PDA
View Full Version : All Motor / Naturally Aspirated
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 [119] 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232
  1. need some dynojet run files
  2. fule management
  3. To install it or not that's the problem
  4. Omni Power test pipe
  5. Oil Leak between head and block.. Fresh Rebuild
  6. what is the best intake manifold for b18c1
  7. need bolts...
  8. Instant message
  9. HAS ANYONE EVER USED BLOX B COMPITION SERIES CAMS?
  10. crank walk on a b-series
  11. Max rpm on STOCK b20 bottom end
  12. 80 f- lbs on B20vtec head bolts
  13. What would you choose?
  14. GSR Throttle Body on ITR Intake Manifold.
  15. Bearings...
  16. Need a ITB SOHC .bin file.
  17. h23vtec help
  18. Should I use a PR3 or P30 Intake Manifold?
  19. Is this crank salvageable or trash?
  20. Coolant evaporating issue?
  21. where is ignitor at?
  22. I need Help in DALLAS TEXAS
  23. d16y8 help, please people
  24. power gain
  25. pls help. converting gsr throttle body pulley to itr or ls
  26. All Motor B18/B20 Owners
  27. JDM ITR HEADER
  28. Intake question! Top Fuel, AEM........
  29. broken mount, mount inserts fix problem?
  30. [Header?]
  31. b16 stroker custom pistons or custom rods?
  32. B16 tunning
  33. Why isnt my engine starting?
  34. help with a strangs piston/compression question
  35. RPM ????
  36. head gasket question(gsr block/b16 head)
  37. ls/vtech build piston choice?
  38. spark plug?
  39. Any input on these ebay ITR cams?
  40. Stock OEM b16a Head gasket
  41. b18c1 stock block with b18c typr head... what compression thus it make????
  42. Bought a b18a head without cam caps, want to do?
  43. Anyone have a b20vtec Fully build Toda with a hytech/smsp header? please tell me how it performs.
  44. LS/Vtec All Motor Build: I/H/E + Cams Basic Info
  45. need help and need it like yesterday
  46. Opinion on Tranny adapter kits..
  47. Rebuild question?
  48. RS Machine Pistons And A Question
  49. Fuel Pressure Question
  50. itr motor up grades
  51. how can u identify between ls, gsr, b16, type R oil pump
  52. What I could do ? ( restriction on the TB, 53mm on a K20A2 )
  53. b18c bottom bottom end
  54. type r k20a + RBC IM + HyTech + PRC stack header dyno un-tuned vs. tuned (soon)
  55. Dyno of B18B
  56. Best 2 liter Header
  57. motor building mathmatics
  58. stock long block dynos
  59. h22a build up for safe 8k rev?
  60. UK Owner needs quality header....
  61. news and dyno #s
  62. b16 head question
  63. f20b injectors - what size are they?
  64. Who Will Win?
  65. What's a good setup?
  66. differences in b16 heads
  67. Another Rod Bearing Question...
  68. Engine code 67
  69. Dyno of LSVTEC With New Big Tube Prototype Header
  70. Buddy Club Spec IV dyno w/ Exhaust cutout
  71. b18c1 what year would fix 01 integra?
  72. 2500
  73. 2 liter build....
  74. Civic- all motor parts
  75. chipped ecu???
  76. (searched already!) b16a q's
  77. Where can I get a 98 Spec R header?
  78. Anyone Have Quiet High Compression?
  79. spoon/mugen HG on a ls?
  80. rmf headers
  81. Main and Rod Bearing?
  82. please explain something to me
  83. Omni Power ITB's??? Anyone heard about this yet
  84. Dynod The 98 Ek with 98 JDM ITR!
  85. timing still off, very odd situation
  86. which arp studs
  87. Finding a TB and Porter
  88. B20 vtec best cams for driveability
  89. What type of ITB's the silver S2000 have?
  90. ITB question about pcv (searched)
  91. what pistons are these? B20B
  92. b18c1/b16a
  93. k24 swap?
  94. RMS vs WHITFIELD Racing TRY Y SS Header
  95. buddy club specIV
  96. b16 differential?
  97. i need help
  98. Quietest high flow muffler?
  99. I-H-E...what next?
  100. Good base?
  101. Gsr rods and pistons in b20 vtec?
  102. what cams would you guys use?
  103. What is the best header for my GSR build???
  104. Buddy Club
  105. Oil Change on a B20 Vtec???
  106. Want someone to port my ITR Intake manifold for a reasonable price.
  107. Will OBD2 gsr harness work with JDM ITR motor?
  108. reusing new damaged pistons in an all motor build from scratch
  109. VAFC settings for 11.5-1 gsr??
  110. ls/vtec questions...
  111. Building ALL MOTOR b18a, where to get head ported?
  112. confused...b18b1 block? or b20b block? with b16 head and ctr cams
  113. rod/crank choice gsr block
  114. S300 Hondata/TWM ITB tuner wanted. Bay Area
  115. whats with skunk 2 stage 2 cams and the skunk2 chip?
  116. Ls/Vtec Dyno = 200hp Acura Integra GS 06' S2s2 Cams Pr3 Pistons B16 Head Neoh2ning Neoh
  117. Input....
  118. H22 built head and stock bottom will work??
  119. single cam integra
  120. Mini me build w/ zc and cam will the valves clear
  121. higher compression on stock GSR cams
  122. Ring gear slipped on my H22 CM flywheel... how to fix?
  123. another k20 another question
  124. Dyno chart
  125. RLZengineering.com?
  126. evans magic intake
  127. WHAT DO YOU GUYS THINK OF THIS????
  128. whaT COULD BE WRONG????? PLS HELP ME!!!! HOW COME WERE NOT GETING HIGH POWER RESULTS????
