PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Jesusbernal249's LSVTEC build thread: what to do next?
  2. Troubleshooting: B18C1/5 fuel cutting out, No codes present
  3. Intake air restriction? 3" vac at WOT, power falls off BAD up top
  4. Troubleshooting: P2V Contact with B20B low comp and B16 Head- what's next?
  5. H22 370cc injectors: Are these optimal for my H22 Engine?
  6. Feedback request: Vtecthatcould's B20VTEC EG hatch build progress
  7. Is the use of a 70mm throttle body on a stock B18C5 with M22xx cams a good idea?
  8. Crank balance on B18CR Block and PR3 Head
  9. B16a won't start when its warmed up *SOLVED bad starter solenoid*
  10. All Motor B20 high comp build ecu for emissions question
  11. Radiotech's Mild changes to stock B20Vtec- Project build Questions
  12. B16a Fuel rail bolts for skunk 2 intake manifold
  13. Staggered intake valve lash? & Analysis of intake flow
  14. B20 w. P72 head or B18C5: 200hp for 2k (ish)
  15. The use of budget-made rods on a k20/24 combination engine
  16. B16 internal block parts into a JDM B18C. Possible to work properly?
  17. How does one remove Arp rod bolts that are already machined in stock rods
  18. AutoX19'S B16 in a Fiat X1/9
  19. Performance fuel pump and Injectors for B series
  20. Cammed B18C1 help
  21. B20-VTEC build with "Mid-Range" power in mind
  22. How are the B16b & B16a2 crankshaft different?
  23. Sherrif445's proposed B18C build - no goals yet
  24. Suggestions request: SanadaSand207's B18C1 block/LS crank/CTR piston build
  25. Low Compression in Adjacent Cylinders
  26. PCT or P73 Pistons on b16 w/ S1 Cams
  27. Skunk2 Pro IM w/ Tuner1 Camshaft:Good improvements for B16?
  28. PabloM isnt sure: p30 pistons on b18a2..good idea or no?
  29. Stock B16 using skunk2 Pro IM: Retune necessary?
  30. Engine assembly checklist Inquirybefore a tune: What should it consist of?
  31. Radiotech's All stock B20/VTEC progress build
  32. Troubleshooting: B-series VTEC vacuum setup
  33. D15B7 Throttle body on a B18C ITR intake
  34. Forged internals or valve tap?
  35. help with build b18b1 with b16 pistons
  36. CT-Engineering gone? Closed? Out Of Business?
  37. Engine knock or just pistons?
  38. Coontech's custom B-series build for 235whp
  39. Garf is Bringing an Old EM1 back to factory spec
  40. Dyno-tuned NA OBD1 JDM GSR: 198whp, 138wtrq (ITR intake cam, I/H/E)
  41. B20 Integra's questionable build using B16B/B20B Block Combo-Suggestions?
  42. Strange noise when reving motor help!
  43. Hatch Man's B-series VTEC custom build questions
  44. pabloH's multiple questioned GS-R intake manifold thread
  45. Suggestions requested: H22 custom rebuild plans
  46. DC JDM 4-1 Dimensions
  47. What are Performance Camshaft options for the Acura CL 2.2 litre?
  48. Crankshaft and camshaft oil seasl - how much weeping of oil is acceptable?
