- Anybody have experience with Wiseco K594M84 pistons?
- camshaft degreeing?
- Assistance Please: No VTEC engagement - intermittent problem - Code 21 & 22
- WOW CRAPPY DAY GSR BUILD GONE WRONG LS/CRANK
- B16A2 wet/dry compression numbers help
- Who on here is/was building a hi-end replica race header?
- b16a block ctr pistons question.
- Looking for that OEM accord budget build thread
- H23A tune for stock motor.
- Anybody daily driving 11.5:1 compression?
- What can i do with this CHECK ENGINE CODES!
- gsr with Type-R pistons??
- ** TWIN LOOP MUFFLER ON A B16A ** ???
- ecu tuning help obd2
- vtec engaging issue
- need some answers
- PLEASE HElp!! (No bashing) Desperate need of help with my build!
- Piston valve clearance
- ITB's + Plenum and intake pipe DYNO?
- When you rebuild a motor do you have to use stop leak to stop the water pump leaking
- Can I use b20 cams on an ls head?
- ls vtec swap.. PLEASE HELP
- Starting to think my piping is too big??
- PCT's in a built GSR motor, Pro 2's too big?
- Compression Test results - Help me diagnose
- Best place to buy itr longblock?
- gsr rebuild head is leaking a little in the front of the block do to tighten arp stud
- Question about block an head cleaning in oc cali
- best cam gears settings for stock Gsr cams? ?
- What kind of header is this?
- b18 type R or b18 GSR
- ALL M0T0R's 2nd build thread
- F20B vs H22 vs B20vtec
- Ls/vtec fuel issues
- what do i have here? bought out a speed shop and this was with it
- kind of a stupid question ... h22 oversized valves with skunk2 stg 2's
- B16 HEAD!!
- ls vtec cam selection?
- True cam duration #s
- can anyone give me a ballpark number for my build?
- Anyone having contact issues with Brad @ RLZ?
- LS/V???'S, PLEASE HELP...
- ls/vtec rebuilt s4c tranny and more goodies
- Problems after swapping b18 into civic PLEASE HELP!!!
- F20B swap help...
- problem with water in cylinder!?!?
- B16b with 89 crank
- Head work opinions w/pics
- b20b.......b18c1 parts???
- Idle Problem... it wont stay at stable idle, how do i fix it?
- Car wont start! Got spark & fuel. Crower headpackage/B18c5
- New eBay B16 heads?
- resistor box with p28
- which supertech springs?for bc4
- identifying valve spring retainers?
- itbs
- oil pump!
- motor build
- Building a B18C1
- head gasket thickness gsr block LS crank/rods cp gsr slugs
- whats up with all these people cutting valve covers
- Type R valve train vs. GS-R valve train
- Nitrous is NOT naturally aspirated.
- Engine Whistling (throttle body related?)
- Exhaust size B series
- compression numbers on a b20vtec
- help me identify my cams... Toda???
- oil leak between head and block
- Can a GSR manifold out perform a Performer X?
- All stock block/head 262whp with cams
- i need adivce!
- ITR 98 Stock TB Size
- bearings questions oem vs acl specs?
- F***in timing belt
- 87mm b series ??? sleeved
- ITR valvetrain support skunk2 stage 2 tuner cams ?
- Help for cam degree on GSR/skunk2 pro2 cam
- cams choice concerns
- IL4 Pro Cast pistons?
- Valvetrain Maintenance
- help throwing code 9 and 14 obd2 to obd1 wireing harness lsvtec in ek
- All motor gsr won't rev at all after rebuild
- internal pressure question?
- Pressure plate still able to reuse with new disc?
- rocket motorsports m22 cams
- would i need bigger injectors for my set-up?
- nippon engine rebuild kit - nippon racing - on ebay - opinion/experience?
- Block Guard or no Block Guard?
- itr engine question
- Best All Motor Headgasket?
- d16z6 Nitrous setup
- B18 non vtec build. I'm a newbie looking for pointers.
- questions on a motor I want to assemble
- Identify these cams...Pics inside.
- Ring End Gap to big!!! WTF!?!?
- I need help understanding the h22 oil control orrifice and o-ring
- Blew up >>> into a build thread
- help!! temperature problems and coolant leaked into chamber # 1
- Throttle Body Question
- D15B Dual Carburetor/fuel injected
- All Motor
- Stock H22A Larger throttle body or ITB?
- help rc injectors, aem fuel rail, skunk 2 intake
- Will this catch on? Valve spring-less engine
- f20b exhaust and cam?
- Crankshaft sticking.
- injector questions
- buddy club spec 4 cams install...
- h22a swap in a 3rd gen integra
- got a few questions regarding ls-vtec.
- bottom block rebuild
- Help... B20B/VTEC or rebuild B18C1?
- Any update on the ACL bearing crisis lol
- how acurate is zealautowerks CR calculator?
- itbs vs skunk2 IM & s2 70mm
- crank issue
- My all motor b20b build part list
- JUN Stage 2 cams
- Stock Sleeves HC B20/Vtec+Nitrous????
- b20b p8r build questions
- b20 block: worth buying?
- g motor q
- NPR Pistons
- ported performance x vs victor x comparison
- LF: 2001 ITR Cams
- insanely low dyno numbers h2b please help
- yonaka engine rebuild gasket kit. anyone used it?
