PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 [230] 231 232
  1. Ebay header
  2. Deck plate motor pros and cons
  3. Another camshaft war!!!RS camshafts VS. All Manufactured stage 3 camshafts
  4. b18c block with b16 head(poor man R)
  5. Shops in Charlotte?
  6. how high can i rev?
  7. , the elevation Is this slow for a B16 ?
  8. need to know name of bolt-on rollcage!
  9. what pistons
  10. Header Tech CRX questions
  11. is there anyone here running stock obd2 ecu with Jun 3 cams
  12. 00 jdm itr (NGK R PFR7G-11)
  13. What are you guys with b20vtec/CRVTEC coupes running?
  14. dyno numbers on stock bore b18's ???
  15. pic of where oil pick up feed lineis on block ?
  16. MY motor set up
  17. B18C1 (gsr motor) in a 95 integra RS??
  18. 00' jdm itr NGK copper or platinum?
  19. N/A Intake Manifold specs?
  20. WTB busted b16 si, b18c1, or b18c5 head, need cam holders asap
  21. H22 all-motor street potential?
  22. can i make 140 hp off bolt ons
  23. is there a speed limiter? on stock usdm b20z2(w/ knock sensor b20)
  24. Finished car...what you think???what kind of power.
  25. 98 JDM spec ITR 170 whp, how to make it 200whp?
  26. EF-1 M22's V's CTR
  27. RC Injectors...plug and play ?
  28. B16 cable trans final drive upgrades? who makes them?
  29. check out the manifold available from total flow products.com --- SWEET!
  30. portflow or alaniz ?
  31. All motor problem??
  32. help decide setup or give opinion on cams
  33. what you guys think of this one?
  34. 200+ all-motor WHP people, setups?
  35. Is it recommended to build the bottom end for ls/Vtec? Will it last?
  36. WTF! skunk 2 cam help
  37. cheap parts where u can get
  38. motor is f***ed UP!
  39. How much to mill head,gsr w/ ctr pistons
  40. rod and main bearings for crank?
  41. Planned setup, Need opinions.
  42. ATS final drive? for what applications and is it worth it?
  43. toda spec a rev limit?
  44. ls crank + r block
  45. What is the life span of a turbo motor vs a stock motor?
  46. anyone using a type r intake manifold with jun 3's?
  47. Stock computer?
  48. crank pulley question
  49. ctr vs. skunk 2 cams
  50. Erik got his 9 today
  51. Going to go with jdm teg type r pistons what about fuel management?
  52. what is an all motor ITR capable of?
  53. S2K rods and pistons
  54. Think of all-motor..
  55. Idrc allmotor class in Denver?
  56. anybody have any fitment issues with there jdm itr tranny?
  57. how much horsepower can i get from jdm type-r engine?
  58. what should i do with my ecu???
  59. help with my valvetrain selection
  60. b18c5 ALLMOTOR...
  61. throttle body question
  62. all go!!!
  63. B17 crank into a b16a?
  64. My B16a Dyno Good Or BAD?
  65. Question about Setup
  66. gearing
  67. Put motor together today made a dumb mistake
  68. 90 Si Hatch Mods
  69. stock injectors ok for built b20vtec break in?
  70. what do you guys do with your power steering???
  71. No power to the ECU
  72. Individual throttle body benefits?
  73. build the c1 bottom or swap out for b20 bottom??????
  74. what is heat soak?
  75. lsvtec question
  76. Motor torn apart, but not sure why it smoked.
  77. ITR Assemblers I need YOUR Help 01 Type R head Getting Assembled!!!!
  78. JG Single Valve Springs & Ti Retainers
  79. sound right for my setup...?
  80. Engine Builders & Machinists opinion on tool please.......
  81. skunk 2 manifold problems!!!
  82. All motor LS with Auto tranny Q's
  83. simple question: 99' B16 and 99 GSR valves the same?
  84. high 13sec all-motor b16a EK civic
  85. LS/VTEC horsepower question
  86. My AN-R.com H-series Header Install/Review...
  87. My CIvic Is Running Rough PLEASE HELP
  88. DH Racing
  89. M&H Canada
  90. skunk 2 intake manifold and a 70mm bbk tb
  91. how to install a new sk2 intake manifold
  92. ITR shortblocks still available from Acura?
  93. Good places to dyno in Arizona
  94. Newb to all motor
  95. lsvtec dowel pin holes
  96. need help calculating compression.
  97. b16a2 cams and high compression question...
  98. Skunk2 Cams
  99. Proper way to adjust FPR
  100. streetable all motor question
  101. ITBs for an SOHC
  102. P-28 ECU--Where To Put it?
  103. 11-1 +5-6psi+110 degree weather= what??
  104. Good places to DYNO TUNE in socal
  105. LS/Vtec Help
  106. Best Valves for All-Motor
  107. 2.0 B18B worth it?
  108. "The Beast" as it is dubbed..
  109. latest pics of my h22 setup!!
  110. I got a new block
  111. stock b18c1 vs low compression 84mm b18c1 with some extras...
  112. Where do i Buy Wiseco pistons
  113. skunk2 ecu
  114. race header 4-2-1 different pairing ....
  115. should I still get skunk 2 cams?
  116. building an lsvtec, should i keep it non obd or obd1?
  117. How to built Ls all motor ????
  118. skunk2 stage 2 cams into itr..........