  49. JDM H23a Vtec /USDM F20b cams
  50. OEM radiator for B18 N/A build
  51. Opinions needed: What direction to go on my B20VTEC build
  52. Suggestions Needed: SiR2 b16a with CTR cams, I/H/E - Mods before opening the engine?
  53. Minnick83's B18C1 circle track build-suggestions welcomed
  54. Complicated Question: What is the safest maximum power output of a J35A8 engine?
  55. Anyone running buddyclub spec V?
  56. K2H setup-using K series intake manifold on an F20B. Thoughts?
  57. Cusco oil catch tank on b20v 13:1
  58. Guesstimate Power Gains B20 Non Vtec
  59. D15z1 build questions
  60. Jeff Evans Videos on Tuning Tips & checklists for your car
  61. Are the Skunk2 Pro3 Camshafts too large for a relatively stock LS/VTEC Build?
  62. Troubleshooting: Attempting to identify Intake Manifold- EF B20/VTEC Swap build
  63. B20 high comp only the head?
  64. Exhaust EXTREMELY DRONY
  65. Can I use a pipe clamp on the airbox/rubber inlet manifold junction?
  66. How to get access to check cambelt condition on a B20 engine?
  67. Circle track b18c1 build
  68. Source for JDM H22 Internal Coil Distributor?
  69. Power Division GSC N2 Cams - Always Check P2V & Degree Before Install!
  70. B18 all motor build questions
  71. B20v, 92 octane compression limit?
  72. Rebuilt D16Z6 okay to run without retuning?
  73. Castillo or Lopez Crankshafts
  74. KiNGDEE206's B18c block CTR piston/ Gsr head progress build
  75. Squeezing the most power from my h22a
  76. B20 Vtec Type R - Crank, No Start
  77. B18 gsr skunk2 tuner stage 2 cams
  78. Honda civic '01 and '00 motors
  79. Is it worth using a modified GS-R Head on a stock JDM block?
  80. Qtr Mile Estimator
  81. Skunk 2 Ultra 2 cams specification question: Inlet valve opening /P2W measurements
  82. ej_jake's quest to create a H2B/H22A4 build for a street/strip purpose
  83. 43!'s Projected K24 Build Thread
  84. 1997 CRV Oil Consumption
  85. SOHC - Machined Camshaft vs. Adjustable Cam Sprocket
  86. Troubleshooting: understanding electrical issues 1992 Integra
  87. H23A1 anyone know what how much compression it should make per cylinder?
  88. B16B Step-by-step instruction guidance: B16B/Austin-Mini Project
  89. B18c5 more compression before adding boost
  90. Mystery knock
  91. Identify my cams? B series vtec
  92. Suggestions/Peer Review /Approval Needed: Another B20-Vtec-Build
  93. B20V N/A confused with compression
  94. Troubleshooting:B20/VTEC Timing Belt not encapsulating both Cam gears w/ tensioner
  95. Using a Fuel Pressure Regulator on a Stock D16Y7. Any Benefits?
  96. B20VTEC Power Loss issue: (Australia)
  97. 05 D16Y8--What NA mods will increase my power?
  98. Best upgrade for hp on b18c-R? Street car
  99. Will a American made engine work in a Canadian built car?
  100. whats needed for a b16 head onto a b18 block
  101. what carwas b16a originally available in?
