- toda B16A stroker kit
- how to find optimal placement of primary merge and secondary merge on headers?
- problem with IBspec Wiseco pistons
- Spark Plugs Question - NGK Iriway 9
- common knowledge??
- what kind of cams?
- Outlaw Engineering TB
- what cams are you useing with port flow valve springs and retainers??????
- Whos got the fastest lsvtec??
- need help with this!
- all motor set up need in-put
- itr v.s gsr tranny
- ross machine racing fuel rail???
- pLZ post pics of BRAND NEW GREDDY HEADERS!
- what header for my N/A b16 in my DA?
- home hone? what hone do you use?
- post up your ls/vtec numbers
- Are toda spec As hard to tune?
- B16b w/ls crank?
- apexi vtec controller wiring diagrams?????
- weight of a complete B16 bottom end
- HP & Quarter Mile Times Can I Expect???
- P30 pistons with GSR rods ?
- advice building up my engine please ;
- torque specs on b16head oem headgasket/gsr block
- 1 layer headgasket?
- TB size recommendations 70-65mm for a NA setup
- Toda all motor experts.. Need your help...
- Opinions on JUN Stage 2's
- ctr cams b16 valvetrain
- Hondata Intake manifold gasket.."Is it worth the money"
- GSR all motor ignition question
- stage1's or ctr pistons? dilemma :(
- Reliable Lsvtec??s
- DH power crank pulley ???
- b20vtec
- Which Intake manifold for B18A LS?
- Hondata and a wideband O2?
- D series Header question
- spark plugs
- stroker kit
- 12:1 GSR
- header exhaust cat combo
- filtering itbs
- B16 idles at 400 RPM's with with fuel pressure at 20 PSI
- DA to ED trim question
- code 22 vtec oil pressure switch
- Help with head swap Please!!
- b16a buildup w/ ctr internals
- Code 43? Fuel Supply System
- anyone heard of gude ecu for a LS
- Wanted : B16/B18 vids with JUN cams!!!
- k20a2 all motor build q's
- LS\VTEC or B20\VTEC making some wierd sounds??? Any suggestions???
- Guessing?
- my lsvtec is smoking under the hood:( Help please.
- Dyno tuning in/around Maryland?
- which ecu
- price range for a set of ctr cams
- ls/vtec?
- icm and msd problems on 94 civic ex
- What do you guys think about the BBK Intake Manifold for the GS-R?
- 97 eg H22A4 SH Swap Help
- Went to the track!!
- type r valves
- Has anyone used this external fuel pump before?
- b20 engine mounts
- torque specs for b18b cam caps
- SRP 5.7 dome pistons w/ big cams?
- LM1 Wideband unit
- HELP!! Just did a swap...car is dumping fuel in cyl.
- how to build a b16a2
- or b20 swap?
- Tb on 2nd gen b16
- b18c swap
- B16 resleeving?
- B16 N/a
- Thoughts on using NITROUS on older engines
- 2001 honda civic Dx
- Dynoed the sedan 194/136 OEM internals
- pics of progress on my new build
- Problem with Mugen Headgasket?
- vafc tuners..plz read :)
- Thermostat?
- 3 inch carsound cat...how much restriction will this cause?
- need engine swap help
- what does a resonator do?
- civic with no engine? which to drop in?
- Ls all motor?
- All motor LS......New Ideas....
- B18c5 with 86mm bore & stroker kit
- ls/vtec crank pulley
- Just Purchased an ACT Prolite Flywheel
- Cali swap
- Want a AN-R header for ur H22 or B series?
- ls/vtec
- I searched but didnt get an answer.. compression tests (how to?)
- b18c5 with idling problems!!!!!!! HONDA FAMILY PLEASE HELP!
- K20 head swap on a SI???
- NSX build anyone?
- Question about b16
- VAFC on Stock motor
- what kevlar disc do to you?
- swapping short block?????
- spec clutch
- Rocket Motorsports Gen II valvetrain?
- ROCKET MOTORSPORTS ALL MOTOR VAVLES.
- help me decide what header for my b16?? AN-R? or SMSP??
- which valves on my application
- Main and Rod Cap Torque Specs for B17A?
- easy DIY ported GSR manifold....Finally!
- Givin you guys first dibs on my header...
- highest compression on pump gas
- cable clutch question
- removeing balanceing shaft???
- LS VTEC oil line thickness?
- Need help to finish my new set up!!
- NEW source of Reflashes ..for K-Series Ecu's?
- 550 injectors overkill?
- Upgrade to SS valves?
- 2000 B16 in a 99 ex
- import builder springs?
- question with H22a swap into 93 integra
- Toda ITBs?
- Where is the best place online to get a jdm 4.7 final drive
- questions about building head d16z6
- will accord sohc vtec fit in my 97 civic hb??