- Gsr cam great help
- High compression daily driven?
- Will an single cam AEM fuel rail fit a B serie?
- Gsr head on b16a2 Block
- SMooTHn'z B20 VTEC Problems
- question
- ls vtec problem
- Help with engine swap
- high compression pistons for b20vtec
- Sohc
- HELP ME B18c1 8000rpm+ PROBLEM ?!?!?!
- Tuning, and low rpm KNOCK question
- Which is better All Motor h2b or B-series?
- Any one has a jdm itr 98+ spec hondata calibration? or tune?
- Intake manifold
- Whats the name of the crank pully removal tool
- npr pistons any good?
- Fresh gsr crank grind & balance need bearing advise LOOK !
- what would be the best Intake manifold for my set-up
- 2.1l build
- upgrade valve springs with itr retainers?
- will this wrk or is this possible ?
- B20Vtec N/A Dyno pull - I want your comments
- flat circle in the center of the piston. what is it?
- LS/VTEC N/A Motor, what can cause this?
- H22 differences?
- can any one help me id my h22 cams and valve train?
- 85x89 B20 non vtec dyno plus muffler silencer comparison
- budget build b20V advice/comments
- reviews blackworks vtec conversion kit
- B series swapping OEM parts from honda and non honda cars
- Are these rockers trashed? help asap!
- D15b v-tech motor
- my setup only making 165whp?why?
- Trying to break 200HP B18C5 W/ Bolt on's
- quick question
- H23AVtec Blue Top 97mm Stroke All Motor Build Questions for H guru's
- H2B PARTOUT!!! SKUNK2 SUPERTECH
- Help: No injector pulse
- ITB on B16?
- Spoolin Headers(Toda rep)
- digital gauge single din indash unit? is there any?
- ls-vtec head gasket info. please help
- b18b1 all motor build suggestion?
- LS Block with CTR pistons and LS rods?
- buddy club spec III+ cams for sale. mint
- Your thoughts on my build...?
- Best engine building shop in MI?
- rod caps...pain im my a$$. any tips
- d15b high comp pistons
- LS-Vtec wierd compression , and a bit of smoke.
- need a shop to rebuilt my motor!!!
- Oil pump discussion
- 1st Build Looking For Help...................
- Traction Bar Info
- Strange rpm happening above 8000
- Need Help.. New build, starts but dies when warms up
- supertech valvesprings with stock valves?
- High Mileage LS able to handle mild cams?
- Mini me head swap dyno's?
- advice for building a engine
- CRX H series 2.3 build. guess WHP n were to tune??
- Poor Mans R Setup. P30 pistons or CTR or ITR Pistons ?
- how di i figure ou what cams are in my car
- Baseline dyno inside,thoughts/advice request...
- Need help on N/A build purchase!
- Head CFM Vs Manifold CFM
- JDM_SiR2 2010 B20VTEC baseline run no tuning
- 93 GSR SNAPPED TIMING BELT HELP please.
- Header Length
- D15b7 Build
- into my final build phase.. question still need to be answer.
- h22 obd1 vtec injectors on my lsv
- 200whp built b20 with gsr cams?
- cost of ALL MOTOR build(post yours) or someone you know
- Oversized .5 valves with pro1?? help
- DIY piston and rod change out, how to?
- Putting in new LSV, want to freshen up the head
- LSV SETUPS!!! post ur lsvtec setup an #'s
- my ls na build
- Method for Cleaning Block
- Best intake choice for a 70mm throttle body. Advice please!
- Tuning a completely stock engine?
- Need a few quick questions on the F23
- My Allmotor b series at import wars
- BCIII+ valve lash setting?
- TODA C2 Camshafts cant find any good info on them
- remind me why an ITR intake manifold won't fit on a GSR...
- Any new cams on the market?
- flowbench and piston coating in seattle area?
- another intake manifold question.
- Skunk 2 cam gears - Top dead center?
- built d15b, knowledge neededd!
- Quick question on valvetrain?
- hastings or oem.....
- why so many people selling their pro2 cams?
- HOW CAN I MAKE MORE POWER?
- Toyota Black Top 20-Valve 4A-GELU ITB on D16z6??!! can it be done
- Alternator Belt Issue
- Question for h22 injectors
- IM and TB
- Lobe seperations, P2Vs and V2Vs
- Repairing camshafts.
- P8R Cams in a ls head
- overboring worth it? cost and power difference?
- JDM H22A with bent connecting rod.. what else could be wrong
- B18C5 w/Buddy Club Camshaft Kit w/various other ?'s
- TURBO'D D15b7
- D16Y5 Noise
- help me make more power!!!!! dyno inside!!!
- Spark plug heat range & gap???
- What gains from 99 ITR inlet manifold and cams on B16
- b16a build piston to valve clearance?
- DB8 motor swap
- ░▒▓ BLOX Type-B Camshafts Compatible with 1mm Oversized Valves?
- All Motor D Series Build?
- what clutch would be good for my set-up?
- Tight piston to head clearance
- building my b20 - few quick questions
- help me build my 1.8
- Rocket Motorsport M22X Dealer
- Ls Vtec with CTR pistons
