PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 [199] 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. Timing belt busted. Fixed, but new problem arose!
  2. jun 3 calibrating spec??
  3. quick question.. b20vtec
  4. daily driven stroked????
  5. b18c1 or b18c6..Which is best in the long run ?
  6. Reusing Piston rings...
  7. DC Sports Stainless headers?
  8. 4.7 final drive re-tune?
  9. how much would you pay for this swap?
  10. Stock air box=the best?
  11. could bent valves do anything to your cams?
  12. Fastest Swap For An EG Hachback??
  13. $500 budget for header... what to get with this setup...
  14. H22 *dyno results*
  15. welding a bung in cast iron header??
  16. CSF radiator? Opinions?
  17. Degreeing Cams???
  18. help with fuel system
  19. CTR N1 pulley, which belt to use with a AEM Pulley
  20. CRX Type R lost to ITR?!
  21. Opinions on ITR Transmission with ATS 4.9 FD
  22. #1
  23. best place for jdm motor
  24. CP Pistons 84mm 12.5 compression with b20block and vtec head??? (stock shelf pistons question)
  25. Forza Tuning 2.5" Catback Exhaust.. NEED OPINIONS OR ADVICE!!!! ASAP!
  26. So what if you use a new headgasket to clay...right?
  27. H22 head???
  28. Stock Rod bolts...
  29. what do you think of this duty cycle??
  30. help me out
  31. rev valvetrain or supertech?
  32. part 2 w/ pics
  33. 13:1 and above compression: Which cams?
  34. ITB filters ?
  35. can you run itb's without velocity stacks?
  36. Accord Timing belt problems
  37. High Compression and High Elevation...
  38. Max piston speed on a K-series
  39. cylinder head repair: Machine shop in San Jose or Sac area
  40. what cams do i have?
  41. MSD 2 STEP MODULE SELECTOR fits on all type of cars ?
  42. CTR pistons for LS/VTEC? What are you running?
  43. The F-22
  44. All Motor B16 Compression Questions
  45. Would you do this all-motor LS/VTEC trade?? Please give your Opinion!!
  46. Cylinderhead repair in N-MD area, got anyone good?
  47. Wanna go all motor help?
  48. which HONDATA for my set up?
  49. all motor ls what valves?
  50. JG ls cams?
  51. Latest dyno of the old motor-open header.
  52. Dyno Results....comments welcome
  53. ITR/GSR LMAs with ~12mm lift - necessary?
  54. piston to cylinder wall tolerances???
  55. I have $14k to spend....
  56. TWM ITB Wide open throttle problem
  57. ok, bought the dc jdm 4-1 now what
  58. SMSP Header exhaust cat power gains...
  59. Help w/ injector cc size for ITR-------------------------
  60. D16Z6 complete rebuild quote....good or bad
  61. Reving 10,000 RPM's!? What is needed???
  62. ALL-Motor D16 Build Up: What size and type of injectors ahould I use
  63. should i plug oil squirters??
  64. GSR Girdle with B20 block
  65. retainers
  66. Type R camshafts
  67. question about msd chips
  68. External fuel pump problems. Help needed please
  69. ctr cam wear.....
  70. FD options for S4C tranny...
  71. what pulley is this and how to change it??
  72. Distributorless Ignition
  73. have anyone deal with www.JerryBuiltRacing.com
  74. Spec clutch/B16b = boom?
  75. Catch Can install...?
  76. Couple of Questions
  77. busa throttle body?
  78. My new Spoon header.....
  79. what problems come with high compression?
  80. Aero-turbine exhaust
  81. has anybody had a full-rebuilt tranny ?? replacing all the tranny components ??? wat shop ??
  82. RS machine cams valve adjustment?
  83. Help! My exaust is making puffing noises!
  84. which spark plugs to use
  85. timing belt and dyno tunning?
  86. Is this DC's version of the jdm?!?!?
  87. Cusco 5.0 final drive, WHERE?
  88. Any quick SOHC cars here?
  89. acceleration problem
  90. Suggestions before i start buying some stuff
  91. 10-94 mike
  92. will a 2000 itr ring gear fit on a DC2 lsd?
  93. CTR Cams
  94. what would be cheaper? short block building
  95. reducing fuel and advancing timing in gsr
  96. does this header look like crap or do you think it looks ok?
  97. does this header look like crap or do you think it looks ok?
  98. metal shavings in the oil pan
  99. WHo can install LSD's
  100. head gasket
  101. Cam question
  102. best vtec cams ,gsr 11.0 comp
  103. Performance Header for All Motor?
  104. Quietest Muffler and Resonator setup?
  105. JUN II intake cam..what exhaust cam should i use?
  106. Bent Valve Question
  107. problem with rocket ef-1 valve springs?
  108. Tuner Toys oil fittings....
  109. Synthetic vs. regular
  110. Next mod??
  111. f22b1 can u do alot with it?
  112. Checking codes: obd2 car with obd1 conversion.
  113. heater, climate control for 88 crx HF
  114. valve adjustment.......
  115. Looking for a link...
  116. H22A vtec conversion on '93SI non-vtec prelude?
  117. Which cams??????
  118. New clutch- Clutch engages when pedal is almost all out.
  119. got a question, jrsc for b16 and b16a2
  120. Ls/vtec with 94+block (PCV?!?!)
  121. All Motor Setup...please help
  122. need help with suggestions for a b20vtec build!
  123. LoveFab Header
  124. where to get a itb setup??
