PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 [138] 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. what header you guys running?
  2. D16Y8 intake manifold on D16Z6 - - - which TB?
  3. B16a2 +extras > B18c1 ? Whats would you do?
  4. CP pistons...piston to deck height???
  5. Buddy Club Spec III cams with other cam gears
  6. B16 And Itr head questions.
  7. New to Building LsV w/ ?'s
  8. gsr head bolts or si head bolt
  9. 150 wheel horse power for cheap
  10. im finally going to put on my sk2 camshafts n camgears!! were would i redline now??
  11. 98 itr 4.785 final drive in a 96 itr tranny?
  12. *searched* stock rods and after market pistons
  13. whats the biggest stroke on a h22 or h33?....
  14. p30 pistons
  15. jdm gsr build
  16. wich cams wich head?
  17. Need help and parts!! Complete B20 setup and more.....
  18. SPARK PLUGS!!
  19. EF $ four with a 2.0 Ls-vtec 248.8hp
  20. npr rings?
  21. Gsr belt dont Fit at all
  22. gsr 12.1 compression, what cams?
  23. 12:1 compression on a stock B16 head...
  24. major b16 build
  25. all motor crx...itr motor w/individual throttle bodies..any opinions?
  26. Pro 2's or Pro 3's with 13:1 CR
  27. Street Drag EG6 Project> 230WHP, 2L, All Motor > Short Video inside
  28. Short Ram Vs. Cold Air
  29. NEED HELP WITH B20 VTEC CAMS
  30. B16a2 Redline!!
  31. 91 crx si fuel injector problem
  32. info on my mild build
  33. will skunkpro1 cams help my setup???
  34. ITR Bottom end b16 topend question...
  35. Should I get a Crower or Eagle crank for stroker motor?
  36. High compression people...odd oil issue.
  37. How to determine what parts to order to get 10.5-1 cr
  38. b18c1 N/A setup help
  39. question about PMS pistons (GX pistons)
  40. d15z to an h22a
  41. Barring wear question????
  42. bought a b16a for 500 have some questions???
  43. boring & measuring... how much should I pay?
  44. who much power? Havent found a setup like this before..
  45. my jdm b16a need a head mild rebuild??? LOOKING FOR HEAD BOLTS AND GASKET
  46. couple of quick intake manifold questions
  47. Quick forged ls rod ???
  48. HELP NEEDED!!!......Dart tall deck.....what extractor can be fitted on???
  49. installing gsr camshaft on my b16a2 head Need help!!
  50. ls/vtec need help!!!!!!!!
  51. diagnose my car...
  52. Help Identify these cam gears....
  53. B20 in an EK?
  54. CTR cams vs BC3 cams
  55. Need info on part?
  56. Vtech INFO
  57. 99 Civic Si Stock what MORE?
  58. What Valvetrain for BC IV Cam's and Gear's
  59. Injecot Help
  60. e-cut out na?
  61. T Body size?
  62. ITB setup
  63. higher compression with stock head, new cams
  64. gsr tranny vs. b16 tranny in an lsvtec
  65. WTF is this?
  66. Need base map with Atmel 29C256.
  67. Injector question
  68. p30 computer
  69. ENDYN's Civic - All Motor Street Car Power (lots of it) ...
  70. aluminum rods
  71. the beast?
  72. Help Help Help All most finish with my build have one final question HOPEFULLY
  73. 94 civic all motor
  74. Crower camshaft
  75. fuel injectors
  76. building NA beast
  77. My 2.0LSVTEC Dyno, preliminary results
  78. buddy club spec 2 exhuast on a ef with b20 vtec??? is this exhuast loud??
  79. Where can I send my head to get LINE HONED?????????
  80. Uberdata naz6.bin basemap question? Pic included
  81. Bearing size and crank specs on all motor buld
  82. how much whp
  83. which pistons?
  84. CTR or JE 11.5 pistons for LS/VTEC
  85. Vtec vs. i-Vtec, whats the difference?
  86. working on 240+whp but I need some help !
  87. LS/VTEC
  88. b16 track times
  89. Any Videos of someone Building a motor?
  90. Intake Help
  91. D series all motor
  92. Best intake manifold for a basically stock gsr?
  93. what way to go on an all motor setup on LS vtec?
  94. valve adjustment changed ARR's
  95. Best Valvetrain and Cam Combo's for My Set-up.
  96. jdm 4.7 final drive in a y21 tranny?
  97. post your b16 eg track times and hp
  98. DIY ITB and brake booster
  99. what do you guys think?
  100. in regards to runnig open loop??
  101. thinking its about time for a rebuild
  102. mild build.. what cams???
  103. honda crx for sale
  104. GSR IACV & Skunk 2 Intake Manifold
  105. si to gsr oil cooler conversion
  106. DSM 450's vs H22 injectors
  107. Hyoshi Performance High Performance Timing Belts...Anyone???
  108. happy new year!!!
  109. My 92 Honda Civic Bogs down with low rpms
  110. slave cylinder question
  111. What do you guys think?? Any input on the engine build??
  112. new oil pump leaking
  113. A K series DISCUSSION. IPS/Skunk2/Your real world expierience
  114. anyone know the inlet size of the skunk2 pro series intake manifold?
  115. this is a EG 92-95 civic EX valev cover ( VTEC )
  116. what are the optimum valve seat angles for performance.
  117. Calling all 96-00 Civic coupes
  118. Dynod My Endyne Built GSR
  119. b16 + left over money > b18?