  102. Will a ITR intake and header fit in a B16A SIRii?
  103. Camshaft & Similar Modification Suggestions for 200-220whp - B20/VTEC in South Africa
  104. B18c1 build~200whp goal(Do-able or not)
  105. Z0831xiz's goal to 220whp -Qualifying parts list?
  106. D15Z - Occasional Idle Surge and Surge When Cruising on HWY
  107. Where to buy distributor for H22A 5 Series?
  108. Header glow red from timing- D-series. Suggestions?
  109. Suggestions needed: what parts are necessary for a 190whp LSVTEC
  110. B18C1 Build Questions. The quest for 250whp-300whp NA
  111. Build Suggestions: DC Chassis for an H2B Setup. What new options are available now?
  112. Smoking when cold
  113. Engine feels like it trying to stall
  114. b16a all motor build
  115. B16B: Reducing HP by Using the Wrong Heat Range Spark Plug
  116. B16a2 Pistons Rods upgrade
  117. What direction should I go?
  118. Troubleshooting:VTEC HighCam. Oil Pressure? Spark? Solenoid? What's the deal?
  119. Oil pressure switch
  120. B16 Stroker - Limited by regulations
  121. Skunk2 Pro3 G23 Idling
  122. B20B/P8R parts suggestions for B20b's high compression build
  123. Lilvader's GSR parts upgrade discussion thread
  124. H22A1 Rev Limit Possibilities - discussion of ideas
  125. Brji1989's CTR head/ITR block change-out: Progression to perfection or road to ruin?
  126. Thermal throttle body gaskets..
  127. Mattvivsound's B20-VTEC on "Pump" gas-part selection
  128. Why A Big Cam Setup Needs to be Checked For Clearance
  129. Anyone has used skunk 2 stage 2 tuner series cams on a k24?
  130. b16a2 air filter fitted directly onto tb
  131. is there a way to tuck a ls/b20 vtec oil line
  132. Fuel pump question regarding K-series engine
  133. Suggestions needed: What specific exhaust would work best with a Mugen header
  134. How to get my k20a3 to rev to 9000 rpm safely?
  135. G"LS"R High Compression Setup. Need Suggestions on parts combinations
  136. The common use of CTR pistons in A JDM B18C block
  137. Question: 2.5inch Exhaust piping? or 2.75inch to 2.36inch piping for Spoon muffler
  138. My 88x99 14.5:1 k24 making some jam on the dyno
  139. Assistance Needed: B20VTEC RS Machine Piston Installation
  140. DC2_Richard's Quest For 200whp from a B20B
  141. Opinions /Suggestions requested: The potential capabilities of this B20 Longblock
  142. D15b2+Z6 Distributor Timing / Ignition timing Questions
  143. k20z3 oil pump RPM & balance shaft limits question
  144. 96 ITR motor mis-fire
  145. Civic D16Z6 does not start!
  146. Help me find my CR!
  147. Comparison power numbers of a G"LS"R with stock camshaft
  148. SavageEm1's B16 block rebuild progress thread
  149. Suggestions needed: How to make the F20B SOHC VTEC a more powerful platform
  150. Suggestions on what the purpose of this engine should be
  151. ITR intake manifold or Skunk2 IM?
  152. K24a1 - Locking VTC mechanism at a fixed angle
  153. Basic B16 - 10.8:1 Compression and the possibility of using dual ecu maps. Possible?
  154. Fuel Injector Sizing Calculator
  155. About to bring b16a for retune,need advice.
  156. Which VTC Cam Gear is most recommended for the 06-08 TSX?
  157. The day the music died... Video of when I blew my NA d16z6
  158. Twin Cam's B20/VTEC Progress Build
  159. k_swapDA's 250hp all motor b series build
  160. Need help! I have a 1990 Honda Accord stock with the h22a1 motor..
  161. Digging the Horse Out of the Grave - Best Header for Built B20V?
  162. How do I get my 2005 Acura RSX to 200whp?
  163. Assistance Needed:B20 VTEC High Compression build - Driver experiences
  164. lowblow143's Current B20VTEC Progress Build
  165. H23A VTEC, bored to 89mm...best cams for street?
  166. Assitance Needed: B20VTEC Engine Knock + CEL Issues
  167. Type R pistons in GSR, Which cams?
  168. k20a2 jumped 4-5 teeth, would this affect compression.
  169. Suggestions Requested: Reasonable H22A4 Upgrades To Enhance Performance Potential
  170. Opinions Welcomed: ChristosDC2's Type R Project
  171. Help identifying vtec cams.
  172. Crushed spark plug!? How!? Happened at the track.
  173. Assistance Needed: Redline shift to 4th, engine shut off
  174. N1 Muffler Sound Question
  175. 12:5.1 compression on 93 pump
  176. Suggestions needed:F22b1 Block using K20 piston possible combinations
  177. Another G"LS"R GLSR build question thread.
  178. f22b1 170+ whp possible?
  179. Issue: Severe compression loss after valvetrain install. K20A2
  180. Z0831xiz's 01' ITR High-Compression Longblock Progress Build
  181. What are the most reasonable power upgrade options for the B20B?
  182. Feedback Appreciated: B16B Component List for Circuit/Hillside Racing -Netherlands
  183. Inquiry: "Budget" B-series Exhaust Header options available for 2017
  184. Dyno tuned NA d16z6: 158whp, 116wtrq (Mustang Dyno)
  185. Suggestions Needed: Possible Options for obtaining 150-200hp D16Y8 Goal
  186. 97' ITR - Best cams for my application?
