of the BEST CAI for drag racing!!!
- Cam install: to soon and to much??
- Help & advice on a all motor daily use b18c5
- dynos on zex d16z6 cam wanted'
- Another LS/VTEC Question????
- what size injectors?
- FS: sohc Dx bolt ons
- new parts , need new whp guesstimate
- ? About Proposed LS/VTEC Setup- HELP!
- new setup
- b18c (5)
- H22 FRM Honing Mystery?
- how to identify jun cams?
- bore a B16A short blok (ALLMOTOR GURU'S NEED HELP BADLY)
- What's next?????
- ZC
- Twin disc clutch for K20a2
- what next
- what kinda h22 setups are ppl running? allready searched
- Drag Racing header
- Good GS-R setup?
- any one seen 200whp from a stock bottom end on a jdm b18c
- 190 whp with stock clutch
- Gathering thoughts about this B16 setup
- My B16 Dyno Sheet
- New Personal Best Et and Mph
- comp cams 57202i anyone got the profiles/specs on these?
- doing a small-time buildup but need to know do I have everything and is this a good set-up.
- B16 Tranny On Ls?
- D-Series q..b18b rods w/zc pistons d16z6 block/crank
- what are good cams for a b16a 2nd gen
- Anyone runnin SMSP header on an N/A B16?
- goin all motor can someone give me a result of this
- Best way to check how much head is milled?
- b18c cams fit in a b16a2?
- Stroked Engines...
- AN-R header...
- good manifold and TB for race motor
- anyone with the endyne cf intake manifold?
- most powerful header "BUT" got to have best fitment
- Flywheel Issue
- B18A1 head on JDM B16A SIR2 P30 BLOCK?????HELP!!!!
- the clearance issuesInstalled DC JDM 4-1, impressions...
- tell me how to loose weight???
- Hand Built vs. C & C Machined
- looking for a good h22a set-up can anyone tell me some things I should get?
- B20 Sleeved "any suggestions"
- Car doesn't see to be very happy
- Skunk2 Stagee 2's Vtec point?...opinions
- Performance shops in Houston?
- Pics and Benefits of SMS Header??
- 300zx
- What Oil Should I use
- Need quick response! Easy answer for engine builders
- What is the largest motor Honda makes?
- Cryo Cams ???
- Why all motor?
- where to find inexpensive IM gasket
- CONGRATULATIONS
- Estimated WHP for a B18C1 bored to a 2 liter/stock head
- what cams would fit with this setup
- best 60fts worst compression readings
- B16b Block, Piston and Cam Clearance ?
- anyone have a sohc deckplated?
- Serious Problem With Z-10 block girdle!!
- what kinda power ?
- Where Can I get one of these?
- B16a Block Girdle
- ECU help
- Florida tuners?
- fun with a good header
- Purpose of a block guard?
- Where can I find only the lower part of the JDM 4-2-1 ITR Header?
- acl bearing question
- ??? on t/b size for my motor
- Realistic times with LS'VTEC in gutted CRX?
- Which has more midrange CTR/SK2 Stg 2 cams?
- DTR header section done... (dyno graphs)
- Dyno of my B18C 12:1CR on PFC
- will b16a rods work with ctr pistons
- Power FC users who still have AC - feedback wanted
- 1.4Litre D-serries N/A monster dyno graph..
- PICS REQUEST: Anyone got pics of a Endyne ported ITR manifold???
- Building H22 bottom end. Any sugestions?
- Head/Cam Choices for all motor H22
- Allmotor crx aug26 bg raceway
- fastest allmotor b16
- My N/A Setup...what's next?
- building b21a1
- another repeat ques / ls internals in gsr block?
- Stage 1 or stage 2 cams?
- B16A2 Compression? Boring out... What should I go with???
- Cunningham rods, worth it?
- MAP Sensor V-AFC Problem, Please Help!
- Few Questions about my set up.
- dyno numbers before dynotuning
- header tech ground clearance
- Q on GSR rod strength in higher rpm range
- which one would be a better swap? the b20 or the h22?
- Have some pretty conservative goals....can they be met with.........
- confused about bottom end...
- What Cams for my NA setup? Opinons please.
- New track times (nothing special)
- Skunk2 cam gears fitment problem on Toda spec A's...
- LS motor build ups
- Quick Question: Which In-tank Fuel Pump For 87 CRX Si W/ CRVTEC?