- What should I do next to my SOL
- conversion harness obd - 0 to obd - 1
- Nitrous all motor????
- Buddy Club Cams and Gears
- b18c1 cam gear settings
- Will my B20Vtec setup last in RoadRacing?
- HX head?
- K20A2 dyno numbers
- Decision time.....build a B or swap in a K
- Which CAMS are better?
- websites that have clutchmaster clutchs for B18c1 motors
- F22 all motor?
- It's time to make the big decisions....
- automatic dyno/qtr mile registry :)
- Whats more fun turbo or N/A?
- what cam brand?should i pick with this set up?
- stage 2 and stage 3 cams
- So, I'll be buying my chipped p28...
- Rocker arm order importance
- How much and I mill a stock gsr head with out have clearance issues?
- took some vids, how do they look?
- crower 404s
- Wondering what Numbers I can expect.
- What HP out of this newly build setup for my ITR
- frankenstein?
- Valve spring poll.......
- LS VTEC QUESTION.....NOT AN EDYNO
- AN-R header on H22 - ANYONE?
- All motor d15b?
- Flow Bench #
- JE vs CP vs Wiseco pistons
- homemade ITB idle clip
- Ls crank in gsr block?
- 310cc injectors too small????
- S-AFC and injector question
- Has anyone used Buddy Club Spec-3 B-Series VTEC camshafts?
- [B](P29 pistons, D16y8 head, PR4 rods, D16a block)[/B] About what compression will I be making? Look
- does your gsr's vtec lag too?
- Fuel octane
- what pistons to use for my b16
- ITR intake manifold runner lengths
- Toda As or Skunk2 stage 1s
- ALL MOTOR setup -- I need help and/or suggestions
- running too rich
- Building B21A motor
- HT Dyno Day part2
- b16a vs b18c1 . .
- 190 hb 140tq what should my time be?
- all motor b16a
- toda b video clips
- USDM vs JDM
- What springs can I use with Skunk2 retainers?
- 200whp on Toda A cams........
- jun ecu
- what would be cheper allmotor/turbo?
- head ?
- nice pull out of my rebuild.
- 200whp, yes yes another question
- Question on Spoon 1.8L stroker kit.
- Looky what I found! LS/VTEC kit
- normal hp gains (did search)
- Can I achieve 175whp on b16a with these mods???
- any good tuning shops around here?
- power difference w/ stg 1 or 2 cams in my ls/vtec
- Hondata or VAFC to tune?
- Should i buy this B series motor? Help me please
- camshaft question
- HELP! Catch/Breather Can has too much oil, blow by, or wrong installation?
- Gas Mileage? Need info.
- My NA set up weak!
- N/A reliability?
- went to dyno and got Hondata today and wasn't able to use
- DSM Injector for b20vtec question
- AN-R Header
- b16 high compression?
- all motor input question???
- 200 or more whp all motor
- B16 PISTONS&RODS >>>> D16 PISTONS&RODS ???? Interchangable????
- AEBS racing water pump ?
- B16a2 vs Type R valve retainers.... is there a difference?
- Is 225whp too much for Exedy Organic clutch? What about the cerametallic 3-puck???
- Headers for B16A on a DA??
- aftermarket pistons, stock rods.
- Some new motor swap options..K20 & H22 pics.
- Is it possible to hot tank block with internals intact?
- CTR pistons (PCT) in a JDM ITR engine?
- Chevron with Techron pushed to its limits!
- a few cam questions
- itr tranny
- ITB's or carb's..help me choose!
- Core Charge
- Prospeed Header for H22a
- Serious crossroads....Head job(hehehe)or block built
- exhaust pipe diameter
- Selling my car. Ebay baby!
- itr cams or skunk stg 1
- LS RODS WITH ARP's, 8500 RPMS?
- What does "clay the motor" mean?
- base settings on field vtec controller
- Quick question on my possible setup? L00k inside!
- Difference in 63403's and 63413's
- b18a1 dyno #'s
- Need help with fuel line
- what injector
- injector size?
- Quick question about the b16a,a2 and a3
- Weird smoking in upper RPMs
- Which model header to buy
- will toda springs effect jun cams?
- B16a Y1,J1, or S1 which is the best??? possible gearings?
- Lowest possible times in an all motor B18C1?
- help choosing pistons
- crank trigger for msd asap!!!
- Who bores stock t/b?
- Anyone using Greddy E-Manage or HKS F-Con
- MSD IGNITION HELP WANTED
- b18 tranny adapter onto h22
- Helms question.
- B18C, B16A Intake port size?
- I need to find out which cams I have...
- Tech request - RC 440's wont fire
- LS/VTEC settings???
- vtec killer