  125. act stage 3 clutch, what does it consist of???
  126. Is my head warped?
  127. B16 Bearings in a B20??
  128. what do you respect more?
  129. ARIAS OR CP PISTONS NEEDED ASAP FOR B20/VTEC
  130. ITB's and Backfire!?
  131. head gasket
  132. What does Hondata come with???
  133. H22 head Milling...
  134. A challenge for u guys..b18c4 tuning
  135. gsr head questions
  136. buddyclub cam gears?
  137. CBR ITB's rough/rich idle....any help?
  138. LSVTEC Spark Plugs
  139. Optimum A/F Ratio...
  140. cam q's
  141. B20B block + B16A head = CRVtec..What are the pros and cons??
  142. 2000 Civic Si Timing Belt replacement???
  143. B20B + B16A = CRVtec... What are the pros and cons??
  144. My B16 Hatch. Nothin special.
  145. Gsr lsd break in time? used jdm
  146. any power from a testpipe only???
  147. Stock Block B18C1....fastest 1/4
  148. built gsr or built poor mans type r
  149. Any one used the Spoon Ventuli Plate (IM gasket) ??
  150. Help with oil problem, I've tried everything.
  151. Does anyone have an injen short ram intake???
  152. Why is my exhaust cam wearing like this?
  153. N/A & turbo HP&TQ differences?
  154. 200wHP b18c1 with STOCK bottom end?
  155. Valve train upgrade on b18c questions
  156. Are these compatible parts?!?
  157. running cold all the time, does it hurt?
  158. B20 Block with B16 bearings??
  159. what are the pros and cons of just running an alternater on the street
  160. Couple of small clips of my car. VIDEO/SOUND RACING
  161. Good Bye ls-vtec (you will be missed)
  162. D16 crank removal
  163. D16y8 n/a max numbers
  164. UNTUNED LS/VTEC
  165. B16 with ITR internals, help please.
  166. how do these cams look as far as wear?
  167. breaking in.. and tuning. questions
  168. Ghetto build diary
  169. type r clutch good enough for a street ls/vtec???
  170. yup..another ls/vtec thread.. few quick questions...
  171. k20a2
  172. Skunk2 stage3 cams
  173. Squealing noise, Vacuum related, where is it?
  174. Pre-Tuning Ideas?
  175. Whatever happened to SgT?
  176. what motor is this?
  177. Engine Swap Question
  178. b16 head on a b18c block....
  179. Headwork in Orange County?
  180. Any dyno sheets of SOHC VTEC cams ?
  181. Anyone have an injen SRI??
  182. obd1 head obd2 motor
  183. how "reliable" is the b20?
  184. Input on new build.
  185. What can I do to make my LS motor run harder?
  186. Eibach valvetrain versus JG, etc? already did a search... for b series..not k series
  187. mix and match clutch components???
  188. LS crank in B20b4?
  189. best street clutch???
  190. Can you mate these?
  191. are these #'s possible?
  192. is it bad to have higher lift on exhaust cam than intake cam?
  193. alaniz competition head work results. with lots of pics and flow chart!!!!!!
  194. --Roll cage fabs in so cal where ya at?--
  195. crower cam
  196. Fuel System
  197. AEM Cam Gears and TDC Marks
  198. Compression Ratio ?
  199. Is it possible/feesable?
  200. SSautochrome header any good??
  201. ZC Question
  202. missmatching exhaust and intake cams
  203. 1996 Civic CX Stalling: Need Help
  204. should i do this......
  205. MY GOAL. 200WHP with JDM B18CR
  206. DO I NEED TO SWAP TRANNY FOR AN LSD ON MY 00 SI CIVIC
  207. does an-r make intake heatshield gasket for d series?
  208. D16Z6 and D16Y8?
  209. vafc settings?
  210. benefits of lighter pistons/rods???
  211. B16A2 build
  212. NEED HELP! Calling all D-Series tranny guru's!
  213. ACT clutch pedal feeling lighter than usual....
  214. Dyno Tuning decision
  215. 2000 b16a2 block
  216. final drive ?
  217. dynoed my b20z
  218. B16 intake ports vs. B18b intake ports
  219. Need LSvtec advice!
  220. Machine Shop Near Pittsburgh, Pa.
  221. which header and IM to go with??
  222. Coolant question
  223. intake manifolds for b20 vtec builds.....
  224. What do you guys think about Hastings break in procedures?
  225. all motor 2.0 Vtec dynoed & 1/4 mile numbers
  226. HOW GOOD IS THE SQUARE PORT?
  227. couldnt post in other forum...
  228. square port head
  229. Erick's Racing?? What the????
  230. DH-Racing Crank Pulley Fitment
  231. difference between type r clutch and b16 clutch???
  232. Greddy E-Manage on all motor car?
  233. b18c1 mutt
  234. Post your VTEC engagement RPM if you are using skunk2 cams.
  235. Advice on power please
  236. good place to get oem bearings?
  237. ITB's allowed in Battle of the Imports street class?????
  238. is 400cc too big for lsvtec?
  239. lsvtec
  240. how can you tell if you valves are bent???????????
  241. Do V-afc's really help performanc?
  242. What else can be done
  243. Cam recomendations
  244. ls/vtec 12:1 with b16a1 cams???
  245. specs on rs machine cams
  246. CX block + D15 Vtec head = What Comp?
  247. golden eagle lsvtec dowl pins anyone using them ?
  248. race port work streetable ?
  249. synchronizer???????
  250. D15B8 Header problems
