- Six Sigma Racing (DTR-Fab) H22A Street Header Recieved!
- RM M22's in B16A Running odd (no doubt my fault)
- skunk2 intake cam and itr ex cam combo....
- Apexi or K&N? short ram or cai?
- 216 WHP 1.8 liter ITR-graph inside------------->
- Timing EMERGENCY
- JG valve train question!
- skunk2 stage2 cam gear settings
- things to address with crank during rebuild
- engine build associated costs
- LoVitalRacer
- Dpr cams on 11:5 compression Ls Vtec
- Gen 2 Rocket Motorsports Titanium spring and retainers
- Update: 92mm Crank motor with Endyn parts buildup
- need to know where to find cam specs
- Type R valvetrain with s2 pro series 1 cams
- B18c1 Torque...
- ls vtec help!!!! pls
- Slight damage to crank...will it affect anythinig?
- Has anyone ever run the intake cam advanced one tooth? CTR cam power loss.
- dc 4 into 1 header gasket
- b16a all motor or b16a turbo??which one?
- GSR block with B16 head dyno
- piston and crank options in a gsr block
- busted spot on block where oil pressure sending unit goes...
- Stock B16 Dyno
- replacing B18C cam cap bolts without having to reset timing belt or valve lash
- Installing VAFC
- Intake Manifold for ls/vtec
- d series tps on b series throttle boddy?
- Skunk2 Pro 1 vs. Buddy Club spec 3+
- CARB legal header or a way around the system?
- project Lsvtec ?uestion
- B18C ARP main studs, question for people that used them
- is there more that i can do to my sohc zc motor?
- ctr set up
- ALL motor B16
- Holley vs. Walboro Fuel Pump
- arp rod bolts on lsvtec
- Question about rockers.
- lightened flywheel?
- CTR b16b on stock DX piping
- Spark Plug gap for JDM B16A
- ENDYN girdle on ls, what is needed from GSR??
- injectors acting funny!
- BLOX Camshafts: Blox HSL or Type B
- 3-Angle job standard on Honda B-series?
- why would i use a p72 over a p28 in my allmotor application?
- this year...I have mainly...
- LS/Vtec Opinions
- looking for H22a stock fuel/timing maps
- Which header?
- Ls rods??? Strong enough for all motor set up???
- what kind of power ??? with this setup
- NEED GUIDENCE ON CAMS
- wondering if i can use jun3 intake cam and skunk2 stg2 exh cam with 11.6-1 compression?
- ys1 tranny ?
- tranny ???
- ctr valvetrain.
- Need a B18C block
- b18 crank into b16
- B20z ecu improvement better than running a stock p75?
- k series all motor
- NATURAL GAS PISTONS
- Injector ???'s
- Question about cams?
- Worth porting a K20A head?
- ? about transmision
- usdm type r pistons
- All motor cam for d16a6
- Tricks to remove and reinstall valve springs/retainers/keepers in a JDM B16A
- Thanks to DFE Enterprises (DONF) for fixing a Head of mine
- All motor b20vtec...worth it?????????
- HELP! anyone know or had this problem before?
- Help Diagnose this problem
- Prelude Type S cams...which valve springs
- Need help starting my b18c1 motor build
- i need torque specs pleease
- building a head,ITR or something more worth it?need opinions
- ECU CHIPING FOR LSVTEC
- portflow headwork for 37 cen
- All Motor B16 Hatchback - Cost effective power gains?
- stage 2 cam on h series help.
- Advantages to "tuning" in 3rd gear instead of 4th on a DYNO
- pistons and rods for ls/vtec???
- all b -series dizzy rotor same?
- What slicl size to use?
- Best Throttlebody used on B-series......
- cell code 14
- plans for all mota setup
- guide to headgasket install anywhere?
- P72 ECU with Skunk 2 manifold
- VTEC Solenoid gasket issue
- What Causes an Engine To Run Rich Suddenly?
- LS/Vtec 4 Sale
- P28 or P75 ECU for a Crome tune?
- M22 Cold Valve Lash specs?
- B18C5 WTIH JE 12.5:1 COMP AND STOCK B16A2 CAMS
- GSR block Girdle in LS block
- Opinions on JE 11.5 Pistons in LS/VTEC
- p72 or p28? why?
- K series guys, Look here
- timing belt cover wont fit?
- vibrant 4-2-1 header flange doesnt match?
- outer diameter of password power chamber
- New Final Drive OR TWM ITBs
- Is something wrong here? Concerning Toda Spec B's.
- Where can I buy a H23 crankshaft
- Velocity stack dust covers/socks
- where to buy p29 pistons!!!!!!
- Questions about bolt on parts for b16a in an eg
- Blown LSD cause these problems???
- Breakin up
- b16a2 head on C5 block, worth it?
- Stock GSR On Crower 3's
- 6 puck sprung disc where can i find one??
- Eagle crankshaft vs Crower crankshaft.....which is beta??
- not starting hot
- What is the difference between NGK ZFR5F-11 and ZFR6F-11 spark plugs?
- edelbrock 70 mm throttle body
- Fuel pumps mess up tuning?
- Buddy Club or Omni Power
- My experience with Rocket M22's NO NO NO!!!!
- vibrant 4-2-1 race header
- Project 300whp NA B-series begins. Brought to you by Tbone and Rlz engineering
- Crankshaft for AM built b18c
- Myth or Truth? ITB's installed on a medium modified motor runs out the cams faster.