  119. Best clutch and fly wheel combo
  120. L'Natural Drag CRX for sale!!!! Auction's last day!!!!!
  121. New Aftermarket BVTEC Head
  122. ef-1/TrackMasters Dyno Racing - July 19th 2003
  123. Opinions on my B20 Setup
  124. Does someoen have that compression calculator?
  125. itb filter kit????
  126. problems with Crower 404's
  127. Ok, What next?
  128. problem with vafc
  129. 99 d16y8.....horsepower and torque output?
  130. B18C5 swaps
  131. will 99-00 si comptech intake/icebox work for 92 b16 hatch?
  132. I'm new to all-motor
  133. ing a B20 bottom end in,Building a B20 VTEC
  134. Spoon ITR pistons
  135. safe compression for everyday driving?
  136. Cons of sleeving block
  137. miss shifted and over revved
  138. skank 2 stage 1 cams in GSR head..
  139. msd, or similar, on a built motor?
  140. port and polish Question
  141. Are Darton sleeves overkill?
  142. B20 vtec ?
  143. Tuning question.....
  144. how much more powerful is crvtec(b20 vtec) vs lsvtec?
  145. Revving a D16A6
  146. itr cams, valves, springs, retainers, ecu...anything else?
  147. Block breakdown/head breakdown.
  148. Valve cover cam gear cut outs
  149. what clutch are you using?
  150. trouble finding leak
  151. Throttle Body for B16, 10.x cr
  152. What engine management on 13.5:1 + compression.
  153. Suggestion
  154. B16a2 Block n Crank on B18C???
  155. Using a USDM GSR Oil pump in a JDM GSR block.
  156. Skunk2 vs. CTR
  157. which headers best?
  158. itr valve springs to big???
  159. Stepped Dowels for LS/VTEC >> Anyone know where to get some.
  160. D16Y8 N/A
  161. Need some advice..... what kind of power am I making....
  162. How to Compression test on a built engine Q's
  163. option for integra 90 LS
  164. Building a b17a
  165. more ls/vtec q's
  166. b16a...girdle/squirters?
  167. p30 pistons?
  168. ls crank/rods in a gsr block
  169. ls crank in a gsr......
  170. CTR cam potential???
  171. question about clutch/f.w combo
  172. Psi...to compression ratio
  173. cam gear settings?
  174. what times will i run?
  175. LS crank in a GSR block
  176. LS/VTEC conversion kit... anybody ever delt with this kit?
  177. timing tuning question
  178. skunk2 valvetrain with stock retainers???ASAP
  179. Powerband location wrong??
  180. best b20vtec im
  181. All mota tuning???
  182. Just finished building my 2.0 nonvtec monster
  183. Best setup for a 94 LS on gas...
  184. Best Motor Oil ?? for N/A
  185. porting IM ?
  186. Pistons or not?
  187. timing belt
  188. jg valves
  189. Anyone use the MSD Rich/Lean Indicator?
  190. oem injector install
  191. Anybody reuse their oilpan gasket?
  192. sleeving
  193. what size slicks is everybody using in here.
  194. idea for street/beater engine....
  195. Key points to a good B20/VTEC?
  196. Ek h22 hatch for sale
  197. All Motor Gsr hatchback eg
  198. Who is going to break ericks racing all motor records.
  199. All motor is done. need help finalizing problems.
  200. :: ctr pistons in an ls/vtec ::
  201. L'Natural Drag CRX for sale!!!! Father's day Re-post...
  202. ctr or itr pistons in gsr motor?
  203. you think i could use a side-exit header on the streets?
  204. 10.6.1 to 12.1.1 CR ?
  205. using 929rr itb's?
  206. blew the b18c now what? need opinions...
  207. Car is dead...part 2...still!
  208. Resleeved B16a block or just a B18c1 block
  209. For those running skunk2 stg2 cams....
  210. Help with setup
  211. Upgraded ARP Rod Bolts...........
  212. NA setups--- Questions
  213. what can i make power to wiht skunk stage 2's....
  214. merge collector?
  215. :: oem injectors for all-motor ::
  216. ANYONE sick of this....????
  217. Here's the set-up, and what's next
  218. What do you run your stock b20b/b20z block to?
  219. more all-motor H22's!
  220. Can you list some highly regarded and respected B-x internal work shops in the west coast
  221. Skunk 2 cams broken on dyno
  222. jun 3 vs skunk2(stage 2)
  223. dilemna
  224. help on LS all motor in 93 civic hb?
  225. Do the valvesprings need to be replaced for my setup?
  226. what types of 1/4 times with toda cams? Which cams should i go with?
  227. pump gas tuning for high comp
  228. I'm a noob what does CTR stand for
  229. Stock Sleeves + Forged Pistons
  230. CTR how much
  231. does the track calculate 0-60?
  232. Piston Choices for 200 + WHP
  233. GSR Pistons in a B16 block?
  234. B16 stock compression with jun 3's--spark plug gap size?
  235. vtec set at 2500!
  236. Difference between gsr b16 blocks
  237. adjustment of V-afc
  238. B&M Oil Coolers??
  239. 4 door GSR with 200whp
  240. Street cam help...
  241. Results are in: Skunk Stage 2/3s versus Toda Spec Ds
  242. Skunk stg1 cams, maxing out injectors....
  243. Comptech Ice Box VS REST
  244. b16a2 in a 92-95 hatch ???
  245. Stock b20b + b16a2 head...which would be next worthwhile upgrade?
  246. Engine builder on East Coast
  247. SKunk2 stage1 vs. Type R
  248. B16a....nonvtec ?... my theory? vs. LS all motor?
  249. cant go to the track!!!
  250. NA B16 Spark Plug: Recomendations
