- gsr s2 manifold with p72? anyone??
- cams and valvetrain
- Na setup on b18c1..hows it sound?
- any one have an ls fifth gear in there b16?
- CTR Pistons on Eagle Connecting Rods.
- what wrong with car
- Omnipower valvetrain w/ BuddyCLub St.3 Cams & BC cam gears
- Knife edged cranks > Good or bad idea > engine builder's please help
- pump gas
- All motor jdm d15b
- run 13:1 on 91?
- DC 4-1, 4-2-1, ITR Headers, ground clearance? power loss?
- ctr pistons/b18c spoon headgasket
- question about d16y8 in 91 civic hatch......times??
- NEED HELP!!!!!
- Sound ok?
- aftermarket pistons on stock b16 rods
- UH OH SIR... Possibly blown enigne??? pics...
- D16A vs D16Z6(ZC)
- Your opinion on running BC Stage IV cams @ 11.2:1 c ompression?
- just purchased a b21 block
- red OEM b18b connecting rod
- weird sounds coming from ITBs??
- Help with rod ratio and deckplate
- What OEM piston in gsr block
- rod/ stroke ratio with regard to high rpm's... what have you found to be true?
- best exhuast
- Running 370cc inj. with pump gas at 13.6:1?????
- ls/vtec girdle - do I need it??
- Question about camshaft specs
- poor mans type r
- crower 405 or 404 cams for non-vtec?
- crank counterweights proportional to the piston/rod weight?
- **P8r head on B18b with Ctr pistons** Lowered Comprssion, help.
- pretty much done with my motor...
- 404 cams in non-vtec what numbers should i use for valve clearance?
- GSR crank vs LS crank
- skunk 2 stage 2/ stage 3 on a stock compression?
- Honda piston code???Need Help
- Question for you ITR 5 LUG users???
- What belt for Toda B's
- Where the ell do I find a T1R exhaust?
- Dyno results:B18c-r with Spoon rods and Skunk2 head with stage 2's
- has anyone know of DRIVEN AUTOMOTIVE?
- Went to the Dyno (=
- Does anyone make an off-shelf 85.5mm piston?
- b18c1 or b20z vtec
- BKR6ES-11 good
- building a motor for efficiency
- Help me pick a header!!!!!!!!
- Opening dual runner earlier than 5800 ?
- Backup stuff from IB
- REV HARD....Victor X manifold on 2.0L
- finally finished my ls/vtec
- are these good non Vtec cams good..Specs inside
- spun a bearing
- Installing Crower Cam 404 Non-vtec does anyone have any tips?
- H22 intake manifold port and polish ?
- All motor pistons JE 11.5:1 83m
- ****P8R head, please *****
- Question on tps for twm's
- cam question are these good cams
- k24 crank in f23 block....
- Intake manifold to make power all the way to 9K!
- b16 wont start, help!
- can i
- Which Cam Gears Are Best for B18C Poll
- buddy club st. 4's ?????
- What is the recomended Compression Ration to use with s2s2 cams?
- ITR tranny/block brace
- Installed ITR intake manifold on B16a
- Buddy Club Cams... stage 3 or 4?
- ls rods question?
- 2.2 GSR 95mm Eagle Stroke...est 300+whp, which crank pulley?
- Buddy Club PRO-SPEC exhaust?
- What kind of Internals to get???
- obd1 or obd2 gsr ecu please help
- Crower 405a with Ctr pistons on ls rods. Clearance issues????
- DIY header
- Are all obd 2 alternators the same for the gsr, type - r and ls? If u know please reply!
- My D16A9 N/A tune up...
- JDM GSR engine buildup (for N/A)
- Future plans
- Skunk2 Manifold THrottle cable question
- AEBS Manifold
- Smoggable d16a6?
- will a h22 fit into an 89 si???
- cam gears?
- hondata
- How to tell difference between cams - appearance wise?
- During a hard week of driving how much oil do you guys burn?
- Is there a writeup on h-t, website or book out there explaining Honda/Acura engine building?
- cams switch ard?
- I just received my 2nd Hytech Header this year
- Sheared a tooth off my power enterprise belt
- what valvetrain to use with s2s2?
- 86mm street/strip B18C5motor, how reliable?
- LS block
- Retainers and dimensions
- 11.7:1 comp and fuel
- anyone useing skunk2cams + crower spring/retainers on h22
- type s internals. what ya think.
- exhaust size question. PLEASE HELP!
- Engine Builders/Tuners - S2000 Valve Events?
- Anyone using Port Flow Valve Train?
- Are ls/v-tech motors reliable?
- Octane question
- intake manifold flange for ITB setup ???
- Has anybody heard of Hazidous Racing in California?
- Is it safe..?
- Is it absolutely necessary to hone my cylinders?
- 1.8 or 2.0????
- BuddyClub III+ < x < BuddyClub 4
- jdm shit race header (JSR)
- Flat-Bottom Valves
- Can I check my flywheel without resurfacing???
- Spun Bodied Cat
- Will a porting the inside of a s2 intake manifold give the same hp as itb's?
- GSR or B20Vtec??
- HIGH 12:1 comp, daily driven ls/vtEC [56k nap]
- All motor websites/clubs
- Crazyitr's 10,000 rpm pull, open SMS header!!!! Vtec Scream!!!!