  129. b16 with b17 crank and rods it worth it?
  130. Poor mans type r ef build couple of quick questions. . .
  131. B20VTEC build opinions
  132. b16b pistons?
  133. Bone stock low compression B20 non VTEC dyno.
  134. Simple question: Is the PROFAB header made for 2.0L vtec motors???????
  135. B20b questions (dissapointed d15b7 owner)
  136. throttle body size for my setup
  137. help needed with dialing with toda vtec killer cams
  138. PORTFLOW OR FERREA's??
  139. Where to get JDM P72 pistons?
  140. ERICK'S RACING HEADER?
  141. ...and yet some more B-SERIES heat...muahaha
  142. Cooling/Coolant issue
  143. SRS Airbag Light
  144. is my motor stolen?
  145. Intake mani for an h22
  146. How can I see that it is Rm Rocket cams? (picking up some M22x..)
  147. Interested in doing B20 vtec N/A
  148. what causes this
  149. 92-95 d15b jdm v-tech swap in 90 civic hatch
  150. Building a custom H22 header
  151. high revving d series
  152. F20B for B20/Vtec for all-motor/nitrous build?
  153. Greddy Hi Rev/VTEC Oil
  154. ANOTHER BUILT B20/VTEC FROM PRO-STREET IMPORT(247WHP)
  155. need some advise on a b20 VTEC
  156. K20A and B18C5 Injector Question
  157. LSVTEC cam and header question
  158. high revving cams
  159. GSR swap 92 civic dx ?'s skunk2 im ericks tb 94 gsr wire harness chipped ecu
  160. compresion check 150 is that normal?
  161. Buddy Club Spec III+ cams installed, tuned, not impressed!
  162. cr ratio which pistons
  163. Erick's racing TB
  164. A Groovy engine mod to increase efficiency and power?
  165. motor smoking, very confused
  166. LOOSING POWER
  167. Crower 401's Make Power to 8900??????
  168. where can I purchase new transmition internals?
  169. 220/230/230/210 with bent valves?
  170. BIG ?
  171. Motor wont start but cranks over??? HELP PLEASE!!
  172. Which intake manifold
  173. need help with allmotor..
  174. will d series valve keepers (locks) fit on a b16?
  175. How to build a "reliable" lsvtec/b20vtec
  176. some charts i made concerning clearances
  177. trade tranny for motor/
  178. B20 ALL MOTOR Q's !!!PLS HELP!
  179. Whats a safe shift point for my motor?
  180. Best sites / forum thread on tuning ignition timing
  181. sugar in the gas tank damages engine?
  182. not off by half a tooth. still got questions.
  183. Engine Code Issue (searched)
  184. which header?
  185. Are B20B rings ans B20Z rings the same?
  186. Dyno Testing - Velocity Stack w and w/o filter
  187. Open Suggestions on gapping my rings!!
  188. Valvetrain/engine noise
  189. Slightly OT: b16b head value
  190. Wonder how much power i should make on my build?
  191. Fuel Pressure Regulator
  192. what kind of ECU program is the best to run
  193. what cams would you go with
  194. sugar in the gas tank
  195. B20 oil-pan....
  196. intake manifold bracket
  197. ls crankshaft needed!!! please
  198. Can anyone guess what kind of Skunk2 cam this is? *VID*
  199. Throttle bodie's/im?
  200. What mod do I talk to?
  201. post your b16 numbers,mods,times on here
  202. intake manifold
  203. K24 rods...??
  204. weird sound from engine
  205. blox manifold heat
  206. civic LX '06 oil drain plug torque
  207. Unorthodox pulleys
  208. toda b spec cams
  209. Best type if Civic
  210. Got tuned at Mainstream Performance Today
  211. How to adj. vafc.
  212. engine sleeves
  213. cheap header
  214. motor rebuild help
  215. skunk2 intake manifold
  216. 1/4 Mile times
  217. dyno with bc5s...
  218. Skunk2 manifold
  219. My goal realistic?
  220. Am i off a tooth?? with pics
  221. old or new skunk2 intake manifold
  222. Piston and Rods???
  223. Going back to stock? Lsv help
  224. Hasport shift linkage??
  225. building ls/vtec eagle rods...
  226. LS/Vtec????
  227. Piston choices in a gsr motor
  228. my all motor build tell me what you guys think
  229. Eagle rotating assembly questions
  230. Searched! Can I hone my H22A?
  231. Setup Help needed
  232. obd0 ecu w/ obd-1 injectors?
  233. jdm b16 throw out bearing
  234. help me build my gsr for autox
  235. my B20tec plans
  236. I need this information urgently!!!
  237. Dyno of Jun 3 after taking to another tuner and headworks
  238. warped b16 head, whats the most i can take off?
  239. Will this work?
  240. FYI... RC Plug-n-Play Injector Clips
  241. Bisimoto header
  242. H22 valve guide to Retainer clearances. Looking for input from users with non stock cams
  243. Will a K20 head & K24 block combo clear the hood in an EG?
  244. Oil leaking on high RPM from the 1-layer headgasket
  245. LS Vtec build... any suggestions
  246. H22 swap
  247. help with my n/a build? pistons?
  248. NEW HEADER AVAIALBLE
  249. Milling head/thinner headgasket, effective way to raise compression?
  250. Code throwing