- dc2 auto v.s a 03 celica GT 5sp
- please help me choose, cllutchmasters stage 3 or 4??
- ITR cams, LMA's,and a B16A
- advantage!
- drag racing battery CCA's??
- Vtec went bad..
- Cam re-install
- light weight flywheels????????????????????????????????help
- best header for all motor?
- Y1 lsd cable tranny 900?
- b16a distributor vs. b18c distributor
- need a little help with engine building
- Have $1100, need some N/A setup advice (this needs to include a bare b20 block too)
- All motor LS B16 pistons and 2 layer head gasket..... gains??
- CTR Pistons with TODA B's
- best rod and main bearings to buy?
- How to tell if these cams are Skunk 2 Stage1 cams???
- How can i tell skunk2 cams stage 2 from stage 3 appart ??
- What kind of power gain by going from 9:1 to 10:1 compression?
- 13.1 on stock sleeves
- How fast can an EG with a stock JDM H22 run at the track?
- Straight Pipe
- Diagnose this....
- Tb gains on B20vtec
- Skunk2 Rear Drag Coils
- Cost of Porting?
- higest compression on pump gas(93)
- Guestimate this hp/tq...
- 2.0l all motor set up, 13:1 compression with nitrious....
- High compression LS.. what kind of power gains?
- b17 compression
- Intake mani??
- should i get a b20longblock for the displacement or stay with a b18b long for the compression?
- some questions before i start my build..
- B16A head or GSR head?
- Thoughts on Zex B series cams?
- searched: will b18a injectors work on b18c?
- Name parts you bought that made power or no power.
- bout to trade crower stage 2 for jun type III
- Are portflow valvesprings ok for JUN 3??
- b20 sleeves
- 1990 Acura header Question????
- ITR Cams Identification... Did Search
- Dissapointed about track times...
- what to do in my k series???
- When I received my Jun 3's...
- Apr rod bolts
- Crane SOHC VTEC (D16Y8) Cam - where to buy?
- Piston Rings?
- highflow cat..how much will it hurt?
- 2.0 GSR slow?
- Check engine light question
- anyone compared a g-tech pro with a true dyno test
- fields hyper afc
- help me confirm my LS build up ideas
- portflow h22a spring set???
- catback bolt on 63.5 mm or 70 mm exhaust
- gude head package on b17 ?
- Newb Question
- 63.5 mm vs. 70 mm exhaust?
- What is the highest compression ratio that is safe for 91 octane?
- 187.6 whp 134ft lbs, will higher compression get me up to 200whp??
- LS block build up for later LS/VTEC
- Will b18c5 crank fit ina b16 block?
- question about gsr head studs
- Question - 81.5mm TODA Pistons w/std HG - safe on pump gas?
- Bare ITR Head, with new valvetrain, better than PNP?
- Crx with Ati harmonic balancer problems
- anyone on here ever used the MUGEN 2 layer head gasket????????
- perfect compression test BUT............
- B20 Vtec (B16 Head) Reving abilities???
- golden eagle adapter kit
- B20 Ls-VTEC?
- fuel pressure regulator
- crank pulley question
- ls results?
- pretty pissed about results...
- like this race header?
- Help! Anyone know any places that does performance upgrades
- need some "go faster" advice
- PRY Racing Camshaft, anyone know much about them?
- trying to find a b18b with low miles....
- specs on h22 swap vs. an h23
- Alright I decided on my pistons now cams...........
- qustion on if a clutch will work....
- Over 200 WHP possible...
- quick piston ?
- Crower stage 2 or Skunk stage 2
- h22 lsd... where to get it
- hp for all motor b18c1 motor
- head stud question?
- piston question?
- Would s2000 injectors be wise?
- hondata and skunk2 stage 2 cams
- LS-Vtec in works
- i just totalled my eg coupe, need a new car
- Piston to valve clearance
- what kind of hp have u guys seen with hi compression d16z6 or mini me
- B18C1 need help
- best midrange cam?
- NEED HELP TUNING
- Will milling the head change the cam timing? (retard)
- quietest exhaust that doesnt sacrifice power
- civic hatchback curb weight??
- 200whp possible?
- cams for poorman type r
- Injectors
- Inline Four Overvored TB's
- Skunk2 Stage 1's?
- Engine shop in VA/MD/DC?
- b16 or h22
- Went to the track on sunday....
- 92/93 b17 gsr