  120. To Much Fuel Pressure or Not??
  121. School me on retainers
  122. Another badass all motor vid I found
  123. Need Help = Customer motor question
  124. breaking in cams
  125. Angle milling
  126. B20/VTEC numbers
  127. .015-.016" ring gap clearance too big
  128. oil pump problems
  129. question about lsd
  130. k20a2 with ice box dyno
  131. b16a2 lsd intallation
  132. b16a2 transmission fluid
  133. ctr pistons or itr piston on a b16a2
  134. b16a2 keep is stock or buy ctr pistons or itr pistons
  135. any diy itb dyno sheets? real gains?
  136. Basemap needed for TWM startup
  137. How much HP would a new SI pickup with a Race header/Exhuast?
  138. skunk2 pro1 in b18c1
  139. video I ran across
  140. bulding 93 ls, need help with oil/water pump.
  141. Starting problem.
  142. buddy club spec III dilemma
  143. stock ITR with skunk2 pro 2 1st drive impression
  144. CTR pistons?
  145. sodium fillved vs titanium valves
  146. ITR Internals into a GSR Head...help..
  147. question about FD
  148. Valvetrain/misc qusetions for a mild NA B16a
  149. AEBS intake manifold.....check the cable
  150. Need to know
  151. LS/VTEC forged pistons
  152. auto to manual, need manual intake mani?
  153. 92 civic b16a water pump shot!!!!!!!!!
  154. Should I get a B16 or Type-R head ported?
  155. Help me out here guys?
  156. Update on the car...
  157. buddy club 3's w/ ITR valve train
  158. who does a good port job in cali??
  159. b16b cam selection / compresion help needed
  160. high compression
  161. gsr crank in b20???????
  162. b16a with JDM CTR pistons or LS/VTEC with itr pistons? ADVICE PLEASE
  163. know the answer?
  164. What oil do you use to break in a brand new built motor?
  165. Anyone own either of these... which is better??? Prototype V-Stack OR Turbohoses Airram
  166. knock sensor CEL
  167. H22 Headers with 2.5" collector: DC VS Greaddy
  168. k20 Swap Pricing
  169. topline pistons??
  170. affordable rods?
  171. Prelude Knock Sensor Problem
  172. arp rod bolt holes URGENT
  173. cwoer stage 3 cams.. rockers?
  174. Using a Throttle Body as an Active Exhaust Silencer Idea Poll!
  175. 310cc fuel injector
  176. motor oil
  177. b16a2 transmission or b18c1 transmission
  178. All Motor LS/Vtec
  179. Lookin for place to install/tune
  180. Ls Vtec Question?
  181. Building a B-series, pump gas, steet motor
  182. Which CAMS to get???
  183. Rocket Cam's in JDM H22
  184. Comptech Regular header question
  185. help me spend money$$$$
  186. Scott @ Bseries All Motor Street Killer K Build
  187. stolen
  188. My new part for the new motor...
  189. need help with emissions
  190. My 2020cc B16 is up for grabs guys!
  191. spark plugs
  192. B16 build thumbs up or down
  193. Storing a block for winter
  194. brand new JDM motor burning coolant
  195. Crower stage 3
  196. NEED HELP! ZC questions and ITB setup.
  197. b18c5 block question
  198. D15B2 and a D16 V-tec head, What do I need to put them together?
  199. couple of h22 questions
  200. Is it hard to installed a alternator?
  201. WEB cams for LS-vtec?
  202. ITB's or Skunk2 intake manifold?
  203. 50 shot w/ 12:1 c/r
  204. CTR Pistons handle a 50 shot?
  205. Alternator problem
  206. Clevite bearings???
  207. Skunk 2 intake manifold install on a B18C1....please help????
  208. color coating on rod bearings??
  209. Lightening a 91 CRX SI? 1900lbs.?
  210. help!!asap-will b16 TB work on my gsr??
  211. need opinions on which block i should use w/ my FULLY built head?
  212. Buddy Club Spec IV Cam problems
  213. Crane Roller Cams and Rockers
  214. Can anyone help me with TWM ITb's
  215. Removing harmonic balancer minimum ft lbs torque impact gun?
  216. rc 440cc injectors what fuel pressure fuel pressure
  217. B-Series Swapped CRX, will ITB's with air box fit?
  218. Transmissions final drive
  219. stock head gasket on a high compression engine
  220. weigh of oil on my rebuilt b18c1
  221. lets talk about raising b20b CR
  222. Idle Problem , need some help before I dyno next week.
  223. Just got K20R Motor Tuned, Feel Free to chime in with some insight or comments.
  224. b16a2 block with gsr head
  225. oil squirters
  226. New Project: Teggy ONTO SALVATION
  227. does an B18a block have spots to put oil squirters and a gsr girdle?
  228. h22a VS. h23
  229. for all with chipped ecu's..who's would you go with
  230. For people with deckplated motors in Integras...
  231. ek9slut's b20vtek build
  232. what is anyone's opinion on changing gears without using the clutch?
  233. safest compression to run on DD on 93 octane tuned with hondata
  234. lack of power???
  235. apr head studs
  236. Difference in b16 heads?
  237. my b20 set-up
  238. Air filters for DIY cbr 954 ITB's?
  239. Defi D-series A/F guage- is it accurate?
  240. few random valvetrain questions
  241. High N/A hp
  242. which timing belt?
  243. Headgasket blown Please help!!!!!!!!
  244. Bigger valves with a P&P...
  245. Head flow
  246. what do i need to do to put typer pistons in b20
  247. 2 piece VS. 1 piece, 4-2-1 VS. 4-1 headers
  248. b18c cam gear help
  249. Header Question
  250. b18c1 sleeve problem