- H22 VS B18c1
- jdm 4-1 header ? clearances ?
- 93 del sol si d16z6 vtec is it stock?
- VAFC or FPR to tune cams?
- INTERTUNETV: Questions about Omni's 200whp B16 DVD? Post them here!
- My SOHC all motor project...need some help
- My motor project needs some help.
- Anyone else running Cat stage 1 cams?
- Full Race Intake Mani: NA Applications?
- what tranny is better for 96 ls
- Eagle 'ESP' H-beam connecting rods....
- Will stock gsr bottom end rev to 10k with upgraded valvetrain?
- bad idea using "used" arp head bolts
- hotshot header ?
- Opinions on ATS 4.9 Final
- my all motor ls/vtec setup
- MSD Sport Compact Ignition OBD-0 LSVTEC: WHICH WIRES?
- Timing belt came loose!!
- Broken axle suggestions anyone?
- Skunk 2 Racing Camshaft Test - Stage 2, Pro 1, Pro 2
- My gsr JRSC is throwing a code, HELPPPPPP !!!!!
- Bad experience with blacktrax
- Anyone Run Rocket Motorsports M22's in a LS Vtec?
- TPS acting up during hot weather?
- Stock b16 rods with ARP Max RPM?
- Trade my VictorX for skunk2? JUN3/JDM ITR/GSR Head
- Would this be overkill?
- just cuz im curious....
- Do these bearings look ok to reuse?
- Why Would you want a light-weight flywheel?????
- Diagnostic Code 1457
- tuning cam gears
- valve clearance specs for skunk 2 stage 2 ?
- need help i have no power when vtec kicks in
- Jason (st00pidr)from Houston comming up on Aug. 27th for a tuning session (Ft.Worth)
- Tranny Problem, Input Shaft gets hard to spin sometimes
- Ahh The Sound Of Vtec
- ATT:EVERYONE
- High Idle / Vacuum Leak
- Timing HELP!!!
- what cc's r h22 injecters??
- HOW DO I RETIME MY LS VTEC
- EG6 B16a Near Stock, need to upgrade, use skunk2 stage 1 or 2?
- What to substance to use when threading arp head studs into block
- How to read Oil Pressure Gauge
- Stock H22 I/H/E dyno day (videos inside)
- oil in spark plug chamber and plug wires...
- my new header
- k-series question
- Velocity Stack?
- i figured out why i couldnt shift.....
- i figured out why i could shift.....
- vtec did't pull hard!just add abit power after vtec kick in?Why?
- optimal dome is no dome at all???
- fuel return line
- gsr cams
- Is this crankshaft acceptable to use in my build?
- Intertune.tv All Motor B16A DVD
- polarbeartuning.com ported b18a1 ls integra intake manifold 90-93 acura 55 shipped
- polarbeartuning.com ported d16z6 sohc vtec intake manifold 65 shipped
- Differnce between VAFC 1st version and 2nd?
- can someone explain me
- quick question: rod bolts
- OIL PRESSURE ON A LS VTEC
- LS VTEC RUNNIG TO RICH
- DIY Cold Air Intake Heat wrap
- Sk2 Stg.2 Cams in a stock b16..
- built b16 or ls vtec
- what injecters will fit????
- change valve springs in car??
- built k24 head with a k20 head... whats the most power someone has seen?
- b16 stock compression w/ junIII's??
- b18c1 headgasket on 81.25 bore
- H22 in eg hatch with integra radiator need pics and dyi info
- dyno proven j's racing intake??
- itb's + iac + brake mc + map sensor + vacuum can..... how did you route yours?
- engine reassemble question
- Dropped Valve
- Build?
- What motor should i get!! someone help me out i am in a bind
- Exhaust not loud..y?
- rocket m22x cams and other goodies!! (56k be warned!! lots of pics)
- 96 Civic swap question
- ls crank+gsr block= oil squirt problem
- Need opinions on my cylinder walls.
- Proposed b18 build... comments please
- Transmission rebuild diagrams ???
- Dyno'd my h22 euro R and a story.
- Possible B17 N/A build
- ls vtec plan whats ur opinion????
- skunk2 valve springs BAD OR GOOD
- HELP! obd2 vs. obd1 b18c1 block. What is the difference?
- ls/v question
- motor rebuild price?
- crower valve springs for ctr cams?
- nitrous
- best honda 2 buy
- Bronze valve guides ?
- need some user opinions and info on TECH43 RACING INC. s 82mm b16 piston and stroker kit
- Exhaust valve identification needed B series
- Max bore on a b18 block??
- more than one way to get a specific CR which is best
- b16a block, pr3 head, CTR piston
- Cam help
- need pointers on installing itr lsd
- blox type B cams
- Maybe a "Noob" question but i dont care.
- clearence problems
- need eny b series CAM CAPS
- My All Motor b16 "build"
- Skunk Stage 2 on GSRs
- supertech valve springs+ti ret. combo
- My dyno results, All motor b16
- This forum would be 10x more helpful if people put more thought into their replies
- Quick Questions need Opinions
- wuts a better mani for all motor
- lsvtec all motor ef
- Just wanna make a poll ARIAS or WISECO?
- Ep3 All Motor Power
- Which parts to use for Honda Day!!!
- omni power o2 bumg bolt
- best intake manifold
- valvetrain set-up