- is there a BC3 and a BC3+ ???
- What's up with the choice of carbs on some extreme all motor applications?
- eg winter progect pics
- Rocket M22 in a stock CR GSR
- Should I be worried with this?
- Lifespan of OEM Honda rods
- richmond va lsvtec
- My all motor setup
- b16 cam caps
- How is idle when using aftermarket cams on a street car?
- Steetable B18a Build Advice
- Toda B or C?? ok with B18cR with PCT pistons??
- Question re: adapting Honda TPS to Suzuki ITBs
- carbon itb's?
- need some advice here itb guys.
- quick question..ECU
- DIY ITB - 42mm vs. 45mm for 2L
- I got a this car for $500
- Need help with tuning
- Is my catch can setup correct for b18c
- 2.5 outlet header options...
- Dropped the pan and.......
- dtr 421 header or an-r compact help \
- my all motor build on any suggestions?
- anybody use this?
- my all motor project
- Cams decisions ... need info from your experiences!!!
- Eagle LS H beam rods Do I need to get it cracked?
- ********Minimum compression needed for Buddy Club Spec 4's?
- has anyone got over 200 whp with a ls?
- high compression poor mans type r?
- f20b rev?
- Comptech Race VS. AN-R
- anyone delt with importbuilders.com??
- to bore or not to bore
- breakin process after piston install not necessary?
- boreing a ls block to 82mm safe?
- The never ending question on exhausts
- 04 civic Lx VS 91 accord lx
- what should my #'s be??????
- valve to valve and valve to piston clearance registry!
- need help!!!!
- Vtec hitting twice is it possible?
- ITR head or GSR head with Alaniz streetmaster p&p???
- Need Help with cams, no ideas
- 217 whp... 1.8 liter (dyno chart, time slip, and video inside) Enjoy!!!!!!
- need help with vtec problem
- Piston to wall clearances, thermal droop
- Bisimoto B-series header...
- need help wit B18A1
- Finally, Poormans R on the stand (beginning the build)
- have a problem with o2 sensor
- "Keying" the crank...same effect as cam gears?
- Suprdave's B20VTEC Street Motor *Dynochart Inside*
- guess whp
- jdm gsr w/ ITR pistons and skunk 2 stage 2 cams??
- B18C1
- CTR B16b dyno good/bad?
- B16 potential....
- dropping a B20 block under a LS head
- IN NEED OF HELP! I have an all-motor motor and need to get smog check in SoCal
- LS vtec which engine harness do i need?
- I need b16 cam holder... pleeeaaasssseeee.....
- Cam Comparison: BCIII+ vs. S2S1
- Has anybody made a diy itb setup for a dohc zc?
- needs experienced hondata tuner in south florida.
- Supertech Pistons: Good or Bad?
- 11 Sec All Motor street Cars
- Battle @ 10,000 rpm (I lost!!!!) Major Carnage
- Should I use oil squirters?? Balancing cranks?
- ctr pistons or mill pr3 head???
- Thought you guys might like these pics
- fuel pressure inquiry
- AN-R compact header dyno results? Anyone have any info on this?
- Lets talk about rings
- Valve jobs, angles ....
- Stumped about which engine to drop in ?
- whats the most whp you've seen on skunk2 stage 1's
- An odd question for those of you with Crower cams (and cam gurus)
- help me debug my chipped p28
- Stand alone setup
- tried searching: Head Stud Question?
- B16 tranny
- D16z6 head gasket????
- All motor type r????i got a question
- B series transmission adapter for H22
- 83mm Bore on Stock Sleeves
- Merge collector vs. stamp collector???
- Buddy club spec 3 and CR?
- Do i need to upgrade my injectors??
- Kevin Tran
- IS THIS A WISE DECISION FOR MY ENGINE?
- All Motor H23
- Aftermarket CAMS question?
- Dented header!!!
- do u guys recommend a s2 type r manifold in my gsr?
- can i hit 12's in my DA
- which is better skunk stage 2 or toda spec b's
- ARP rod bolts in ls vtec????
- jdm p30 vs us p30 ecu?
- ARP 2000 8mm LS Rod Bolts
- what should i get for $1500-2000
- Type R rods?
- Stock Tach
- what cams to get on my b18c1? s2s2?
- zc head on d16z6
- hit the dyno today... big thanks to jeff evans :) (profab header)
- Bike ITB's - Question about throttle pedal travel
- keepers are the same in b&d series?
- Fuel Pump Question
- All Motor Exhaust Dillema.. ( help )
- helpppp!.. what should i do?
- ***what to do with JUN 3 INTAKE CAM?***
- looking for exhaust
- Skunk2 stage 2 cams....questions...done search
- Toda A's or Skunk 2 Stage 2
- What engine to put in my 88 lude?
- BuddyClub Stage 3 Cams or Toda
- Name this Sensor!!
- [B]Expected[/B] 1/4 Mile time...Not a E-race or Guess thread.
- Bigger cams installed - need suggestions
- H22a jdm
- ctr cams + cam gears?
- BBK intake manifold?
- a/f ratio on dyno?
- To TBone: I will be trying a crankcase evac...
- RS*R EXMAG GTII cat back?
- oil consumption high on y8 with ITB's??