  187. Is there any advantage to using an ITR OBD2a ECU on a B18C1 Engine/ GS-R Camshaft?
  188. ITR Cam ID
  189. Undecided between RDX / RC Injectors
  190. Assistance Needed: Oil on spark plug and piston head
  191. Resized stock rods with ARP bolts or used Eagle rods for B20 VTEC?
  192. Running rich or burning oil?
  193. Lsv with b16 pistons, 272's and bolt ons
  194. Assistance Needed: Question regarding Balancer (shafts)? Unknown engine stated
  195. Will C45 and Other VP Race Fuel Options Yield More Power than C104?
  196. Assistance Needed: Issues With The Ability To Lower Fuel Pressure - B18B
  197. Which is Preferred For A B20VTEC Build: Skunk2 Pro1 or the Tuner 2?
  198. Unknown Issue: A "Lip" Has Formed On Ferrea Exhaust Valves...Possible Cause?
  199. Hello from NZ - JDM 98 spec ITR
  200. Does adding 1.5 points in Compression Ratio Yield Significant Power Gains?
  201. Unsure of the exact Engine Code of my H22 Block
  202. Valve Cover options for the B20 P8R Cylinder head
  203. Can a Sleeved 86mm B Series Engine Be Used As A Daily Driver?
  204. B20vtec which HG to use?
  205. Customized Options For The 850Fabrication H22 4-1 header
  206. Assistance Needed: Vacuum Issue on an LS/VTEC causing a No-start condition
  207. 93 si Type-R Build - Parts suggestions
  208. D15a2 more hp!
  209. Suggestions on EMS Options for an E85 All Motor Project
  210. Helppp! The engine is blown and I have metal shards in the engine oil
  211. Skunk2 Pro1 cams with a lumpy idle passing emissions tests
  212. Looking for tips. Want to build B series engine
  213. B-Series Engine Rod Weight Comparison Question
  214. 2.5 or 3" e-cut out for na h23a?
  215. B18c problem
  216. JDM D15B - 3 stage vtec - Questions
  217. B18C1 needs to rev high and weak throttle response
  218. Question on cams with my build
  219. Maciel's GS-R NA setup build - Suggestions welcome
  220. Discussion: B16A2 Automatic Trans vs. Manual Trans Differences
  221. anyone have build a high compression b20v?
  222. Ported h22 intake manifold for my h2b crx
  223. Taking turbo off
  224. Jdm d15b or jdm d16a
  225. Identify These 1991 B16A Injectors
  226. Honda All-Motor - Natural Aspiration Basics & Overview
  227. spark plug pic + idle
  228. B20V questions?...
  229. Big Question: Is it advisable to build a B20Vtec using stock rods?
  230. Building b16a2 need advice
  231. CAI for 90mm TB on B20vtec?
  232. My H22a4 N/A Build List
  233. D series to B Series Radiator
  234. Suggestions needed:What parts necessary for D16y8 to D16z6 swap?
  235. What size throttle body?
  236. Suggestions Request: California BAR'd Resident: Swap or Stay With Stock?
  237. Parts Selection Suggestions:B20 with unstated goals-Eventual Turbocharger use
  238. Suggestions Needed: K20A3 1st Level Engine Modification list
  239. Another Cam Degree Dumb Question
  240. HKS B Series Cam Gear Availability in 2017. Still possible?
  241. Assistance Needed: B16 w/ Skunk2 Tuner 1 Camshafts on Stock ECU?
  242. 181whp B16 with basic mods
  243. CRV For Me? B20 VTEC Questions
  244. HELP! I need a HONDA mechanic to work on my Buggy in L.A.
  245. Assistance Needed: Custom Velocity Stack Install 1998 Civic
  246. Potential JDM B20 Purchase + Cracked Sleeve Concern
  247. Suggestions Wanted: B16 Head/GS-R Block or Complete GS-R?
  248. Suggestions needed: Bolt On exhaust components for B16A2 Engine
  249. What is efficient maximized RPM on a stock K20Z3 w/ TODA RACING Valvetrain?
  250. Stock ITR B Pipe on Mild GSR build ?
